root/radiance/ray/src/hd/rhdobj.h
Revision: 3.2
Committed: Fri Aug 21 11:38:22 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.1: +6 -2 lines
changed dobj_trace() to return name of intersected object
improved "show" lighting with front-directed light source
changed MINTHRESH and cosmetic fixes
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for object display routines for rholo drivers.
7 */
8
9 /* additional user commands */
10 #define DO_LOAD 0 /* load octree object */
11 #define DO_UNLOAD 1 /* unload (free) octree object */
12 #define DO_XFORM 2 /* set/print object transform */
13 #define DO_MOVE 3 /* add to object transform */
14 #define DO_UNMOVE 4 /* undo last transform change */
15 #define DO_DUP 5 /* duplicate object */
16 #define DO_SHOW 6 /* show object (low quality) */
17 #define DO_LIGHT 7 /* illuminate object (high quality) */
18 #define DO_HIDE 8 /* hide object */
19 #define DO_OBJECT 9 /* print object statistics */
20
21 #define DO_NCMDS 10 /* number of object display commands */
22
23 /* commands entered on stdin only */
24 #define DO_INIT {"load","unload","xform","move","unmove","dup",\
25 "show","light","hide","object"}
26
27 /*******************************************************************
28 * The following routines are available for calling from the driver:
29
30 int
31 (*dobj_lightsamp)(c, p, v) : apply next sample for local light sources
32 COLR c; : pixel color (RGBE)
33 FVECT p; : world intersection point
34 FVECT v; : ray direction vector
35
36 If the pointer to the function dobj_lightsamp is non-NULL, then the
37 dev_value() driver routine should call this rather than use a
38 given sample in its own data structures. This pointer is set
39 in the dobj_lighting() function described below, which may be
40 called indirectly by the dobj_command() function.
41
42
43 int
44 dobj_command(cmd, args) : check/run object display command
45 char *cmd, *args; : command name and argument string
46
47 Check to see if this is an object display command, and return the command
48 number after running it if it is, or -1 if it isn't. Error messages should
49 be printed with error(COMMAND,err).
50
51
52 double
53 dobj_trace(nm, rorg, rdir) : check for ray intersection with objects
54 char nm[]; : object name (modified)
55 FVECT rorg, rdir; : ray origin and direction
56
57 Check to see if the given ray intersects the given object,
58 returning the distance the ray traveled if it did, or FHUGE if it didn't.
59 If nm contains "*", then all visible objects are checked and the name
60 of the intersected object is returned, or "" if none. If nm is NULL,
61 then all visible objects are checked, but the name is not returned.
62
63
64 void
65 dobj_render() : render visible objects to OpenGL
66
67 Renders all display objects using OpenGL, assuming desired view has
68 been set. This routine also assumes that the tone-mapping library
69 is being used to set exposure, and it queries this information to
70 adjust light sources as necessary for illuminated objects.
71
72
73 void
74 dobj_cleanup() : clean up data structures
75
76 Frees all allocated data structures and objects.
77
78
79 ++++ The following routines are usually called through dobj_command() ++++
80
81
82 int
83 dobj_load(oct, nam) : create/load an octree object
84 char *oct, *nam; : octree and object name
85
86 Load an octree for rendering as a local object, giving it the indicated name.
87 Returns 1 on success, 0 on failure (with COMMAND error message).
88
89
90 int
91 dobj_unload(nam) : free the named object
92 char *nam; : object name
93
94 Free all memory associated with the named object.
95 Returns 1 on success, 0 on failure (with COMMAND error message).
96
97
98 int
99 dobj_xform(nam, add, ac, av) : set/add transform for nam
100 char *nam; : object name
101 int add; : add to transform or create new one?
102 int ac; : transform argument count
103 char *av[]; : transform arguments
104
105 Set or add to the transform for the named object.
106 Returns 1 on success, 0 on failure (with COMMAND error message).
107
108
109 int
110 dobj_unmove() : undo last transform change
111
112 Undo the last transform change.
113 Returns 1 on success, 0 on failure (with COMMAND error message).
114
115
116 int
117 dobj_dup(oldnm, nam) : duplicate object oldnm as nam
118 char *oldnm, *nam;
119
120 Duplicate the named object and give the copy a new name.
121 Returns 1 on success, 0 on failure (with COMMAND error message).
122
123
124 int
125 dobj_lighting(nam, cn) : set up lighting for display object
126 char *nam; : object name
127 int cn; : new drawing code
128
129 Set the lighting of the named object to DO_SHOW, DO_HIDE or DO_LIGHT.
130 Change lighting of all objects if nam is "*".
131 Returns 1 on success, 0 on failure (with COMMAND error message).
132
133
134 int
135 dobj_putstats(nam, fp) : print object statistics
136 char *nam; : object name
137 FILE *fp; : output file
138
139 Print current position, size and transform for the named object,
140 or all objects if nam is "*".
141 Returns 1 on success, 0 on failure (with COMMAND error message).
142
143
144 ******************************************************************/
145
146
147 extern double dobj_trace();
148
149 extern char rhdcmd[DO_NCMDS][8];
150
151 extern int (*dobj_lightsamp)(); /* pointer to function to get lights */
