root/radiance/ray/src/hd/rholo.c
Revision: 3.67
Committed: Thu Sep 9 01:06:19 2004 UTC (20 years, 11 months ago) by greg
Changes since 3.66: +8 -11 lines
2 static const char RCSid[] = "$Id: rholo.c,v 3.66 2004/09/09 00:25:59 greg Exp $";
5 * Radiance holodeck generation controller
6 */
7
8 #include <stdio.h>
9 #include <time.h>
10 #include <signal.h>
11 #include <sys/stat.h>
12 #include <string.h>
13
14 #include "platform.h"
15 #include "rterror.h"
16 #include "resolu.h"
17 #include "rholo.h"
18 #include "random.h"
19
20 #ifndef FRAGWARN
21 #define FRAGWARN 20 /* fragmentation for warning (%) */
22 #endif
23 #ifndef MAXQTIME
24 #define MAXQTIME 5 /* target maximum seconds in queue */
25 #endif
26 /* manual cache flushing frequency */
27 #ifndef RTFLUSH
28 #if MAXQTIME
29 #define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */
30 #else
31 #define RTFLUSH (50*totqlen) /* just guess */
32 #endif
33 #endif
34 /* the following must be consistent with rholo.h */
35 int NVARS = NRHVARS; /* total number of variables */
36
37 VARIABLE vv[] = RHVINIT; /* variable-value pairs */
38
39 char *progname; /* our program name */
40 char *hdkfile; /* holodeck file name */
41 char froot[256]; /* root file name */
42
43 int ncprocs = 0; /* desired number of compute processes */
44
45 char *outdev = NULL; /* output device name */
46
47 int readinp = 0; /* read commands from stdin */
48
49 int force = 0; /* allow overwrite of holodeck (-1 == read-only) */
50
51 time_t starttime; /* time we got started */
52 time_t endtime; /* time we should end by */
53 time_t reporttime; /* time for next report */
54
55 off_t maxdisk; /* maximum file space (bytes) */
56
57 int rtargc = 1; /* rtrace command */
58 char *rtargv[128] = {"rtrace", NULL};
59
60 int orig_mode = -1; /* original file mode (-1 if unchanged) */
61
62 long nraysdone = 0L; /* number of rays done */
63 long npacksdone = 0L; /* number of packets done */
64
65 PACKET *freepacks; /* available packets */
66 int totqlen; /* maximum queue length (number of packets) */
67
68 char *sigerr[NSIG]; /* signal error messages */
69
70 extern int nowarn; /* turn warnings off? */
71
72 static void onsig(int signo);
73 static void sigdie(int signo, char *msg);
74 static int resfmode(int fd, int mod);
75 static void initrholo(void);
76 static int rholo(void);
77 static void setdefaults(HDGRID *gp);
78 static void creatholo(HDGRID *gp);
79 static gethfunc headline;
80 static void loadholo(void);
81 static void rootname(char *rn, char *fn);
82 static void badvalue(int vc);
83
84
85 int
86 main(
87 int argc,
88 char *argv[]
89 )
90 {
91 int i;
92
93 initurand(16384); /* initialize urand */
94 progname = argv[0]; /* get arguments */
95 for (i = 1; i < argc && argv[i][0] == '-'; i++)
96 switch (argv[i][1]) {
97 case 'w': /* turn off warnings */
98 nowarn++;
99 break;
100 case 'f': /* force overwrite */
101 force = 1;
102 break;
103 case 'r': /* read-only mode */
104 force = -1;
105 break;
106 case 'i': /* read input from stdin */
107 readinp++;
108 break;
109 case 'n': /* compute processes */
110 if (i >= argc-2)
111 goto userr;
112 ncprocs = atoi(argv[++i]);
113 break;
114 case 'o': /* output display */
115 if (i >= argc-2)
116 goto userr;
117 outdev = argv[++i];
118 break;
119 default:
120 goto userr;
121 }
122 /* get root file name */
123 if (i >= argc)
124 goto userr;
125 rootname(froot, hdkfile=argv[i++]);
126 /* load variables? */
127 if (i < argc)
128 if (argv[i][0] != '-' && argv[i][0] != '+')
129 loadvars(argv[i]); /* load variables from file */
130
131 if (i >= argc || argv[i][0] == '+')
132 loadholo(); /* load existing holodeck */
133
134 while (++i < argc) /* get command line settings */
135 if (setvariable(argv[i], matchvar) < 0) {
136 sprintf(errmsg, "unknown variable: %s", argv[i]);
137 error(USER, errmsg);
138 }
139 /* check settings */
140 checkvalues();
141 /* load rad input file */
