root/radiance/ray/src/hd/rhdriver.h
Revision: 3.8
Committed: Thu Dec 11 16:45:59 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.7: +21 -10 lines
normalized commands between driver and standard input
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for holodeck device driver routines.
7 */
8
9 #include "view.h"
10
11 extern struct driver {
12 char *name; /* holodeck name or title */
13 VIEW v; /* preferred view parameters */
14 int hres, vres; /* device resolution */
15 int ifd; /* input file descriptor (for select) */
16 } odev; /* our open device */
17
18 /* user commands */
19 #define DC_SETVIEW 0 /* set the view */
20 #define DC_GETVIEW 1 /* print the current view */
21 #define DC_LASTVIEW 2 /* restore previous view */
22 #define DC_PAUSE 3 /* pause the current calculation */
23 #define DC_RESUME 4 /* resume the calculation */
24 #define DC_REDRAW 5 /* redraw from server */
25 #define DC_QUIT 6 /* quit the program */
26
27 #define DC_NCMDS 7 /* number of commands */
28
29 /* dev_input() returns flags from above */
30 #define DFL(dc) (1<<(dc))
31
32 #define CTRL(c) ((c)-'@')
33 /* commands entered in display window */
34 #define DV_INIT {'\0','v','l','p','\r',CTRL('R'),'q'}
35 /* commands entered on stdin */
36 #define DC_INIT {"VIEW=","where","last","pause","resume","redraw",\
37 "quit"}
38
39
40 /************************************************************************
41 * Driver routines (all are required):
42
43
44 void
45 dev_open(nm) : prepare the device
46 char *nm; : appropriate title bar annotation
47
48 Sets fields of odev structure and prepares the display for i/o.
49 The view type, horizontal and vertical view angles and other default
50 parameters in odev.v should also be assigned.
51
52
53 int
54 dev_view(nv) : set display view parameters
55 VIEW *nv; : the new view
56
57 Updates the display for the given view change.
58 Look for nv==&odev.v when making view current after dev_input()
59 returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
60 new view would conflict with device requirements. In the latter
61 case, reset parameters in nv to make it more agreeable, calling
62 error(COMMAND, "appropriate user warning").
63
64
65 void
66 dev_value(c, p, v) : register new point of light
67 COLR c; : pixel color (RGBE)
68 FVECT p; : world intersection point
69 FVECT v; : ray direction vector
70
71 Add the given color point to the display output queue.
72
73
74 int
75 dev_flush() : flush the output and prepare for select call
76
77 Updates display, taking any pending action required before select(2) call.
78 Returns non-zero if there is device input available.
79
80
81 int
82 dev_input() : process pending display input
83
84 Called when odev struct file descriptor shows input is ready.
85 Returns flags indicating actions to take in the control process.
86 If the DC_VIEW or DC_RESIZE flag is returned, the odev
87 structure must be updated beforehand.
88
89
90 void
91 dev_close() : close the display
92
93 Close the display device and free up resources in preparation for exit.
94 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
95
96
97 ************************************************************************/
