1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for loading and displaying Radiance objects in rholo with GLX. |
9 |
10 |
11 |
#include "radogl.h" |
12 |
#include "tonemap.h" |
13 |
#include "rhdisp.h" |
14 |
#include "rhdriver.h" |
15 |
#include "rhdobj.h" |
16 |
17 |
extern FILE *sstdout; /* user standard output */ |
18 |
19 |
char rhdcmd[DO_NCMDS][8] = DO_INIT; /* user command list */ |
20 |
21 |
int (*dobj_lightsamp)() = NULL; /* pointer to function to get lights */ |
22 |
23 |
#define AVGREFL 0.5 /* assumed average reflectance */ |
24 |
25 |
#define MAXAC 64 /* maximum number of args */ |
26 |
27 |
#ifndef MINTHRESH |
28 |
#define MINTHRESH 5.0 /* source threshold w.r.t. mean */ |
29 |
#endif |
30 |
31 |
#ifndef NALT |
32 |
#define NALT 11 /* # sampling altitude angles */ |
33 |
#endif |
34 |
#ifndef NAZI |
35 |
#define NAZI ((int)(PI/2.*NALT+.5)) |
36 |
#endif |
37 |
38 |
typedef struct dlights { |
39 |
struct dlights *next; /* next in lighting set list */ |
40 |
FVECT lcent; /* computed lighting center */ |
41 |
double ravg; /* harmonic mean free range radius */ |
42 |
TMbright larb; /* average reflected brightness */ |
43 |
COLOR lamb; /* local ambient value */ |
44 |
short nl; /* number of lights in this set */ |
45 |
struct lsource { |
46 |
FVECT direc; /* source direction */ |
47 |
double omega; /* source solid angle */ |
48 |
COLOR val; /* source color */ |
49 |
} li[MAXLIGHTS]; /* light sources */ |
50 |
} DLIGHTS; /* a light source set */ |
51 |
52 |
typedef struct dobject { |
53 |
struct dobject *next; /* next object in list */ |
54 |
char name[64]; /* object name */ |
55 |
FVECT center; /* orig. object center */ |
56 |
FLOAT radius; /* orig. object radius */ |
57 |
int listid; /* GL display list identifier */ |
58 |
int rtp[3]; /* associated rtrace process */ |
59 |
DLIGHTS *ol; /* object lights */ |
60 |
FULLXF xfb; /* coordinate transform */ |
61 |
short drawcode; /* drawing code */ |
62 |
short xfac; /* transform argument count */ |
63 |
char *xfav[MAXAC+1]; /* transform args */ |
64 |
} DOBJECT; /* a displayable object */ |
65 |
66 |
static DLIGHTS *dlightsets; /* lighting sets */ |
67 |
static DOBJECT *dobjects; /* display object list */ |
68 |
static DOBJECT *curobj; /* current (last referred) object */ |
69 |
static int lastxfac; /* last number of transform args */ |
70 |
static char *lastxfav[MAXAC+1]; /* saved transform arguments */ |
71 |
72 |
#define getdcent(c,op) multp3(c,(op)->center,(op)->xfb.f.xfm) |
73 |
#define getdrad(op) ((op)->radius*(op)->xfb.f.sca) |
74 |
75 |
#define RTARGC 8 |
76 |
static char *rtargv[RTARGC+1] = {"rtrace", "-h-", "-w-", "-fdd", |
77 |
"-x", "1", "-oL"}; |
78 |
79 |
static struct { |
80 |
int nsamp; /* number of ray samples */ |
81 |
COLOR val; /* value (sum) */ |
82 |
} ssamp[NALT][NAZI]; /* current sphere samples */ |
83 |
84 |
#define curname (curobj==NULL ? (char *)NULL : curobj->name) |
85 |
86 |
87 |
static DOBJECT * |
88 |
getdobj(nm) /* get object from list by name */ |
89 |
char *nm; |
90 |
91 |
register DOBJECT *op; |
92 |
93 |
if (nm == NULL) |
94 |
return(NULL); |
95 |
if (nm == curname) |
96 |
return(curobj); |
97 |
for (op = dobjects; op != NULL; op = op->next) |
98 |
if (!strcmp(op->name, nm)) |
99 |
break; |
100 |
return(op); |
101 |
102 |
103 |
104 |
static |
105 |
freedobj(op) /* free resources and memory assoc. with op */ |
106 |
107 |
108 |
int foundlink = 0; |
109 |
DOBJECT ohead; |
