root/radiance/ray/src/hd/rhdobj.c
Revision: 3.3
Committed: Tue Aug 25 18:10:12 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.2: +24 -13 lines
minor improvements
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Routines for loading and displaying Radiance objects under OpenGL in rholo.
9 */
10
11 #include "radogl.h"
12 #include "tonemap.h"
13 #include "rhdisp.h"
14 #include "rhdriver.h"
15 #include "rhdobj.h"
16
17 extern FILE *sstdout; /* user standard output */
18
19 char rhdcmd[DO_NCMDS][8] = DO_INIT; /* user command list */
20
21 int (*dobj_lightsamp)() = NULL; /* pointer to function to get lights */
22
23 #define AVGREFL 0.5 /* assumed average reflectance */
24
25 #define MAXAC 64 /* maximum number of args */
26
27 #ifndef MINTHRESH
28 #define MINTHRESH 5.0 /* source threshold w.r.t. mean */
29 #endif
30
31 #ifndef NALT
32 #define NALT 11 /* # sampling altitude angles */
33 #endif
34 #ifndef NAZI
35 #define NAZI ((int)(PI/2.*NALT+.5))
36 #endif
37
38 typedef struct dlights {
39 struct dlights *next; /* next in lighting set list */
40 FVECT lcent; /* computed lighting center */
41 double ravg; /* harmonic mean free range radius */
42 TMbright larb; /* average reflected brightness */
43 COLOR lamb; /* local ambient value */
44 short nl; /* number of lights in this set */
45 struct lsource {
46 FVECT direc; /* source direction */
47 double omega; /* source solid angle */
48 COLOR val; /* source color */
49 } li[MAXLIGHTS]; /* light sources */
50 } DLIGHTS; /* a light source set */
51
52 typedef struct dobject {
53 struct dobject *next; /* next object in list */
54 char name[64]; /* object name */
55 FVECT center; /* orig. object center */
56 FLOAT radius; /* orig. object radius */
57 int listid; /* GL display list identifier */
58 int rtp[3]; /* associated rtrace process */
59 DLIGHTS *ol; /* object lights */
60 FULLXF xfb; /* coordinate transform */
61 short drawcode; /* drawing code */
62 short xfac; /* transform argument count */
63 char *xfav[MAXAC+1]; /* transform args */
64 } DOBJECT; /* a displayable object */
65
66 static DLIGHTS *dlightsets; /* lighting sets */
67 static DOBJECT *dobjects; /* display object list */
68 static DOBJECT *curobj; /* current (last referred) object */
69 static int lastxfac; /* last number of transform args */
70 static char *lastxfav[MAXAC+1]; /* saved transform arguments */
71
72 #define getdcent(c,op) multp3(c,(op)->center,(op)->xfb.f.xfm)
73 #define getdrad(op) ((op)->radius*(op)->xfb.f.sca)
74
75 #define RTARGC 8
76 static char *rtargv[RTARGC+1] = {"rtrace", "-h-", "-w-", "-fdd",
77 "-x", "1", "-oL"};
78
79 static struct {
80 int nsamp; /* number of ray samples */
81 COLOR val; /* value (sum) */
82 } ssamp[NALT][NAZI]; /* current sphere samples */
83
84 #define curname (curobj==NULL ? (char *)NULL : curobj->name)
85
86
87 static DOBJECT *
88 getdobj(nm) /* get object from list by name */
89 char *nm;
90 {
91 register DOBJECT *op;
92
93 if (nm == NULL)
94 return(NULL);
95 if (nm == curname)
96 return(curobj);
97 for (op = dobjects; op != NULL; op = op->next)
98 if (!strcmp(op->name, nm))
99 break;
100 return(op);
101 }
102
103
104 static
105 freedobj(op) /* free resources and memory assoc. with op */
106 register DOBJECT *op;
107 {
108 int foundlink = 0;
109 DOBJECT ohead;
110 register DOBJECT *opl;
111
112 if (op == NULL)
113 return(0);