142 getradfile();
143
144 if (hdlist[0] == NULL) { /* create new holodeck */
145 HDGRID hdg[HDMAX];
146 /* set defaults */
147 setdefaults(hdg);
148 /* check read-only */
149 if (force < 0)
150 error(USER, "cannot create read-only holodeck");
151 /* holodeck exists? */
152 if (!force && access(hdkfile, R_OK|W_OK) == 0)
153 error(USER,
154 "holodeck file exists -- use -f to overwrite");
155 /* create holodeck */
156 creatholo(hdg);
157 } else /* else just set defaults */
158 setdefaults(NULL);
159 /* initialize */
160 initrholo();
161 /* main loop */
162 while (rholo())
163 ;
164 /* done */
165 quit(0);
166 userr:
167 fprintf(stderr,
168 "Usage: %s [-n nprocs][-o disp][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n",
169 progname);
170 quit(1);
171 return 1; /* pro forma return */
172 }
173
174
175 static void
176 onsig( /* fatal signal */
177 int signo
178 )
179 {
180 static int gotsig = 0;
181
182 if (gotsig > 1) /* we're going as fast as we can! */
183 return;
184 if (gotsig++) { /* two signals and we split */
185 hdsync(NULL, 0); /* don't leave w/o saying goodbye */
186 _exit(signo);
187 }
188 alarm(300); /* allow 5 minutes to clean up */
189 eputs("signal - ");
190 eputs(sigerr[signo]);
191 eputs("\n");
192 quit(3);
193 }
194
195
196 static void
197 sigdie( /* set fatal signal */
198 int signo,
199 char *msg
200 )
201 {
202 if (signal(signo, onsig) == SIG_IGN)
203 signal(signo, SIG_IGN);
204 sigerr[signo] = msg;
205 }
206
207
208 static int
209 resfmode( /* restrict open file access mode */
210 int fd,
211 int mod
212 )
213 {
214 struct stat stbuf;
215 /* get original mode */
216 if (fstat(fd, &stbuf) < 0)
217 error(SYSTEM, "cannot stat open holodeck file");
218 mod &= stbuf.st_mode; /* always more restrictive */
219 if (mod == (stbuf.st_mode & 0777))
220 return(-1); /* already set */
221 /* else change it */
222 if (fchmod(fd, mod) < 0) {
223 error(WARNING, "cannot change holodeck file access mode");
224 return(-1);
225 }
226 return(stbuf.st_mode); /* return original mode */
227 }
228
229
230 static void
231 initrholo(void) /* get our holodeck running */
232 {
233 extern int global_packet();
234 register int i;
235 /* close holodeck on exec() */
236 fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC);
237
238 if (outdev != NULL) /* open output device */
239 disp_open(outdev);
240 else if (ncprocs > 0) /* else use global ray feed */
241 init_global();
242 /* record disk space limit */
243 if (!vdef(DISKSPACE))
244 maxdisk = ((off_t)1<<(sizeof(off_t)*8-2)) - 1024;
245 else
246 maxdisk = 1024.*1024.*vflt(DISKSPACE);
247 /* set up memory cache */
248 if (outdev == NULL)
249 hdcachesize = 0; /* manual flushing */
250 else if (vdef(CACHE))
251 hdcachesize = 1024.*1024.*vflt(CACHE);
252 /* open report file */
253 if (vdef(REPORT)) {
254 register char *s = sskip2(vval(REPORT), 1);
255 if (*s && freopen(s, "a", stderr) == NULL)
256 quit(2);
257 }
258 /* mark the starting time */
259 starttime = time(NULL);
260 /* compute end time */
261 if (!vdef(TIME) || vflt(TIME) <= FTINY)
262 endtime = 0;
263 else
264 endtime = starttime + vflt(TIME)*3600. + .5;
265 /* start rtrace */
266 if (ncprocs > 0) {
267 totqlen = i = start_rtrace();
268 if (i < 1)
269 error(USER, "cannot start rtrace process(es)");
270 if (vdef(REPORT)) { /* make first report */
271 printargs(rtargc, rtargv, stderr);
272 report(0);
273 }
274 /* allocate packets */
275 freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
276 if (freepacks == NULL)
277 goto memerr;
278 freepacks[--i].nr = 0;
279 freepacks[i].next = NULL;
280 if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) {
281 freepacks[i].offset = (float *)bmalloc(
282 RPACKSIZ*sizeof(float)*(i+1) );
283 if (freepacks[i].offset == NULL)
284 goto memerr;
285 } else
286 freepacks[i].offset = NULL;
287 while (i--) {
288 freepacks[i].nr = 0;
289 freepacks[i].offset = freepacks[i+1].offset == NULL ?
