root/radiance/ray/src/hd/rhdriver.h
Revision: 3.25
Committed: Wed Jun 7 17:52:04 2006 UTC (19 years ago) by schorsch
CVS Tags: rad4R0, rad3R8, rad3R9
1 /* RCSid: $Id: rhdriver.h,v 3.24 2004/01/01 11:21:55 schorsch Exp $ */
2 /*
3 * Header file for holodeck device driver routines.
4 */
5 #ifndef _RAD_RHDRIVER_H_
6 #define _RAD_RHDRIVER_H_
7
8 #include "view.h"
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 extern struct driver {
15 char *name; /* holodeck name or title */
16 VIEW v; /* base view parameters */
17 int hres, vres; /* base view resolution */
18 int ifd; /* input file descriptor (for select) */
19 int firstuse; /* non-zero if driver can't recycle samples */
20 int inpready; /* number of unprocessed input events */
21 } odev; /* our open device */
22
23 extern char odev_args[]; /* command arguments, if any */
24
25 extern int imm_mode; /* bundles are being delivered immediately */
26
27 extern double eyesepdist; /* world eye separation distance */
28
29 /* user commands */
30 #define DC_SETVIEW 0 /* set the base view */
31 #define DC_GETVIEW 1 /* print the current base view */
32 #define DC_LASTVIEW 2 /* restore previous view */
33 #define DC_FOCUS 3 /* view focus */
34 #define DC_PAUSE 4 /* pause the current calculation */
35 #define DC_RESUME 5 /* resume the calculation */
36 #define DC_REDRAW 6 /* redraw from server */
37 #define DC_KILL 7 /* kill rtrace process(es) */
38 #define DC_RESTART 8 /* restart rtrace process(es) */
39 #define DC_CLOBBER 9 /* clobber holodeck file */
40 #define DC_QUIT 10 /* quit the program */
41
42 #define DC_NCMDS 11 /* number of commands */
43
44 /* dev_input() returns flags from above */
45 #define DFL(dc) (1<<(dc))
46
47 #define CTRL(c) ((c)-'@')
48 /* commands entered in display window */
49 #define DV_INIT {'\0','v','l','f','p','\r',CTRL('L'),'K','R','C','q'}
50 /* commands entered on stdin */
51 #define DC_INIT {"VIEW=","where","last","frame","pause","resume",\
52 "redraw","kill","restart","clobber","quit"}
53
54
55 /************************************************************************
56 * Driver routines (all are required):
57
58
59 void
60 dev_open(nm) : prepare the device
61 char *nm; : appropriate title bar annotation
62
63 Sets fields of odev structure and prepares the display for i/o.
64 The base view type, horizontal and vertical view angles and other
65 default parameters in odev.v should also be assigned.
66
67
68 int
69 dev_view(nv) : set base view parameters
70 VIEW *nv; : the new view
71
72 Updates the display for the given base view change.
73 Look for nv==&odev.v when making view current after dev_input()
74 returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
75 new view would conflict with device requirements. In the latter
76 case, reset parameters in nv to make it more agreeable, calling
77 error(COMMAND, "appropriate user warning").
78
79
80 void
81 dev_clear() : clear device memory
82
83 Clear the device memory in preparation for fresh data. Clearing
84 the screen is optional.
85
86
87 void
88 dev_value(c, d, p) : register new point of light
89 COLR c; : pixel color (RGBE)
90 FVECT d; : ray direction vector
91 FVECT p; : world intersection point
92
93 Add the given color point to the display output queue. If imm_mode is
94 non-zero, then values are being sent in rapid succession. If p is NULL,
95 then the point is at infinity.
96
97
98 int
99 dev_flush() : flush the output and prepare for select call
100
101 Updates display, taking any pending action required before select(2) call.
102 Returns non-zero if there is device input available, setting odev.inpready.
103
104
105 int
106 dev_input() : process pending display input
107
108 Called when odev struct file descriptor shows input is ready.
109 Returns flags indicating actions to take in the control process.
110 If the DC_VIEW or DC_RESIZE flag is returned, the odev
111 structure must be updated beforehand. If the DC_FOCUS
112 flag is set, then odev_args contains the frame dimensions.
113 No events shall remain when this function returns,
114 and odev.inpready will therefore be 0.
115
116 void
117 dev_auxcom(cmd, args) : process auxiliary command
118 char *cmd, *args; : command name and argument string
119
120 Execute an auxiliary command (not one of those listed at the head of
121 this file). The cmd argument points to the command name itself, and
122 the args argument points to a string with the rest of the input line.
123 If the command isn't known or there ARE no auxiliary commands, print
124 an appropriate COMMAND error message and return.
125
126
127 VIEW *
128 dev_auxview(n, hv) : return nth auxiliary view
129 int n; : auxiliary view number
130 int hv[2]; : returned horiz. and vert. image resolution
131
132 Return the nth auxiliary view associated with the current base view.
133 The hv entries are assigned the horizontal and vertical view resolution,
134 respectively. Function returns NULL if there are no more auxiliary
135 views. The zeroeth auxiliary view is the base view itself.
136
137
138 void
139 dev_section(gf, pf) : add geometry and ports for rendering
140 char *gf; : geometry file name
141 char *pf; : portal file name(s)
142
143 Add the given geometry file to the list of geometry to render for
144 intermediate views if direct geometry rendering is available. The
145 second argument gives the name(s) of any portal geometry files
146 associated with this section. Multiple portal file names are separated
147 by spaces. A single octree file will be given for the geometry, ending
148 in the ".oct" suffix. Portal files will be given as zero or more
149 Radiance scene description file names. If no portals are given for
150 this section, the string may be NULL. The character strings are
151 guaranteed to be static (or permanently allocated) such that they may
152 be safely stored as a pointer. The same pointers or file lists may be
153 (and often are) given repeatedly. If a given geometry file does not
154 exist, the call should be silently ignored. If gf is NULL, then the
155 last section has been given, and the display can be updated with the
156 new information.
157
158
159 void
160 dev_close() : close the display
161
162 Close the display device and free up resources in preparation for exit.
163 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
164
165
166 ************************************************************************/
167
168
169 /*
170 extern VIEW *dev_auxview();
171 */
172 extern int16 *beam_view(VIEW *vn, int hr, int vr);
173
174
175 extern void dev_open(char *id);
176 extern void dev_close(void);
177 extern void dev_clear(void);
178 extern int dev_view(register VIEW *nv);
179 extern void dev_section(char *gfn, char *pfn);
180 extern void dev_auxcom(char *cmd, char *args);
181 extern VIEW *dev_auxview(int n, int hvres[2]);
182 extern int dev_input(void);
183 extern void dev_value(COLR c, FVECT d, FVECT p);
184 extern int dev_flush(void);
185 extern void dev_paintr(BYTE rgb[3], int xmin, int ymin, int xmax, int ymax);
186 extern void dev_cone(BYTE rgb[3], FVECT ip, double rad);
187
188 #ifdef __cplusplus
189 }
190 #endif
191 #endif /* _RAD_RHDRIVER_H_ */
192
