--- ray/src/hd/rhdobj.c 2003/07/21 22:30:18 3.15 +++ ray/src/hd/rhdobj.c 2004/03/30 20:40:04 3.17 @@ -1,11 +1,12 @@ #ifndef lint -static const char RCSid[] = "$Id: rhdobj.c,v 3.15 2003/07/21 22:30:18 schorsch Exp $"; +static const char RCSid[] = "$Id: rhdobj.c,v 3.17 2004/03/30 20:40:04 greg Exp $"; #endif /* * Routines for loading and displaying Radiance objects in rholo with GLX. */ #include +#include #include "radogl.h" #include "tonemap.h" @@ -18,7 +19,8 @@ extern FILE *sstdout; /* user standard output */ char rhdcmd[DO_NCMDS][8] = DO_INIT; /* user command list */ -int (*dobj_lightsamp)() = NULL; /* pointer to function to get lights */ +/* pointer to function to get lights */ +void (*dobj_lightsamp)(COLR clr, FVECT direc, FVECT pos) = NULL; #define AVGREFL 0.5 /* assumed average reflectance */ @@ -84,10 +86,21 @@ static struct { #define curname (curobj==NULL ? (char *)NULL : curobj->name) +static DOBJECT *getdobj(char *nm); +static int freedobj(DOBJECT *op); +static int savedxf(DOBJECT *op); +static void ssph_sample(COLR clr, FVECT direc, FVECT pos); +static void ssph_direc(FVECT direc, int alt, int azi); +static int ssph_neigh(int sp[2], int next); +static int ssph_compute(void); +static int getdlights(DOBJECT *op, int force); +static void cmderror(int cn, char *err); + static DOBJECT * -getdobj(nm) /* get object from list by name */ -char *nm; +getdobj( /* get object from list by name */ + char *nm +) { register DOBJECT *op; @@ -102,9 +115,10 @@ char *nm; } -static -freedobj(op) /* free resources and memory assoc. with op */ -register DOBJECT *op; +static int +freedobj( /* free resources and memory assoc. with op */ + register DOBJECT *op +) { int foundlink = 0; DOBJECT ohead; @@ -130,9 +144,10 @@ register DOBJECT *op; } -static -savedxf(op) /* save transform for display object */ -register DOBJECT *op; +static int +savedxf( /* save transform for display object */ + register DOBJECT *op +) { /* free old */ while (lastxfac) @@ -150,10 +165,12 @@ register DOBJECT *op; } -static -ssph_sample(clr, direc, pos) /* add sample to current source sphere */ -COLR clr; -FVECT direc, pos; +static void +ssph_sample( /* add sample to current source sphere */ + COLR clr, + FVECT direc, + FVECT pos +) { COLOR col; double d; @@ -177,10 +194,12 @@ FVECT direc, pos; } -static -ssph_direc(direc, alt, azi) /* compute sphere sampling direction */ -FVECT direc; -int alt, azi; +static void +ssph_direc( /* compute sphere sampling direction */ + FVECT direc, + int alt, + int azi +) { double phi, d; @@ -193,9 +212,10 @@ int alt, azi; static int -ssph_neigh(sp, next) /* neighbor counter on sphere */ -register int sp[2]; -int next; +ssph_neigh( /* neighbor counter on sphere */ + register int sp[2], + int next +) { static short nneigh = 0; /* neighbor count */ static short neighlist[NAZI+6][2]; /* neighbor list (0 is home) */ @@ -208,7 +228,7 @@ int next; sp[1] = neighlist[nneigh][1]; return(1); } - if (sp[0] < 0 | sp[0] >= NALT | sp[1] < 0 | sp[1] >= NAZI) + if ((sp[0] < 0) | (sp[0] >= NALT) | (sp[1] < 0) | (sp[1] >= NAZI)) return(nneigh=0); neighlist[0][0] = sp[0]; neighlist[0][1] = sp[1]; nneigh = 1; @@ -258,8 +278,8 @@ int next; } -static -ssph_compute() /* compute source set from sphere samples */ +static int +ssph_compute(void) /* compute source set from sphere samples */ { int ncells, nsamps; COLOR csum; @@ -282,7 +302,7 @@ ssph_compute() /* compute source set from sphere sam nsamps += ssamp[alt][azi].nsamp; ncells++; } - if (dlightsets == NULL | ncells < NALT*NAZI/4) { + if ((dlightsets == NULL) | (ncells < NALT*NAZI/4)) { ncells = 0; goto done; } @@ -345,10 +365,11 @@ done: /* clear sphere sample array */ } -static -getdlights(op, force) /* get lights for display object */ -register DOBJECT *op; -int force; +static int +getdlights( /* get lights for display object */ + register DOBJECT *op, + int force +) { double d2, mind2 = FHUGE*FHUGE; FVECT ocent; @@ -414,26 +435,29 @@ int force; return(1); memerr: error(SYSTEM, "out