--- ray/src/hd/rholo.c 1997/12/12 18:33:50 3.23 +++ ray/src/hd/rholo.c 1997/12/15 20:43:01 3.28 @@ -88,25 +88,27 @@ char *argv[]; default: goto userr; } - /* do we have a job? */ - if (outdev == NULL && ncprocs <= 0) - goto userr; /* get root file name */ rootname(froot, hdkfile=argv[i++]); - /* load... */ - if (i < argc) { /* variables */ - loadvars(argv[i++]); - /* cmdline settings */ - for ( ; i < argc; i++) - if (setvariable(argv[i], matchvar) < 0) { - sprintf(errmsg, "unknown variable: %s", - argv[i]); - error(USER, errmsg); - } - /* check settings */ - checkvalues(); - /* load RIF if any */ - getradfile(); + /* load variables? */ + if (i < argc) + if (argv[i][0] != '-' && argv[i][0] != '+') + loadvars(argv[i]); /* load variables from file */ + + if (i >= argc || argv[i][0] == '+') + loadholo(); /* load existing holodeck */ + + while (++i < argc) /* get command line settings */ + if (setvariable(argv[i], matchvar) < 0) { + sprintf(errmsg, "unknown variable: %s", argv[i]); + error(USER, errmsg); + } + /* check settings */ + checkvalues(); + /* load RIF if any */ + getradfile(); + + if (hdlist[0] == NULL) { /* create new holodeck */ /* set defaults */ setdefaults(&hdg); /* holodeck exists? */ @@ -115,15 +117,8 @@ char *argv[]; "holodeck file exists -- use -f to overwrite"); /* create holodeck */ creatholo(&hdg); - } else { /* else load holodeck */ - loadholo(); - /* check settings */ - checkvalues(); - /* load RIF if any */ - getradfile(); - /* set defaults */ + } else /* else just set defaults */ setdefaults(NULL); - } /* initialize */ initrholo(); /* main loop */ @@ -133,7 +128,7 @@ char *argv[]; quit(0); userr: fprintf(stderr, -"Usage: %s {-n nprocs|-o disp} [-w][-f] output.hdk [control.hif [VAR=val ..]]\n", +"Usage: %s [-n nprocs][-o disp][-w][-f] output.hdk [control.hif|+|- [VAR=val ..]]\n", progname); quit(1); } @@ -147,7 +142,7 @@ int signo; if (gotsig++) /* two signals and we're gone! */ _exit(signo); - alarm(30); /* allow 30 seconds to clean up */ + alarm(60); /* allow 60 seconds to clean up */ signal(SIGALRM, SIG_DFL); /* make certain we do die */ eputs("signal - "); eputs(sigerr[signo]); @@ -233,7 +228,7 @@ initrholo() /* get our holodeck running */ goto memerr; freepacks[--i].nr = 0; freepacks[i].next = NULL; - if (!vbool(OBSTRUCTIONS)) { + if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) { freepacks[i].offset = (float *)bmalloc( RPACKSIZ*sizeof(float)*(i+1) ); if (freepacks[i].offset == NULL) @@ -277,13 +272,14 @@ rholo() /* holodeck main loop */ if (!disp_check(idle)) return(0); /* display only? */ - if (nprocs <= 0) + if (nprocs <= 0) { + idle = 1; return(outdev != NULL); + } /* check file size */ if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { error(WARNING, "file limit exceeded"); done_rtrace(); - idle = 1; return(1); /* comes back */ } /* check time */ @@ -292,12 +288,11 @@ rholo() /* holodeck main loop */ if (endtime > 0 && t >= endtime) { error(WARNING, "time limit exceeded"); done_rtrace(); - idle = 1; return(1); /* comes back */ } if (reporttime > 0 && t >= reporttime) report(t); - /* get packets to process */ + idle = 0; /* get packets to process */ while (freepacks != NULL) { p = freepacks; freepacks = p->next; p->next = NULL; if (!next_packet(p)) { @@ -337,18 +332,10 @@ register HDGRID *gp; sprintf(vval(OCTREE), "%s.oct", froot); vdef(OCTREE)++; } - if (!vdef(OBSTRUCTIONS)) { - vval(OBSTRUCTIONS) = "T"; - vdef(OBSTRUCTIONS)++; - } if (!vdef(VDIST)) { vval(VDIST) = "F"; vdef(VDIST)++; } - if (!vdef(OCCUPANCY)) { - vval(OCCUPANCY) = "U"; - vdef(OCCUPANCY)++; - } /* append rendering options */ if (vdef(RENDER)) rtargc += wordstring(rtargv+rtargc, vval(RENDER)); @@ -548,10 +535,9 @@ int ec; { int status = 0; - if (hdlist[0] != NULL) { /* flush holodeck */ + if (hdlist[0] != NULL) { /* close holodeck */ if (nprocs > 0) - status = done_rtrace(); - hdflush(NULL); + status = done_rtrace(); /* calls hdsync() */ if (ncprocs > 0 && vdef(REPORT)) { long fsiz, fuse; fsiz = hdfilen(hdlist[0]->fd);
