root/radiance/ray/src/hd/rholo.c
Revision: 3.69
Committed: Wed Jun 15 15:36:51 2005 UTC (20 years ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
Changes since 3.68: +1 -2 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.69 static const char RCSid[] = "$Id: rholo.c,v 3.68 2004/09/09 01:41:21 greg Exp $";
3 gregl 3.1 #endif
4     /*
5     * Radiance holodeck generation controller
6     */
7
8 schorsch 3.64 #include <stdio.h>
9     #include <time.h>
10 schorsch 3.59 #include <signal.h>
11     #include <sys/stat.h>
12     #include <string.h>
13
14 greg 3.63 #include "platform.h"
15 schorsch 3.64 #include "rterror.h"
16     #include "resolu.h"
17 gregl 3.1 #include "rholo.h"
18 gregl 3.14 #include "random.h"
19 gregl 3.1
20 gwlarson 3.44 #ifndef FRAGWARN
21     #define FRAGWARN 20 /* fragmentation for warning (%) */
22     #endif
23 gregl 3.33 #ifndef MAXQTIME
24     #define MAXQTIME 5 /* target maximum seconds in queue */
25     #endif
26 gwlarson 3.49 /* manual cache flushing frequency */
27     #ifndef RTFLUSH
28     #if MAXQTIME
29     #define RTFLUSH (300/MAXQTIME*totqlen) /* <= 5 minutes */
30     #else
31     #define RTFLUSH (50*totqlen) /* just guess */
32     #endif
33     #endif
34 gregl 3.1 /* the following must be consistent with rholo.h */
35     int NVARS = NRHVARS; /* total number of variables */
36
37     VARIABLE vv[] = RHVINIT; /* variable-value pairs */
38
39     char *progname; /* our program name */
40     char *hdkfile; /* holodeck file name */
41 gregl 3.22 char froot[256]; /* root file name */
42 gregl 3.1
43     int ncprocs = 0; /* desired number of compute processes */
44
45     char *outdev = NULL; /* output device name */
46
47 gregl 3.17 int readinp = 0; /* read commands from stdin */
48
49 gwlarson 3.51 int force = 0; /* allow overwrite of holodeck (-1 == read-only) */
50 gregl 3.20
51 gregl 3.1 time_t starttime; /* time we got started */
52     time_t endtime; /* time we should end by */
53     time_t reporttime; /* time for next report */
54
55 greg 3.54 off_t maxdisk; /* maximum file space (bytes) */
56 gregl 3.8
57 gregl 3.1 int rtargc = 1; /* rtrace command */
58     char *rtargv[128] = {"rtrace", NULL};
59
60 gregl 3.12 int orig_mode = -1; /* original file mode (-1 if unchanged) */
61
62 gregl 3.1 long nraysdone = 0L; /* number of rays done */
63     long npacksdone = 0L; /* number of packets done */
64
65     PACKET *freepacks; /* available packets */
66 gwlarson 3.49 int totqlen; /* maximum queue length (number of packets) */
67 gregl 3.1
68 gregl 3.12 char *sigerr[NSIG]; /* signal error messages */
69
70 gwlarson 3.40 extern int nowarn; /* turn warnings off? */
71
72 schorsch 3.64 static void onsig(int signo);
73     static void sigdie(int signo, char *msg);
74     static int resfmode(int fd, int mod);
75     static void initrholo(void);
76     static int rholo(void);
77     static void setdefaults(HDGRID *gp);
78     static void creatholo(HDGRID *gp);
79 schorsch 3.65 static gethfunc headline;
80 schorsch 3.64 static void loadholo(void);
81     static void rootname(char *rn, char *fn);
82     static void badvalue(int vc);
83 gregl 3.1
84
85 schorsch 3.64 int
86     main(
