1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Radiance holodeck generation controller |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "paths.h" |
13 |
#include <signal.h> |
14 |
#include <sys/types.h> |
15 |
#include <sys/stat.h> |
16 |
17 |
/* the following must be consistent with rholo.h */ |
18 |
int NVARS = NRHVARS; /* total number of variables */ |
19 |
20 |
VARIABLE vv[] = RHVINIT; /* variable-value pairs */ |
21 |
22 |
char *progname; /* our program name */ |
23 |
char *hdkfile; /* holodeck file name */ |
24 |
char froot[MAXPATH]; /* root file name */ |
25 |
26 |
int nowarn = 0; /* turn warnings off? */ |
27 |
28 |
double expval = 1.; /* global exposure value */ |
29 |
30 |
int ncprocs = 0; /* desired number of compute processes */ |
31 |
32 |
char *outdev = NULL; /* output device name */ |
33 |
34 |
time_t starttime; /* time we got started */ |
35 |
time_t endtime; /* time we should end by */ |
36 |
time_t reporttime; /* time for next report */ |
37 |
38 |
long maxdisk; /* maximum file space (bytes) */ |
39 |
40 |
int rtargc = 1; /* rtrace command */ |
41 |
char *rtargv[128] = {"rtrace", NULL}; |
42 |
43 |
int orig_mode = -1; /* original file mode (-1 if unchanged) */ |
44 |
45 |
long nraysdone = 0L; /* number of rays done */ |
46 |
long npacksdone = 0L; /* number of packets done */ |
47 |
48 |
PACKET *freepacks; /* available packets */ |
49 |
50 |
char *sigerr[NSIG]; /* signal error messages */ |
51 |
52 |
extern time_t time(); |
53 |
54 |
55 |
main(argc, argv) |
56 |
int argc; |
57 |
char *argv[]; |
58 |
59 |
HDGRID hdg; |
60 |
int i; |
61 |
int force = 0; |
62 |
/* mark start time */ |
63 |
starttime = time(NULL); |
64 |
progname = argv[0]; /* get arguments */ |
65 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
66 |
switch (argv[i][1]) { |
67 |
case 'w': /* turn off warnings */ |
68 |
nowarn++; |
69 |
break; |
70 |
case 'f': /* force overwrite */ |
71 |
force++; |
72 |
break; |
73 |
case 'n': /* compute processes */ |
74 |
if (i >= argc-2) |
75 |
goto userr; |
76 |
ncprocs = atoi(argv[++i]); |
77 |
break; |
78 |
case 'o': /* output display */ |
79 |
if (i >= argc-2) |
80 |
goto userr; |
81 |
outdev = argv[++i]; |
82 |
break; |
83 |
default: |
84 |
goto userr; |
85 |
86 |
/* do we have a job? */ |
87 |
if (outdev == NULL && ncprocs <= 0) |
88 |
goto userr; |
89 |
/* get root file name */ |
90 |
rootname(froot, hdkfile=argv[i++]); |
91 |
/* load... */ |
92 |
if (i < argc) { /* variables */ |
93 |
loadvars(argv[i++]); |
94 |
/* cmdline settings */ |
95 |
for ( ; i < argc; i++) |
96 |
if (setvariable(argv[i], matchvar) < 0) { |
97 |
sprintf(errmsg, "unknown variable: %s", |
98 |
argv[i]); |
99 |
error(USER, errmsg); |
100 |
101 |
/* check settings */ |
102 |
checkvalues(); |
103 |
/* load RIF if any */ |
104 |
if (vdef(RIF)) |
105 |
getradfile(vval(RIF)); |
106 |
/* set defaults */ |
107 |
setdefaults(&hdg); |
108 |