114 ohead.next = dobjects;
115 for (opl = &ohead; opl->next != NULL; opl = opl->next) {
116 if (opl->next == op && (opl->next = op->next) == NULL)
117 break;
118 foundlink += opl->next->listid == op->listid;
119 }
120 dobjects = ohead.next;
121 if (!foundlink) {
122 glDeleteLists(op->listid, 1);
123 close_process(op->rtp);
124 }
125 while (op->xfac)
126 freestr(op->xfav[--op->xfac]);
127 free((char *)op);
128 return(1);
129 }
130
131
132 static
133 savedxf(op) /* save transform for display object */
134 register DOBJECT *op;
135 {
136 /* free old */
137 while (lastxfac)
138 freestr(lastxfav[--lastxfac]);
139 /* nothing to save? */
140 if (op == NULL) {
141 lastxfav[0] = NULL;
142 return(0);
143 }
144 /* else save new */
145 for (lastxfac = 0; lastxfac < op->xfac; lastxfac++)
146 lastxfav[lastxfac] = savestr(op->xfav[lastxfac]);
147 lastxfav[lastxfac] = NULL;
148 return(1);
149 }
150
151
152 static
153 ssph_sample(clr, direc, pos) /* add sample to current source sphere */
154 COLR clr;
155 FVECT direc, pos;
156 {
157 COLOR col;
158 double d;
159 register int alt, azi;
160
161 if (dlightsets == NULL)
162 return;
163 if (pos == NULL)
164 d = FHUGE; /* sample is at infinity */
165 else if ((d = (pos[0] - dlightsets->lcent[0])*direc[0] +
166 (pos[1] - dlightsets->lcent[1])*direc[1] +
167 (pos[2] - dlightsets->lcent[2])*direc[2]) > FTINY)
168 dlightsets->ravg += 1./d;
169 else
170 return; /* sample is behind us */
171 alt = NALT*(1.-FTINY)*(.5*(1.+FTINY) + direc[2]*.5);
172 azi = NAZI*(1.-FTINY)*(.5*(1.+FTINY) + .5/PI*atan2(direc[1],direc[0]));
173 colr_color(col, clr);
174 addcolor(ssamp[alt][azi].val, col);
175 ssamp[alt][azi].nsamp++;
176 }
177
178
179 static
180 ssph_direc(direc, alt, azi) /* compute sphere sampling direction */
181 FVECT direc;
182 int alt, azi;
183 {
184 double phi, d;
185
186 direc[2] = 2./NALT*(alt+.5) - 1.;
187 d = sqrt(1. - direc[2]*direc[2]);
188 phi = 2.*PI/NAZI*(azi+.5) - PI;
189 direc[0] = d*cos(phi);
190 direc[1] = d*sin(phi);
191 }
192
193
194 static int
195 ssph_neigh(sp, next) /* neighbor counter on sphere */
196 register int sp[2];
197 int next;
198 {
199 static short nneigh = 0; /* neighbor count */
200 static short neighlist[NAZI+6][2]; /* neighbor list (0 is home) */
201 register int i;
202
203 if (next) {
204 if (nneigh <= 0)
205 return(0);
206 sp[0] = neighlist[--nneigh][0];
207 sp[1] = neighlist[nneigh][1];
208 return(1);
209 }
210 if (sp[0] < 0 | sp[0] >= NALT | sp[1] < 0 | sp[1] >= NAZI)
211 return(nneigh=0);
212 neighlist[0][0] = sp[0]; neighlist[0][1] = sp[1];
213 nneigh = 1;
214 if (sp[0] == 0) {
215 neighlist[nneigh][0] = 1;
216 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
217 neighlist[nneigh][0] = 1;
218 neighlist[nneigh++][1] = sp[1];
219 neighlist[nneigh][0] = 1;
220 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
221 for (i = 0; i < NAZI; i++)
222 if (i != sp[1]) {
223 neighlist[nneigh][0] = 0;
224 neighlist[nneigh++][1] = i;
225 }
226 } else if (sp[0] == NALT-1) {
227 neighlist[nneigh][0] = NALT-2;
228 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
229 neighlist[nneigh][0] = NALT-2;
230 neighlist[nneigh++][1] = sp[1];
231 neighlist[nneigh][0] = NALT-2;
232 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
233 for (i = 0; i < NAZI; i++)
234 if (i != sp[1]) {
235 neighlist[nneigh][0] = NALT-1;
236 neighlist[nneigh++][1] = i;