290 NULL : freepacks[i+1].offset+RPACKSIZ ;
291 freepacks[i].next = &freepacks[i+1];
292 }
293 }
294 /* set up signal handling */
295 sigdie(SIGINT, "Interrupt");
296 sigdie(SIGTERM, "Terminate");
297 #ifdef SIGHUP
298 sigdie(SIGHUP, "Hangup");
299 #endif
300 #ifdef SIGPIPE
301 sigdie(SIGPIPE, "Broken pipe");
302 #endif
303 #ifdef SIGALRM
304 sigdie(SIGALRM, "Alarm clock");
305 #endif
306 #ifdef SIGXCPU
307 sigdie(SIGXCPU, "CPU limit exceeded");
308 #endif
309 #ifdef SIGXFSZ
310 sigdie(SIGXFSZ, "File size exceeded");
311 #endif
312 /* protect holodeck file */
313 orig_mode = resfmode(hdlist[0]->fd, (ncprocs>0) & (force>=0) ? 0 : 0444);
314 return;
315 memerr:
316 error(SYSTEM, "out of memory in initrholo");
317 }
318
319
320 static int
321 rholo(void) /* holodeck main loop */
322 {
323 static long nextfragwarn = 100*(1L<<20);
324 static int idle = 0;
325 PACKET *pl = NULL, *plend;
326 off_t fsiz, fuse;
327 int pksiz;
328 register PACKET *p;
329 time_t t;
330 /* check display */
331 if (nprocs <= 0)
332 idle = 1;
333 if (outdev != NULL) {
334 if (!disp_check(idle))
335 return(0); /* quit request */
336 if (nprocs <= 0)
337 return(1);
338 } else if (idle)
339 return(0); /* all done */
340 fsiz = hdfilen(hdlist[0]->fd); /* check file size */
341 if (maxdisk > 0 && fsiz >= maxdisk) {
342 error(WARNING, "file limit exceeded");
343 done_rtrace();
344 return(1); /* comes back */
345 }
346 #if FRAGWARN
347 if (fsiz >= nextfragwarn &&
348 (fsiz-(fuse=hdfiluse(hdlist[0]->fd)))/(fsiz/100) > FRAGWARN) {
349 sprintf(errmsg, "holodeck file fragmentation is %.0f%%",
350 100.*(fsiz-fuse)/fsiz);
351 error(WARNING, errmsg);
352 nextfragwarn = fsiz + (fsiz>>2);
353 }
354 #endif
355 t = time(NULL); /* check time */
356 if (endtime > 0 && t >= endtime) {
357 error(WARNING, "time limit exceeded");
358 done_rtrace();
359 return(1); /* comes back */
360 }
361 if (reporttime > 0 && t >= reporttime)
362 report(t);
363 /* figure out good packet size */
364 pksiz = RPACKSIZ;
365 #if MAXQTIME
366 if (!chunkycmp) {
367 pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L));
368 if (pksiz < 1) pksiz = 1;
369 else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ;
370 }
371 #endif
372 idle = 0; /* get packets to process */
373 while (freepacks != NULL) {
374 p = freepacks; freepacks = p->next; p->next = NULL;
375 if (!next_packet(p, pksiz)) {
376 p->next = freepacks; freepacks = p;
377 idle = 1;
378 break;
379 }
380 if (pl == NULL) pl = p;
381 else plend->next = p;
382 plend = p;
383 }
384 /* process packets */
385 done_packets(do_packets(pl));
386 return(1); /* and continue */
387 }
388
389
390 static void
391 setdefaults( /* set default values */
392 register HDGRID *gp
393 )
394 {
395 extern char *atos();
396 register int i;
397 int n;
398 double len[3], d;
399
400 if (!vdef(SECTION)) {
401 sprintf(errmsg, "%s must be defined", vnam(SECTION));
402 error(USER, errmsg);
403 }
404 if (!vdef(OCTREE)) {
405 if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
406 error(SYSTEM, "out of memory");
407 sprintf(vval(OCTREE), "%s.oct", froot);
408 vdef(OCTREE)++;
409 }
410 if (!vdef(VDIST)) {
411 vval(VDIST) = "F";
412 vdef(VDIST)++;
413 }
414 /* append rendering options */
415 if (vdef(RENDER))
416 rtargc += wordstring(rtargv+rtargc, vval(RENDER));