110 |
register DOBJECT *opl; |
111 |
112 |
if (op == NULL) |
113 |
return(0); |
114 |
ohead.next = dobjects; |
115 |
for (opl = &ohead; opl->next != NULL; opl = opl->next) { |
116 |
if (opl->next == op && (opl->next = op->next) == NULL) |
117 |
break; |
118 |
foundlink += opl->next->listid == op->listid; |
119 |
120 |
dobjects = ohead.next; |
121 |
if (!foundlink) { |
122 |
glDeleteLists(op->listid, 1); |
123 |
close_process(op->rtp); |
124 |
125 |
while (op->xfac) |
126 |
freestr(op->xfav[--op->xfac]); |
127 |
free((char *)op); |
128 |
return(1); |
129 |
130 |
131 |
132 |
static |
133 |
savedxf(op) /* save transform for display object */ |
134 |
135 |
136 |
/* free old */ |
137 |
while (lastxfac) |
138 |
freestr(lastxfav[--lastxfac]); |
139 |
/* nothing to save? */ |
140 |
if (op == NULL) { |
141 |
lastxfav[0] = NULL; |
142 |
return(0); |
143 |
144 |
/* else save new */ |
145 |
for (lastxfac = 0; lastxfac < op->xfac; lastxfac++) |
146 |
lastxfav[lastxfac] = savestr(op->xfav[lastxfac]); |
147 |
lastxfav[lastxfac] = NULL; |
148 |
return(1); |
149 |
150 |
151 |
152 |
static |
153 |
ssph_sample(clr, direc, pos) /* add sample to current source sphere */ |
154 |
COLR clr; |
155 |
FVECT direc, pos; |
156 |
157 |
COLOR col; |
158 |
double d; |
159 |
register int alt, azi; |
160 |
161 |
if (dlightsets == NULL) |
162 |
return; |
163 |
if (pos == NULL) |
164 |
d = FHUGE; /* sample is at infinity */ |
165 |
else if ((d = (pos[0] - dlightsets->lcent[0])*direc[0] + |
166 |
(pos[1] - dlightsets->lcent[1])*direc[1] + |
167 |
(pos[2] - dlightsets->lcent[2])*direc[2]) > FTINY) |
168 |
dlightsets->ravg += 1./d; |
169 |
else |
170 |
return; /* sample is behind us */ |
171 |
alt = NALT*(1.-FTINY)*(.5*(1.+FTINY) + direc[2]*.5); |
172 |
azi = NAZI*(1.-FTINY)*(.5*(1.+FTINY) + .5/PI*atan2(direc[1],direc[0])); |
173 |
colr_color(col, clr); |
174 |
addcolor(ssamp[alt][azi].val, col); |
175 |
ssamp[alt][azi].nsamp++; |
176 |
177 |
178 |
179 |
static |
180 |
ssph_direc(direc, alt, azi) /* compute sphere sampling direction */ |
181 |
FVECT direc; |
182 |
int alt, azi; |
183 |
184 |
double phi, d; |
185 |
186 |
direc[2] = 2./NALT*(alt+.5) - 1.; |
187 |
d = sqrt(1. - direc[2]*direc[2]); |
188 |
phi = 2.*PI/NAZI*(azi+.5) - PI; |
189 |
direc[0] = d*cos(phi); |
190 |
direc[1] = d*sin(phi); |
191 |
192 |
193 |
194 |
static int |
195 |
ssph_neigh(sp, next) /* neighbor counter on sphere */ |
196 |
register int sp[2]; |
197 |
int next; |
198 |
199 |
static short nneigh = 0; /* neighbor count */ |
200 |
static short neighlist[NAZI+6][2]; /* neighbor list (0 is home) */ |
201 |
register int i; |
202 |
203 |
if (next) { |
204 |
if (nneigh <= 0) |
205 |
return(0); |
206 |
sp[0] = neighlist[--nneigh][0]; |
207 |
sp[1] = neighlist[nneigh][1]; |
208 |
return(1); |
209 |
210 |
if (sp[0] < 0 | sp[0] >= NALT | sp[1] < 0 | sp[1] >= NAZI) |
211 |
return(nneigh=0); |
212 |
neighlist[0][0] = sp[0]; neighlist[0][1] = sp[1]; |
213 |
nneigh = 1; |
214 |
if (sp[0] == 0) { |
215 |
neighlist[nneigh][0] = 1; |
216 |
neighlist[nneigh++][1] = (sp[1]+1)%NAZI; |
217 |
218 |
neighlist[nneigh++][1] = sp[1]; |
219 |
220 |
neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI; |
221 |
for (i = 0; i < NAZI; i++) |
222 |
if (i != sp[1]) { |
223 |
neighlist[nneigh][0] = 0; |
224 |
neighlist[nneigh++][1] = i; |
225 |
226 |
} else if (sp[0] == NALT-1) { |
227 |
neighlist[nneigh][0] = NALT-2; |
228 |
229 |
230 |
231 |