237 }
238 } else {
239 neighlist[nneigh][0] = sp[0]-1;
240 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
241 neighlist[nneigh][0] = sp[0]-1;
242 neighlist[nneigh++][1] = sp[1];
243 neighlist[nneigh][0] = sp[0]-1;
244 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
245 neighlist[nneigh][0] = sp[0];
246 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
247 neighlist[nneigh][0] = sp[0];
248 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
249 neighlist[nneigh][0] = sp[0]+1;
250 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
251 neighlist[nneigh][0] = sp[0]+1;
252 neighlist[nneigh++][1] = sp[1];
253 neighlist[nneigh][0] = sp[0]+1;
254 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
255 }
256 return(nneigh);
257 }
258
259
260 static
261 ssph_compute() /* compute source set from sphere samples */
262 {
263 int ncells, nsamps;
264 COLOR csum;
265 FVECT v;
266 double d, thresh, maxbr;
267 int maxalt, maxazi, spos[2];
268 register int alt, azi;
269 register struct lsource *ls;
270 /* count & average sampled cells */
271 setcolor(csum, 0., 0., 0.);
272 ncells = nsamps = 0;
273 for (alt = 0; alt < NALT; alt++)
274 for (azi = 0; azi < NAZI; azi++)
275 if (ssamp[alt][azi].nsamp) {
276 if (ssamp[alt][azi].nsamp > 1) {
277 d = 1.0/ssamp[alt][azi].nsamp;
278 scalecolor(ssamp[alt][azi].val, d);
279 }
280 addcolor(csum, ssamp[alt][azi].val);
281 nsamps += ssamp[alt][azi].nsamp;
282 ncells++;
283 }
284 if (dlightsets == NULL | ncells < NALT*NAZI/4) {
285 ncells = 0;
286 goto done;
287 }
288 /* harmonic mean distance */
289 if (dlightsets->ravg > FTINY)
290 dlightsets->ravg = nsamps / dlightsets->ravg;
291 else
292 dlightsets->ravg = FHUGE;
293 /* light source threshold */
294 thresh = MINTHRESH*bright(csum)/ncells;
295 if (thresh <= FTINY) {
296 ncells = 0;
297 goto done;
298 }
299 /* avg. reflected brightness */
300 d = AVGREFL / (double)ncells;
301 scalecolor(csum, d);
302 if (tmCvColors(&dlightsets->larb, TM_NOCHROM, csum, 1) != TM_E_OK)
303 error(CONSISTENCY, "tone mapping problem in ssph_compute");
304 /* greedy light source clustering */
305 while (dlightsets->nl < MAXLIGHTS) {
306 maxbr = 0.; /* find brightest cell */
307 for (alt = 0; alt < NALT; alt++)
308 for (azi = 0; azi < NAZI; azi++)
309 if ((d = bright(ssamp[alt][azi].val)) > maxbr) {
310 maxalt = alt; maxazi = azi;
311 maxbr = d;
312 }
313 if (maxbr < thresh) /* below threshold? */
314 break;
315 ls = dlightsets->li + dlightsets->nl++;
316 spos[0] = maxalt; spos[1] = maxazi; /* cluster */
317 for (ssph_neigh(spos, 0); ssph_neigh(spos, 1); ) {
318 alt = spos[0]; azi = spos[1];
319 if ((d = bright(ssamp[alt][azi].val)) < .75*thresh)
320 continue; /* too dim */
321 ssph_direc(v, alt, azi); /* else add it in */
322 VSUM(ls->direc, ls->direc, v, d);
323 ls->omega++;
324 addcolor(ls->val, ssamp[alt][azi].val);
325 setcolor(ssamp[alt][azi].val, 0., 0., 0.);
326 }
327 d = 1./ls->omega; /* avg. brightness */
328 scalecolor(ls->val, d);
329 ls->omega *= 4.*PI/(NALT*NAZI); /* solid angle */
330 normalize(ls->direc); /* direction */
331 }
332 /* compute ambient remainder */
333 for (alt = 0; alt < NALT; alt++)
334 for (azi = 0; azi < NAZI; azi++)
335 if (ssamp[alt][azi].nsamp)
336 addcolor(dlightsets->lamb, ssamp[alt][azi].val);
337 d = 1.0/ncells;
338 scalecolor(dlightsets->lamb, d);
339 done: /* clear sphere sample array */
