root/radiance/ray/src/hd/rhdriver.h
Changes since 3.23: +16 -2 lines
Diff to previous 3.23 , to selected 3.15
Ansification and prototypes.
Mon Jul 14 22:24:00 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.22: +14 -1 lines
Diff to previous 3.22 , to selected 3.15
Changes since 3.21: +2 -2 lines
Diff to previous 3.21 , to selected 3.15
Sat Feb 22 02:07:25 2003 UTC (21 years, 3 months ago) by greg
Changes since 3.20: +1 -4 lines
Diff to previous 3.20 , to selected 3.15
Thu Mar 4 10:29:23 1999 UTC (25 years, 3 months ago) by gwlarson
Diff to previous 3.19 , to selected 3.15
Sun Dec 20 20:39:31 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.18: +17 -12 lines
Diff to previous 3.18 , to selected 3.15
added new "portals" variable for multiple section geometry
Fri Dec 18 11:56:10 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.17: +19 -0 lines
Diff to previous 3.17 , to selected 3.15
Thu Dec 10 10:45:55 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.16: +18 -13 lines
Diff to previous 3.16 , to selected 3.15
created "frame" command to focus calculation
Wed Aug 19 17:43:08 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.15: +4 -2 lines
Diff to previous 3.15
added odev.inpready member and periodic input checking to rhdisp
Revision 3.15 - (view) (download) (annotate) - [selected]
Mon Aug 10 18:39:46 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.14: +4 -3 lines
Diff to previous 3.14
changed dev_value() interface so NULL is passed for infinite points
Wed Jun 17 15:44:07 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 3.13: +13 -1 lines
Diff to previous 3.13 , to selected 3.15
added dev_auxcom() for auxiliary command handling
Thu May 14 13:06:32 1998 UTC (26 years ago) by gwlarson
Changes since 3.12: +22 -8 lines
Diff to previous 3.12 , to selected 3.15
added multiple device view capability
Tue Jan 6 05:26:20 1998 UTC (26 years, 5 months ago) by gregl
Changes since 3.11: +7 -0 lines
Diff to previous 3.11 , to selected 3.15
created dev_clear() routine to clear device ray cache
Wed Dec 31 09:06:54 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.10: +4 -1 lines
Diff to previous 3.10 , to selected 3.15
hack so dev_value() doesn't drop leaves in immediate mode
Sun Dec 14 09:45:48 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 3.9 , to selected 3.15
fixed wrong character command
Fri Dec 12 11:13:16 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.8: +8 -5 lines
Diff to previous 3.8 , to selected 3.15
Thu Dec 11 16:45:59 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.7: +21 -10 lines
Diff to previous 3.7 , to selected 3.15
normalized commands between driver and standard input
Thu Dec 11 09:34:51 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.6: +6 -2 lines
Diff to previous 3.6 , to selected 3.15
added DEV_LASTVIEW return flag for dev_input()
added comment about dev_view() new behavior
Mon Dec 8 18:51:15 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 3.5 , to selected 3.15
Thu Dec 4 10:54:23 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.4: +2 -1 lines
Diff to previous 3.4 , to selected 3.15
added direction vector to dev_value() call
Fri Nov 21 16:10:18 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.3: +4 -3 lines
Diff to previous 3.3 , to selected 3.15
added server-driven redraw function to replace display quadtree
Fri Nov 21 15:11:43 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 3.2 , to selected 3.15
stopped pause function from resuming upon iconification and
interfering with full view updates
Thu Nov 20 18:06:16 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +1 -0 lines
Diff to previous 3.1 , to selected 3.15
added pause function
Wed Nov 19 18:01:03 1997 UTC (26 years, 6 months ago) by gregl
Diff to selected 3.15
