root/radiance/ray/src/hd/rhdobj.c
Revision: 3.11
Committed: Sat Feb 22 02:07:24 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.10: +6 -9 lines
5 * Routines for loading and displaying Radiance objects in rholo with GLX.
6 */
7
8 #include "radogl.h"
9 #include "tonemap.h"
10 #include "rhdisp.h"
11 #include "rhdriver.h"
12 #include "rhdobj.h"
13
14 extern FILE *sstdout; /* user standard output */
15
16 char rhdcmd[DO_NCMDS][8] = DO_INIT; /* user command list */
17
18 int (*dobj_lightsamp)() = NULL; /* pointer to function to get lights */
19
20 #define AVGREFL 0.5 /* assumed average reflectance */
21
22 #define MAXAC 512 /* maximum number of args */
23
24 #ifndef MINTHRESH
25 #define MINTHRESH 5.0 /* source threshold w.r.t. mean */
26 #endif
27
28 #ifndef NALT
29 #define NALT 11 /* # sampling altitude angles */
30 #endif
31 #ifndef NAZI
32 #define NAZI ((int)(PI/2.*NALT+.5))
33 #endif
34
35 typedef struct dlights {
36 struct dlights *next; /* next in lighting set list */
37 FVECT lcent; /* computed lighting center */
38 double ravg; /* harmonic mean free range radius */
39 TMbright larb; /* average reflected brightness */
40 COLOR lamb; /* local ambient value */
41 short nl; /* number of lights in this set */
42 struct lsource {
43 FVECT direc; /* source direction */
44 double omega; /* source solid angle */
45 COLOR val; /* source color */
46 } li[MAXLIGHTS]; /* light sources */
47 } DLIGHTS; /* a light source set */
48
49 typedef struct dobject {
50 struct dobject *next; /* next object in list */
51 char name[64]; /* object name */
52 FVECT center; /* orig. object center */
53 FLOAT radius; /* orig. object radius */
54 int listid; /* GL display list identifier */
55 int nlists; /* number of lists allocated */
56 int rtp[3]; /* associated rtrace process */
57 DLIGHTS *ol; /* object lights */
58 FULLXF xfb; /* coordinate transform */
59 short drawcode; /* drawing code */
60 short xfac; /* transform argument count */
61 char *xfav[MAXAC+1]; /* transform args */
62 } DOBJECT; /* a displayable object */
63
64 static DLIGHTS *dlightsets; /* lighting sets */
65 static DOBJECT *dobjects; /* display object list */
66 static DOBJECT *curobj; /* current (last referred) object */
67 static int lastxfac; /* last number of transform args */
68 static char *lastxfav[MAXAC+1]; /* saved transform arguments */
69
70 #define getdcent(c,op) multp3(c,(op)->center,(op)->xfb.f.xfm)
71 #define getdrad(op) ((op)->radius*(op)->xfb.f.sca)
72
73 #define RTARGC 8
74 static char *rtargv[RTARGC+1] = {"rtrace", "-h-", "-w-", "-fdd",
75 "-x", "1", "-oL"};
76
77 static struct {
78 int nsamp; /* number of ray samples */
79 COLOR val; /* value (sum) */
80 } ssamp[NALT][NAZI]; /* current sphere samples */
81
82 #define curname (curobj==NULL ? (char *)NULL : curobj->name)
83
84
85 static DOBJECT *
86 getdobj(nm) /* get object from list by name */
87 char *nm;
88 {
89 register DOBJECT *op;
90
91 if (nm == NULL)
92 return(NULL);
93 if (nm == curname)
94 return(curobj);
95 for (op = dobjects; op != NULL; op = op->next)
96 if (!strcmp(op->name, nm))
97 break;
98 return(op);
99 }
100
101
102 static
103 freedobj(op) /* free resources and memory assoc. with op */
104 register DOBJECT *op;
105 {
106 int foundlink = 0;