/* holodeck exists? */ |
109 |
if (!force && access(hdkfile, R_OK|W_OK) == 0) |
110 |
error(USER, |
111 |
"holodeck file exists -- use -f to overwrite"); |
112 |
/* create holodeck */ |
113 |
creatholo(&hdg); |
114 |
} else { /* else load holodeck */ |
115 |
loadholo(); |
116 |
if (vdef(RIF)) /* load RIF if any */ |
117 |
118 |
119 |
/* initialize */ |
120 |
initrholo(); |
121 |
/* run */ |
122 |
while (rholo()) |
123 |
124 |
/* done */ |
125 |
quit(0); |
126 |
userr: |
127 |
fprintf(stderr, |
128 |
"Usage: %s {-n nprocs|-o disp} [-w][-f] output.hdk [control.hif [VAR=val ..]]\n", |
129 |
progname); |
130 |
quit(1); |
131 |
132 |
133 |
134 |
onsig(signo) /* fatal signal */ |
135 |
int signo; |
136 |
137 |
static int gotsig = 0; |
138 |
139 |
if (gotsig++) /* two signals and we're gone! */ |
140 |
_exit(signo); |
141 |
142 |
alarm(30); /* allow 30 seconds to clean up */ |
143 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
144 |
eputs("signal - "); |
145 |
eputs(sigerr[signo]); |
146 |
eputs("\n"); |
147 |
quit(3); |
148 |
149 |
150 |
151 |
sigdie(signo, msg) /* set fatal signal */ |
152 |
int signo; |
153 |
char *msg; |
154 |
155 |
if (signal(signo, onsig) == SIG_IGN) |
156 |
signal(signo, SIG_IGN); |
157 |
sigerr[signo] = msg; |
158 |
159 |
160 |
161 |
int |
162 |
resfmode(fd, mod) /* restrict open file access mode */ |
163 |
int fd, mod; |
164 |
165 |
struct stat stbuf; |
166 |
/* get original mode */ |
167 |
if (fstat(fd, &stbuf) < 0) |
168 |
error(SYSTEM, "cannot stat open holodeck file"); |
169 |
mod &= stbuf.st_mode; /* always more restrictive */ |
170 |
if (mod == stbuf.st_mode) |
171 |
return(-1); /* already set */ |
172 |
/* else change it */ |
173 |
if (fchmod(fd, mod) < 0) { |
174 |
error(WARNING, "cannot change holodeck file access mode"); |
175 |
return(-1); |
176 |
177 |
return(stbuf.st_mode); /* return original mode */ |
178 |
179 |
180 |
181 |
initrholo() /* get our holodeck running */ |
182 |
183 |
extern int global_packet(); |
184 |
register int i; |
185 |
186 |
if (outdev != NULL) /* open output device */ |
187 |
disp_open(outdev); |
188 |
else if (ncprocs > 0) /* else use global ray feed */ |
189 |
init_global(); |
190 |
/* record disk space limit */ |
191 |
if (!vdef(DISKSPACE)) |
192 |
maxdisk = 0; |
193 |
else |
194 |
maxdisk = 1024.*1024.*vflt(DISKSPACE); |
195 |
/* record end time */ |
196 |
if (!vdef(TIME) || vflt(TIME) <= FTINY) |
197 |
endtime = 0; |
198 |
else |
199 |
endtime = starttime + vflt(TIME)*3600.; |
200 |
/* set up memory cache */ |
201 |
if (outdev == NULL) |
202 |
hdcachesize = 0; /* manual flushing */ |
203 |
else if (vdef(CACHE)) |
204 |
hdcachesize = 1024.*1024.*vflt(CACHE); |
205 |
/* open report file */ |
206 |
if (vdef(REPORT)) { |
207 |
register char *s = sskip2(vval(REPORT), 1); |
208 |
if (*s && freopen(s, "a", stderr) == NULL) |
209 |
quit(2); |
210 |
211 |
/* start rtrace */ |
212 |
