| 1 |
/* RCSid: $Id: rhdobj.h,v 3.8 2004/01/01 11:21:55 schorsch Exp $ */
| 2 |
| 3 |
* Header file for object display routines for rholo drivers.
| 4 |
| 5 |
#ifndef _RAD_RHDOBJ_H_
| 6 |
#define _RAD_RHDOBJ_H_
| 7 |
| 8 |
#ifdef __cplusplus
| 9 |
extern "C" {
| 10 |
#endif
| 11 |
| 12 |
/* additional user commands */
| 13 |
#define DO_LOAD 0 /* load octree object */
| 14 |
#define DO_UNLOAD 1 /* unload (free) octree object */
| 15 |
#define DO_XFORM 2 /* set/print object transform */
| 16 |
#define DO_MOVE 3 /* add to object transform */
| 17 |
#define DO_UNMOVE 4 /* undo last transform change */
| 18 |
#define DO_DUP 5 /* duplicate object */
| 19 |
#define DO_SHOW 6 /* show object (low quality) */
| 20 |
#define DO_LIGHT 7 /* illuminate object (high quality) */
| 21 |
#define DO_HIDE 8 /* hide object */
| 22 |
#define DO_OBJECT 9 /* print object statistics */
| 23 |
| 24 |
#define DO_NCMDS 10 /* number of object display commands */
| 25 |
| 26 |
/* commands entered on stdin only */
| 27 |
#define DO_INIT {"load","clear","xform","move","unmove","dup",\
| 28 |
"show","light","hide","object"}
| 29 |
| 30 |
| 31 |
* The following routines are available for calling from the driver:
| 32 |
| 33 |
int
| 34 |
(*dobj_lightsamp)(c, p, v) : apply next sample for local light sources
| 35 |
COLR c; : pixel color (RGBE)
| 36 |
FVECT p; : world intersection point
| 37 |
FVECT v; : ray direction vector
| 38 |
| 39 |
If the pointer to the function dobj_lightsamp is non-NULL, then the
| 40 |
dev_value() driver routine should call this rather than use a
| 41 |
given sample in its own data structures. This pointer is set
| 42 |
in the dobj_lighting() function described below, which may be
| 43 |
called indirectly by the dobj_command() function.
| 44 |
| 45 |
| 46 |
int
| 47 |
dobj_command(cmd, args) : check/run object display command
| 48 |
char *cmd, *args; : command name and argument string
| 49 |
| 50 |
Check to see if this is an object display command, and return -1 if
| 51 |
it isn't. If it is a valid command that results in some visible
| 52 |
change, return non-zero, otherwise return 0. Error messages should
| 53 |
be printed with error(COMMAND,err).
| 54 |
| 55 |
| 56 |
double
| 57 |
dobj_trace(nm, rorg, rdir) : check for ray intersection with objects
| 58 |
char nm[]; : object name (modified)
| 59 |
FVECT rorg, rdir; : ray origin and direction
| 60 |
| 61 |
Check to see if the given ray intersects the given object,
| 62 |
returning the distance the ray traveled if it did, or FHUGE if it didn't.
| 63 |
If nm contains "*", then all visible objects are checked and the name
| 64 |
of the intersected object is returned, or "" if none. If nm is NULL,
| 65 |
then all visible objects are checked, but the name is not returned.
| 66 |
| 67 |
| 68 |
int
| 69 |
dobj_render() : render visible objects to OpenGL
| 70 |
| 71 |
Renders all display objects using OpenGL, assuming desired view has
| 72 |
been set. This routine also assumes that the tone-mapping library
| 73 |
is being used to set exposure, and it queries this information to
| 74 |
adjust light sources as necessary for illuminated objects. Returns
| 75 |
the number of objects rendered.
| 76 |
| 77 |
| 78 |
void
| 79 |
dobj_cleanup() : clean up data structures
| 80 |
| 81 |
Frees all allocated data structures and objects.
| 82 |
| 83 |
| 84 |
++++ The following routines are usually called through dobj_command() ++++
| 85 |
| 86 |
| 87 |
int
| 88 |
dobj_load(oct, nam) : create/load an octree object
| 89 |
char *oct, *nam; : octree and object name
| 90 |
| 91 |
Load an octree for rendering as a local object, giving it the indicated name.
| 92 |
Returns 1 on success, 0 on failure (with COMMAND error message).
| 93 |
| 94 |
| 95 |
int
| 96 |
dobj_unload(nam) : free the named object
| 97 |
char *nam; : object name
| 98 |
| 99 |
Free all memory associated with the named object.
| 100 |
| 101 |
| 102 |
| 103 |
int
| 104 |
dobj_xform(nam, add, ac, av) : set/add transform for nam
| 105 |
| 106 |
int add; : add to transform or create new one?
| 107 |
int ac; : transform argument count
| 108 |
char *av[]; : transform arguments
| 109 |
| 110 |
Set or add to the transform for the named object.
| 111 |
| 112 |
| 113 |
| 114 |
int
| 115 |
dobj_unmove() : undo last transform change
| 116 |
| 117 |
Undo the last transform change.
| 118 |
| 119 |
| 120 |
| 121 |
int
| 122 |
dobj_dup(oldnm, nam) : duplicate object oldnm as nam
| 123 |
char *oldnm, *nam;
| 124 |
| 125 |
Duplicate the named object and give the copy a new name.
| 126 |
| 127 |
| 128 |
| 129 |
int
| 130 |
dobj_lighting(nam, cn) : set up lighting for display object
| 131 |
| 132 |
int cn; : new drawing code
| 133 |
| 134 |
Set the lighting of the named object to DO_SHOW, DO_HIDE or DO_LIGHT.
| 135 |
Change lighting of all objects if nam is "*".
| 136 |
| 137 |
| 138 |
| 139 |
int
| 140 |
dobj_putstats(nam, fp) : print object statistics
| 141 |
| 142 |
FILE *fp; : output file
| 143 |
| 144 |
Print current position, size and transform for the named object,
| 145 |
or all objects if nam is "*".
| 146 |
| 147 |
| 148 |
| 149 |
| 150 |
| 151 |
extern TMstruct *tmGlobal;
| 152 |
| 153 |
extern char rhdcmd[DO_NCMDS][8];
| 154 |
| 155 |
/* pointer to function to get lights */
| 156 |
extern void (*dobj_lightsamp)(COLR clr, FVECT direc, FVECT pos);
| 157 |
| 158 |
| 159 |
extern int dobj_cleanup(void);
| 160 |
extern int dobj_command(char *cmd, register char *args);
| 161 |
extern int dobj_render(void);
| 162 |
extern double dobj_trace(char nm[], FVECT rorg, FVECT rdir);
| 163 |
extern int dobj_load(char *oct, char *nam);
| 164 |
extern int dobj_unload(char *nam);
| 165 |
extern int dobj_xform(char *nam, int rel, int ac, char **av);
| 166 |
extern int dobj_putstats(char *nam, FILE *fp);
| 167 |
extern int dobj_unmove(void);
| 168 |
extern int dobj_dup(char *oldnm, char *nam);
| 169 |
extern int dobj_lighting(char *nam, int cn);
| 170 |
| 171 |
| 172 |
#ifdef __cplusplus
| 173 |
| 174 |
#endif
| 175 |
#endif /* _RAD_RHDOBJ_H_ */
| 176 |
