Added missing -i from Usage: message
Updated a few constants to account for faster machines with more memory
Rholo now refuses to compute rays w/o display process on read-only holodeck
Fixed fragment warning repetition for holodecks approaching 2 GBytes
Changed file size and time limit errors to "fatal," which they are
Reduced frequency of fragmentation checks and improved logic
Eliminated spurious warning about holodeck fragmentation when there is none
Ansification and prototypes.
Handling of zero vectors in dircode.c and long long lseek fixes for holodecks
Type fixing to lseek() call
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -r option for read-only holodecks
simplified flushing with RTFLUSH macro
added hdsync() call prior to double-signal exit
added RTFLUSH define for continuous holodeck flushing (dangerous)
increased alarm signal to 2 minutes for cleanup
added warning about excessive file fragmentation
changed default grid size to correspond with different view beams
added holodeck synchronization when cache size is unlimited
changed wputs to library call
changed error message in loadholo()
fixed queue length computation
changed default behavior when GRID is unspecified
made loading of rad input file optional
fixed bug in file mode checking
made loading of RIF dependent on -n option
modify ray packet size based on computation time
fixed core dump when run without arguments
increased time between holodeck flushes in batch mode
fixed another bug in idle logic of rholo()
finally enabled multiple holodeck sections
eliminated OCCUPANCY variable and fixed a couple of new bugs
allow command-line setting of variables even when reusing holodeck
allow rholo to create a holodeck even if there is nothing to do
allow OBSTRUCTIONS to be undefined, and use random offset in that case
modified hdsync() to optionally sync all unflushed beams
reset start time and ray counts in new_rtrace()
moved a few routines from rholo.c to rholo2.c
now we don't quit display process when our calculation ends
made nprocs (number of running processes) global
fixed call to initurand
added optional grid dimensions to section variable
removed useless EXPOSURE variable added setdefaults() call after loading holodeck
added "VDISTANCE" variable for virtual distance calculation changed ray sampling to low discrepency sequence
changed flushing code to account for multiple processes
made program more robust against signals and multiple invocations
put dev_close() call last in quit()
fixed improper pointer alignment in loadholo()
made file length testing more efficient
changed logic on disk space checking and added warning messages
changed disp_packet to take PACKHEAD* r.t. PACKET*
minor efficiency improvement
added manual flushing for when there is no display process
bug fix in getradfile() for no variables to match
initial bug fixes