340 bzero((char *)ssamp, sizeof(ssamp));
341 return(ncells);
342 }
343
344
345 static
346 getdlights(op, force) /* get lights for display object */
347 register DOBJECT *op;
348 int force;
349 {
350 double d2, mind2 = FHUGE*FHUGE;
351 FVECT ocent;
352 VIEW cvw;
353 register DLIGHTS *dl;
354
355 op->ol = NULL;
356 if (op->drawcode != DO_LIGHT)
357 return(0);
358 /* check for usable light set */
359 getdcent(ocent, op);
360 for (dl = dlightsets; dl != NULL; dl = dl->next)
361 if ((d2 = dist2(dl->lcent, ocent)) < mind2) {
362 op->ol = dl;
363 mind2 = d2;
364 }
365 /* the following is heuristic */
366 d2 = 2.*getdrad(op); d2 *= d2;
367 if ((dl = op->ol) != NULL && (mind2 < 0.0625*dl->ravg*dl->ravg ||
368 mind2 < 4.*getdrad(op)*getdrad(op)))
369 return(1);
370 if (!force)
371 return(0);
372 /* need to compute new light set */
373 copystruct(&cvw, &stdview);
374 cvw.type = VT_PER;
375 VCOPY(cvw.vp, ocent);
376 cvw.vup[0] = 1.; cvw.vup[1] = cvw.vup[2] = 0.;
377 cvw.horiz = 90; cvw.vert = 90.;
378 beam_init(1); /* query beams through center */
379 cvw.vdir[0] = cvw.vdir[1] = 0.; cvw.vdir[2] = 1.;
380 setview(&cvw); beam_view(&cvw, 0, 0);
381 cvw.vdir[0] = cvw.vdir[1] = 0.; cvw.vdir[2] = -1.;
382 setview(&cvw); beam_view(&cvw, 0, 0);
383 cvw.vup[0] = cvw.vup[1] = 0.; cvw.vup[2] = 1.;
384 cvw.vdir[0] = cvw.vdir[2] = 0.; cvw.vdir[1] = 1.;
385 setview(&cvw); beam_view(&cvw, 0, 0);
386 cvw.vdir[0] = cvw.vdir[2] = 0.; cvw.vdir[1] = -1.;
387 setview(&cvw); beam_view(&cvw, 0, 0);
388 cvw.vdir[1] = cvw.vdir[2] = 0.; cvw.vdir[0] = 1.;
389 setview(&cvw); beam_view(&cvw, 0, 0);
390 cvw.vdir[1] = cvw.vdir[2] = 0.; cvw.vdir[0] = -1.;
391 setview(&cvw); beam_view(&cvw, 0, 0);
392 /* allocate new light set */
393 dl = (DLIGHTS *)calloc(1, sizeof(DLIGHTS));
394 if (dl == NULL)
395 goto memerr;
396 VCOPY(dl->lcent, ocent);
397 /* push onto our light set list */
398 dl->next = dlightsets;
399 dlightsets = dl;
400 dobj_lightsamp = ssph_sample; /* get beams from server */
401 imm_mode = beam_sync(-1) > 0;
402 while (imm_mode)
403 if (serv_result() == DS_SHUTDOWN)
404 quit(0);
405 if (!ssph_compute()) { /* compute light sources from sphere */
406 dlightsets = dl->next;
407 free((char *)dl);
408 return(0);
409 }
410 op->ol = dl;
411 return(1);
412 memerr:
413 error(SYSTEM, "out of memory in getdlights");
414 }
415
416
417 static int
418 cmderror(cn, err) /* report command error */
419 int cn;
420 char *err;
421 {
422 sprintf(errmsg, "%s: %s", rhdcmd[cn], err);
423 error(COMMAND, errmsg);
424 return(cn);
425 }
426
427
428 int
429 dobj_command(cmd, args) /* run object display command */
430 char *cmd;
431 register char *args;
432 {
433 int cn, na, doxfm;
434 register int nn;
435 char *alist[MAXAC+1], *nm;
436 /* find command */
437 for (cn = 0; cn < DO_NCMDS; cn++)
438 if (!strcmp(cmd, rhdcmd[cn]))
439 break;
440 if (cn >= DO_NCMDS)
441 return(-1); /* not in our list */
442 /* make argument list */
443 for (na = 0; *args; na++) {
444 if (na > MAXAC)
445 goto toomany;
446 alist[na] = args;
447 while (*args && !isspace(*args))
448 args++;
449 while (isspace(*args))
450 *args++ = '\0';
451 }
452 alist[na] = NULL;
453 /* execute command */
454 switch (cn) {
455 case DO_LOAD: /* load an octree */
456 if (na == 1)
457 dobj_load(alist[0], alist[0]);
458 else if (na == 2)
459 dobj_load(alist[0], alist[1]);
460 else