87     int argc,
88     char *argv[]
89     )
90 gregl 3.1 {
91     int i;
92 gregl 3.33
93 gregl 3.1 progname = argv[0]; /* get arguments */
94     for (i = 1; i < argc && argv[i][0] == '-'; i++)
95     switch (argv[i][1]) {
96     case 'w': /* turn off warnings */
97     nowarn++;
98     break;
99     case 'f': /* force overwrite */
100 gwlarson 3.51 force = 1;
101 gregl 3.1 break;
102 gwlarson 3.51 case 'r': /* read-only mode */
103     force = -1;
104     break;
105 gregl 3.17 case 'i': /* read input from stdin */
106     readinp++;
107     break;
108 gregl 3.1 case 'n': /* compute processes */
109     if (i >= argc-2)
110     goto userr;
111     ncprocs = atoi(argv[++i]);
112     break;
113     case 'o': /* output display */
114     if (i >= argc-2)
115     goto userr;
116     outdev = argv[++i];
117     break;
118     default:
119     goto userr;
120     }
121     /* get root file name */
122 gregl 3.32 if (i >= argc)
123     goto userr;
124 gregl 3.1 rootname(froot, hdkfile=argv[i++]);
125 gregl 3.27 /* load variables? */
126     if (i < argc)
127     if (argv[i][0] != '-' && argv[i][0] != '+')
128     loadvars(argv[i]); /* load variables from file */
129
130     if (i >= argc || argv[i][0] == '+')
131     loadholo(); /* load existing holodeck */
132
133     while (++i < argc) /* get command line settings */
134     if (setvariable(argv[i], matchvar) < 0) {
135     sprintf(errmsg, "unknown variable: %s", argv[i]);
136     error(USER, errmsg);
137     }
138     /* check settings */
139     checkvalues();
140 gregl 3.36 /* load rad input file */
141     getradfile();
142 gregl 3.27
143 gregl 3.28 if (hdlist[0] == NULL) { /* create new holodeck */
144 gregl 3.29 HDGRID hdg[HDMAX];
145 gregl 3.1 /* set defaults */
146 gregl 3.29 setdefaults(hdg);
147 gwlarson 3.51 /* check read-only */
148     if (force < 0)
149     error(USER, "cannot create read-only holodeck");
150 gregl 3.1 /* holodeck exists? */
151     if (!force && access(hdkfile, R_OK|W_OK) == 0)
152     error(USER,
153     "holodeck file exists -- use -f to overwrite");
154     /* create holodeck */
155 gregl 3.29 creatholo(hdg);
156 gregl 3.27 } else /* else just set defaults */
157 gregl 3.15 setdefaults(NULL);
158 gregl 3.1 /* initialize */
159     initrholo();
160 gregl 3.15 /* main loop */
161 gregl 3.1 while (rholo())
162     ;
163     /* done */
164     quit(0);
165     userr:
166     fprintf(stderr,
167 gwlarson 3.51 "Usage: %s [-n nprocs][-o disp][-w][-r|-f] output.hdk [control.hif|+|- [VAR=val ..]]\n",
168 gregl 3.1 progname);
169     quit(1);
170 schorsch 3.64 return 1; /* pro forma return */
171 gregl 3.1 }
172
173
174 schorsch 3.64 static void
175     onsig( /* fatal signal */
176     int signo
177     )
178 gregl 3.12 {
179     static int gotsig = 0;
180
181 gwlarson 3.47 if (gotsig > 1) /* we're going as fast as we can! */
182     return;
183     if (gotsig++) { /* two signals and we split */
184     hdsync(NULL, 0); /* don't leave w/o saying goodbye */
185 gregl 3.12 _exit(signo);
186 gwlarson 3.47 }
187     alarm(300); /* allow 5 minutes to clean up */
188 gregl 3.12 eputs("signal - ");
189     eputs(sigerr[signo]);
190     eputs("\n");
191     quit(3);
