--- ray/src/hd/rholo.c 1997/12/08 18:51:15 3.17 +++ ray/src/hd/rholo.c 1997/12/12 11:13:16 3.20 @@ -32,6 +32,8 @@ char *outdev = NULL; /* output device name */ int readinp = 0; /* read commands from stdin */ +int force = 0; /* allow overwrite of holodeck */ + time_t starttime; /* time we got started */ time_t endtime; /* time we should end by */ time_t reporttime; /* time for next report */ @@ -59,10 +61,9 @@ char *argv[]; { HDGRID hdg; int i; - int force = 0; /* mark start time */ starttime = time(NULL); - initurand(10240); /* initialize urand */ + initurand(16384); /* initialize urand */ progname = argv[0]; /* get arguments */ for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { @@ -224,7 +225,7 @@ initrholo() /* get our holodeck running */ if (ncprocs > 0) { i = start_rtrace(); if (i < 1) - error(USER, "cannot start rtrace process"); + error(USER, "cannot start rtrace process(es)"); if (vdef(REPORT)) { /* make first report */ printargs(rtargc, rtargv, stderr); report(0); @@ -279,7 +280,7 @@ rholo() /* holodeck main loop */ if (!disp_check(idle)) return(0); /* display only? */ - if (ncprocs <= 0) + if (nprocs <= 0) return(1); /* check file size */ if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { @@ -500,13 +501,25 @@ PACKET *pl; p->next = freepacks; freepacks = p; } - if (n2flush > 512*RPACKSIZ*ncprocs) { + if (n2flush > 512*RPACKSIZ*nprocs) { hdflush(NULL); /* flush holodeck buffers */ n2flush = 0; } } +checkrad() /* check to make sure octree is up to date */ +{ + char combuf[128]; + + if (!vdef(RIF)) + return; + sprintf(combuf, "rad -v 0 -s -w %s", vval(RIF)); + if (system(combuf)) + error(WARNING, "error running rad"); +} + + getradfile(rfargs) /* run rad and get needed variables */ char *rfargs; { @@ -540,10 +553,9 @@ char *rfargs; else sprintf(cp, ")[ \t]*=' > %s", tf2); if (system(combuf)) { - error(SYSTEM, "cannot execute rad command"); unlink(tf2); /* clean up */ unlink(tf1); - quit(1); + error(SYSTEM, "cannot execute rad command"); } if (pippt == NULL) { loadvars(tf2); /* load variables */ @@ -610,22 +622,21 @@ int ec; int status = 0; if (hdlist[0] != NULL) { /* flush holodeck */ - if (ncprocs > 0) { + if (nprocs > 0) { done_packets(flush_queue()); status = end_rtrace(); /* close rtrace */ - hdflush(NULL); - if (vdef(REPORT)) { - long fsiz, fuse; - report(0); - fsiz = hdfilen(hdlist[0]->fd); - fuse = hdfiluse(hdlist[0]->fd, 1); - fprintf(stderr, + } + hdflush(NULL); + if (ncprocs > 0 && vdef(REPORT)) { + long fsiz, fuse; + report(0); + fsiz = hdfilen(hdlist[0]->fd); + fuse = hdfiluse(hdlist[0]->fd, 1); + fprintf(stderr, "%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n", - hdkfile, fsiz/(1024.*1024.), - 100.*(fsiz-fuse)/fsiz); - } - } else - hdflush(NULL); + hdkfile, fsiz/(1024.*1024.), + 100.*(fsiz-fuse)/fsiz); + } } if (orig_mode >= 0) /* reset holodeck access mode */ fchmod(hdlist[0]->fd, orig_mode);
