1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* Header file for holodeck device driver routines. |
7 |
8 |
9 |
#include "view.h" |
10 |
11 |
extern struct driver { |
12 |
char *name; /* holodeck name or title */ |
13 |
VIEW v; /* preferred view parameters */ |
14 |
int hres, vres; /* device resolution */ |
15 |
int ifd; /* input file descriptor (for select) */ |
16 |
} odev; /* our open device */ |
17 |
18 |
extern int imm_mode; /* bundles are being delivered immediately */ |
19 |
20 |
/* user commands */ |
21 |
#define DC_SETVIEW 0 /* set the view */ |
22 |
#define DC_GETVIEW 1 /* print the current view */ |
23 |
#define DC_LASTVIEW 2 /* restore previous view */ |
24 |
#define DC_PAUSE 3 /* pause the current calculation */ |
25 |
#define DC_RESUME 4 /* resume the calculation */ |
26 |
#define DC_REDRAW 5 /* redraw from server */ |
27 |
#define DC_KILL 6 /* kill rtrace process(es) */ |
28 |
#define DC_RESTART 7 /* restart rtrace process(es) */ |
29 |
#define DC_CLOBBER 8 /* clobber holodeck file */ |
30 |
#define DC_QUIT 9 /* quit the program */ |
31 |
32 |
#define DC_NCMDS 10 /* number of commands */ |
33 |
34 |
/* dev_input() returns flags from above */ |
35 |
#define DFL(dc) (1<<(dc)) |
36 |
37 |
#define CTRL(c) ((c)-'@') |
38 |
/* commands entered in display window */ |
39 |
#define DV_INIT {'\0','v','l','p','\r',CTRL('L'),'K','R','C','q'} |
40 |
/* commands entered on stdin */ |
41 |
#define DC_INIT {"VIEW=","where","last","pause","resume","redraw",\ |
42 |
"kill","restart","clobber","quit"} |
43 |
44 |
45 |
46 |
* Driver routines (all are required): |
47 |
48 |
49 |
void |
50 |
dev_open(nm) : prepare the device |
51 |
char *nm; : appropriate title bar annotation |
52 |
53 |
Sets fields of odev structure and prepares the display for i/o. |
54 |
The view type, horizontal and vertical view angles and other default |
55 |
parameters in odev.v should also be assigned. |
56 |
57 |
58 |
int |
59 |
dev_view(nv) : set display view parameters |
60 |
VIEW *nv; : the new view |
61 |
62 |
Updates the display for the given view change. |
63 |
Look for nv==&odev.v when making view current after dev_input() |
64 |
returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the |
65 |
new view would conflict with device requirements. In the latter |
66 |
case, reset parameters in nv to make it more agreeable, calling |
67 |
error(COMMAND, "appropriate user warning"). |
68 |
69 |
70 |
void |
71 |
dev_clear() : clear device memory |
72 |
73 |
Clear the device memory in preparation for fresh data. Clearing |
74 |
the screen is optional. |
75 |
76 |
77 |
void |
78 |
dev_value(c, p, v) : register new point of light |
79 |
COLR c; : pixel color (RGBE) |
80 |
FVECT p; : world intersection point |
81 |
FVECT v; : ray direction vector |
82 |
83 |
Add the given color point to the display output queue. If imm_mode is |
84 |
non-zero, then values are being sent in rapid succession. |
85 |
86 |
87 |
int |
88 |
dev_flush() : flush the output and prepare for select call |
89 |
90 |
Updates display, taking any pending action required before select(2) call. |
91 |
Returns non-zero if there is device input available. |
92 |
93 |
94 |
int |
95 |
dev_input() : process pending display input |
96 |
97 |
Called when odev struct file descriptor shows input is ready. |
98 |
Returns flags indicating actions to take in the control process. |
99 |
If the DC_VIEW or DC_RESIZE flag is returned, the odev |
100 |
structure must be updated beforehand. |
101 |
102 |
103 |
void |
104 |
dev_close() : close the display |
105 |
106 |
Close the display device and free up resources in preparation for exit. |
107 |
Set odev.v.type=0 and odev.hres=odev.vres=0 when done. |
108 |
109 |
110 |