417
418 if (gp == NULL) /* already initialized? */
419 return;
420 /* set grid parameters */
421 for (n = 0; n < vdef(SECTION); n++, gp++) {
422 gp->grid[0] = gp->grid[1] = gp->grid[2] = 0;
423 if (sscanf(nvalue(SECTION, n),
424 "%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd",
425 &gp->orig[0], &gp->orig[1], &gp->orig[2],
426 &gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
427 &gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
428 &gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2],
429 &gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12)
430 badvalue(SECTION);
431 for (i = 0; i < 3; i++)
432 len[i] = VLEN(gp->xv[i]);
433 if (!vdef(GRID)) {
434 d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] +
435 len[2]*len[2] + 4*len[1]*len[2])
436 + len[1]*len[1]*len[2]*(len[2] + 4*len[0])
437 + 4*len[0]*len[1]*len[2]*len[2] );
438 d = sqrt(sqrt(d));
439 } else if ((d = vflt(GRID)) <= FTINY)
440 badvalue(GRID);
441 for (i = 0; i < 3; i++)
442 if (gp->grid[i] <= 0)
443 gp->grid[i] = len[i]/d + (1.-FTINY);
444 }
445 }
446
447
448 static void
449 creatholo( /* create a holodeck output file */
450 HDGRID *gp
451 )
452 {
453 extern char VersionID[];
454 int32 lastloc, nextloc;
455 int n;
456 int fd;
457 FILE *fp;
458 /* open & truncate file */
459 if ((fp = fopen(hdkfile, "w+")) == NULL) {
460 sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
461 error(SYSTEM, errmsg);
462 }
463 /* write information header */
464 newheader("RADIANCE", fp);
465 fprintf(fp, "SOFTWARE= %s\n", VersionID);
466 printvars(fp);
467 fputformat(HOLOFMT, fp);
468 fputc('\n', fp);
469 putw(HOLOMAGIC, fp); /* put magic number */
470 fd = dup(fileno(fp));
471 fclose(fp); /* flush and close stdio stream */
472 lastloc = lseek(fd, (off_t)0, SEEK_END);
473 for (n = vdef(SECTION); n--; gp++) { /* initialize each section */
474 nextloc = 0L;
475 write(fd, (char *)&nextloc, sizeof(nextloc));
476 hdinit(fd, gp); /* writes beam index */
477 if (!n)
478 break;
479 nextloc = hdfilen(fd); /* write section pointer */
480 if (lseek(fd, (off_t)lastloc, SEEK_SET) < 0)
481 error(SYSTEM,
482 "cannot seek on holodeck file in creatholo");
483 write(fd, (char *)&nextloc, sizeof(nextloc));
484 lseek(fd, (off_t)(lastloc=nextloc), SEEK_SET);
485 }
486 }
487
488
489 static int
490 headline( /* process information header line */
491 char *s,
492 void *p
493 )
494 {
495 extern char FMTSTR[];
496 register char *cp;
497 char fmt[32];
498
499 if (formatval(fmt, s)) {
500 if (strcmp(fmt, HOLOFMT)) {
501 sprintf(errmsg, "%s file \"%s\" has %s%s",
502 HOLOFMT, hdkfile, FMTSTR, fmt);
503 error(USER, errmsg);
504 }
505 return(0);
506 }
507 for (cp = s; *cp; cp++) /* take off any comments */
508 if (*cp == '#') {
509 *cp = '\0';
510 break;
511 }
512 setvariable(s, matchvar); /* don't flag errors */
513 return(0);
514 }
515
516
517 static void
518 loadholo(void) /* start loading a holodeck from fname */
519 {
520 FILE *fp;
521 int fd;
522 int n;
523 int32 nextloc;
524
525 if ((ncprocs > 0) & (force >= 0))
526 fp = fopen(hdkfile, "r+");
527 else
528 fp = NULL;
529 if (fp == NULL) {
530 if ((fp = fopen(hdkfile, "r")) == NULL) {
531 sprintf(errmsg, "cannot open \"%s\"", hdkfile);
532 error(SYSTEM, errmsg);
533 }
