root/radiance/ray/src/hd/rhdobj.c
Diff to previous 3.19 , to selected 3.12
Fri Feb 18 17:31:09 2011 UTC (13 years, 3 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.12
Fix for new gcc compiler
Fri Jan 7 20:33:02 2005 UTC (19 years, 5 months ago) by greg
Changes since 3.17: +5 -4 lines
Diff to previous 3.17 , to selected 3.12
Tue Mar 30 20:40:04 2004 UTC (20 years, 2 months ago) by greg
Changes since 3.16: +2 -3 lines
Diff to previous 3.16 , to selected 3.12
Changes since 3.15: +113 -67 lines
Diff to previous 3.15 , to selected 3.12
Ansification and prototypes.
Changes since 3.14: +3 -3 lines
Diff to previous 3.14 , to selected 3.12
Changes since 3.13: +7 -5 lines
Diff to previous 3.13 , to selected 3.12
Changes since 3.12: +7 -6 lines
Diff to previous 3.12
Revision 3.12 - (view) (download) (annotate) - [selected]
Tue May 13 17:58:33 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.11: +5 -6 lines
Diff to previous 3.11
Changes since 3.10: +6 -9 lines
Diff to previous 3.10 , to selected 3.12
Fri Jan 29 15:33:36 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.9: +3 -2 lines
Diff to previous 3.9 , to selected 3.12
added number of lists for proper list deallocation
Thu Dec 31 12:57:06 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.8: +12 -13 lines
Diff to previous 3.8 , to selected 3.12
fixed redrawing of local objects in OpenGL driver
Wed Dec 23 17:41:14 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.7: +13 -6 lines
Diff to previous 3.7 , to selected 3.12
made it so dobj_command() only calls dev_view() if necessary
Fri Dec 18 11:06:45 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.6: +5 -2 lines
Diff to previous 3.6 , to selected 3.12
changed dobj_render() to return the number of objects rendered
Fri Oct 9 17:34:00 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.5: +38 -9 lines
Diff to previous 3.5 , to selected 3.12
changed moved command to do rotations and scaling relative to object center
Thu Aug 27 19:32:43 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.4: +6 -6 lines
Diff to previous 3.4 , to selected 3.12
bug fix in dobj_command()
Wed Aug 26 17:26:26 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.3: +6 -5 lines
Diff to previous 3.3 , to selected 3.12
replaced error message for insufficient lighting samples
fixed drawing mode, which wasn't restored exactly by dobj_render()
Tue Aug 25 18:10:12 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.2: +24 -13 lines
Diff to previous 3.2 , to selected 3.12
minor improvements
Fri Aug 21 11:38:22 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.1: +75 -32 lines
Diff to previous 3.1 , to selected 3.12
changed dobj_trace() to return name of intersected object
improved "show" lighting with front-directed light source
changed MINTHRESH and cosmetic fixes
Wed Aug 19 17:45:24 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to selected 3.12
