--- ray/src/hd/rhdriver.h 1998/12/18 11:56:10 3.18 +++ ray/src/hd/rhdriver.h 2006/06/07 17:52:04 3.25 @@ -1,13 +1,16 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid: $Id: rhdriver.h,v 3.25 2006/06/07 17:52:04 schorsch Exp $ */ /* * Header file for holodeck device driver routines. */ +#ifndef _RAD_RHDRIVER_H_ +#define _RAD_RHDRIVER_H_ #include "view.h" +#ifdef __cplusplus +extern "C" { +#endif + extern struct driver { char *name; /* holodeck name or title */ VIEW v; /* base view parameters */ @@ -133,19 +136,24 @@ views. The zeroeth auxiliary view is the base view it void -dev_section(otf) : add octree geometry for rendering -char *otf; : octree and portal file names +dev_section(gf, pf) : add geometry and ports for rendering +char *gf; : geometry file name +char *pf; : portal file name(s) -Add the given octree file to the list of geometry to be used to render -intermediate views if direct geometry rendering is available. Additional -file names (separated by spaces) are Radiance scene files containing -the geometry for "portals" to separate sections. The given -character string is guaranteed to be static (or permanently allocated) -such that it may be safely stored as a pointer. The same pointer or -file list may be (and often is) given repeatedly. If a given octree -does not exist, the call should be silently ignored. If otn is NULL, -then the last octree has been given, and the display can be updated -with the new information. +Add the given geometry file to the list of geometry to render for +intermediate views if direct geometry rendering is available. The +second argument gives the name(s) of any portal geometry files +associated with this section. Multiple portal file names are separated +by spaces. A single octree file will be given for the geometry, ending +in the ".oct" suffix. Portal files will be given as zero or more +Radiance scene description file names. If no portals are given for +this section, the string may be NULL. The character strings are +guaranteed to be static (or permanently allocated) such that they may +be safely stored as a pointer. The same pointers or file lists may be +(and often are) given repeatedly. If a given geometry file does not +exist, the call should be silently ignored. If gf is NULL, then the +last section has been given, and the display can be updated with the +new information. void @@ -158,6 +166,27 @@ Set odev.v.type=0 and odev.hres=odev.vres=0 when done. ************************************************************************/ +/* extern VIEW *dev_auxview(); +*/ +extern int16 *beam_view(VIEW *vn, int hr, int vr); -extern int *beam_view(); + +extern void dev_open(char *id); +extern void dev_close(void); +extern void dev_clear(void); +extern int dev_view(register VIEW *nv); +extern void dev_section(char *gfn, char *pfn); +extern void dev_auxcom(char *cmd, char *args); +extern VIEW *dev_auxview(int n, int hvres[2]); +extern int dev_input(void); +extern void dev_value(COLR c, FVECT d, FVECT p); +extern int dev_flush(void); +extern void dev_paintr(BYTE rgb[3], int xmin, int ymin, int xmax, int ymax); +extern void dev_cone(BYTE rgb[3], FVECT ip, double rad); + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_RHDRIVER_H_ */ +
