root/radiance/ray/src/hd/rhinfo.c
Thu Sep 9 01:06:19 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 3.10 , to selected 3.7
Changes since 3.9: +22 -12 lines
Diff to previous 3.9 , to selected 3.7
Ansification and prototypes.
Wed Oct 22 02:06:34 2003 UTC (20 years, 6 months ago) by greg
Changes since 3.8: +2 -2 lines
Diff to previous 3.8 , to selected 3.7
Mon Oct 20 16:01:55 2003 UTC (20 years, 6 months ago) by greg
Changes since 3.7: +3 -2 lines
Diff to previous 3.7
Revision 3.7 - (view) (download) (annotate) - [selected]
Diff to previous 3.6
Thu May 29 16:26:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.5: +0 -1 lines
Diff to previous 3.5 , to selected 3.7
Sat Feb 22 02:07:25 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.4: +2 -5 lines
Diff to previous 3.4 , to selected 3.7
Wed Feb 3 10:48:06 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.3: +3 -0 lines
Diff to previous 3.3 , to selected 3.7
added reporting of section volume
Wed Jan 20 15:16:35 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.2: +9 -2 lines
Diff to previous 3.2 , to selected 3.7
added sum of samples and beams for all sections
Tue Jan 5 11:17:25 1999 UTC (25 years, 4 months ago) by gwlarson
Diff to previous 3.1 , to selected 3.7
moved section header so it comes before error messages if any
Thu Dec 31 16:25:26 1998 UTC (25 years, 4 months ago) by gwlarson
Diff to selected 3.7