534 if (ncprocs > 0) {
535 sprintf(errmsg,
536 "\"%s\" opened read-only; new rays will be discarded",
537 hdkfile);
538 error(WARNING, errmsg);
539 force = -1;
540 }
541 }
542 /* load variables from header */
543 getheader(fp, headline, NULL);
544 /* check magic number */
545 if (getw(fp) != HOLOMAGIC) {
546 sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
547 hdkfile);
548 error(USER, errmsg);
549 }
550 nextloc = ftell(fp); /* get stdio position */
551 fd = dup(fileno(fp));
552 fclose(fp); /* done with stdio */
553 for (n = 0; nextloc > 0L; n++) { /* initialize each section */
554 lseek(fd, (off_t)nextloc, SEEK_SET);
555 read(fd, (char *)&nextloc, sizeof(nextloc));
556 hdinit(fd, NULL);
557 }
558 if (n != vdef(SECTION)) {
559 sprintf(errmsg, "number of sections does not match %s setting",
560 vnam(SECTION));
561 error(WARNING, errmsg);
562 }
563 }
564
565
566 extern void
567 done_packets( /* handle finished packets */
568 PACKET *pl
569 )
570 {
571 static int n2flush = 0;
572 register PACKET *p;
573
574 while (pl != NULL) {
575 p = pl; pl = p->next; p->next = NULL;
576 if (p->nr > 0) { /* add to holodeck */
577 memcpy( (void *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
578 (void *)p->ra,
579 p->nr*sizeof(RAYVAL));
580 if (outdev != NULL) /* display it */
581 disp_packet((PACKHEAD *)p);
582 if (hdcachesize <= 0)
583 n2flush++;
584 nraysdone += p->nr;
585 npacksdone++;
586 p->nr = 0;
587 }
588 p->next = freepacks; /* push onto free list */
589 freepacks = p;
590 }
591 if (n2flush >= RTFLUSH) {
592 if (outdev != NULL)
593 hdsync(NULL, 1);
594 else
595 hdflush(NULL);
596 n2flush = 0;
597 }
598 }
599
600
601 static void
602 rootname( /* remove tail from end of fn */
603 register char *rn,
604 register char *fn
605 )
606 {
607 char *tp, *dp;
608
609 for (tp = NULL, dp = rn; (*rn = *fn++); rn++) {
610 if (*rn == '/')
611 dp = rn;
612 else if (*rn == '.')
613 tp = rn;
614 }
615 if (tp != NULL && tp > dp)
616 *tp = '\0';
617 }
618
619
620 static void
621 badvalue( /* report bad variable value and exit */
622 int vc
623 )
624 {
625 sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
626 error(USER, errmsg);
627 }
628
629
630 void
631 eputs(s) /* put error message to stderr */
632 register char *s;
633 {
634 static int midline = 0;
635
636 if (!*s)
637 return;
638 if (!midline++) { /* prepend line with program name */
639 fputs(progname, stderr);
640 fputs(": ", stderr);
641 }
642 fputs(s, stderr);
643 if (s[strlen(s)-1] == '\n') {
644 fflush(stderr);
645 midline = 0;
646 }
647 }
648
649
650 void
651 quit(ec) /* exit program gracefully */
652 int ec;
653 {
654 int status = 0;
655
656 if (hdlist[0] != NULL) { /* close holodeck */
657 if (nprocs > 0)
658 status = done_rtrace(); /* calls hdsync() */
659 if ((ncprocs > 0) & (force >= 0) && vdef(REPORT)) {
660 off_t fsiz, fuse;
661 fsiz = hdfilen(hdlist[0]->fd);
662 fuse = hdfiluse(hdlist[0]->fd);
663 fprintf(stderr,
664 "%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
665 hdkfile, fsiz/(1024.*1024.),
666 100.*(fsiz-fuse)/fsiz);
667 }
668 }
669 if (orig_mode >= 0) /* reset holodeck access mode */
670 fchmod(hdlist[0]->fd, orig_mode);
671 if (outdev != NULL) /* close display */
672 disp_close();
673 exit(ec ? ec : status); /* exit */
674 }