232 |
233 |
234 |
if (i != sp[1]) { |
235 |
neighlist[nneigh][0] = NALT-1; |
236 |
237 |
238 |
} else { |
239 |
neighlist[nneigh][0] = sp[0]-1; |
240 |
241 |
242 |
243 |
244 |
245 |
neighlist[nneigh][0] = sp[0]; |
246 |
247 |
248 |
249 |
neighlist[nneigh][0] = sp[0]+1; |
250 |
251 |
252 |
253 |
254 |
255 |
256 |
return(nneigh); |
257 |
258 |
259 |
260 |
static |
261 |
ssph_compute() /* compute source set from sphere samples */ |
262 |
263 |
int ncells, nsamps; |
264 |
COLOR csum; |
265 |
FVECT v; |
266 |
double d, thresh, maxbr; |
267 |
int maxalt, maxazi, spos[2]; |
268 |
269 |
register struct lsource *ls; |
270 |
/* count & average sampled cells */ |
271 |
setcolor(csum, 0., 0., 0.); |
272 |
ncells = nsamps = 0; |
273 |
for (alt = 0; alt < NALT; alt++) |
274 |
for (azi = 0; azi < NAZI; azi++) |
275 |
if (ssamp[alt][azi].nsamp) { |
276 |
if (ssamp[alt][azi].nsamp > 1) { |
277 |
d = 1.0/ssamp[alt][azi].nsamp; |
278 |
scalecolor(ssamp[alt][azi].val, d); |
279 |
280 |
addcolor(csum, ssamp[alt][azi].val); |
281 |
nsamps += ssamp[alt][azi].nsamp; |
282 |
ncells++; |
283 |
284 |
if (dlightsets == NULL | ncells < NALT*NAZI/4) { |
285 |
ncells = 0; |
286 |
goto done; |
287 |
288 |
/* harmonic mean distance */ |
289 |
if (dlightsets->ravg > FTINY) |
290 |
dlightsets->ravg = nsamps / dlightsets->ravg; |
291 |
else |
292 |
dlightsets->ravg = FHUGE; |
293 |
/* light source threshold */ |
294 |
thresh = MINTHRESH*bright(csum)/ncells; |
295 |
if (thresh <= FTINY) { |
296 |
ncells = 0; |
297 |
goto done; |
298 |
299 |
/* avg. reflected brightness */ |
300 |
d = AVGREFL / (double)ncells; |
301 |
scalecolor(csum, d); |
302 |
if (tmCvColors(&dlightsets->larb, TM_NOCHROM, csum, 1) != TM_E_OK) |
303 |
error(CONSISTENCY, "tone mapping problem in ssph_compute"); |
304 |
/* greedy light source clustering */ |
305 |
while (dlightsets->nl < MAXLIGHTS) { |
306 |
maxbr = 0.; /* find brightest cell */ |
307 |
308 |
309 |
if ((d = bright(ssamp[alt][azi].val)) > maxbr) { |
310 |
maxalt = alt; maxazi = azi; |
311 |
maxbr = d; |
312 |
313 |
if (maxbr < thresh) /* below threshold? */ |
314 |
break; |
315 |
ls = dlightsets->li + dlightsets->nl++; |
316 |
spos[0] = maxalt; spos[1] = maxazi; /* cluster */ |
317 |
for (ssph_neigh(spos, 0); ssph_neigh(spos, 1); ) { |
318 |
alt = spos[0]; azi = spos[1]; |
319 |
if ((d = bright(ssamp[alt][azi].val)) < .75*thresh) |
320 |
continue; /* too dim */ |
321 |
ssph_direc(v, alt, azi); /* else add it in */ |
322 |
VSUM(ls->direc, ls->direc, v, d); |
323 |
ls->omega++; |
324 |
addcolor(ls->val, ssamp[alt][azi].val); |
325 |
setcolor(ssamp[alt][azi].val, 0., 0., 0.); |
326 |
327 |
d = 1./ls->omega; /* avg. brightness */ |
328 |
scalecolor(ls->val, d); |
329 |
ls->omega *= 4.*PI/(NALT*NAZI); /* solid angle */ |
330 |
normalize(ls->direc); /* direction */ |
331 |
332 |
/* compute ambient remainder */ |
333 |
334 |
335 |
if (ssamp[alt][azi].nsamp) |
336 |
addcolor(dlightsets->lamb, ssamp[alt][azi].val); |
337 |
d = 1.0/ncells; |
338 |
scalecolor(dlightsets->lamb, d); |
339 |
done: /* clear sphere sample array */ |
340 |
bzero((char *)ssamp, sizeof(ssamp)); |
341 |
return(ncells); |
342 |
343 |
344 |
345 |
static |
346 |
getdlights(op, force) /* get lights for display object */ |
347 |
348 |
int force; |
349 |
350 |
double d2, mind2 = FHUGE*FHUGE; |
351 |
FVECT ocent; |
352 |
VIEW cvw; |
353 |
register DLIGHTS *dl; |
354 |
355 |
op->ol = NULL; |
356 |
