--- ray/src/hd/rhdriver.h 2003/07/14 22:24:00 3.23 +++ ray/src/hd/rhdriver.h 2011/05/20 02:06:39 3.26 @@ -1,4 +1,4 @@ -/* RCSid: $Id: rhdriver.h,v 3.23 2003/07/14 22:24:00 schorsch Exp $ */ +/* RCSid: $Id: rhdriver.h,v 3.26 2011/05/20 02:06:39 greg Exp $ */ /* * Header file for holodeck device driver routines. */ @@ -166,10 +166,24 @@ Set odev.v.type=0 and odev.hres=odev.vres=0 when done. ************************************************************************/ +/* extern VIEW *dev_auxview(); +*/ +extern int16 *beam_view(VIEW *vn, int hr, int vr); -extern int16 *beam_view(); +extern void dev_open(char *id); +extern void dev_close(void); +extern void dev_clear(void); +extern int dev_view(register VIEW *nv); +extern void dev_section(char *gfn, char *pfn); +extern void dev_auxcom(char *cmd, char *args); +extern VIEW *dev_auxview(int n, int hvres[2]); +extern int dev_input(void); +extern void dev_value(COLR c, FVECT d, FVECT p); +extern int dev_flush(void); +extern void dev_paintr(uby8 rgb[3], int xmin, int ymin, int xmax, int ymax); +extern void dev_cone(uby8 rgb[3], FVECT ip, double rad); #ifdef __cplusplus }
