root/radiance/ray/src/hd/rhdobj.h
Revision 3.9 - (view) (download) (annotate) - [selected]
Fri Jan 7 20:33:02 2005 UTC (20 years, 5 months ago) by greg
CVS Tags: HEAD, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 3.8: +2 -1 lines
Diff to previous 3.8
Thu Jan 1 11:21:55 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 3.7: +17 -4 lines
Diff to previous 3.7 , to selected 3.9
Ansification and prototypes.
Mon Jul 14 22:24:00 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.6: +13 -1 lines
Diff to previous 3.6 , to selected 3.9
Sat Feb 22 02:07:24 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.5: +1 -4 lines
Diff to previous 3.5 , to selected 3.9
Thu Dec 31 12:57:06 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.4: +3 -2 lines
Diff to previous 3.4 , to selected 3.9
fixed redrawing of local objects in OpenGL driver
Fri Dec 18 11:06:46 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.3: +3 -2 lines
Diff to previous 3.3 , to selected 3.9
changed dobj_render() to return the number of objects rendered
Thu Aug 27 19:33:28 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.2: +1 -1 lines
Diff to previous 3.2 , to selected 3.9
changed "unload" command to "clear"
Fri Aug 21 11:38:22 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.1: +6 -2 lines
Diff to previous 3.1 , to selected 3.9
changed dobj_trace() to return name of intersected object
improved "show" lighting with front-directed light source
changed MINTHRESH and cosmetic fixes
Wed Aug 19 17:45:24 1998 UTC (26 years, 9 months ago) by gwlarson
Diff to selected 3.9