107 DOBJECT ohead;
108 register DOBJECT *opl;
109
110 if (op == NULL)
111 return(0);
112 ohead.next = dobjects;
113 for (opl = &ohead; opl->next != NULL; opl = opl->next) {
114 if (opl->next == op && (opl->next = op->next) == NULL)
115 break;
116 foundlink += opl->next->listid == op->listid;
117 }
118 dobjects = ohead.next;
119 if (!foundlink) {
120 glDeleteLists(op->listid, op->nlists);
121 close_process(op->rtp);
122 }
123 while (op->xfac)
124 freestr(op->xfav[--op->xfac]);
125 free((void *)op);
126 return(1);
127 }
128
129
130 static
131 savedxf(op) /* save transform for display object */
132 register DOBJECT *op;
133 {
134 /* free old */
135 while (lastxfac)
136 freestr(lastxfav[--lastxfac]);
137 /* nothing to save? */
138 if (op == NULL) {
139 lastxfav[0] = NULL;
140 return(0);
141 }
142 /* else save new */
143 for (lastxfac = 0; lastxfac < op->xfac; lastxfac++)
144 lastxfav[lastxfac] = savestr(op->xfav[lastxfac]);
145 lastxfav[lastxfac] = NULL;
146 return(1);
147 }
148
149
150 static
151 ssph_sample(clr, direc, pos) /* add sample to current source sphere */
152 COLR clr;
153 FVECT direc, pos;
154 {
155 COLOR col;
156 double d;
157 register int alt, azi;
158
159 if (dlightsets == NULL)
160 return;
161 if (pos == NULL)
162 d = FHUGE; /* sample is at infinity */
163 else if ((d = (pos[0] - dlightsets->lcent[0])*direc[0] +
164 (pos[1] - dlightsets->lcent[1])*direc[1] +
165 (pos[2] - dlightsets->lcent[2])*direc[2]) > FTINY)
166 dlightsets->ravg += 1./d;
167 else
168 return; /* sample is behind us */
169 alt = NALT*(1.-FTINY)*(.5*(1.+FTINY) + direc[2]*.5);
170 azi = NAZI*(1.-FTINY)*(.5*(1.+FTINY) + .5/PI*atan2(direc[1],direc[0]));
171 colr_color(col, clr);
172 addcolor(ssamp[alt][azi].val, col);
173 ssamp[alt][azi].nsamp++;
174 }
175
176
177 static
178 ssph_direc(direc, alt, azi) /* compute sphere sampling direction */
179 FVECT direc;
180 int alt, azi;
181 {
182 double phi, d;
183
184 direc[2] = 2./NALT*(alt+.5) - 1.;
185 d = sqrt(1. - direc[2]*direc[2]);
186 phi = 2.*PI/NAZI*(azi+.5) - PI;
187 direc[0] = d*cos(phi);
188 direc[1] = d*sin(phi);
189 }
190
191
192 static int
193 ssph_neigh(sp, next) /* neighbor counter on sphere */
194 register int sp[2];
195 int next;
196 {
197 static short nneigh = 0; /* neighbor count */
198 static short neighlist[NAZI+6][2]; /* neighbor list (0 is home) */
199 register int i;
200
201 if (next) {
202 if (nneigh <= 0)
203 return(0);
204 sp[0] = neighlist[--nneigh][0];
205 sp[1] = neighlist[nneigh][1];
206 return(1);
207 }
208 if (sp[0] < 0 | sp[0] >= NALT | sp[1] < 0 | sp[1] >= NAZI)
209 return(nneigh=0);
210 neighlist[0][0] = sp[0]; neighlist[0][1] = sp[1];
211 nneigh = 1;
212 if (sp[0] == 0) {
213 neighlist[nneigh][0] = 1;
214 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
215 neighlist[nneigh][0] = 1;
216 neighlist[nneigh++][1] = sp[1];
217 neighlist[nneigh][0] = 1;
218 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
219 for (i = 0; i < NAZI; i++)
220 if (i != sp[1]) {
221 neighlist[nneigh][0] = 0;
222 neighlist[nneigh++][1] = i;
223 }
224 } else if (sp[0] == NALT-1) {
225 neighlist[nneigh][0] = NALT-2;
226 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
227 neighlist[nneigh][0] = NALT-2;
228 neighlist[nneigh++][1] = sp[1];
