| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
/* SCCSid "$SunId$ SGI" */
| 4 |
| 5 |
| 6 |
* Header file for holodeck device driver routines.
| 7 |
| 8 |
| 9 |
#include "view.h"
| 10 |
| 11 |
extern struct driver {
| 12 |
char *name; /* holodeck name or title */
| 13 |
VIEW v; /* preferred view parameters */
| 14 |
int hres, vres; /* device resolution */
| 15 |
int ifd; /* input file descriptor (for select) */
| 16 |
} odev; /* our open device */
| 17 |
| 18 |
/* user commands */
| 19 |
#define DC_SETVIEW 0 /* set the view */
| 20 |
#define DC_GETVIEW 1 /* print the current view */
| 21 |
#define DC_LASTVIEW 2 /* restore previous view */
| 22 |
#define DC_PAUSE 3 /* pause the current calculation */
| 23 |
#define DC_RESUME 4 /* resume the calculation */
| 24 |
#define DC_REDRAW 5 /* redraw from server */
| 25 |
#define DC_KILL 6 /* kill rtrace process(es) */
| 26 |
#define DC_RESTART 7 /* restart rtrace process(es) */
| 27 |
#define DC_CLOBBER 8 /* clobber holodeck file */
| 28 |
#define DC_QUIT 9 /* quit the program */
| 29 |
| 30 |
#define DC_NCMDS 10 /* number of commands */
| 31 |
| 32 |
/* dev_input() returns flags from above */
| 33 |
#define DFL(dc) (1<<(dc))
| 34 |
| 35 |
#define CTRL(c) ((c)-'@')
| 36 |
/* commands entered in display window */
| 37 |
#define DV_INIT {'\0','v','l','p','\r',CTRL('L'),'K','R','C','q'}
| 38 |
/* commands entered on stdin */
| 39 |
#define DC_INIT {"VIEW=","where","last","pause","resume","redraw",\
| 40 |
"kill","restart","clobber","quit"}
| 41 |
| 42 |
| 43 |
| 44 |
* Driver routines (all are required):
| 45 |
| 46 |
| 47 |
void
| 48 |
dev_open(nm) : prepare the device
| 49 |
char *nm; : appropriate title bar annotation
| 50 |
| 51 |
Sets fields of odev structure and prepares the display for i/o.
| 52 |
The view type, horizontal and vertical view angles and other default
| 53 |
parameters in odev.v should also be assigned.
| 54 |
| 55 |
| 56 |
int
| 57 |
dev_view(nv) : set display view parameters
| 58 |
VIEW *nv; : the new view
| 59 |
| 60 |
Updates the display for the given view change.
| 61 |
Look for nv==&odev.v when making view current after dev_input()
| 62 |
returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
| 63 |
new view would conflict with device requirements. In the latter
| 64 |
case, reset parameters in nv to make it more agreeable, calling
| 65 |
error(COMMAND, "appropriate user warning").
| 66 |
| 67 |
| 68 |
void
| 69 |
dev_value(c, p, v) : register new point of light
| 70 |
COLR c; : pixel color (RGBE)
| 71 |
FVECT p; : world intersection point
| 72 |
FVECT v; : ray direction vector
| 73 |
| 74 |
Add the given color point to the display output queue.
| 75 |
| 76 |
| 77 |
int
| 78 |
dev_flush() : flush the output and prepare for select call
| 79 |
| 80 |
Updates display, taking any pending action required before select(2) call.
| 81 |
Returns non-zero if there is device input available.
| 82 |
| 83 |
| 84 |
int
| 85 |
dev_input() : process pending display input
| 86 |
| 87 |
Called when odev struct file descriptor shows input is ready.
| 88 |
Returns flags indicating actions to take in the control process.
| 89 |
If the DC_VIEW or DC_RESIZE flag is returned, the odev
| 90 |
structure must be updated beforehand.
| 91 |
| 92 |
| 93 |
void
| 94 |
dev_close() : close the display
| 95 |
| 96 |
Close the display device and free up resources in preparation for exit.
| 97 |
Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
| 98 |
| 99 |
| 100 |
