root/Development/ray/src/hd/rhdriver.h
Revision: 3.3
Committed: Fri Nov 21 15:11:43 1997 UTC (28 years ago) by gregl
stopped pause function from resuming upon iconification and
interfering with full view updates
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for holodeck device driver routines.
7 */
8
9 #include "view.h"
10
11 extern struct driver {
12 char *name; /* holodeck name or title */
13 VIEW v; /* preferred view parameters */
14 int hres, vres; /* device resolution */
15 int ifd; /* input file descriptor (for select) */
16 } odev; /* our open device */
17
18 /* dev_input() return flags */
19 #define DEV_SHUTDOWN 01 /* user shutdown request */
20 #define DEV_NEWVIEW 02 /* view change (new view in odev.v) */
21 #define DEV_NEWSIZE 04 /* device resolution change */
22 #define DEV_WAIT 010 /* pause computation and wait for input */
23 #define DEV_RESUME 020 /* resume after pause */
24
25
26 /************************************************************************
27 * Driver routines (all are required):
28
29
30 void
31 dev_open(nm) : prepare the device
32 char *nm; : appropriate title bar annotation
33
34 Sets fields of odev structure and prepares the display for i/o.
35 The view type, horizontal and vertical view angles and other default
36 parameters in odev.v should also be assigned.
37
38
39 void
40 dev_view(nv) : set display view parameters
41 VIEW *nv; : the new view
42
43 Updates the display for the given view change.
44 Look for nv==&odev.v when making view current after dev_input()
45 returns DEV_NEWVIEW flag.
46
47
48 void
49 dev_value(c, p) : register new point of light
50 COLR c; : pixel color (RGBE)
51 FVECT p; : world intersection point
52
53 Add the given color point to the display output queue.
54
55
56 int
57 dev_flush() : flush the output and prepare for select call
58
59 Updates display, taking any pending action required before select(2) call.
60 Returns non-zero if there is device input available.
61
62
63 int
64 dev_input() : process pending display input
65
66 Called when odev struct file descriptor shows input is ready.
67 Returns flags indicating actions to take in the control process.
68 If the DEV_NEWVIEW or DEV_NEWSIZE flag is returned, the odev
69 structure must be updated beforehand.
70
71
72 void
73 dev_close() : close the display
74
75 Close the display device and free up resources in preparation for exit.
76 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
77
78
79 ************************************************************************/
