root/radiance/ray/src/hd/rhinfo.c
Wed Dec 20 23:09:34 2023 UTC (17 months, 2 weeks ago) by greg
Changes since 3.15: +8 -8 lines
Diff to previous 3.15 , to selected 3.2
fix(rhinfo): Fixed spurious reporting of median sample count being less than minimum
Mon Oct 21 18:19:32 2019 UTC (5 years, 7 months ago) by greg
CVS Tags: rad5R3, rad5R4
Diff to previous 3.14 , to selected 3.2
Added binary option for Windows
Fri Oct 5 19:19:16 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 3.13 , to selected 3.2
Thu Sep 30 17:02:00 2010 UTC (14 years, 8 months ago) by greg
Changes since 3.12: +4 -5 lines
Diff to previous 3.12 , to selected 3.2
Changed section pointer to off_t
Thu Sep 30 14:45:10 2010 UTC (14 years, 8 months ago) by greg
Changes since 3.11: +5 -4 lines
Diff to previous 3.11 , to selected 3.2
Fixed bug in reporting for large files
Thu Sep 9 01:06:19 2004 UTC (20 years, 9 months ago) by greg
Diff to previous 3.10 , to selected 3.2
Thu Jan 1 11:21:55 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 3.9: +22 -12 lines
Diff to previous 3.9 , to selected 3.2
Ansification and prototypes.
Wed Oct 22 02:06:34 2003 UTC (21 years, 7 months ago) by greg
Changes since 3.8: +2 -2 lines
Diff to previous 3.8 , to selected 3.2
Mon Oct 20 16:01:55 2003 UTC (21 years, 7 months ago) by greg
Changes since 3.7: +3 -2 lines
Diff to previous 3.7 , to selected 3.2
Fri Jun 20 00:25:49 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 3.6 , to selected 3.2
Thu May 29 16:26:22 2003 UTC (22 years ago) by greg
Changes since 3.5: +0 -1 lines
Diff to previous 3.5 , to selected 3.2
Sat Feb 22 02:07:25 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.4: +2 -5 lines
Diff to previous 3.4 , to selected 3.2
Wed Feb 3 10:48:06 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.3: +3 -0 lines
Diff to previous 3.3 , to selected 3.2
added reporting of section volume
Wed Jan 20 15:16:35 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.2: +9 -2 lines
Diff to previous 3.2
added sum of samples and beams for all sections
Revision 3.2 - (view) (download) (annotate) - [selected]
Tue Jan 5 11:17:25 1999 UTC (26 years, 5 months ago) by gwlarson
moved section header so it comes before error messages if any
Thu Dec 31 16:25:26 1998 UTC (26 years, 5 months ago) by gwlarson
Diff to selected 3.2