if (ncprocs > 0) { |
213 |
i = start_rtrace(); |
214 |
if (i < 1) |
215 |
error(USER, "cannot start rtrace process"); |
216 |
if (vdef(REPORT)) { /* make first report */ |
217 |
printargs(rtargc, rtargv, stderr); |
218 |
report(0); |
219 |
220 |
/* allocate packets */ |
221 |
freepacks = (PACKET *)bmalloc(i*sizeof(PACKET)); |
222 |
if (freepacks == NULL) |
223 |
goto memerr; |
224 |
freepacks[--i].nr = 0; |
225 |
freepacks[i].next = NULL; |
226 |
if (!vbool(OBSTRUCTIONS)) { |
227 |
freepacks[i].offset = (float *)bmalloc( |
228 |
RPACKSIZ*sizeof(float)*(i+1) ); |
229 |
if (freepacks[i].offset == NULL) |
230 |
goto memerr; |
231 |
} else |
232 |
freepacks[i].offset = NULL; |
233 |
while (i--) { |
234 |
freepacks[i].nr = 0; |
235 |
freepacks[i].offset = freepacks[i+1].offset == NULL ? |
236 |
NULL : freepacks[i+1].offset+RPACKSIZ ; |
237 |
freepacks[i].next = &freepacks[i+1]; |
238 |
239 |
240 |
/* set up signal handling */ |
241 |
sigdie(SIGINT, "Interrupt"); |
242 |
sigdie(SIGHUP, "Hangup"); |
243 |
sigdie(SIGTERM, "Terminate"); |
244 |
sigdie(SIGPIPE, "Broken pipe"); |
245 |
sigdie(SIGALRM, "Alarm clock"); |
246 |
#ifdef SIGXCPU |
247 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
248 |
sigdie(SIGXFSZ, "File size exceeded"); |
249 |
#endif |
250 |
/* protect holodeck file */ |
251 |
orig_mode = resfmode(hdlist[0]->fd, ncprocs>0 ? 0 : 0444); |
252 |
return; |
253 |
memerr: |
254 |
error(SYSTEM, "out of memory in initrholo"); |
255 |
256 |
257 |
258 |
rholo() /* holodeck main loop */ |
259 |
260 |
static int idle = 1; |
261 |
PACKET *pl = NULL, *plend; |
262 |
register PACKET *p; |
263 |
time_t t; |
264 |
long l; |
265 |
266 |
if (outdev != NULL) /* check display */ |
267 |
if (!disp_check(idle)) |
268 |
return(0); |
269 |
/* display only? */ |
270 |
if (ncprocs <= 0) |
271 |
return(1); |
272 |
/* check file size */ |
273 |
if (maxdisk > 0 && hdfilen(hdlist[0]->fd) >= maxdisk) { |
274 |
error(WARNING, "file limit exceeded"); |
275 |
return(0); |
276 |
277 |
/* check time */ |
278 |
if (endtime > 0 || reporttime > 0) |
279 |
t = time(NULL); |
280 |
if (endtime > 0 && t >= endtime) { |
281 |
error(WARNING, "time limit exceeded"); |
282 |
return(0); |
283 |
284 |
if (reporttime > 0 && t >= reporttime) |
285 |
report(t); |
286 |
/* get packets to process */ |
287 |
while (freepacks != NULL) { |
288 |
p = freepacks; freepacks = p->next; p->next = NULL; |
289 |
if (!next_packet(p)) { |
290 |
p->next = freepacks; freepacks = p; |
291 |
break; |
292 |
293 |
if (pl == NULL) pl = p; |
294 |
else plend->next = p; |
295 |
plend = p; |
296 |
297 |
idle = pl == NULL && freepacks != NULL; |
298 |
/* are we out of stuff to do? */ |
299 |
if (idle && outdev == NULL) |
300 |
return(0); |
301 |
/* else process packets */ |
302 |
done_packets(do_packets(pl)); |
303 |
return(1); /* and continue */ |
304 |
305 |
306 |
307 |
report(t) /* report progress so far */ |