of memory in getdlights"); + return 0; /* pro forma return */ } -static -cmderror(cn, err) /* report command error */ -int cn; -char *err; +static void +cmderror( /* report command error */ + int cn, + char *err +) { sprintf(errmsg, "%s: %s", rhdcmd[cn], err); error(COMMAND, errmsg); } -int -dobj_command(cmd, args) /* run object display command */ -char *cmd; -register char *args; +extern int +dobj_command( /* run object display command */ + char *cmd, + register char *args +) { int somechange = 0; - int cn, na, doxfm; + int cn, na; register int nn; char *alist[MAXAC+1], *nm; /* find command */ @@ -531,12 +555,16 @@ register char *args; } return(somechange); toomany: - return(cmderror(cn, "too many arguments")); + cmderror(cn, "too many arguments"); + return(-1); } -dobj_load(oct, nam) /* create/load an octree object */ -char *oct, *nam; +extern int +dobj_load( /* create/load an octree object */ + char *oct, + char *nam +) { char *fpp, fpath[128]; register DOBJECT *op; @@ -549,7 +577,7 @@ char *oct, *nam; error(COMMAND, "missing name"); return(0); } - if (*nam == '*' | *nam == '-') { + if ((*nam == '*') | (*nam == '-')) { error(COMMAND, "illegal name"); return(0); } @@ -590,8 +618,10 @@ char *oct, *nam; } -dobj_unload(nam) /* free the named object */ -char *nam; +extern int +dobj_unload( /* free the named object */ + char *nam +) { register DOBJECT *op; @@ -605,7 +635,8 @@ char *nam; } -dobj_cleanup() /* free all resources */ +extern int +dobj_cleanup(void) /* free all resources */ { register DLIGHTS *lp; @@ -620,10 +651,13 @@ dobj_cleanup() /* free all resources */ } -dobj_xform(nam, rel, ac, av) /* set/add transform for nam */ -char *nam; -int rel, ac; -char **av; +extern int +dobj_xform( /* set/add transform for nam */ + char *nam, + int rel, + int ac, + char **av +) { register DOBJECT *op; FVECT cent; @@ -682,9 +716,11 @@ char **av; } -dobj_putstats(nam, fp) /* put out statistics for nam */ -char *nam; -FILE *fp; +extern int +dobj_putstats( /* put out statistics for nam */ + char *nam, + FILE *fp +) { FVECT ocent; register DOBJECT *op; @@ -723,7 +759,8 @@ FILE *fp; } -dobj_unmove() /* undo last transform change */ +extern int +dobj_unmove(void) /* undo last transform change */ { int txfac; char *txfav[MAXAC+1]; @@ -749,8 +786,11 @@ dobj_unmove() /* undo last transform change */ } -dobj_dup(oldnm, nam) /* duplicate object oldnm as nam */ -char *oldnm, *nam; +extern int +dobj_dup( /* duplicate object oldnm as nam */ + char *oldnm, + char *nam +) { register DOBJECT *op, *opdup; /* check arguments */ @@ -762,7 +802,7 @@ char *oldnm, *nam; error(COMMAND, "missing name"); return(0); } - if (*nam == '*' | *nam == '-') { + if ((*nam == '*') | (*nam == '-')) { error(COMMAND, "illegal name"); return(0); } @@ -788,9 +828,11 @@ char *oldnm, *nam; } -dobj_lighting(nam, cn) /* set up lighting for display object */ -char *nam; -int cn; +extern int +dobj_lighting( /* set up lighting for display object */ + char *nam, + int cn +) { int i, res[2]; VIEW *dv; @@ -822,13 +864,16 @@ int cn; beam_view(dv, res[0], res[1]); beam_sync(1); /* update server */ } + return 0; /* XXX not sure if this is the right value */ } -double -dobj_trace(nm, rorg, rdir) /* check for ray intersection with object(s) */ -char nm[]; -FVECT rorg, rdir; +extern double +dobj_trace( /* check for ray intersection with object(s) */ + char nm[], + FVECT rorg, + FVECT rdir +) { register DOBJECT *op; FVECT xorg, xdir; @@ -872,8 +917,8 @@ FVECT rorg, rdir; } -int -dobj_render() /* render our objects in OpenGL */ +extern int +dobj_render(void) /* render our objects in OpenGL */ { int nrendered = 0; GLboolean normalizing; @@ -958,8 +1003,8 @@ dobj_render() /* render our objects in OpenGL */ } /* set up object transform */ if (op->xfac) { - if (!normalizing && op->xfb.f.sca < 1.-FTINY | - op->xfb.f.sca > 1.+FTINY) + if (!normalizing && (op->xfb.f.sca < 1.-FTINY) | + (op->xfb.f.sca > 1.+FTINY)) glEnable(GL_NORMALIZE); glMatrixMode(GL_MODELVIEW); glPushMatrix();