if (op->drawcode != DO_LIGHT) |
357 |
return(0); |
358 |
/* check for usable light set */ |
359 |
getdcent(ocent, op); |
360 |
for (dl = dlightsets; dl != NULL; dl = dl->next) |
361 |
if ((d2 = dist2(dl->lcent, ocent)) < mind2) { |
362 |
op->ol = dl; |
363 |
mind2 = d2; |
364 |
365 |
/* the following is heuristic */ |
366 |
d2 = 2.*getdrad(op); d2 *= d2; |
367 |
if ((dl = op->ol) != NULL && (mind2 < 0.0625*dl->ravg*dl->ravg || |
368 |
mind2 < 4.*getdrad(op)*getdrad(op))) |
369 |
return(1); |
370 |
if (!force) |
371 |
return(0); |
372 |
/* need to compute new light set */ |
373 |
copystruct(&cvw, &stdview); |
374 |
cvw.type = VT_PER; |
375 |
VCOPY(cvw.vp, ocent); |
376 |
cvw.vup[0] = 1.; cvw.vup[1] = cvw.vup[2] = 0.; |
377 |
cvw.horiz = 90; cvw.vert = 90.; |
378 |
beam_init(1); /* query beams through center */ |
379 |
cvw.vdir[0] = cvw.vdir[1] = 0.; cvw.vdir[2] = 1.; |
380 |
setview(&cvw); beam_view(&cvw, 0, 0); |
381 |
cvw.vdir[0] = cvw.vdir[1] = 0.; cvw.vdir[2] = -1.; |
382 |
383 |
cvw.vup[0] = cvw.vup[1] = 0.; cvw.vup[2] = 1.; |
384 |
cvw.vdir[0] = cvw.vdir[2] = 0.; cvw.vdir[1] = 1.; |
385 |
386 |
cvw.vdir[0] = cvw.vdir[2] = 0.; cvw.vdir[1] = -1.; |
387 |
388 |
cvw.vdir[1] = cvw.vdir[2] = 0.; cvw.vdir[0] = 1.; |
389 |
390 |
cvw.vdir[1] = cvw.vdir[2] = 0.; cvw.vdir[0] = -1.; |
391 |
392 |
/* allocate new light set */ |
393 |
dl = (DLIGHTS *)calloc(1, sizeof(DLIGHTS)); |
394 |
if (dl == NULL) |
395 |
goto memerr; |
396 |
VCOPY(dl->lcent, ocent); |
397 |
/* push onto our light set list */ |
398 |
dl->next = dlightsets; |
399 |
dlightsets = dl; |
400 |
dobj_lightsamp = ssph_sample; /* get beams from server */ |
401 |
imm_mode = beam_sync(-1) > 0; |
402 |
while (imm_mode) |
403 |
if (serv_result() == DS_SHUTDOWN) |
404 |
quit(0); |
405 |
if (!ssph_compute()) { /* compute light sources from sphere */ |
406 |
dlightsets = dl->next; |
407 |
free((char *)dl); |
408 |
return(0); |
409 |
410 |
op->ol = dl; |
411 |
return(1); |
412 |
memerr: |
413 |
error(SYSTEM, "out of memory in getdlights"); |
414 |
415 |
416 |
417 |
static int |
418 |
cmderror(cn, err) /* report command error */ |
419 |
int cn; |
420 |
char *err; |
421 |
422 |
sprintf(errmsg, "%s: %s", rhdcmd[cn], err); |
423 |
error(COMMAND, errmsg); |
424 |
return(cn); |
425 |
426 |
427 |
428 |
int |
429 |
dobj_command(cmd, args) /* run object display command */ |
430 |
char *cmd; |
431 |
register char *args; |
432 |
433 |
int cn, na, doxfm; |
434 |
register int nn; |
435 |
char *alist[MAXAC+1], *nm; |
436 |
/* find command */ |
437 |
for (cn = 0; cn < DO_NCMDS; cn++) |
438 |
if (!strcmp(cmd, rhdcmd[cn])) |
439 |
break; |
440 |
if (cn >= DO_NCMDS) |
441 |
return(-1); /* not in our list */ |
442 |
/* make argument list */ |
443 |
for (na = 0; *args; na++) { |
444 |
if (na > MAXAC) |
445 |
goto toomany; |
446 |
alist[na] = args; |
447 |
while (*args && !isspace(*args)) |
448 |
args++; |
449 |
while (isspace(*args)) |
450 |
*args++ = '\0'; |
451 |
452 |
alist[na] = NULL; |
453 |
/* execute command */ |
454 |
switch (cn) { |
455 |
case DO_LOAD: /* load an octree */ |
456 |
if (na == 1) |
457 |
dobj_load(alist[0], alist[0]); |
458 |
else if (na == 2) |
459 |
dobj_load(alist[0], alist[1]); |
460 |
else |
461 |
return(cmderror(cn, "need octree [name]")); |
462 |
break; |
463 |
case DO_UNLOAD: /* clear an object */ |
464 |
if (na > 1) goto toomany; |
465 |
if (na && alist[0][0] == '*') |
466 |
dobj_cleanup(); |
467 |
else |
468 |