308 |
time_t t; |
309 |
310 |
if (t == 0) |
311 |
t = time(NULL); |
312 |
fprintf(stderr, "%s: %ld packets (%ld rays) done after %.2f hours\n", |
313 |
progname, npacksdone, nraysdone, (t-starttime)/3600.); |
314 |
fflush(stderr); |
315 |
if (vdef(REPORT)) |
316 |
reporttime = t + (time_t)(vflt(REPORT)*60.+.5); |
317 |
318 |
319 |
320 |
setdefaults(gp) /* set default values */ |
321 |
register HDGRID *gp; |
322 |
323 |
extern char *atos(); |
324 |
register int i; |
325 |
double len[3], maxlen, d; |
326 |
char buf[64]; |
327 |
328 |
if (!vdef(SECTION)) { |
329 |
sprintf(errmsg, "%s must be defined", vnam(SECTION)); |
330 |
331 |
332 |
if (vdef(SECTION) > 1) { |
333 |
sprintf(errmsg, "ignoring all but first %s", vnam(SECTION)); |
334 |
error(WARNING, errmsg); |
335 |
336 |
if (sscanf(vval(SECTION), |
337 |
"%lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf %lf", |
338 |
&gp->orig[0], &gp->orig[1], &gp->orig[2], |
339 |
&gp->xv[0][0], &gp->xv[0][1], &gp->xv[0][2], |
340 |
&gp->xv[1][0], &gp->xv[1][1], &gp->xv[1][2], |
341 |
&gp->xv[2][0], &gp->xv[2][1], &gp->xv[2][2]) != 12) |
342 |
badvalue(SECTION); |
343 |
maxlen = 0.; |
344 |
for (i = 0; i < 3; i++) |
345 |
if ((len[i] = VLEN(gp->xv[i])) > maxlen) |
346 |
maxlen = len[i]; |
347 |
if (!vdef(GRID)) { |
348 |
sprintf(buf, "%.4f", maxlen/8.); |
349 |
vval(GRID) = savqstr(buf); |
350 |
vdef(GRID)++; |
351 |
352 |
if ((d = vflt(GRID)) <= FTINY) |
353 |
badvalue(GRID); |
354 |
355 |
gp->grid[i] = len[i]/d + (1.-FTINY); |
356 |
if (!vdef(EXPOSURE)) { |
357 |
sprintf(errmsg, "%s must be defined", vnam(EXPOSURE)); |
358 |
359 |
360 |
expval = vval(EXPOSURE)[0] == '-' || vval(EXPOSURE)[0] == '+' ? |
361 |
pow(2., vflt(EXPOSURE)) : vflt(EXPOSURE); |
362 |
if (!vdef(OCTREE)) { |
363 |
if ((vval(OCTREE) = bmalloc(strlen(froot)+5)) == NULL) |
364 |
error(SYSTEM, "out of memory"); |
365 |
sprintf(vval(OCTREE), "%s.oct", froot); |
366 |
vdef(OCTREE)++; |
367 |
368 |
if (!vdef(OBSTRUCTIONS)) { |
369 |
vval(OBSTRUCTIONS) = "T"; |
370 |
vdef(OBSTRUCTIONS)++; |
371 |
372 |
if (!vdef(OCCUPANCY)) { |
373 |
vval(OCCUPANCY) = "U"; |
374 |
vdef(OCCUPANCY)++; |
375 |
376 |
/* append rendering options */ |
377 |
if (vdef(RENDER)) |
378 |
rtargc += wordstring(rtargv+rtargc, vval(RENDER)); |
379 |
380 |
381 |
382 |
creatholo(gp) /* create a holodeck output file */ |
383 |
HDGRID *gp; |
384 |
385 |
extern char VersionID[]; |
386 |
long endloc = 0; |
387 |
int fd; |
388 |
FILE *fp; |
389 |
/* open & truncate file */ |
390 |
if ((fp = fopen(hdkfile, "w+")) == NULL) { |
391 |
sprintf(errmsg, "cannot open \"%s\" for writing", hdkfile); |
392 |
error(SYSTEM, errmsg); |
393 |
394 |
/* write information header */ |
395 |
newheader("RADIANCE", fp); |
396 |
fprintf(fp, "SOFTWARE= %s\n", VersionID); |
397 |
printvars(fp); |
398 |
fputformat(HOLOFMT, fp); |
399 |
fputc('\n', fp); |
400 |
putw(HOLOMAGIC, fp); /* put magic number & terminus */ |