461 return(cmderror(cn, "need octree [name]"));
462 break;
463 case DO_UNLOAD: /* unload an object */
464 if (na > 1) goto toomany;
465 if (na && alist[0][0] == '*')
466 dobj_cleanup();
467 else
468 dobj_unload(na ? alist[0] : curname);
469 break;
470 case DO_XFORM: /* transform object */
471 case DO_MOVE:
472 if (na && alist[0][0] != '-') {
473 nm = alist[0]; nn = 1;
474 } else {
475 nm = curname; nn = 0;
476 }
477 if (cn == DO_MOVE && nn >= na)
478 return(cmderror(cn, "missing transform"));
479 dobj_xform(nm, cn==DO_MOVE, na-nn, alist+nn);
480 break;
481 case DO_UNMOVE: /* undo last transform */
482 dobj_unmove();
483 break;
484 case DO_OBJECT: /* print object statistics */
485 if (dobj_putstats(na ? alist[0] : curname, sstdout))
486 if (na && alist[0][0] != '*' &&
487 strcmp(alist[0], curname))
488 savedxf(curobj = getdobj(alist[0]));
489 break;
490 case DO_DUP: /* duplicate object */
491 for (nn = 0; nn < na; nn++)
492 if (alist[nn][0] == '-')
493 break;
494 switch (nn) {
495 case 0:
496 return(cmderror(cn, "need new object name"));
497 case 1:
498 nm = curname;
499 break;
500 case 2:
501 nm = alist[0];
502 break;
503 default:
504 goto toomany;
505 }
506 if (!dobj_dup(nm, alist[nn-1]))
507 break;
508 if (na > nn)
509 dobj_xform(curname, 1, na-nn, alist+nn);
510 else
511 curobj->drawcode = DO_HIDE;
512 savedxf(curobj);
513 break;
514 case DO_SHOW: /* change rendering option */
515 case DO_LIGHT:
516 case DO_HIDE:
517 if (na > 1) goto toomany;
518 dobj_lighting(na ? alist[0] : curname, cn);
519 break;
520 default:
521 error(CONSISTENCY, "bad command id in dobj_command");
522 }
523 dev_view(&odev.v); /* redraw */
524 return(cn);
525 toomany:
526 return(cmderror(cn, "too many arguments"));
527 }
528
529
530 dobj_load(oct, nam) /* create/load an octree object */
531 char *oct, *nam;
532 {
533 extern char *getlibpath(), *getpath();
534 char *fpp, fpath[128];
535 register DOBJECT *op;
536 /* check arguments */
537 if (oct == NULL) {
538 error(COMMAND, "missing octree");
539 return(0);
540 }
541 if (nam == NULL) {
542 error(COMMAND, "missing name");
543 return(0);
544 }
545 if (*nam == '*' | *nam == '-') {
546 error(COMMAND, "illegal name");
547 return(0);
548 }
549 if (getdobj(nam) != NULL) {
550 error(COMMAND, "name already taken (unload first)");
551 return(0);
552 }
553 /* get octree path */
554 if ((fpp = getpath(oct, getlibpath(), R_OK)) == NULL) {
555 sprintf(errmsg, "cannot find octree \"%s\"", oct);
556 error(COMMAND, errmsg);
557 return(0);
558 }
559 strcpy(fpath, fpp);
560 op = (DOBJECT *)malloc(sizeof(DOBJECT));
561 if (op == NULL)
562 error(SYSTEM, "out of memory in dobj_load");
563 /* set struct fields */
564 strcpy(op->name, nam);
565 op->ol = NULL;
566 op->drawcode = DO_HIDE;
567 setident4(op->xfb.f.xfm); op->xfb.f.sca = 1.;
568 setident4(op->xfb.b.xfm); op->xfb.b.sca = 1.;
569 op->xfav[op->xfac=0] = NULL;
570 /* load octree into display list */
571 dolights = 0;
572 op->listid = rgl_octlist(fpath, op->center, &op->radius);
573 /* start rtrace */
574 rtargv[RTARGC-1] = fpath;
575 rtargv[RTARGC] = NULL;
576 open_process(op->rtp, rtargv);
577 /* insert into main list */
578 op->next = dobjects;
579 curobj = dobjects = op;
580 savedxf(NULL);
581 return(1);
582 }
583
584
585 dobj_unload(nam) /* free the named object */
586 char *nam;
587 {
588 register DOBJECT *op;
589
590 if ((op = getdobj(nam)) == NULL) {
