root/radiance/ray/src/hd/rhdriver.h
Revision: 3.11
Committed: Wed Dec 31 09:06:54 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.10: +4 -1 lines
hack so dev_value() doesn't drop leaves in immediate mode
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for holodeck device driver routines.
7 */
8
9 #include "view.h"
10
11 extern struct driver {
12 char *name; /* holodeck name or title */
13 VIEW v; /* preferred view parameters */
14 int hres, vres; /* device resolution */
15 int ifd; /* input file descriptor (for select) */
16 } odev; /* our open device */
17
18 extern int imm_mode; /* bundles are being delivered immediately */
19
20 /* user commands */
21 #define DC_SETVIEW 0 /* set the view */
22 #define DC_GETVIEW 1 /* print the current view */
23 #define DC_LASTVIEW 2 /* restore previous view */
24 #define DC_PAUSE 3 /* pause the current calculation */
25 #define DC_RESUME 4 /* resume the calculation */
26 #define DC_REDRAW 5 /* redraw from server */
27 #define DC_KILL 6 /* kill rtrace process(es) */
28 #define DC_RESTART 7 /* restart rtrace process(es) */
29 #define DC_CLOBBER 8 /* clobber holodeck file */
30 #define DC_QUIT 9 /* quit the program */
31
32 #define DC_NCMDS 10 /* number of commands */
33
34 /* dev_input() returns flags from above */
35 #define DFL(dc) (1<<(dc))
36
37 #define CTRL(c) ((c)-'@')
38 /* commands entered in display window */
39 #define DV_INIT {'\0','v','l','p','\r',CTRL('L'),'K','R','C','q'}
40 /* commands entered on stdin */
41 #define DC_INIT {"VIEW=","where","last","pause","resume","redraw",\
42 "kill","restart","clobber","quit"}
43
44
45 /************************************************************************
46 * Driver routines (all are required):
47
48
49 void
50 dev_open(nm) : prepare the device
51 char *nm; : appropriate title bar annotation
52
53 Sets fields of odev structure and prepares the display for i/o.
54 The view type, horizontal and vertical view angles and other default
55 parameters in odev.v should also be assigned.
56
57
58 int
59 dev_view(nv) : set display view parameters
60 VIEW *nv; : the new view
61
62 Updates the display for the given view change.
63 Look for nv==&odev.v when making view current after dev_input()
64 returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
65 new view would conflict with device requirements. In the latter
66 case, reset parameters in nv to make it more agreeable, calling
67 error(COMMAND, "appropriate user warning").
68
69
70 void
71 dev_value(c, p, v) : register new point of light
72 COLR c; : pixel color (RGBE)
73 FVECT p; : world intersection point
74 FVECT v; : ray direction vector
75
76 Add the given color point to the display output queue. If imm_mode is
77 non-zero, then values are being sent in rapid succession.
78
79
80 int
81 dev_flush() : flush the output and prepare for select call
82
83 Updates display, taking any pending action required before select(2) call.
84 Returns non-zero if there is device input available.
85
86
87 int
88 dev_input() : process pending display input
89
90 Called when odev struct file descriptor shows input is ready.
91 Returns flags indicating actions to take in the control process.
92 If the DC_VIEW or DC_RESIZE flag is returned, the odev
93 structure must be updated beforehand.
94
95
96 void
97 dev_close() : close the display
98
99 Close the display device and free up resources in preparation for exit.
100 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
101
102
103 ************************************************************************/