401 |
fwrite(&endloc, sizeof(long), 1, fp); |
402 |
fd = dup(fileno(fp)); |
403 |
fclose(fp); /* flush and close stdio stream */ |
404 |
hdinit(fd, gp); /* allocate and initialize index */ |
405 |
406 |
407 |
408 |
headline(s) /* process information header line */ |
409 |
char *s; |
410 |
411 |
extern char FMTSTR[]; |
412 |
register char *cp; |
413 |
char fmt[32]; |
414 |
415 |
if (formatval(fmt, s)) { |
416 |
if (strcmp(fmt, HOLOFMT)) { |
417 |
sprintf(errmsg, "%s file \"%s\" has %s%s", |
418 |
HOLOFMT, hdkfile, FMTSTR, fmt); |
419 |
420 |
421 |
return; |
422 |
423 |
for (cp = s; *cp; cp++) /* take off any comments */ |
424 |
if (*cp == '#') { |
425 |
*cp = '\0'; |
426 |
break; |
427 |
428 |
setvariable(s, matchvar); /* don't flag errors */ |
429 |
430 |
431 |
432 |
loadholo() /* start loading a holodeck from fname */ |
433 |
434 |
extern long ftell(); |
435 |
FILE *fp; |
436 |
int fd; |
437 |
long fpos; |
438 |
/* open holodeck file */ |
439 |
if ((fp = fopen(hdkfile, ncprocs>0 ? "r+" : "r")) == NULL) { |
440 |
sprintf(errmsg, "cannot open \"%s\" for %s", hdkfile, |
441 |
ncprocs>0 ? "appending" : "reading"); |
442 |
443 |
444 |
/* load variables from header */ |
445 |
getheader(fp, headline, NULL); |
446 |
/* check magic number */ |
447 |
if (getw(fp) != HOLOMAGIC) { |
448 |
sprintf(errmsg, "bad magic number in holodeck file \"%s\"", |
449 |
hdkfile); |
450 |
451 |
452 |
fread(&fpos, sizeof(long), 1, fp); |
453 |
if (fpos != 0) |
454 |
error(WARNING, "ignoring multiple sections in holodeck file"); |
455 |
fpos = ftell(fp); /* get stdio position */ |
456 |
457 |
fclose(fp); /* done with stdio */ |
458 |
lseek(fd, fpos, 0); /* align system file pointer */ |
459 |
hdinit(fd, NULL); /* allocate and load index */ |
460 |
461 |
462 |
463 |
done_packets(pl) /* handle finished packets */ |
464 |
PACKET *pl; |
465 |
466 |
static int nunflushed = 0; |
467 |
468 |
469 |
while (pl != NULL) { |
470 |
p = pl; pl = p->next; p->next = NULL; |
471 |
if (p->nr > 0) { /* add to holodeck */ |
472 |
bcopy((char *)p->ra, |
473 |
(char *)hdnewrays(hdlist[p->hd],p->bi,p->nr), |
474 |
p->nr*sizeof(RAYVAL)); |
475 |
if (outdev != NULL) /* display it */ |
476 |
disp_packet((PACKHEAD *)p); |
477 |
else |
478 |
nunflushed += p->nr; |
479 |
nraysdone += p->nr; |
480 |
npacksdone++; |
481 |
482 |
p->nr = 0; /* push onto free list */ |
483 |
p->next = freepacks; |
484 |
freepacks = p; |
485 |
486 |
if (nunflushed >= 256*RPACKSIZ) { |
487 |
hdflush(NULL); /* flush holodeck buffers */ |
488 |
nunflushed = 0; |
489 |
490 |
491 |
492 |
493 |
getradfile(rfargs) /* run rad and get needed variables */ |
494 |
char *rfargs; |
495 |
496 |
static short mvar[] = {OCTREE,EXPOSURE,-1}; |
497 |
static char tf1[] = TEMPLATE; |
498 |
char tf2[64]; |
499 |
char combuf[256]; |
500 |
char *pippt; |
501 |
register int i; |
502 |
503 |
/* create rad command */ |
504 |
