Ansification and prototypes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added number of lists for proper list deallocation
fixed redrawing of local objects in OpenGL driver
made it so dobj_command() only calls dev_view() if necessary
changed dobj_render() to return the number of objects rendered
changed moved command to do rotations and scaling relative to object center
bug fix in dobj_command()
replaced error message for insufficient lighting samples fixed drawing mode, which wasn't restored exactly by dobj_render()
minor improvements
changed dobj_trace() to return name of intersected object improved "show" lighting with front-directed light source changed MINTHRESH and cosmetic fixes