192     }
193
194
195 schorsch 3.64 static void
196     sigdie( /* set fatal signal */
197     int signo,
198     char *msg
199     )
200 gregl 3.12 {
201     if (signal(signo, onsig) == SIG_IGN)
202     signal(signo, SIG_IGN);
203     sigerr[signo] = msg;
204     }
205
206
207 schorsch 3.64 static int
208     resfmode( /* restrict open file access mode */
209     int fd,
210     int mod
211     )
212 gregl 3.12 {
213     struct stat stbuf;
214     /* get original mode */
215     if (fstat(fd, &stbuf) < 0)
216     error(SYSTEM, "cannot stat open holodeck file");
217     mod &= stbuf.st_mode; /* always more restrictive */
218 gregl 3.35 if (mod == (stbuf.st_mode & 0777))
219 gregl 3.12 return(-1); /* already set */
220     /* else change it */
221     if (fchmod(fd, mod) < 0) {
222     error(WARNING, "cannot change holodeck file access mode");
223     return(-1);
224     }
225     return(stbuf.st_mode); /* return original mode */
226     }
227
228
229 schorsch 3.64 static void
230     initrholo(void) /* get our holodeck running */
231 gregl 3.1 {
232     extern int global_packet();
233     register int i;
234 gregl 3.17 /* close holodeck on exec() */
235     fcntl(hdlist[0]->fd, F_SETFD, FD_CLOEXEC);
236 gregl 3.4
237     if (outdev != NULL) /* open output device */
238     disp_open(outdev);
239 gregl 3.1 else if (ncprocs > 0) /* else use global ray feed */
240     init_global();
241 gregl 3.8 /* record disk space limit */
242     if (!vdef(DISKSPACE))
243 greg 3.58 maxdisk = ((off_t)1<<(sizeof(off_t)*8-2)) - 1024;
244 gregl 3.8 else
245 gregl 3.9 maxdisk = 1024.*1024.*vflt(DISKSPACE);
246 gregl 3.1 /* set up memory cache */
247 gregl 3.5 if (outdev == NULL)
248 gwlarson 3.50 hdcachesize = 0; /* manual flushing */
249 gregl 3.5 else if (vdef(CACHE))
250     hdcachesize = 1024.*1024.*vflt(CACHE);
251 gregl 3.1 /* open report file */
252     if (vdef(REPORT)) {
253     register char *s = sskip2(vval(REPORT), 1);
254     if (*s && freopen(s, "a", stderr) == NULL)
255     quit(2);
256     }
257 gregl 3.33 /* mark the starting time */
258     starttime = time(NULL);
259     /* compute end time */
260     if (!vdef(TIME) || vflt(TIME) <= FTINY)
261     endtime = 0;
262     else
263     endtime = starttime + vflt(TIME)*3600. + .5;
264 gregl 3.1 /* start rtrace */
265     if (ncprocs > 0) {
266 gwlarson 3.38 totqlen = i = start_rtrace();
267 gregl 3.1 if (i < 1)
268 gregl 3.20 error(USER, "cannot start rtrace process(es)");
269 gregl 3.1 if (vdef(REPORT)) { /* make first report */
270     printargs(rtargc, rtargv, stderr);
271     report(0);
272     }
273     /* allocate packets */
274     freepacks = (PACKET *)bmalloc(i*sizeof(PACKET));
275     if (freepacks == NULL)
276     goto memerr;
277     freepacks[--i].nr = 0;
278     freepacks[i].next = NULL;
279 gregl 3.25 if (!vdef(OBSTRUCTIONS) || !vbool(OBSTRUCTIONS)) {
280 gregl 3.1 freepacks[i].offset = (float *)bmalloc(
281     RPACKSIZ*sizeof(float)*(i+1) );
282     if (freepacks[i].offset == NULL)
283     goto memerr;
284     } else
285     freepacks[i].offset = NULL;
286     while (i--) {
287     freepacks[i].nr = 0;
288     freepacks[i].offset = freepacks[i+1].offset == NULL ?
