--- ray/src/hd/rholo.c 2008/12/04 23:34:00 3.73 +++ ray/src/hd/rholo.c 2010/09/30 15:43:30 3.75 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rholo.c,v 3.73 2008/12/04 23:34:00 greg Exp $"; +static const char RCSid[] = "$Id: rholo.c,v 3.75 2010/09/30 15:43:30 greg Exp $"; #endif /* * Radiance holodeck generation controller @@ -164,7 +164,7 @@ main( quit(0); userr: fprintf(stderr, -"Usage: %s [-n nprocs][-o disp][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", +"Usage: %s [-n nprocs][-o disp][-i][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", progname); quit(1); return 1; /* pro forma return */ @@ -453,7 +453,7 @@ creatholo( /* create a holodeck output file */ ) { extern char VersionID[]; - int32 lastloc, nextloc; + off_t lastloc, nextloc; int n; int fd; FILE *fp; @@ -479,11 +479,11 @@ creatholo( /* create a holodeck output file */ if (!n) break; nextloc = hdfilen(fd); /* write section pointer */ - if (lseek(fd, (off_t)lastloc, SEEK_SET) < 0) + if (lseek(fd, lastloc, SEEK_SET) < 0) error(SYSTEM, "cannot seek on holodeck file in creatholo"); write(fd, (char *)&nextloc, sizeof(nextloc)); - lseek(fd, (off_t)(lastloc=nextloc), SEEK_SET); + lseek(fd, (lastloc=nextloc), SEEK_SET); } } @@ -522,7 +522,7 @@ loadholo(void) /* start loading a holodeck from fnam FILE *fp; int fd; int n; - int32 nextloc; + off_t nextloc; if ((ncprocs > 0) & (force >= 0)) fp = fopen(hdkfile, "r+"); @@ -554,7 +554,7 @@ loadholo(void) /* start loading a holodeck from fnam fd = dup(fileno(fp)); fclose(fp); /* done with stdio */ for (n = 0; nextloc > 0L; n++) { /* initialize each section */ - lseek(fd, (off_t)nextloc, SEEK_SET); + lseek(fd, nextloc, SEEK_SET); read(fd, (char *)&nextloc, sizeof(nextloc)); hdinit(fd, NULL); }
