--- ray/src/hd/rhdriver.h 1997/12/11 09:34:51 3.7 +++ ray/src/hd/rhdriver.h 1998/08/10 18:39:46 3.15 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ /* SCCSid "$SunId$ SGI" */ @@ -10,22 +10,40 @@ extern struct driver { char *name; /* holodeck name or title */ - VIEW v; /* preferred view parameters */ - int hres, vres; /* device resolution */ + VIEW v; /* base view parameters */ + int hres, vres; /* base view resolution */ int ifd; /* input file descriptor (for select) */ } odev; /* our open device */ - /* dev_input() return flags */ -#define DEV_SHUTDOWN 01 /* user shutdown request */ -#define DEV_NEWVIEW 02 /* view change (new view in odev.v) */ -#define DEV_NEWSIZE 04 /* device resolution change */ -#define DEV_WAIT 010 /* pause computation and wait for input */ -#define DEV_RESUME 020 /* resume after pause */ -#define DEV_REDRAW 040 /* redraw from server */ -#define DEV_PUTVIEW 0100 /* print out current view */ -#define DEV_LASTVIEW 0200 /* restore previous view */ +extern int imm_mode; /* bundles are being delivered immediately */ +extern double eyesepdist; /* world eye separation distance */ + /* user commands */ +#define DC_SETVIEW 0 /* set the base view */ +#define DC_GETVIEW 1 /* print the current base view */ +#define DC_LASTVIEW 2 /* restore previous view */ +#define DC_PAUSE 3 /* pause the current calculation */ +#define DC_RESUME 4 /* resume the calculation */ +#define DC_REDRAW 5 /* redraw from server */ +#define DC_KILL 6 /* kill rtrace process(es) */ +#define DC_RESTART 7 /* restart rtrace process(es) */ +#define DC_CLOBBER 8 /* clobber holodeck file */ +#define DC_QUIT 9 /* quit the program */ + +#define DC_NCMDS 10 /* number of commands */ + + /* dev_input() returns flags from above */ +#define DFL(dc) (1<<(dc)) + +#define CTRL(c) ((c)-'@') + /* commands entered in display window */ +#define DV_INIT {'\0','v','l','p','\r',CTRL('L'),'K','R','C','q'} + /* commands entered on stdin */ +#define DC_INIT {"VIEW=","where","last","pause","resume","redraw",\ + "kill","restart","clobber","quit"} + + /************************************************************************ * Driver routines (all are required): @@ -35,15 +53,15 @@ dev_open(nm) : prepare the device char *nm; : appropriate title bar annotation Sets fields of odev structure and prepares the display for i/o. -The view type, horizontal and vertical view angles and other default -parameters in odev.v should also be assigned. +The base view type, horizontal and vertical view angles and other +default parameters in odev.v should also be assigned. int -dev_view(nv) : set display view parameters +dev_view(nv) : set base view parameters VIEW *nv; : the new view -Updates the display for the given view change. +Updates the display for the given base view change. Look for nv==&odev.v when making view current after dev_input() returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the new view would conflict with device requirements. In the latter @@ -52,12 +70,21 @@ error(COMMAND, "appropriate user warning"). void -dev_value(c, p, v) : register new point of light +dev_clear() : clear device memory + +Clear the device memory in preparation for fresh data. Clearing +the screen is optional. + + +void +dev_value(c, d, p) : register new point of light COLR c; : pixel color (RGBE) +FVECT d; : ray direction vector FVECT p; : world intersection point -FVECT v; : ray direction vector -Add the given color point to the display output queue. +Add the given color point to the display output queue. If imm_mode is +non-zero, then values are being sent in rapid succession. If p is NULL, +then the point is at infinity. int @@ -72,10 +99,31 @@ dev_input() : process pending display input Called when odev struct file descriptor shows input is ready. Returns flags indicating actions to take in the control process. -If the DEV_NEWVIEW or DEV_NEWSIZE flag is returned, the odev +If the DC_VIEW or DC_RESIZE flag is returned, the odev structure must be updated beforehand. +void +dev_auxcom(cmd, args) : process auxiliary command +char *cmd, *args; : command name and argument string +Execute an auxiliary command (not one of those listed at the head of +this file). The cmd argument points to the command name itself, and +the args argument points to a string with the rest of the input line. +If the command isn't known or there ARE no auxiliary commands, print +an appropriate COMMAND error message and return. + + +VIEW * +dev_auxview(n, hv) : return nth auxiliary view +int n; : auxiliary view number +int hv[2]; : returned horiz. and vert. image resolution + +Return the nth auxiliary view associated with the current base view. +The hv entries are assigned the horizontal and vertical view resolution, +respectively. Function returns NULL if there are no more auxiliary +views. The zeroeth auxiliary view is the base view itself. + + void dev_close() : close the display @@ -84,3 +132,6 @@ Set odev.v.type=0 and odev.hres=odev.vres=0 when done. ************************************************************************/ + + +extern VIEW *dev_auxview();