289     NULL : freepacks[i+1].offset+RPACKSIZ ;
290     freepacks[i].next = &freepacks[i+1];
291     }
292     }
293 gregl 3.12 /* set up signal handling */
294     sigdie(SIGINT, "Interrupt");
295 schorsch 3.62 sigdie(SIGTERM, "Terminate");
296     #ifdef SIGHUP
297 gregl 3.12 sigdie(SIGHUP, "Hangup");
298 schorsch 3.62 #endif
299     #ifdef SIGPIPE
300 gregl 3.12 sigdie(SIGPIPE, "Broken pipe");
301 schorsch 3.62 #endif
302     #ifdef SIGALRM
303 gregl 3.12 sigdie(SIGALRM, "Alarm clock");
304 schorsch 3.62 #endif
305 gregl 3.12 #ifdef SIGXCPU
306     sigdie(SIGXCPU, "CPU limit exceeded");
307 schorsch 3.62 #endif
308     #ifdef SIGXFSZ
309 gregl 3.12 sigdie(SIGXFSZ, "File size exceeded");
310     #endif
311 gwlarson 3.50 /* protect holodeck file */
312 schorsch 3.60 orig_mode = resfmode(hdlist[0]->fd, (ncprocs>0) & (force>=0) ? 0 : 0444);
313 gregl 3.1 return;
314     memerr:
315     error(SYSTEM, "out of memory in initrholo");
316     }
317
318
319 schorsch 3.64 static int
320     rholo(void) /* holodeck main loop */
321 gregl 3.1 {
322 greg 3.68 static long nextfragwarn = 100L<<20;
323 gregl 3.30 static int idle = 0;
324 gregl 3.1 PACKET *pl = NULL, *plend;
325 greg 3.68 off_t fsiz;
326 gregl 3.33 int pksiz;
327 gregl 3.1 register PACKET *p;
328     time_t t;
329 gregl 3.30 /* check display */
330     if (nprocs <= 0)
331     idle = 1;
332     if (outdev != NULL) {
333 gregl 3.4 if (!disp_check(idle))
334 gregl 3.30 return(0); /* quit request */
335     if (nprocs <= 0)
336     return(1);
337     } else if (idle)
338     return(0); /* all done */
339 gwlarson 3.44 fsiz = hdfilen(hdlist[0]->fd); /* check file size */
340     if (maxdisk > 0 && fsiz >= maxdisk) {
341 gregl 3.8 error(WARNING, "file limit exceeded");
342 gregl 3.21 done_rtrace();
343     return(1); /* comes back */
344 gregl 3.8 }
345 gwlarson 3.44 #if FRAGWARN
346 greg 3.68 if (fsiz >= nextfragwarn) {
347     double pctfrag = 100.*(fsiz-hdfiluse(hdlist[0]->fd))/fsiz;
348     if (pctfrag >= (double)FRAGWARN) {
349     sprintf(errmsg, "holodeck file fragmentation is %.0f%%",
350     pctfrag);
351     error(WARNING, errmsg);
352     nextfragwarn = fsiz + (fsiz>>2);
353     } else
354     nextfragwarn = fsiz + (10L<<20);
355 gwlarson 3.44 }
356     #endif
357 gregl 3.33 t = time(NULL); /* check time */
358 gregl 3.8 if (endtime > 0 && t >= endtime) {
359     error(WARNING, "time limit exceeded");
360 gregl 3.21 done_rtrace();
361     return(1); /* comes back */
362 gregl 3.8 }
363 gregl 3.3 if (reporttime > 0 && t >= reporttime)
364 gregl 3.1 report(t);
365 gregl 3.33 /* figure out good packet size */
366 gwlarson 3.48 pksiz = RPACKSIZ;
367 gregl 3.33 #if MAXQTIME
368 gwlarson 3.48 if (!chunkycmp) {
369     pksiz = nraysdone*MAXQTIME/(totqlen*(t - starttime + 1L));
370     if (pksiz < 1) pksiz = 1;
371     else if (pksiz > RPACKSIZ) pksiz = RPACKSIZ;
372     }
373 gregl 3.33 #endif
374 gregl 3.28 idle = 0; /* get packets to process */
375 gregl 3.1 while (freepacks != NULL) {
376     p = freepacks; freepacks = p->next; p->next = NULL;
377 gregl 3.33 if (!next_packet(p, pksiz)) {