dobj_unload(na ? alist[0] : curname); |
469 |
break; |
470 |
case DO_XFORM: /* transform object */ |
471 |
case DO_MOVE: |
472 |
if (na && alist[0][0] != '-') { |
473 |
nm = alist[0]; nn = 1; |
474 |
} else { |
475 |
nm = curname; nn = 0; |
476 |
477 |
if (cn == DO_MOVE && nn >= na) |
478 |
return(cmderror(cn, "missing transform")); |
479 |
dobj_xform(nm, cn==DO_MOVE, na-nn, alist+nn); |
480 |
break; |
481 |
case DO_UNMOVE: /* undo last transform */ |
482 |
dobj_unmove(); |
483 |
break; |
484 |
case DO_OBJECT: /* print object statistics */ |
485 |
if (dobj_putstats(na ? alist[0] : curname, sstdout)) |
486 |
if (na && alist[0][0] != '*' && (curobj == NULL || |
487 |
strcmp(alist[0], curobj->name))) |
488 |
savedxf(curobj = getdobj(alist[0])); |
489 |
break; |
490 |
case DO_DUP: /* duplicate object */ |
491 |
for (nn = 0; nn < na; nn++) |
492 |
if (alist[nn][0] == '-') |
493 |
break; |
494 |
switch (nn) { |
495 |
case 0: |
496 |
return(cmderror(cn, "need new object name")); |
497 |
case 1: |
498 |
nm = curname; |
499 |
break; |
500 |
case 2: |
501 |
nm = alist[0]; |
502 |
break; |
503 |
default: |
504 |
goto toomany; |
505 |
506 |
if (!dobj_dup(nm, alist[nn-1])) |
507 |
break; |
508 |
if (na > nn) |
509 |
dobj_xform(curname, 1, na-nn, alist+nn); |
510 |
else |
511 |
curobj->drawcode = DO_HIDE; |
512 |
savedxf(curobj); |
513 |
break; |
514 |
case DO_SHOW: /* change rendering option */ |
515 |
case DO_LIGHT: |
516 |
case DO_HIDE: |
517 |
518 |
dobj_lighting(na ? alist[0] : curname, cn); |
519 |
break; |
520 |
default: |
521 |
error(CONSISTENCY, "bad command id in dobj_command"); |
522 |
523 |
dev_view(&odev.v); /* redraw */ |
524 |
return(cn); |
525 |
toomany: |
526 |
return(cmderror(cn, "too many arguments")); |
527 |
528 |
529 |
530 |
dobj_load(oct, nam) /* create/load an octree object */ |
531 |
char *oct, *nam; |
532 |
533 |
extern char *getlibpath(), *getpath(); |
534 |
char *fpp, fpath[128]; |
535 |
536 |
/* check arguments */ |
537 |
if (oct == NULL) { |
538 |
error(COMMAND, "missing octree"); |
539 |
return(0); |
540 |
541 |
if (nam == NULL) { |
542 |
error(COMMAND, "missing name"); |
543 |
return(0); |
544 |
545 |
if (*nam == '*' | *nam == '-') { |
546 |
error(COMMAND, "illegal name"); |
547 |
return(0); |
548 |
549 |
if (getdobj(nam) != NULL) { |
550 |
error(COMMAND, "name already taken (clear first)"); |
551 |
return(0); |
552 |
553 |
/* get octree path */ |
554 |
if ((fpp = getpath(oct, getlibpath(), R_OK)) == NULL) { |
555 |
sprintf(errmsg, "cannot find octree \"%s\"", oct); |
556 |
557 |
return(0); |
558 |
559 |
strcpy(fpath, fpp); |
560 |
op = (DOBJECT *)malloc(sizeof(DOBJECT)); |
561 |
if (op == NULL) |
562 |
error(SYSTEM, "out of memory in dobj_load"); |
563 |
/* set struct fields */ |
564 |
strcpy(op->name, nam); |
565 |
op->ol = NULL; |
566 |
op->drawcode = DO_HIDE; |
567 |
setident4(op->xfb.f.xfm); op->xfb.f.sca = 1.; |
568 |
setident4(op->xfb.b.xfm); op->xfb.b.sca = 1.; |
569 |
op->xfav[op->xfac=0] = NULL; |
570 |
/* load octree into display list */ |
571 |
dolights = 0; |
572 |
op->listid = rgl_octlist(fpath, op->center, &op->radius); |
573 |
/* start rtrace */ |
574 |
rtargv[RTARGC-1] = fpath; |
575 |
rtargv[RTARGC] = NULL; |
576 |
open_process(op->rtp, rtargv); |
577 |
/* insert into main list */ |
578 |
op->next = dobjects; |
579 |
curobj = dobjects = op; |
580 |
savedxf(NULL); |
581 |
return(1); |
582 |
583 |
584 |
585 |
