fix(rhinfo): Fixed spurious reporting of median sample count being less than minimum
Added binary option for Windows
Changed section pointer to off_t
Fixed bug in reporting for large files
Ansification and prototypes.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added reporting of section volume
added sum of samples and beams for all sections
moved section header so it comes before error messages if any
