--- ray/src/hd/rhdobj.h 1998/08/27 19:33:28 3.3 +++ ray/src/hd/rhdobj.h 1998/12/18 11:06:46 3.4 @@ -61,13 +61,14 @@ of the intersected object is returned, or "" if none. then all visible objects are checked, but the name is not returned. -void +int dobj_render() : render visible objects to OpenGL Renders all display objects using OpenGL, assuming desired view has been set. This routine also assumes that the tone-mapping library is being used to set exposure, and it queries this information to -adjust light sources as necessary for illuminated objects. +adjust light sources as necessary for illuminated objects. Returns +the number of objects rendered. void