378 gregl 3.1 p->next = freepacks; freepacks = p;
379 gregl 3.21 idle = 1;
380 gregl 3.1 break;
381     }
382     if (pl == NULL) pl = p;
383     else plend->next = p;
384     plend = p;
385     }
386 gregl 3.21 /* process packets */
387 gregl 3.1 done_packets(do_packets(pl));
388     return(1); /* and continue */
389     }
390
391
392 schorsch 3.64 static void
393     setdefaults( /* set default values */
394     register HDGRID *gp
395     )
396 gregl 3.1 {
397     extern char *atos();
398     register int i;
399 gregl 3.29 int n;
400 gregl 3.37 double len[3], d;
401 gregl 3.1
402     if (!vdef(SECTION)) {
403     sprintf(errmsg, "%s must be defined", vnam(SECTION));
404     error(USER, errmsg);
405     }
406     if (!vdef(OCTREE)) {
407     if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL)
408     error(SYSTEM, "out of memory");
409     sprintf(vval(OCTREE), "%s.oct", froot);
410     vdef(OCTREE)++;
411 gregl 3.14 }
412     if (!vdef(VDIST)) {
413     vval(VDIST) = "F";
414     vdef(VDIST)++;
415 gregl 3.1 }
416     /* append rendering options */
417     if (vdef(RENDER))
418     rtargc += wordstring(rtargv+rtargc, vval(RENDER));
419 gregl 3.15
420     if (gp == NULL) /* already initialized? */
421     return;
422     /* set grid parameters */
423 gregl 3.29 for (n = 0; n < vdef(SECTION); n++, gp++) {
424     gp->grid[0] = gp->grid[1] = gp->grid[2] = 0;
425     if (sscanf(nvalue(SECTION, n),
426 gregl 3.16 "%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %hd %hd %hd",
427 gregl 3.29 &gp->orig[0], &gp->orig[1], &gp->orig[2],
428     &gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2],
429     &gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2],
430     &gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2],
431     &gp->grid[0], &gp->grid[1], &gp->grid[2]) < 12)
432     badvalue(SECTION);
433     for (i = 0; i < 3; i++)
434 gregl 3.37 len[i] = VLEN(gp->xv[i]);
435     if (!vdef(GRID)) {
436 gwlarson 3.43 d = 2/2e5*( len[0]*len[0]*(len[1]*len[1] +
437 gregl 3.37 len[2]*len[2] + 4*len[1]*len[2])
438     + len[1]*len[1]*len[2]*(len[2] + 4*len[0])
439     + 4*len[0]*len[1]*len[2]*len[2] );
440     d = sqrt(sqrt(d));
441     } else if ((d = vflt(GRID)) <= FTINY)
442 gregl 3.29 badvalue(GRID);
443     for (i = 0; i < 3; i++)
444     if (gp->grid[i] <= 0)
445     gp->grid[i] = len[i]/d + (1.-FTINY);
446 gregl 3.15 }
447 gregl 3.1 }
448
449
450 schorsch 3.64 static void
451     creatholo( /* create a holodeck output file */
452     HDGRID *gp
453     )
454 gregl 3.1 {
455 gregl 3.12 extern char VersionID[];
456 greg 3.57 int32 lastloc, nextloc;
457 gregl 3.29 int n;
458 gregl 3.10 int fd;
459 gregl 3.1 FILE *fp;
460     /* open & truncate file */
461     if ((fp = fopen(hdkfile, "w+")) == NULL) {
462     sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile);
463     error(SYSTEM, errmsg);
464     }
465     /* write information header */
466     newheader("RADIANCE", fp);
467 gregl 3.12 fprintf(fp, "SOFTWARE= %s\n", VersionID);
468 gregl 3.1 printvars(fp);
469     fputformat(HOLOFMT, fp);
470     fputc('\n', fp);
