--- ray/src/hd/rhdobj.c 1998/08/27 19:32:43 3.5 +++ ray/src/hd/rhdobj.c 1998/12/18 11:06:45 3.7 @@ -22,7 +22,7 @@ int (*dobj_lightsamp)() = NULL; /* pointer to function #define AVGREFL 0.5 /* assumed average reflectance */ -#define MAXAC 64 /* maximum number of args */ +#define MAXAC 512 /* maximum number of args */ #ifndef MINTHRESH #define MINTHRESH 5.0 /* source threshold w.r.t. mean */ @@ -320,9 +320,11 @@ ssph_compute() /* compute source set from sphere sam continue; /* too dim */ ssph_direc(v, alt, azi); /* else add it in */ VSUM(ls->direc, ls->direc, v, d); - ls->omega++; + ls->omega += 1.; addcolor(ls->val, ssamp[alt][azi].val); + /* remove from list */ setcolor(ssamp[alt][azi].val, 0., 0., 0.); + ssamp[alt][azi].nsamp = 0; } d = 1./ls->omega; /* avg. brightness */ scalecolor(ls->val, d); @@ -612,28 +614,55 @@ dobj_cleanup() /* free all resources */ } -dobj_xform(nam, add, ac, av) /* set/add transform for nam */ +dobj_xform(nam, rel, ac, av) /* set/add transform for nam */ char *nam; -int add, ac; +int rel, ac; char **av; { register DOBJECT *op; + FVECT cent; + double rad; + char scoord[16]; + int i; if ((op = getdobj(nam)) == NULL) { error(COMMAND, "no object"); return(0); } - if (add) add = op->xfac; - if (ac + add > MAXAC) { + if (rel) + rel = op->xfac + 8; + if (ac + rel > MAXAC) { error(COMMAND, "too many transform arguments"); return(0); } - savedxf(curobj = op); - if (!add) + savedxf(curobj = op); /* remember current transform */ + if (rel && ac == 4 && !strcmp(av[0], "-t")) + rel = -1; /* don't move for translate */ + else { + getdcent(cent, op); /* don't move if near orig. */ + rad = getdrad(op); + if (DOT(cent,cent) < rad*rad) + rel = -1; + } + if (!rel) { /* remove old transform */ while (op->xfac) freestr(op->xfav[--op->xfac]); + } else if (rel > 0) { /* relative move */ + op->xfav[op->xfac++] = savestr("-t"); + for (i = 0; i < 3; i++) { + sprintf(scoord, "%.4e", -cent[i]); + op->xfav[op->xfac++] = savestr(scoord); + } + } while (ac--) op->xfav[op->xfac++] = savestr(*av++); + if (rel > 0) { /* move back */ + op->xfav[op->xfac++] = savestr("-t"); + for (i = 0; i < 3; i++) { + sprintf(scoord, "%.4e", cent[i]); + op->xfav[op->xfac++] = savestr(scoord); + } + } op->xfav[op->xfac] = NULL; if (fullxf(&op->xfb, op->xfac, op->xfav) != op->xfac) { error(COMMAND, "bad transform arguments"); @@ -670,7 +699,7 @@ FILE *fp; return(0); } getdcent(ocent, op); - fprintf(fp, "%s: %s, center [%f %f %f], radius %f", op->name, + fprintf(fp, "%s: %s, center [%g %g %g], radius %g", op->name, op->drawcode==DO_HIDE ? "hidden" : op->drawcode==DO_LIGHT && op->ol!=NULL ? "lighted" : "shown", @@ -837,8 +866,10 @@ FVECT rorg, rdir; } +int dobj_render() /* render our objects in OpenGL */ { + int nrendered = 0; GLboolean normalizing; GLfloat vec[4]; FVECT v1; @@ -849,7 +880,7 @@ dobj_render() /* render our objects in OpenGL */ if (op->drawcode != DO_HIDE) break; if (op == NULL) - return(1); + return(0); /* set up general rendering params */ glGetBooleanv(GL_NORMALIZE, &normalizing); glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT|GL_ENABLE_BIT| @@ -935,6 +966,7 @@ dobj_render() /* render our objects in OpenGL */ } /* render the display list */ glCallList(op->listid); + nrendered++; /* restore matrix */ if (op->xfac) { glMatrixMode(GL_MODELVIEW); @@ -952,5 +984,5 @@ dobj_render() /* render our objects in OpenGL */ } glPopAttrib(); /* restore rendering params */ rgl_checkerr("rendering objects in dobj_render"); - return(1); + return(nrendered); }