dobj_unload(nam) /* free the named object */ |
586 |
char *nam; |
587 |
588 |
589 |
590 |
if ((op = getdobj(nam)) == NULL) { |
591 |
error(COMMAND, "no object"); |
592 |
return(0); |
593 |
594 |
freedobj(op); |
595 |
savedxf(curobj = NULL); |
596 |
return(1); |
597 |
598 |
599 |
600 |
dobj_cleanup() /* free all resources */ |
601 |
602 |
register DLIGHTS *lp; |
603 |
604 |
while (dobjects != NULL) |
605 |
freedobj(dobjects); |
606 |
607 |
while ((lp = dlightsets) != NULL) { |
608 |
dlightsets = lp->next; |
609 |
free((char *)lp); |
610 |
611 |
return(1); |
612 |
613 |
614 |
615 |
dobj_xform(nam, add, ac, av) /* set/add transform for nam */ |
616 |
char *nam; |
617 |
int add, ac; |
618 |
char **av; |
619 |
620 |
621 |
622 |
623 |
624 |
return(0); |
625 |
626 |
if (add) add = op->xfac; |
627 |
if (ac + add > MAXAC) { |
628 |
error(COMMAND, "too many transform arguments"); |
629 |
return(0); |
630 |
631 |
savedxf(curobj = op); |
632 |
if (!add) |
633 |
while (op->xfac) |
634 |
635 |
while (ac--) |
636 |
op->xfav[op->xfac++] = savestr(*av++); |
637 |
op->xfav[op->xfac] = NULL; |
638 |
if (fullxf(&op->xfb, op->xfac, op->xfav) != op->xfac) { |
639 |
error(COMMAND, "bad transform arguments"); |
640 |
dobj_unmove(); |
641 |
savedxf(op); /* save current transform instead */ |
642 |
return(0); |
643 |
644 |
/* don't know local lights anymore */ |
645 |
getdlights(op, 0); |
646 |
return(1); |
647 |
648 |
649 |
650 |
dobj_putstats(nam, fp) /* put out statistics for nam */ |
651 |
char *nam; |
652 |
FILE *fp; |
653 |
654 |
FVECT ocent; |
655 |
656 |
register int i; |
657 |
658 |
659 |
error(COMMAND, "no current object"); |
660 |
return(0); |
661 |
662 |
if (nam[0] == '*') { |
663 |
i = 0; |
664 |
665 |
i += dobj_putstats(op->name, fp); |
666 |
return(i); |
667 |
668 |
669 |
error(COMMAND, "unknown object"); |
670 |
return(0); |
671 |
672 |
673 |
fprintf(fp, "%s: %s, center [%f %f %f], radius %f", op->name, |
674 |
op->drawcode==DO_HIDE ? "hidden" : |
675 |
op->drawcode==DO_LIGHT && op->ol!=NULL ? "lighted" : |
676 |
"shown", |
677 |
ocent[0],ocent[1],ocent[2], getdrad(op)); |
678 |
if (op->xfac) |
679 |
fputs(", (xform", fp); |
680 |
for (i = 0; i < op->xfac; i++) { |
681 |
putc(' ', fp); |
682 |
fputs(op->xfav[i], fp); |
683 |
684 |
if (op->xfac) |
685 |
fputc(')', fp); |
686 |
fputc('\n', fp); |
687 |
return(1); |
688 |
689 |
690 |
691 |
dobj_unmove() /* undo last transform change */ |
692 |
693 |
int txfac; |
694 |
char *txfav[MAXAC+1]; |
695 |
696 |
if (curobj == NULL) { |
697 |
698 |
return(0); |
699 |
700 |
/* hold last transform */ |
701 |
bcopy((char *)lastxfav, (char *)txfav, |
702 |
(txfac=lastxfac)*sizeof(char *)); |
703 |
/* save this transform */ |
704 |
bcopy((char *)curobj->xfav, (char *)lastxfav, |
705 |
(lastxfac=curobj->xfac)*sizeof(char *)); |
706 |
/* copy back last transform */ |
707 |
bcopy((char *)txfav, (char *)curobj->xfav, |
708 |
(curobj->xfac=txfac)*sizeof(char *)); |
709 |
/* set matrices */ |
710 |
fullxf(&curobj->xfb, curobj->xfac, curobj->xfav); |
711 |
712 |
getdlights(curobj, 0); |
713 |
return(1); |
714 |
715 |
716 |
717 |
dobj_dup(oldnm, nam) /* duplicate object oldnm as nam */ |
718 |
char *oldnm, *nam; |
719 |
720 |
register DOBJECT *op, *opdup; |
721 |
722 |
if ((op = getdobj(oldnm)) == NULL) { |
723 |
724 |
return(0); |
725 |
726 |
727 |
728 |
return(0); |
729 |
730 |
731 |
732 |
return(0); |
733 |
734 |
735 |
736 |
return(0); |
737 |
738 |