471 gregl 3.29 putw(HOLOMAGIC, fp); /* put magic number */
472 gregl 3.10 fd = dup(fileno(fp));
473     fclose(fp); /* flush and close stdio stream */
474 greg 3.61 lastloc = lseek(fd, (off_t)0, SEEK_END);
475 gregl 3.29 for (n = vdef(SECTION); n--; gp++) { /* initialize each section */
476     nextloc = 0L;
477     write(fd, (char *)&nextloc, sizeof(nextloc));
478     hdinit(fd, gp); /* writes beam index */
479     if (!n)
480     break;
481     nextloc = hdfilen(fd); /* write section pointer */
482 greg 3.61 if (lseek(fd, (off_t)lastloc, SEEK_SET) < 0)
483 gregl 3.29 error(SYSTEM,
484     "cannot seek on holodeck file in creatholo");
485     write(fd, (char *)&nextloc, sizeof(nextloc));
486 greg 3.61 lseek(fd, (off_t)(lastloc=nextloc), SEEK_SET);
487 gregl 3.29 }
488 gregl 3.1 }
489
490
491 schorsch 3.64 static int
492     headline( /* process information header line */
493 schorsch 3.65 char *s,
494     void *p
495 schorsch 3.64 )
496 gregl 3.1 {
497     extern char FMTSTR[];
498     register char *cp;
499     char fmt[32];
500
501 gregl 3.2 if (formatval(fmt, s)) {
502 gregl 3.1 if (strcmp(fmt, HOLOFMT)) {
503     sprintf(errmsg, "%s file \"%s\" has %s%s",
504     HOLOFMT, hdkfile, FMTSTR, fmt);
505     error(USER, errmsg);
506     }
507 gwlarson 3.42 return(0);
508 gregl 3.1 }
509     for (cp = s; *cp; cp++) /* take off any comments */
510     if (*cp == '#') {
511     *cp = '\0';
512     break;
513     }
514     setvariable(s, matchvar); /* don't flag errors */
515 gwlarson 3.42 return(0);
516 gregl 3.1 }
517
518
519 schorsch 3.64 static void
520     loadholo(void) /* start loading a holodeck from fname */
521 gregl 3.1 {
522     FILE *fp;
523 gregl 3.10 int fd;
524 gregl 3.29 int n;
525 greg 3.57 int32 nextloc;
526 gwlarson 3.51
527 schorsch 3.60 if ((ncprocs > 0) & (force >= 0))
528 gwlarson 3.51 fp = fopen(hdkfile, "r+");
529     else
530     fp = NULL;
531     if (fp == NULL) {
532     if ((fp = fopen(hdkfile, "r")) == NULL) {
533     sprintf(errmsg, "cannot open \"%s\"", hdkfile);
534     error(SYSTEM, errmsg);
535     }
536     if (ncprocs > 0) {
537     sprintf(errmsg,
538     "\"%s\" opened read-only; new rays will be discarded",
539     hdkfile);
540     error(WARNING, errmsg);
541     force = -1;
542     }
543 gregl 3.1 }
544     /* load variables from header */
545     getheader(fp, headline, NULL);
546     /* check magic number */
547     if (getw(fp) != HOLOMAGIC) {
548     sprintf(errmsg, "bad magic number in holodeck file \"%s\"",
549     hdkfile);
550     error(USER, errmsg);
551     }
552 gregl 3.29 nextloc = ftell(fp); /* get stdio position */
553 gregl 3.10 fd = dup(fileno(fp));
554     fclose(fp); /* done with stdio */
555 gregl 3.29 for (n = 0; nextloc > 0L; n++) { /* initialize each section */
556 greg 3.61 lseek(fd, (off_t)nextloc, SEEK_SET);
557 gregl 3.29 read(fd, (char *)&nextloc, sizeof(nextloc));
558     hdinit(fd, NULL);
559     }
560     if (n != vdef(SECTION)) {
561     sprintf(errmsg, "number of sections does not match %s setting",
562     vnam(SECTION));
563     error(WARNING, errmsg);
564     }
565 gregl 3.1 }
566
567
