root/radiance/ray/src/hd/rhdriver.h
Revision: 3.15
Committed: Mon Aug 10 18:39:46 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.14: +4 -3 lines
changed dev_value() interface so NULL is passed for infinite points
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for holodeck device driver routines.
7 */
8
9 #include "view.h"
10
11 extern struct driver {
12 char *name; /* holodeck name or title */
13 VIEW v; /* base view parameters */
14 int hres, vres; /* base view resolution */
15 int ifd; /* input file descriptor (for select) */
16 } odev; /* our open device */
17
18 extern int imm_mode; /* bundles are being delivered immediately */
19
20 extern double eyesepdist; /* world eye separation distance */
21
22 /* user commands */
23 #define DC_SETVIEW 0 /* set the base view */
24 #define DC_GETVIEW 1 /* print the current base view */
25 #define DC_LASTVIEW 2 /* restore previous view */
26 #define DC_PAUSE 3 /* pause the current calculation */
27 #define DC_RESUME 4 /* resume the calculation */
28 #define DC_REDRAW 5 /* redraw from server */
29 #define DC_KILL 6 /* kill rtrace process(es) */
30 #define DC_RESTART 7 /* restart rtrace process(es) */
31 #define DC_CLOBBER 8 /* clobber holodeck file */
32 #define DC_QUIT 9 /* quit the program */
33
34 #define DC_NCMDS 10 /* number of commands */
35
36 /* dev_input() returns flags from above */
37 #define DFL(dc) (1<<(dc))
38
39 #define CTRL(c) ((c)-'@')
40 /* commands entered in display window */
41 #define DV_INIT {'\0','v','l','p','\r',CTRL('L'),'K','R','C','q'}
42 /* commands entered on stdin */
43 #define DC_INIT {"VIEW=","where","last","pause","resume","redraw",\
44 "kill","restart","clobber","quit"}
45
46
47 /************************************************************************
48 * Driver routines (all are required):
49
50
51 void
52 dev_open(nm) : prepare the device
53 char *nm; : appropriate title bar annotation
54
55 Sets fields of odev structure and prepares the display for i/o.
56 The base view type, horizontal and vertical view angles and other
57 default parameters in odev.v should also be assigned.
58
59
60 int
61 dev_view(nv) : set base view parameters
62 VIEW *nv; : the new view
63
64 Updates the display for the given base view change.
65 Look for nv==&odev.v when making view current after dev_input()
66 returns DEV_NEWVIEW flag. Return 1 on success, or 0 if the
67 new view would conflict with device requirements. In the latter
68 case, reset parameters in nv to make it more agreeable, calling
69 error(COMMAND, "appropriate user warning").
70
71
72 void
73 dev_clear() : clear device memory
74
75 Clear the device memory in preparation for fresh data. Clearing
76 the screen is optional.
77
78
79 void
80 dev_value(c, d, p) : register new point of light
81 COLR c; : pixel color (RGBE)
82 FVECT d; : ray direction vector
83 FVECT p; : world intersection point
84
85 Add the given color point to the display output queue. If imm_mode is
86 non-zero, then values are being sent in rapid succession. If p is NULL,
87 then the point is at infinity.
88
89
90 int
91 dev_flush() : flush the output and prepare for select call
92
93 Updates display, taking any pending action required before select(2) call.
94 Returns non-zero if there is device input available.
95
96
97 int
98 dev_input() : process pending display input
99
100 Called when odev struct file descriptor shows input is ready.
101 Returns flags indicating actions to take in the control process.
102 If the DC_VIEW or DC_RESIZE flag is returned, the odev
103 structure must be updated beforehand.
104
105 void
106 dev_auxcom(cmd, args) : process auxiliary command
107 char *cmd, *args; : command name and argument string
108
109 Execute an auxiliary command (not one of those listed at the head of
110 this file). The cmd argument points to the command name itself, and
111 the args argument points to a string with the rest of the input line.
112 If the command isn't known or there ARE no auxiliary commands, print
113 an appropriate COMMAND error message and return.
114
115
116 VIEW *
117 dev_auxview(n, hv) : return nth auxiliary view
118 int n; : auxiliary view number
119 int hv[2]; : returned horiz. and vert. image resolution
120
121 Return the nth auxiliary view associated with the current base view.
122 The hv entries are assigned the horizontal and vertical view resolution,
123 respectively. Function returns NULL if there are no more auxiliary
124 views. The zeroeth auxiliary view is the base view itself.
125
126
127 void
128 dev_close() : close the display
129
130 Close the display device and free up resources in preparation for exit.
131 Set odev.v.type=0 and odev.hres=odev.vres=0 when done.
132
133
134 ************************************************************************/
135
136
137 extern VIEW *dev_auxview();