/* allocate and copy struct */ |
739 |
opdup = (DOBJECT *)malloc(sizeof(DOBJECT)); |
740 |
if (opdup == NULL) |
741 |
error(SYSTEM, "out of memory in dobj_dup"); |
742 |
copystruct(opdup, op); |
743 |
/* rename */ |
744 |
strcpy(opdup->name, nam); |
745 |
/* get our own copy of transform */ |
746 |
for (opdup->xfac = 0; opdup->xfac < op->xfac; opdup->xfac++) |
747 |
opdup->xfav[opdup->xfac] = savestr(op->xfav[opdup->xfac]); |
748 |
opdup->xfav[opdup->xfac] = NULL; |
749 |
/* insert it into our list */ |
750 |
opdup->next = dobjects; |
751 |
curobj = dobjects = opdup; |
752 |
return(1); |
753 |
754 |
755 |
756 |
dobj_lighting(nam, cn) /* set up lighting for display object */ |
757 |
char *nam; |
758 |
int cn; |
759 |
760 |
int i, res[2]; |
761 |
VIEW *dv; |
762 |
763 |
764 |
765 |
766 |
return(0); |
767 |
768 |
769 |
770 |
if ((op->drawcode = cn) == DO_LIGHT) |
771 |
getdlights(op, 1); |
772 |
else |
773 |
op->ol = NULL; |
774 |
} else if ((op = getdobj(nam)) == NULL) { |
775 |
776 |
return(0); |
777 |
} else if ((op->drawcode = cn) == DO_LIGHT) { |
778 |
if (!getdlights(op, 1)) |
779 |
error(COMMAND, "insufficient samples to light object"); |
780 |
} else |
781 |
op->ol = NULL; |
782 |
783 |
if (dobj_lightsamp != NULL) { /* restore beam set */ |
784 |
dobj_lightsamp = NULL; |
785 |
beam_init(1); |
786 |
for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++) |
787 |
beam_view(dv, res[0], res[1]); |
788 |
beam_sync(1); /* update server */ |
789 |
790 |
791 |
792 |
793 |
double |
794 |
dobj_trace(nm, rorg, rdir) /* check for ray intersection with object(s) */ |
795 |
char nm[]; |
796 |
FVECT rorg, rdir; |
797 |
798 |
799 |
FVECT xorg, xdir; |
800 |
double darr[6]; |
801 |
/* check each visible object? */ |
802 |
if (nm == NULL || *nm == '*') { |
803 |
double dist, mindist = 1.01*FHUGE; |
804 |
805 |
if (nm != NULL) nm[0] = '\0'; |
806 |
for (op = dobjects; op != NULL; op = op->next) { |
807 |
if (op->drawcode == DO_HIDE) |
808 |
continue; |
809 |
dist = dobj_trace(op->name, rorg, rdir); |
810 |
if (dist < mindist) { |
811 |
if (nm != NULL) strcpy(nm, op->name); |
812 |
mindist = dist; |
813 |
814 |
815 |
return(mindist); |
816 |
817 |
/* else check particular object */ |
818 |
if ((op = getdobj(nm)) == NULL) { |
819 |
820 |
return(FHUGE); |
821 |
822 |
if (op->xfac) { /* put ray in local coordinates */ |
823 |
multp3(xorg, rorg, op->xfb.b.xfm); |
824 |
multv3(xdir, rdir, op->xfb.b.xfm); |
825 |
VCOPY(darr, xorg); VCOPY(darr+3, xdir); |
826 |
} else { |
827 |
VCOPY(darr, rorg); VCOPY(darr+3, rdir); |
828 |
829 |
/* trace it */ |
830 |
if (process(op->rtp, darr, darr, sizeof(double), |
831 |
6*sizeof(double)) != sizeof(double)) |
832 |
error(SYSTEM, "rtrace communication error"); |
833 |
/* return distance */ |
834 |
if (darr[0] >= .99*FHUGE) |
835 |
return(FHUGE); |
836 |
return(darr[0]*op->xfb.f.sca); |
837 |
838 |
839 |
840 |
dobj_render() /* render our objects in OpenGL */ |
841 |
842 |
GLboolean normalizing; |
843 |
GLfloat vec[4]; |
844 |
FVECT v1; |
845 |
846 |
register int i; |
847 |
/* anything to render? */ |
848 |
849 |
if (op->drawcode != DO_HIDE) |
850 |
break; |
851 |
if (op == NULL) |
852 |
return(1); |
853 |
/* set up general rendering params */ |
854 |
glGetBooleanv(GL_NORMALIZE, &normalizing); |
855 |
glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT|GL_ENABLE_BIT| |
856 |
GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT|GL_POLYGON_BIT); |