mktemp(tf1); |
505 |
sprintf(tf2, "%s.rif", tf1); |
506 |
sprintf(combuf, |
507 |
"rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH", |
508 |
rfargs, tf1); |
509 |
cp = combuf; |
510 |
while (*cp){ |
511 |
if (*cp == '|') pippt = cp; |
512 |
cp++; |
513 |
} /* match unset variables */ |
514 |
for (i = 0; mvar[i] >= 0; i++) |
515 |
if (!vdef(mvar[i])) { |
516 |
*cp++ = '|'; |
517 |
strcpy(cp, vnam(mvar[i])); |
518 |
while (*cp) cp++; |
519 |
pippt = NULL; |
520 |
521 |
if (pippt != NULL) |
522 |
strcpy(pippt, "> /dev/null"); /* nothing to match */ |
523 |
else |
524 |
sprintf(cp, ")[ \t]*=' > %s", tf2); |
525 |
if (system(combuf)) { |
526 |
error(SYSTEM, "cannot execute rad command"); |
527 |
unlink(tf2); /* clean up */ |
528 |
unlink(tf1); |
529 |
quit(1); |
530 |
531 |
if (pippt == NULL) { |
532 |
loadvars(tf2); /* load variables */ |
533 |
unlink(tf2); |
534 |
535 |
rtargc += wordfile(rtargv+rtargc, tf1); /* get rtrace options */ |
536 |
unlink(tf1); /* clean up */ |
537 |
538 |
539 |
540 |
rootname(rn, fn) /* remove tail from end of fn */ |
541 |
register char *rn, *fn; |
542 |
543 |
char *tp, *dp; |
544 |
545 |
for (tp = NULL, dp = rn; *rn = *fn++; rn++) |
546 |
if (ISDIRSEP(*rn)) |
547 |
dp = rn; |
548 |
else if (*rn == '.') |
549 |
tp = rn; |
550 |
if (tp != NULL && tp > dp) |
551 |
*tp = '\0'; |
552 |
553 |
554 |
555 |
badvalue(vc) /* report bad variable value and exit */ |
556 |
int vc; |
557 |
558 |
sprintf(errmsg, "bad value for variable '%s'", vnam(vc)); |
559 |
560 |
561 |
562 |
563 |
eputs(s) /* put error message to stderr */ |
564 |
register char *s; |
565 |
566 |
static int midline = 0; |
567 |
568 |
if (!*s) |
569 |
return; |
570 |
if (!midline++) { /* prepend line with program name */ |
571 |
fputs(progname, stderr); |
572 |
fputs(": ", stderr); |
573 |
574 |
fputs(s, stderr); |
575 |
if (s[strlen(s)-1] == '\n') { |
576 |
fflush(stderr); |
577 |
midline = 0; |
578 |
579 |
580 |
581 |
582 |
wputs(s) /* put warning string to stderr */ |
583 |
char *s; |
584 |
585 |
if (!nowarn) |
586 |
eputs(s); |
587 |
588 |
589 |
590 |
quit(ec) /* exit program gracefully */ |
591 |
int ec; |
592 |
593 |
int status = 0; |
594 |
595 |
if (hdlist[0] != NULL) { /* flush holodeck */ |
596 |
597 |
done_packets(flush_queue()); |
598 |
status = end_rtrace(); /* close rtrace */ |
599 |
hdflush(NULL); |
600 |
601 |
long fsiz, fuse; |
602 |
report(0); |
603 |
fsiz = hdfilen(hdlist[0]->fd); |
604 |
fuse = hdfiluse(hdlist[0]->fd, 1); |
605 |
fprintf(stderr, |
606 |
"%s: %.1f Mbyte holodeck file, %.1f%% fragmentation\n", |
607 |
hdkfile, fsiz/(1024.*1024.), |
608 |
100.*(fsiz-fuse)/fsiz); |
609 |
610 |
} else |
611 |
hdflush(NULL); |
612 |
613 |
if (orig_mode >= 0) /* reset holodeck access mode */ |
614 |
fchmod(hdlist[0]->fd, orig_mode); |
615 |
if (outdev != NULL) /* close display */ |
616 |
disp_close(); |
617 |
exit(ec ? ec : status); /* exit */ |
618 |
