root/radiance/ray/src/hd/rhdriver.h
Revision: 3.7
Committed: Thu Dec 11 09:34:51 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.6: +6 -2 lines
added DEV_LASTVIEW return flag for dev_input()
added comment about dev_view() new behavior
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for holodeck device driver routines.
7 */
8
9 #include "view.h"
10
11 extern struct driver {
12 char *name; /* holodeck name or title */
13 VIEW v; /* preferred view parameters */
14 int hres, vres; /* device resolution */
15 int ifd; /* input file descriptor (for select) */
16 } odev; /* our open device */
17
18 /* dev_input() return flags */
19 #define DEV_SHUTDOWN 01 /* user shutdown request */
20 #define DEV_NEWVIEW 02 /* view change (new view in odev.v) */
21 #define DEV_NEWSIZE 04 /* device resolution change */
22 #define DEV_WAIT 010 /* pause computation and wait for input */
23 #define DEV_RESUME 020 /* resume after pause */
24 #define DEV_REDRAW 040 /* redraw from server */
25 #define DEV_PUTVIEW 0100 /* print out current view */
26 #define DEV_LASTVIEW 0200 /* restore previous view */
27
28
29 /************************************************************************
30 * Driver routines (all are required):
31
32
33 void
34 dev_open(nm) : prepare the device
35 char *nm; : appropriate title bar annotation
36
37 Sets fields of odev structure and prepares the display for i/o.
38 The view type, horizontal and vertical view angles and other default
39 parameters in odev.v should also be assigned.
40
41
42 int
43 dev_view(nv) : set display view parameters
44 VIEW *nv; : the new view
45
46 Updates the display for the given view change.
47 Look for nv==&odev.v when making view current after dev_input()
48 returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
49 new view would conflict with device requirements. In the latter
50 case, reset parameters in nv to make it more agreeable, calling
51 error(COMMAND, "appropriate user warning").
52
53
54 void
55 dev_value(c, p, v) : register new point of light
56 COLR c; : pixel color (RGBE)
57 FVECT p; : world intersection point
58 FVECT v; : ray direction vector
59
60 Add the given color point to the display output queue.
61
62
63 int
64 dev_flush() : flush the output and prepare for select call
65
66 Updates display, taking any pending action required before select(2) call.
67 Returns non-zero if there is device input available.
68
69
70 int
71 dev_input() : process pending display input
72
73 Called when odev struct file descriptor shows input is ready.
74 Returns flags indicating actions to take in the control process.
75 If the DEV_NEWVIEW or DEV_NEWSIZE flag is returned, the odev
76 structure must be updated beforehand.
77
78
79 void
80 dev_close() : close the display
81
82 Close the display device and free up resources in preparation for exit.
83 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
84
85
86 ************************************************************************/
