root/radiance/ray/src/hd/rhinfo.c
Revision: 3.11
Committed: Thu Sep 9 01:06:19 2004 UTC (19 years, 8 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.11 static const char RCSid[] = "$Id: rhinfo.c,v 3.10 2004/01/01 11:21:55 schorsch Exp $";
3 gwlarson 3.1 #endif
4     /*
5     * Get general information on holodeck file
6     */
7
8 schorsch 3.10 #include <stdio.h>
9
10 greg 3.9 #include "platform.h"
11 schorsch 3.10 #include "resolu.h"
12 gwlarson 3.1 #include "holo.h"
13
14     #ifndef NHBINS
15     #define NHBINS 12 /* number of histogram bins to use for stats */
16     #endif
17
18     char *progname; /* global argv[0] */
19
20 gwlarson 3.3 long beamtot, samptot; /* total beams and samples */
21 gwlarson 3.1
22 schorsch 3.10 static void gethdinfo(char *fname, FILE *fout);
23     static void psectstats(HOLO *hp, FILE *fp);
24
25 gwlarson 3.3
26 schorsch 3.10 int
27     main(
28     int argc,
29     char *argv[]
30     )
31 gwlarson 3.1 {
32     progname = argv[0];
33     if (argc != 2)
34     goto userr;
35     gethdinfo(argv[1], stdout);
36     quit(0);
37     userr:
38     fprintf(stderr, "Usage: %s input.hdk\n", progname);
39     exit(1);
40     }
41
42
43 schorsch 3.10 static void
44     gethdinfo( /* get information on holodeck */
45     char *fname,
46     FILE *fout
47     )
48 gwlarson 3.1 {
49     FILE *fp;
50     HOLO *hdsect;
51     int fd;
52 greg 3.7 int32 nextloc;
53 gwlarson 3.1 int n;
54     /* open holodeck file */
55     if ((fp = fopen(fname, "r")) == NULL) {
56     sprintf(errmsg, "cannot open \"%s\"", fname);
57     error(SYSTEM, errmsg);
58     }
59     /* check header and magic number */
60     if (checkheader(fp, HOLOFMT, fout) < 0 || getw(fp) != HOLOMAGIC) {
61     sprintf(errmsg, "file \"%s\" not in holodeck format", fname);
62     error(USER, errmsg);
63     }
64     fd = dup(fileno(fp)); /* dup file handle */
65     nextloc = ftell(fp); /* get stdio position */
66     fclose(fp); /* done with stdio */
67     for (n = 0; nextloc > 0L; n++) { /* get the section(s) */
68 greg 3.8 lseek(fd, (off_t)nextloc, SEEK_SET);
69 gwlarson 3.1 read(fd, (char *)&nextloc, sizeof(nextloc));
70 gwlarson 3.2 fprintf(fout, "Section %d:\n", n);
71 gwlarson 3.1 hdsect = hdinit(fd, NULL); /* load section directory */
72     psectstats(hdsect, fout); /* print section statistics */
73     }
74     nextloc = hdfilen(fd); /* print global statistics */
75 gwlarson 3.3 fputs("=====================================================\n", fout);
76     fprintf(fout, "Total samples/beams: %ld/%ld (%.2f samples/beam)\n",
77     samptot, beamtot, (double)samptot/beamtot);
78 gwlarson 3.1 fprintf(fout, "%.1f Mbyte file, %.1f%% fragmentation\n",
79     nextloc/(1024.*1024.),
80 greg 3.11 100.*(nextloc-hdfiluse(fd))/nextloc);
81 gwlarson 3.1 /* don't bother with cleanup */
82     #if 0
83     hddone(NULL); /* free sections */
84     close(fd); /* done with the holodeck */
85     #endif
86     }
87
88
89 schorsch 3.10 static void
90     psectstats( /* print statistical information for section */
91     register HOLO *hp,
92     FILE *fp
93     )
94 gwlarson 3.1 {
95     int scount[NHBINS];
96     int minsamp = 10000, maxsamp = 0;
97 gwlarson 3.4 FVECT vt;
98 gwlarson 3.1 double sqrtmaxp;
99     int bmin, bmax, cnt;
100     register int i;
101
102 gwlarson 3.4 fcross(vt, hp->xv[0], hp->xv[1]);
103     fprintf(fp, "\tWorld volume: %g\n", fabs(DOT(vt,hp->xv[2])));
104 gwlarson 3.1 fprintf(fp, "\tGrid resolution: %d x %d x %d\n",
105     hp->grid[0], hp->grid[1], hp->grid[2]);
106 gwlarson 3.3 fprintf(fp, "\tNumber of beams: %ld\n", (long)nbeams(hp));
107     beamtot += nbeams(hp);
108     fprintf(fp, "\tNumber of ray samples: %ld\n", (long)biglob(hp)->nrd);
109     samptot += biglob(hp)->nrd;
110 gwlarson 3.1 if (biglob(hp)->nrd <= 0)
111     return; /* no samples to stat! */
112     for (i = nbeams(hp); i > 0; i--) {
113     if (hp->bi[i].nrd < minsamp)
114     minsamp = hp->bi[i].nrd;
115     if (hp->bi[i].nrd > maxsamp)
116     maxsamp = hp->bi[i].nrd;
117     }
118     sqrtmaxp = sqrt(maxsamp+1.0);
119     for (i = NHBINS; i--; )
120     scount[i] = 0;
121     for (i = nbeams(hp); i > 0; i--)
122     scount[(int)(NHBINS*sqrt((double)hp->bi[i].nrd)/sqrtmaxp)]++;
123     for (cnt = 0, i = 0; i < NHBINS && cnt<<1 < nbeams(hp); i++)
124     cnt += scount[i];
125     fprintf(fp, "\tSamples per beam: [min,med,max]= [%d,%.0f,%d]\n",
126     minsamp,
127     (i-.5)*(i-.5)*(maxsamp+1)/(NHBINS*NHBINS),
128     maxsamp);
129     fprintf(fp, "\tHistogram: [minsamp,maxsamp)= #beams\n");
130     bmax = 0;
131     for (i = 0; i < NHBINS; i++) {
132     bmin = bmax;
133     bmax = (i+1)*(i+1)*(maxsamp+1)/(NHBINS*NHBINS);
134     fprintf(fp, "\t\t[%d,%d)= %d\n", bmin, bmax, scount[i]);
135     }
136     }