568 schorsch 3.64 extern void
569     done_packets( /* handle finished packets */
570     PACKET *pl
571     )
572 gregl 3.1 {
573 gregl 3.13 static int n2flush = 0;
574 gregl 3.1 register PACKET *p;
575
576     while (pl != NULL) {
577     p = pl; pl = p->next; p->next = NULL;
578     if (p->nr > 0) { /* add to holodeck */
579 schorsch 3.59 memcpy( (void *)hdnewrays(hdlist[p->hd],p->bi,p->nr),
580     (void *)p->ra,
581 gregl 3.1 p->nr*sizeof(RAYVAL));
582     if (outdev != NULL) /* display it */
583 gregl 3.7 disp_packet((PACKHEAD *)p);
584 gwlarson 3.49 if (hdcachesize <= 0)
585 gregl 3.33 n2flush++;
586 gregl 3.6 nraysdone += p->nr;
587     npacksdone++;
588 gregl 3.33 p->nr = 0;
589 gregl 3.1 }
590 gregl 3.33 p->next = freepacks; /* push onto free list */
591 gregl 3.1 freepacks = p;
592 gregl 3.5 }
593 gwlarson 3.50 if (n2flush >= RTFLUSH) {
594 gwlarson 3.46 if (outdev != NULL)
595     hdsync(NULL, 1);
596 gwlarson 3.41 else
597 gwlarson 3.46 hdflush(NULL);
598 gregl 3.13 n2flush = 0;
599 gregl 3.1 }
600     }
601
602
603 schorsch 3.64 static void
604     rootname( /* remove tail from end of fn */
605     register char *rn,
606     register char *fn
607     )
608 gregl 3.1 {
609     char *tp, *dp;
610
611 schorsch 3.60 for (tp = NULL, dp = rn; (*rn = *fn++); rn++) {
612 gregl 3.22 if (*rn == '/')
613 gregl 3.1 dp = rn;
614     else if (*rn == '.')
615     tp = rn;
616 schorsch 3.60 }
617 gregl 3.1 if (tp != NULL && tp > dp)
618     *tp = '\0';
619     }
620
621
622 schorsch 3.64 static void
623     badvalue( /* report bad variable value and exit */
624     int vc
625     )
626 gregl 3.1 {
627     sprintf(errmsg, "bad value for variable '%s'", vnam(vc));
628     error(USER, errmsg);
629     }
630
631
632 greg 3.52 void
633 gregl 3.1 eputs(s) /* put error message to stderr */
634     register char *s;
635     {
636     static int midline = 0;
637
638     if (!*s)
639     return;
640     if (!midline++) { /* prepend line with program name */
641     fputs(progname, stderr);
642     fputs(": ", stderr);
643     }
644     fputs(s, stderr);
645     if (s[strlen(s)-1] == '\n') {
646     fflush(stderr);
647     midline = 0;
648     }
649     }
650
651
652 greg 3.52 void
653 gregl 3.1 quit(ec) /* exit program gracefully */
654     int ec;
655     {
656     int status = 0;
657
658 gregl 3.24 if (hdlist[0] != NULL) { /* close holodeck */
659 gregl 3.21 if (nprocs > 0)
660 gregl 3.24 status = done_rtrace(); /* calls hdsync() */
661 schorsch 3.60 if ((ncprocs > 0) & (force >= 0) && vdef(REPORT)) {
662 greg 3.54 off_t fsiz, fuse;
663 gregl 3.19 fsiz = hdfilen(hdlist[0]->fd);
664 greg 3.67 fuse = hdfiluse(hdlist[0]->fd);
665 gregl 3.19 fprintf(stderr,
666 gregl 3.3 "%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n",
667 gregl 3.19 hdkfile, fsiz/(1024.*1024.),
668     100.*(fsiz-fuse)/fsiz);
669     }
670 gregl 3.1 }
671 gregl 3.12 if (orig_mode >= 0) /* reset holodeck access mode */
672     fchmod(hdlist[0]->fd, orig_mode);
673 gregl 3.11 if (outdev != NULL) /* close display */
674     disp_close();
675 gregl 3.1 exit(ec ? ec : status); /* exit */
676     }