591 error(COMMAND, "no object");
592 return(0);
593 }
594 freedobj(op);
595 savedxf(curobj = NULL);
596 return(1);
597 }
598
599
600 dobj_cleanup() /* free all resources */
601 {
602 register DLIGHTS *lp;
603
604 while (dobjects != NULL)
605 freedobj(dobjects);
606 savedxf(curobj = NULL);
607 while ((lp = dlightsets) != NULL) {
608 dlightsets = lp->next;
609 free((char *)lp);
610 }
611 return(1);
612 }
613
614
615 dobj_xform(nam, add, ac, av) /* set/add transform for nam */
616 char *nam;
617 int add, ac;
618 char **av;
619 {
620 register DOBJECT *op;
621
622 if ((op = getdobj(nam)) == NULL) {
623 error(COMMAND, "no object");
624 return(0);
625 }
626 if (add) add = op->xfac;
627 if (ac + add > MAXAC) {
628 error(COMMAND, "too many transform arguments");
629 return(0);
630 }
631 savedxf(curobj = op);
632 if (!add)
633 while (op->xfac)
634 freestr(op->xfav[--op->xfac]);
635 while (ac--)
636 op->xfav[op->xfac++] = savestr(*av++);
637 op->xfav[op->xfac] = NULL;
638 if (fullxf(&op->xfb, op->xfac, op->xfav) != op->xfac) {
639 error(COMMAND, "bad transform arguments");
640 dobj_unmove();
641 savedxf(op); /* save current transform instead */
642 return(0);
643 }
644 /* don't know local lights anymore */
645 getdlights(op, 0);
646 return(1);
647 }
648
649
650 dobj_putstats(nam, fp) /* put out statistics for nam */
651 char *nam;
652 FILE *fp;
653 {
654 FVECT ocent;
655 register DOBJECT *op;
656 register int i;
657
658 if (nam == NULL) {
659 error(COMMAND, "no current object");
660 return(0);
661 }
662 if (nam[0] == '*') {
663 i = 0;
664 for (op = dobjects; op != NULL; op = op->next)
665 i += dobj_putstats(op->name, fp);
666 return(i);
667 }
668 if ((op = getdobj(nam)) == NULL) {
669 error(COMMAND, "unknown object");
670 return(0);
671 }
672 getdcent(ocent, op);
673 fprintf(fp, "%s: %s, center [%f %f %f], radius %f", op->name,
674 op->drawcode==DO_HIDE ? "hidden" :
675 op->drawcode==DO_LIGHT && op->ol!=NULL ? "lighted" :
676 "shown",
677 ocent[0],ocent[1],ocent[2], getdrad(op));
678 if (op->xfac)
679 fputs(", (xform", fp);
680 for (i = 0; i < op->xfac; i++) {
681 putc(' ', fp);
682 fputs(op->xfav[i], fp);
683 }
684 if (op->xfac)
685 fputc(')', fp);
686 fputc('\n', fp);
687 return(1);
688 }
689
690
691 dobj_unmove() /* undo last transform change */
692 {
693 int txfac;
694 char *txfav[MAXAC+1];
695
696 if (curobj == NULL) {
697 error(COMMAND, "no current object");
698 return(0);
699 }
700 /* hold last transform */
701 bcopy((char *)lastxfav, (char *)txfav,
702 (txfac=lastxfac)*sizeof(char *));
703 /* save this transform */
704 bcopy((char *)curobj->xfav, (char *)lastxfav,
705 (lastxfac=curobj->xfac)*sizeof(char *));
706 /* copy back last transform */
707 bcopy((char *)txfav, (char *)curobj->xfav,
708 (curobj->xfac=txfac)*sizeof(char *));
709 /* set matrices */
710 fullxf(&curobj->xfb, curobj->xfac, curobj->xfav);
711 /* don't know local lights anymore */
712 getdlights(curobj, 0);
713 return(1);
714 }
715
716
717 dobj_dup(oldnm, nam) /* duplicate object oldnm as nam */
718 char *oldnm, *nam;
719 {
720 register DOBJECT *op, *opdup;
721 /* check arguments */
722 if ((op = getdobj(oldnm)) == NULL) {
723 error(COMMAND, "no object");
724 return(0);
725 }
726 if (nam == NULL) {
727 error(COMMAND, "missing name");
728 return(0);
729 }
730 if (*nam == '*' | *nam == '-') {
731 error(COMMAND, "illegal name");
