root/radiance/ray/src/hd/rhinfo.c
Revision: 3.7
Committed: Fri Jun 20 00:25:49 2003 UTC (20 years, 11 months ago) by greg
2 static const char RCSid[] = "$Id: rhinfo.c,v 3.6 2003/05/29 16:26:22 greg Exp $";
5 * Get general information on holodeck file
6 */
7
8 #include "holo.h"
9
10 #ifndef NHBINS
11 #define NHBINS 12 /* number of histogram bins to use for stats */
12 #endif
13
14 char *progname; /* global argv[0] */
15
16 long beamtot, samptot; /* total beams and samples */
17
18
19 main(argc, argv)
20 int argc;
21 char *argv[];
22 {
23 int sect;
24
25 progname = argv[0];
26 if (argc != 2)
27 goto userr;
28 gethdinfo(argv[1], stdout);
29 quit(0);
30 userr:
31 fprintf(stderr, "Usage: %s input.hdk\n", progname);
32 exit(1);
33 }
34
35
36 gethdinfo(fname, fout) /* get information on holodeck */
37 char *fname;
38 FILE *fout;
39 {
40 FILE *fp;
41 HOLO *hdsect;
42 int fd;
43 int32 nextloc;
44 int n;
45 /* open holodeck file */
46 if ((fp = fopen(fname, "r")) == NULL) {
47 sprintf(errmsg, "cannot open \"%s\"", fname);
48 error(SYSTEM, errmsg);
49 }
50 /* check header and magic number */
51 if (checkheader(fp, HOLOFMT, fout) < 0 || getw(fp) != HOLOMAGIC) {
52 sprintf(errmsg, "file \"%s\" not in holodeck format", fname);
53 error(USER, errmsg);
54 }
55 fd = dup(fileno(fp)); /* dup file handle */
56 nextloc = ftell(fp); /* get stdio position */
57 fclose(fp); /* done with stdio */
58 for (n = 0; nextloc > 0L; n++) { /* get the section(s) */
59 lseek(fd, (off_t)nextloc, 0);
60 read(fd, (char *)&nextloc, sizeof(nextloc));
61 fprintf(fout, "Section %d:\n", n);
62 hdsect = hdinit(fd, NULL); /* load section directory */
63 psectstats(hdsect, fout); /* print section statistics */
64 }
65 nextloc = hdfilen(fd); /* print global statistics */
66 fputs("=====================================================\n", fout);
67 fprintf(fout, "Total samples/beams: %ld/%ld (%.2f samples/beam)\n",
68 samptot, beamtot, (double)samptot/beamtot);
69 fprintf(fout, "%.1f Mbyte file, %.1f%% fragmentation\n",
70 nextloc/(1024.*1024.),
71 100.*(nextloc-hdfiluse(fd,1))/nextloc);
72 /* don't bother with cleanup */
73 #if 0
74 hddone(NULL); /* free sections */
75 close(fd); /* done with the holodeck */
76 #endif
77 }
78
79
80 psectstats(hp, fp) /* print statistical information for section */
81 register HOLO *hp;
82 FILE *fp;
83 {
84 int scount[NHBINS];
85 int minsamp = 10000, maxsamp = 0;
86 FVECT vt;
87 double sqrtmaxp;
88 int bmin, bmax, cnt;
89 register int i;
90
91 fcross(vt, hp->xv[0], hp->xv[1]);
92 fprintf(fp, "\tWorld volume: %g\n", fabs(DOT(vt,hp->xv[2])));
93 fprintf(fp, "\tGrid resolution: %d x %d x %d\n",
94 hp->grid[0], hp->grid[1], hp->grid[2]);
95 fprintf(fp, "\tNumber of beams: %ld\n", (long)nbeams(hp));
96 beamtot += nbeams(hp);
97 fprintf(fp, "\tNumber of ray samples: %ld\n", (long)biglob(hp)->nrd);
98 samptot += biglob(hp)->nrd;
99 if (biglob(hp)->nrd <= 0)
100 return; /* no samples to stat! */
101 for (i = nbeams(hp); i > 0; i--) {
102 if (hp->bi[i].nrd < minsamp)
103 minsamp = hp->bi[i].nrd;
104 if (hp->bi[i].nrd > maxsamp)
105 maxsamp = hp->bi[i].nrd;
106 }
107 sqrtmaxp = sqrt(maxsamp+1.0);
108 for (i = NHBINS; i--; )
109 scount[i] = 0;
110 for (i = nbeams(hp); i > 0; i--)
111 scount[(int)(NHBINS*sqrt((double)hp->bi[i].nrd)/sqrtmaxp)]++;
112 for (cnt = 0, i = 0; i < NHBINS && cnt<<1 < nbeams(hp); i++)
113 cnt += scount[i];
114 fprintf(fp, "\tSamples per beam: [min,med,max]= [%d,%.0f,%d]\n",
115 minsamp,
116 (i-.5)*(i-.5)*(maxsamp+1)/(NHBINS*NHBINS),
117 maxsamp);
118 fprintf(fp, "\tHistogram: [minsamp,maxsamp)= #beams\n");
119 bmax = 0;
120 for (i = 0; i < NHBINS; i++) {
121 bmin = bmax;
122 bmax = (i+1)*(i+1)*(maxsamp+1)/(NHBINS*NHBINS);
123 fprintf(fp, "\t\t[%d,%d)= %d\n", bmin, bmax, scount[i]);
124 }
125 }