857 |
glDepthFunc(GL_LESS); |
858 |
glEnable(GL_DEPTH_TEST); |
859 |
glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE); |
860 |
glPolygonMode(GL_FRONT_AND_BACK, GL_FILL); |
861 |
glShadeModel(GL_SMOOTH); |
862 |
glFrontFace(GL_CCW); |
863 |
glDisable(GL_CULL_FACE); |
864 |
for (i = MAXLIGHTS; i--; ) |
865 |
glDisable(glightid[i]); |
866 |
glEnable(GL_LIGHTING); |
867 |
rgl_checkerr("setting rendering modes in dobj_render"); |
868 |
/* render each object */ |
869 |
870 |
871 |
continue; |
872 |
/* set up lighting */ |
873 |
if (op->drawcode == DO_LIGHT && op->ol != NULL) { |
874 |
BYTE pval; |
875 |
double expval, d; |
876 |
/* use computed sources */ |
877 |
if (tmMapPixels(&pval, &op->ol->larb, TM_NOCHROM, 1) |
878 |
!= TM_E_OK) |
879 |
error(CONSISTENCY, "dobj_render w/o tone map"); |
880 |
expval = pval * (WHTEFFICACY/256.) / |
881 |
tmLuminance(op->ol->larb); |
882 |
vec[0] = expval * colval(op->ol->lamb,RED); |
883 |
vec[1] = expval * colval(op->ol->lamb,GRN); |
884 |
vec[2] = expval * colval(op->ol->lamb,BLU); |
885 |
vec[3] = 1.; |
886 |
glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec); |
887 |
for (i = op->ol->nl; i--; ) { |
888 |
VCOPY(vec, op->ol->li[i].direc); |
889 |
vec[3] = 0.; |
890 |
glLightfv(glightid[i], GL_POSITION, vec); |
891 |
d = expval * op->ol->li[i].omega; |
892 |
vec[0] = d * colval(op->ol->li[i].val,RED); |
893 |
vec[1] = d * colval(op->ol->li[i].val,GRN); |
894 |
vec[2] = d * colval(op->ol->li[i].val,BLU); |
895 |
vec[3] = 1.; |
896 |
glLightfv(glightid[i], GL_SPECULAR, vec); |
897 |
glLightfv(glightid[i], GL_DIFFUSE, vec); |
898 |
vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.; |
899 |
glLightfv(glightid[i], GL_AMBIENT, vec); |
900 |
glEnable(glightid[i]); |
901 |
902 |
} else { /* fake lighting */ |
903 |
904 |
905 |
getdcent(v1, op); |
906 |
VSUB(v1, odev.v.vp, v1); |
907 |
if (normalize(v1) <= getdrad(op)) { |
908 |
vec[0] = -odev.v.vdir[0]; |
909 |
vec[1] = -odev.v.vdir[1]; |
910 |
vec[2] = -odev.v.vdir[2]; |
911 |
} else |
912 |
VCOPY(vec, v1); |
913 |
vec[3] = 0.; |
914 |
glLightfv(GL_LIGHT0, GL_POSITION, vec); |
915 |
vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.; |
916 |
glLightfv(GL_LIGHT0, GL_SPECULAR, vec); |
917 |
glLightfv(GL_LIGHT0, GL_DIFFUSE, vec); |
918 |
vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.; |
919 |
glLightfv(GL_LIGHT0, GL_AMBIENT, vec); |
920 |
glEnable(GL_LIGHT0); |
921 |
922 |
/* set up object transform */ |
923 |
if (op->xfac) { |
924 |
if (!normalizing && op->xfb.f.sca < 1.-FTINY | |
925 |
op->xfb.f.sca > 1.+FTINY) |
926 |
glEnable(GL_NORMALIZE); |
927 |
glMatrixMode(GL_MODELVIEW); |
928 |
glPushMatrix(); |
929 |
/* matrix order works out to same */ |
930 |
#ifdef SMLFLT |
931 |
glMultMatrixf((GLfloat *)op->xfb.f.xfm); |
932 |
#else |
933 |
glMultMatrixd((GLdouble *)op->xfb.f.xfm); |
934 |
#endif |
935 |
936 |
/* render the display list */ |
937 |
glCallList(op->listid); |
938 |
/* restore matrix */ |
939 |
if (op->xfac) { |
940 |
941 |
glPopMatrix(); |
942 |
if (!normalizing) |
943 |
glDisable(GL_NORMALIZE); |
944 |
945 |
/* restore lighting */ |
946 |
if (op->drawcode == DO_LIGHT && op->ol != NULL) |
947 |
for (i = op->ol->nl; i--; ) |
948 |
949 |
else |
950 |
glDisable(GL_LIGHT0); |
951 |
/* check errors */ |
952 |
953 |
glPopAttrib(); /* restore rendering params */ |
954 |
rgl_checkerr("rendering objects in dobj_render"); |
955 |
return(1); |
956 |
