--- ray/src/hd/rhdobj.c 1998/08/25 18:10:12 3.3 +++ ray/src/hd/rhdobj.c 1998/12/23 17:41:14 3.8 @@ -5,7 +5,7 @@ static char SCCSid[] = "$SunId$ SGI"; #endif /* - * Routines for loading and displaying Radiance objects under OpenGL in rholo. + * Routines for loading and displaying Radiance objects in rholo with GLX. */ #include "radogl.h" @@ -22,7 +22,7 @@ int (*dobj_lightsamp)() = NULL; /* pointer to function #define AVGREFL 0.5 /* assumed average reflectance */ -#define MAXAC 64 /* maximum number of args */ +#define MAXAC 512 /* maximum number of args */ #ifndef MINTHRESH #define MINTHRESH 5.0 /* source threshold w.r.t. mean */ @@ -320,9 +320,11 @@ ssph_compute() /* compute source set from sphere sam continue; /* too dim */ ssph_direc(v, alt, azi); /* else add it in */ VSUM(ls->direc, ls->direc, v, d); - ls->omega++; + ls->omega += 1.; addcolor(ls->val, ssamp[alt][azi].val); + /* remove from list */ setcolor(ssamp[alt][azi].val, 0., 0., 0.); + ssamp[alt][azi].nsamp = 0; } d = 1./ls->omega; /* avg. brightness */ scalecolor(ls->val, d); @@ -430,6 +432,8 @@ dobj_command(cmd, args) /* run object display command char *cmd; register char *args; { + int somechange = 0; + VIEW sameview; int cn, na, doxfm; register int nn; char *alist[MAXAC+1], *nm; @@ -460,12 +464,12 @@ register char *args; else return(cmderror(cn, "need octree [name]")); break; - case DO_UNLOAD: /* unload an object */ + case DO_UNLOAD: /* clear an object */ if (na > 1) goto toomany; if (na && alist[0][0] == '*') - dobj_cleanup(); + somechange += dobj_cleanup(); else - dobj_unload(na ? alist[0] : curname); + somechange += dobj_unload(na ? alist[0] : curname); break; case DO_XFORM: /* transform object */ case DO_MOVE: @@ -476,15 +480,15 @@ register char *args; } if (cn == DO_MOVE && nn >= na) return(cmderror(cn, "missing transform")); - dobj_xform(nm, cn==DO_MOVE, na-nn, alist+nn); + somechange += dobj_xform(nm, cn==DO_MOVE, na-nn, alist+nn); break; case DO_UNMOVE: /* undo last transform */ - dobj_unmove(); + somechange += dobj_unmove(); break; case DO_OBJECT: /* print object statistics */ if (dobj_putstats(na ? alist[0] : curname, sstdout)) - if (na && alist[0][0] != '*' && - strcmp(alist[0], curname)) + if (na && alist[0][0] != '*' && (curobj == NULL || + strcmp(alist[0], curobj->name))) savedxf(curobj = getdobj(alist[0])); break; case DO_DUP: /* duplicate object */ @@ -506,7 +510,7 @@ register char *args; if (!dobj_dup(nm, alist[nn-1])) break; if (na > nn) - dobj_xform(curname, 1, na-nn, alist+nn); + somechange += dobj_xform(curname, 1, na-nn, alist+nn); else curobj->drawcode = DO_HIDE; savedxf(curobj); @@ -516,11 +520,15 @@ register char *args; case DO_HIDE: if (na > 1) goto toomany; dobj_lighting(na ? alist[0] : curname, cn); + somechange++; break; default: error(CONSISTENCY, "bad command id in dobj_command"); } - dev_view(&odev.v); /* redraw */ + if (somechange) { + copystruct(&sameview, &odev.v); /* make 'em think new view */ + dev_view(&sameview); /* redraw */ + } return(cn); toomany: return(cmderror(cn, "too many arguments")); @@ -547,7 +555,7 @@ char *oct, *nam; return(0); } if (getdobj(nam) != NULL) { - error(COMMAND, "name already taken (unload first)"); + error(COMMAND, "name already taken (clear first)"); return(0); } /* get octree path */ @@ -569,6 +577,7 @@ char *oct, *nam; op->xfav[op->xfac=0] = NULL; /* load octree into display list */ dolights = 0; + domats = 1; op->listid = rgl_octlist(fpath, op->center, &op->radius); /* start rtrace */ rtargv[RTARGC-1] = fpath; @@ -612,28 +621,55 @@ dobj_cleanup() /* free all resources */ } -dobj_xform(nam, add, ac, av) /* set/add transform for nam */ +dobj_xform(nam, rel, ac, av) /* set/add transform for nam */ char *nam; -int add, ac; +int rel, ac; char **av; { register DOBJECT *op; + FVECT cent; + double rad; + char scoord[16]; + int i; if ((op = getdobj(nam)) == NULL) { error(COMMAND, "no object"); return(0); } - if (add) add = op->xfac; - if (ac + add > MAXAC) { + if (rel) + rel = op->xfac + 8; + if (ac + rel > MAXAC) { error(COMMAND, "too many transform arguments"); return(0); } - savedxf(curobj = op); - if (!add) + savedxf(curobj = op); /* remember current transform */ + if (rel && ac == 4 && !strcmp(av[0], "-t")) + rel = -1; /* don't move for translate */ + else { + getdcent(cent, op); /* don't move if near orig. */ + rad = getdrad(op); + if (DOT(cent,cent) < rad*rad) + rel = -1; + } + if (!rel) { /* remove old transform */ while (op->xfac) freestr(op->xfav[--op->xfac]); + } else if (rel > 0) { /* relative move */ + op->xfav[op->xfac++] = savestr("-t"); + for (i = 0; i < 3; i++) { + sprintf(scoord, "%.4e", -cent[i]); + op->xfav[op->xfac++] = savestr(scoord); + } + } while (ac--) op->xfav[op->xfac++] = savestr(*av++); + if (rel > 0) { /* move back */ + op->xfav[op->xfac++] = savestr("-t"); + for (i = 0; i < 3; i++) { + sprintf(scoord, "%.4e", cent[i]); + op->xfav[op->xfac++] = savestr(scoord); + } + } op->xfav[op->xfac] = NULL; if (fullxf(&op->xfb, op->xfac, op->xfav) != op->xfac) { error(COMMAND, "bad transform arguments"); @@ -670,7 +706,7 @@ FILE *fp; return(0); } getdcent(ocent, op); - fprintf(fp, "%s: %s, center [%f %f %f], radius %f", op->name, + fprintf(fp, "%s: %s, center [%g %g %g], radius %g", op->name, op->drawcode==DO_HIDE ? "hidden" : op->drawcode==DO_LIGHT && op->ol!=NULL ? "lighted" : "shown", @@ -732,7 +768,7 @@ char *oldnm, *nam; return(0); } if (getdobj(nam) != NULL) { - error(COMMAND, "name already taken (unload first)"); + error(COMMAND, "name already taken (clear first)"); return(0); } /* allocate and copy struct */ @@ -774,9 +810,10 @@ int cn; } else if ((op = getdobj(nam)) == NULL) { error(COMMAND, "unknown object"); return(0); - } else if ((op->drawcode = cn) == DO_LIGHT) - getdlights(op, 1); - else + } else if ((op->drawcode = cn) == DO_LIGHT) { + if (!getdlights(op, 1)) + error(COMMAND, "insufficient samples to light object"); + } else op->ol = NULL; if (dobj_lightsamp != NULL) { /* restore beam set */ @@ -836,8 +873,10 @@ FVECT rorg, rdir; } +int dobj_render() /* render our objects in OpenGL */ { + int nrendered = 0; GLboolean normalizing; GLfloat vec[4]; FVECT v1; @@ -848,11 +887,11 @@ dobj_render() /* render our objects in OpenGL */ if (op->drawcode != DO_HIDE) break; if (op == NULL) - return(1); + return(0); /* set up general rendering params */ glGetBooleanv(GL_NORMALIZE, &normalizing); - glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT| - GL_DEPTH_BUFFER_BIT|GL_POLYGON_BIT); + glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT|GL_ENABLE_BIT| + GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT|GL_POLYGON_BIT); glDepthFunc(GL_LESS); glEnable(GL_DEPTH_TEST); glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE); @@ -934,6 +973,7 @@ dobj_render() /* render our objects in OpenGL */ } /* render the display list */ glCallList(op->listid); + nrendered++; /* restore matrix */ if (op->xfac) { glMatrixMode(GL_MODELVIEW); @@ -951,5 +991,5 @@ dobj_render() /* render our objects in OpenGL */ } glPopAttrib(); /* restore rendering params */ rgl_checkerr("rendering objects in dobj_render"); - return(1); + return(nrendered); }