732 return(0);
733 }
734 if (getdobj(nam) != NULL) {
735 error(COMMAND, "name already taken (unload first)");
736 return(0);
737 }
738 /* allocate and copy struct */
739 opdup = (DOBJECT *)malloc(sizeof(DOBJECT));
740 if (opdup == NULL)
741 error(SYSTEM, "out of memory in dobj_dup");
742 copystruct(opdup, op);
743 /* rename */
744 strcpy(opdup->name, nam);
745 /* get our own copy of transform */
746 for (opdup->xfac = 0; opdup->xfac < op->xfac; opdup->xfac++)
747 opdup->xfav[opdup->xfac] = savestr(op->xfav[opdup->xfac]);
748 opdup->xfav[opdup->xfac] = NULL;
749 /* insert it into our list */
750 opdup->next = dobjects;
751 curobj = dobjects = opdup;
752 return(1);
753 }
754
755
756 dobj_lighting(nam, cn) /* set up lighting for display object */
757 char *nam;
758 int cn;
759 {
760 int i, res[2];
761 VIEW *dv;
762 register DOBJECT *op;
763
764 if (nam == NULL) {
765 error(COMMAND, "no current object");
766 return(0);
767 }
768 if (nam[0] == '*') {
769 for (op = dobjects; op != NULL; op = op->next)
770 if ((op->drawcode = cn) == DO_LIGHT)
771 getdlights(op, 1);
772 else
773 op->ol = NULL;
774 } else if ((op = getdobj(nam)) == NULL) {
775 error(COMMAND, "unknown object");
776 return(0);
777 } else if ((op->drawcode = cn) == DO_LIGHT)
778 getdlights(op, 1);
779 else
780 op->ol = NULL;
781
782 if (dobj_lightsamp != NULL) { /* restore beam set */
783 dobj_lightsamp = NULL;
784 beam_init(1);
785 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
786 beam_view(dv, res[0], res[1]);
787 beam_sync(1); /* update server */
788 }
789 }
790
791
792 double
793 dobj_trace(nm, rorg, rdir) /* check for ray intersection with object(s) */
794 char nm[];
795 FVECT rorg, rdir;
796 {
797 register DOBJECT *op;
798 FVECT xorg, xdir;
799 double darr[6];
800 /* check each visible object? */
801 if (nm == NULL || *nm == '*') {
802 double dist, mindist = 1.01*FHUGE;
803
804 if (nm != NULL) nm[0] = '\0';
805 for (op = dobjects; op != NULL; op = op->next) {
806 if (op->drawcode == DO_HIDE)
807 continue;
808 dist = dobj_trace(op->name, rorg, rdir);
809 if (dist < mindist) {
810 if (nm != NULL) strcpy(nm, op->name);
811 mindist = dist;
812 }
813 }
814 return(mindist);
815 }
816 /* else check particular object */
817 if ((op = getdobj(nm)) == NULL) {
818 error(COMMAND, "unknown object");
819 return(FHUGE);
820 }
821 if (op->xfac) { /* put ray in local coordinates */
822 multp3(xorg, rorg, op->xfb.b.xfm);
823 multv3(xdir, rdir, op->xfb.b.xfm);
824 VCOPY(darr, xorg); VCOPY(darr+3, xdir);
825 } else {
826 VCOPY(darr, rorg); VCOPY(darr+3, rdir);
827 }
828 /* trace it */
829 if (process(op->rtp, darr, darr, sizeof(double),
830 6*sizeof(double)) != sizeof(double))
831 error(SYSTEM, "rtrace communication error");
832 /* return distance */
833 if (darr[0] >= .99*FHUGE)
834 return(FHUGE);
835 return(darr[0]*op->xfb.f.sca);
836 }
837
838
839 dobj_render() /* render our objects in OpenGL */
840 {
841 GLboolean normalizing;
842 GLfloat vec[4];
843 FVECT v1;
844 register DOBJECT *op;
845 register int i;
846 /* anything to render? */
847 for (op = dobjects; op != NULL; op = op->next)
848 if (op->drawcode != DO_HIDE)
849 break;
850 if (op == NULL)
851 return(1);
852 /* set up general rendering params */
853 glGetBooleanv(GL_NORMALIZE, &normalizing);
854 glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT|
