root/radiance/ray/src/hd/rhdriver.h
Revision: 3.17
Committed: Thu Dec 10 10:45:55 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.16: +18 -13 lines
created "frame" command to focus calculation
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for holodeck device driver routines.
7 */
8
9 #include "view.h"
10
11 extern struct driver {
12 char *name; /* holodeck name or title */
13 VIEW v; /* base view parameters */
14 int hres, vres; /* base view resolution */
15 int ifd; /* input file descriptor (for select) */
16 int inpready; /* number of unprocessed input events */
17 } odev; /* our open device */
18
19 extern char odev_args[]; /* command arguments, if any */
20
21 extern int imm_mode; /* bundles are being delivered immediately */
22
23 extern double eyesepdist; /* world eye separation distance */
24
25 /* user commands */
26 #define DC_SETVIEW 0 /* set the base view */
27 #define DC_GETVIEW 1 /* print the current base view */
28 #define DC_LASTVIEW 2 /* restore previous view */
29 #define DC_FOCUS 3 /* view focus */
30 #define DC_PAUSE 4 /* pause the current calculation */
31 #define DC_RESUME 5 /* resume the calculation */
32 #define DC_REDRAW 6 /* redraw from server */
33 #define DC_KILL 7 /* kill rtrace process(es) */
34 #define DC_RESTART 8 /* restart rtrace process(es) */
35 #define DC_CLOBBER 9 /* clobber holodeck file */
36 #define DC_QUIT 10 /* quit the program */
37
38 #define DC_NCMDS 11 /* number of commands */
39
40 /* dev_input() returns flags from above */
41 #define DFL(dc) (1<<(dc))
42
43 #define CTRL(c) ((c)-'@')
44 /* commands entered in display window */
45 #define DV_INIT {'\0','v','l','f','p','\r',CTRL('L'),'K','R','C','q'}
46 /* commands entered on stdin */
47 #define DC_INIT {"VIEW=","where","last","frame","pause","resume",\
48 "redraw","kill","restart","clobber","quit"}
49
50
51 /************************************************************************
52 * Driver routines (all are required):
53
54
55 void
56 dev_open(nm) : prepare the device
57 char *nm; : appropriate title bar annotation
58
59 Sets fields of odev structure and prepares the display for i/o.
60 The base view type, horizontal and vertical view angles and other
61 default parameters in odev.v should also be assigned.
62
63
64 int
65 dev_view(nv) : set base view parameters
66 VIEW *nv; : the new view
67
68 Updates the display for the given base view change.
69 Look for nv==&odev.v when making view current after dev_input()
70 returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
71 new view would conflict with device requirements. In the latter
72 case, reset parameters in nv to make it more agreeable, calling
73 error(COMMAND, "appropriate user warning").
74
75
76 void
77 dev_clear() : clear device memory
78
79 Clear the device memory in preparation for fresh data. Clearing
80 the screen is optional.
81
82
83 void
84 dev_value(c, d, p) : register new point of light
85 COLR c; : pixel color (RGBE)
86 FVECT d; : ray direction vector
87 FVECT p; : world intersection point
88
89 Add the given color point to the display output queue. If imm_mode is
90 non-zero, then values are being sent in rapid succession. If p is NULL,
91 then the point is at infinity.
92
93
94 int
95 dev_flush() : flush the output and prepare for select call
96
97 Updates display, taking any pending action required before select(2) call.
98 Returns non-zero if there is device input available, setting odev.inpready.
99
100
101 int
102 dev_input() : process pending display input
103
104 Called when odev struct file descriptor shows input is ready.
105 Returns flags indicating actions to take in the control process.
106 If the DC_VIEW or DC_RESIZE flag is returned, the odev
107 structure must be updated beforehand. If the DC_FOCUS
108 flag is set, then odev_args contains the frame dimensions.
109 No events shall remain when this function returns,
110 and odev.inpready will therefore be 0.
111
112 void
113 dev_auxcom(cmd, args) : process auxiliary command
114 char *cmd, *args; : command name and argument string
115
116 Execute an auxiliary command (not one of those listed at the head of
117 this file). The cmd argument points to the command name itself, and
118 the args argument points to a string with the rest of the input line.
119 If the command isn't known or there ARE no auxiliary commands, print
120 an appropriate COMMAND error message and return.
121
122
123 VIEW *
124 dev_auxview(n, hv) : return nth auxiliary view
125 int n; : auxiliary view number
126 int hv[2]; : returned horiz. and vert. image resolution
127
128 Return the nth auxiliary view associated with the current base view.
129 The hv entries are assigned the horizontal and vertical view resolution,
130 respectively. Function returns NULL if there are no more auxiliary
131 views. The zeroeth auxiliary view is the base view itself.
132
133
134 void
135 dev_close() : close the display
136
137 Close the display device and free up resources in preparation for exit.
138 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
139
140
141 ************************************************************************/
142
143
144 extern VIEW *dev_auxview();
