| 1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */
| 2 |
| 3 |
/* SCCSid "$SunId$ SGI" */
| 4 |
| 5 |
| 6 |
* Header file for holodeck device driver routines.
| 7 |
| 8 |
| 9 |
#include "view.h"
| 10 |
| 11 |
extern struct driver {
| 12 |
char *name; /* holodeck name or title */
| 13 |
VIEW v; /* base view parameters */
| 14 |
int hres, vres; /* base view resolution */
| 15 |
int ifd; /* input file descriptor (for select) */
| 16 |
int firstuse; /* non-zero if driver can't recycle samples */
| 17 |
int inpready; /* number of unprocessed input events */
| 18 |
} odev; /* our open device */
| 19 |
| 20 |
extern char odev_args[]; /* command arguments, if any */
| 21 |
| 22 |
extern int imm_mode; /* bundles are being delivered immediately */
| 23 |
| 24 |
extern double eyesepdist; /* world eye separation distance */
| 25 |
| 26 |
/* user commands */
| 27 |
#define DC_SETVIEW 0 /* set the base view */
| 28 |
#define DC_GETVIEW 1 /* print the current base view */
| 29 |
#define DC_LASTVIEW 2 /* restore previous view */
| 30 |
#define DC_FOCUS 3 /* view focus */
| 31 |
#define DC_PAUSE 4 /* pause the current calculation */
| 32 |
#define DC_RESUME 5 /* resume the calculation */
| 33 |
#define DC_REDRAW 6 /* redraw from server */
| 34 |
#define DC_KILL 7 /* kill rtrace process(es) */
| 35 |
#define DC_RESTART 8 /* restart rtrace process(es) */
| 36 |
#define DC_CLOBBER 9 /* clobber holodeck file */
| 37 |
#define DC_QUIT 10 /* quit the program */
| 38 |
| 39 |
#define DC_NCMDS 11 /* number of commands */
| 40 |
| 41 |
/* dev_input() returns flags from above */
| 42 |
#define DFL(dc) (1<<(dc))
| 43 |
| 44 |
#define CTRL(c) ((c)-'@')
| 45 |
/* commands entered in display window */
| 46 |
#define DV_INIT {'\0','v','l','f','p','\r',CTRL('L'),'K','R','C','q'}
| 47 |
/* commands entered on stdin */
| 48 |
#define DC_INIT {"VIEW=","where","last","frame","pause","resume",\
| 49 |
"redraw","kill","restart","clobber","quit"}
| 50 |
| 51 |
| 52 |
| 53 |
* Driver routines (all are required):
| 54 |
| 55 |
| 56 |
void
| 57 |
dev_open(nm) : prepare the device
| 58 |
char *nm; : appropriate title bar annotation
| 59 |
| 60 |
Sets fields of odev structure and prepares the display for i/o.
| 61 |
The base view type, horizontal and vertical view angles and other
| 62 |
default parameters in odev.v should also be assigned.
| 63 |
| 64 |
| 65 |
int
| 66 |
dev_view(nv) : set base view parameters
| 67 |
VIEW *nv; : the new view
| 68 |
| 69 |
Updates the display for the given base view change.
| 70 |
Look for nv==&odev.v when making view current after dev_input()
| 71 |
returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
| 72 |
new view would conflict with device requirements. In the latter
| 73 |
case, reset parameters in nv to make it more agreeable, calling
| 74 |
error(COMMAND, "appropriate user warning").
| 75 |
| 76 |
| 77 |
void
| 78 |
dev_clear() : clear device memory
| 79 |
| 80 |
Clear the device memory in preparation for fresh data. Clearing
| 81 |
the screen is optional.
| 82 |
| 83 |
| 84 |
void
| 85 |
dev_value(c, d, p) : register new point of light
| 86 |
COLR c; : pixel color (RGBE)
| 87 |
FVECT d; : ray direction vector
| 88 |
FVECT p; : world intersection point
| 89 |
| 90 |
Add the given color point to the display output queue. If imm_mode is
| 91 |
non-zero, then values are being sent in rapid succession. If p is NULL,
| 92 |
then the point is at infinity.
| 93 |
| 94 |
| 95 |
int
| 96 |
dev_flush() : flush the output and prepare for select call
| 97 |
| 98 |
Updates display, taking any pending action required before select(2) call.
| 99 |
Returns non-zero if there is device input available, setting odev.inpready.
| 100 |
| 101 |
| 102 |
int
| 103 |
dev_input() : process pending display input
| 104 |
| 105 |
Called when odev struct file descriptor shows input is ready.
| 106 |
Returns flags indicating actions to take in the control process.
| 107 |
If the DC_VIEW or DC_RESIZE flag is returned, the odev
| 108 |
structure must be updated beforehand. If the DC_FOCUS
| 109 |
flag is set, then odev_args contains the frame dimensions.
| 110 |
No events shall remain when this function returns,
| 111 |
and odev.inpready will therefore be 0.
| 112 |
| 113 |
void
| 114 |
dev_auxcom(cmd, args) : process auxiliary command
| 115 |
char *cmd, *args; : command name and argument string
| 116 |
| 117 |
Execute an auxiliary command (not one of those listed at the head of
| 118 |
this file). The cmd argument points to the command name itself, and
| 119 |
the args argument points to a string with the rest of the input line.
| 120 |
If the command isn't known or there ARE no auxiliary commands, print
| 121 |
an appropriate COMMAND error message and return.
| 122 |
| 123 |
| 124 |
VIEW *
| 125 |
dev_auxview(n, hv) : return nth auxiliary view
| 126 |
int n; : auxiliary view number
| 127 |
int hv[2]; : returned horiz. and vert. image resolution
| 128 |
| 129 |
Return the nth auxiliary view associated with the current base view.
| 130 |
The hv entries are assigned the horizontal and vertical view resolution,
| 131 |
respectively. Function returns NULL if there are no more auxiliary
| 132 |
views. The zeroeth auxiliary view is the base view itself.
| 133 |
| 134 |
| 135 |
void
| 136 |
dev_section(gf, pf) : add geometry and ports for rendering
| 137 |
char *gf; : geometry file name
| 138 |
char *pf; : portal file name(s)
| 139 |
| 140 |
Add the given geometry file to the list of geometry to render for
| 141 |
intermediate views if direct geometry rendering is available. The
| 142 |
second argument gives the name(s) of any portal geometry files
| 143 |
associated with this section. Multiple portal file names are separated
| 144 |
by spaces. A single octree file will be given for the geometry, ending
| 145 |
in the ".oct" suffix. Portal files will be given as zero or more
| 146 |
Radiance scene description file names. If no portals are given for
| 147 |
this section, the string may be NULL. The character strings are
| 148 |
guaranteed to be static (or permanently allocated) such that they may
| 149 |
be safely stored as a pointer. The same pointers or file lists may be
| 150 |
(and often are) given repeatedly. If a given geometry file does not
| 151 |
exist, the call should be silently ignored. If gf is NULL, then the
| 152 |
last section has been given, and the display can be updated with the
| 153 |
new information.
| 154 |
| 155 |
| 156 |
void
| 157 |
dev_close() : close the display
| 158 |
| 159 |
Close the display device and free up resources in preparation for exit.
| 160 |
Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
| 161 |
| 162 |
| 163 |
| 164 |
| 165 |
| 166 |
extern VIEW *dev_auxview();
| 167 |
| 168 |
extern int *beam_view();