855 GL_DEPTH_BUFFER_BIT|GL_POLYGON_BIT);
856 glDepthFunc(GL_LESS);
857 glEnable(GL_DEPTH_TEST);
858 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
859 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
860 glShadeModel(GL_SMOOTH);
861 glFrontFace(GL_CCW);
862 glDisable(GL_CULL_FACE);
863 for (i = MAXLIGHTS; i--; )
864 glDisable(glightid[i]);
865 glEnable(GL_LIGHTING);
866 rgl_checkerr("setting rendering modes in dobj_render");
867 /* render each object */
868 for (op = dobjects; op != NULL; op = op->next) {
869 if (op->drawcode == DO_HIDE)
870 continue;
871 /* set up lighting */
872 if (op->drawcode == DO_LIGHT && op->ol != NULL) {
873 BYTE pval;
874 double expval, d;
875 /* use computed sources */
876 if (tmMapPixels(&pval, &op->ol->larb, TM_NOCHROM, 1)
877 != TM_E_OK)
878 error(CONSISTENCY, "dobj_render w/o tone map");
879 expval = pval * (WHTEFFICACY/256.) /
880 tmLuminance(op->ol->larb);
881 vec[0] = expval * colval(op->ol->lamb,RED);
882 vec[1] = expval * colval(op->ol->lamb,GRN);
883 vec[2] = expval * colval(op->ol->lamb,BLU);
884 vec[3] = 1.;
885 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
886 for (i = op->ol->nl; i--; ) {
887 VCOPY(vec, op->ol->li[i].direc);
888 vec[3] = 0.;
889 glLightfv(glightid[i], GL_POSITION, vec);
890 d = expval * op->ol->li[i].omega;
891 vec[0] = d * colval(op->ol->li[i].val,RED);
892 vec[1] = d * colval(op->ol->li[i].val,GRN);
893 vec[2] = d * colval(op->ol->li[i].val,BLU);
894 vec[3] = 1.;
895 glLightfv(glightid[i], GL_SPECULAR, vec);
896 glLightfv(glightid[i], GL_DIFFUSE, vec);
897 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
898 glLightfv(glightid[i], GL_AMBIENT, vec);
899 glEnable(glightid[i]);
900 }
901 } else { /* fake lighting */
902 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
903 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
904 getdcent(v1, op);
905 VSUB(v1, odev.v.vp, v1);
906 if (normalize(v1) <= getdrad(op)) {
907 vec[0] = -odev.v.vdir[0];
908 vec[1] = -odev.v.vdir[1];
909 vec[2] = -odev.v.vdir[2];
910 } else
911 VCOPY(vec, v1);
912 vec[3] = 0.;
913 glLightfv(GL_LIGHT0, GL_POSITION, vec);
914 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
915 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
916 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
917 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
918 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
919 glEnable(GL_LIGHT0);
920 }
921 /* set up object transform */
922 if (op->xfac) {
923 if (!normalizing && op->xfb.f.sca < 1.-FTINY |
924 op->xfb.f.sca > 1.+FTINY)
925 glEnable(GL_NORMALIZE);
926 glMatrixMode(GL_MODELVIEW);
927 glPushMatrix();
928 /* matrix order works out to same */
929 #ifdef SMLFLT
930 glMultMatrixf((GLfloat *)op->xfb.f.xfm);
931 #else
932 glMultMatrixd((GLdouble *)op->xfb.f.xfm);
933 #endif
934 }
935 /* render the display list */
936 glCallList(op->listid);
937 /* restore matrix */
938 if (op->xfac) {
939 glMatrixMode(GL_MODELVIEW);
940 glPopMatrix();
941 if (!normalizing)
942 glDisable(GL_NORMALIZE);
943 }
944 /* restore lighting */
945 if (op->drawcode == DO_LIGHT && op->ol != NULL)
946 for (i = op->ol->nl; i--; )
947 glDisable(glightid[i]);
948 else
949 glDisable(GL_LIGHT0);
950 /* check errors */
951 }
952 glPopAttrib(); /* restore rendering params */
953 rgl_checkerr("rendering objects in dobj_render");
954 return(1);
955 }