229 neighlist[nneigh][0] = NALT-2;
230 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
231 for (i = 0; i < NAZI; i++)
232 if (i != sp[1]) {
233 neighlist[nneigh][0] = NALT-1;
234 neighlist[nneigh++][1] = i;
235 }
236 } else {
237 neighlist[nneigh][0] = sp[0]-1;
238 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
239 neighlist[nneigh][0] = sp[0]-1;
240 neighlist[nneigh++][1] = sp[1];
241 neighlist[nneigh][0] = sp[0]-1;
242 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
243 neighlist[nneigh][0] = sp[0];
244 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
245 neighlist[nneigh][0] = sp[0];
246 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
247 neighlist[nneigh][0] = sp[0]+1;
248 neighlist[nneigh++][1] = (sp[1]+1)%NAZI;
249 neighlist[nneigh][0] = sp[0]+1;
250 neighlist[nneigh++][1] = sp[1];
251 neighlist[nneigh][0] = sp[0]+1;
252 neighlist[nneigh++][1] = (sp[1]+(NAZI-1))%NAZI;
253 }
254 return(nneigh);
255 }
256
257
258 static
259 ssph_compute() /* compute source set from sphere samples */
260 {
261 int ncells, nsamps;
262 COLOR csum;
263 FVECT v;
264 double d, thresh, maxbr;
265 int maxalt, maxazi, spos[2];
266 register int alt, azi;
267 register struct lsource *ls;
268 /* count & average sampled cells */
269 setcolor(csum, 0., 0., 0.);
270 ncells = nsamps = 0;
271 for (alt = 0; alt < NALT; alt++)
272 for (azi = 0; azi < NAZI; azi++)
273 if (ssamp[alt][azi].nsamp) {
274 if (ssamp[alt][azi].nsamp > 1) {
275 d = 1.0/ssamp[alt][azi].nsamp;
276 scalecolor(ssamp[alt][azi].val, d);
277 }
278 addcolor(csum, ssamp[alt][azi].val);
279 nsamps += ssamp[alt][azi].nsamp;
280 ncells++;
281 }
282 if (dlightsets == NULL | ncells < NALT*NAZI/4) {
283 ncells = 0;
284 goto done;
285 }
286 /* harmonic mean distance */
287 if (dlightsets->ravg > FTINY)
288 dlightsets->ravg = nsamps / dlightsets->ravg;
289 else
290 dlightsets->ravg = FHUGE;
291 /* light source threshold */
292 thresh = MINTHRESH*bright(csum)/ncells;
293 if (thresh <= FTINY) {
294 ncells = 0;
295 goto done;
296 }
297 /* avg. reflected brightness */
298 d = AVGREFL / (double)ncells;
299 scalecolor(csum, d);
300 if (tmCvColors(&dlightsets->larb, TM_NOCHROM, &csum, 1) != TM_E_OK)
301 error(CONSISTENCY, "tone mapping problem in ssph_compute");
302 /* greedy light source clustering */
303 while (dlightsets->nl < MAXLIGHTS) {
304 maxbr = 0.; /* find brightest cell */
305 for (alt = 0; alt < NALT; alt++)
306 for (azi = 0; azi < NAZI; azi++)
307 if ((d = bright(ssamp[alt][azi].val)) > maxbr) {
308 maxalt = alt; maxazi = azi;
309 maxbr = d;
310 }
311 if (maxbr < thresh) /* below threshold? */
312 break;
313 ls = dlightsets->li + dlightsets->nl++;
314 spos[0] = maxalt; spos[1] = maxazi; /* cluster */
315 for (ssph_neigh(spos, 0); ssph_neigh(spos, 1); ) {
316 alt = spos[0]; azi = spos[1];
317 if ((d = bright(ssamp[alt][azi].val)) < .75*thresh)
318 continue; /* too dim */
319 ssph_direc(v, alt, azi); /* else add it in */
320 VSUM(ls->direc, ls->direc, v, d);
321 ls->omega += 1.;
322 addcolor(ls->val, ssamp[alt][azi].val);
323 /* remove from list */
324 setcolor(ssamp[alt][azi].val, 0., 0., 0.);
325 ssamp[alt][azi].nsamp = 0;
326 }
327 d = 1./ls->omega; /* avg. brightness */
328 scalecolor(ls->val, d);
329 ls->omega *= 4.*PI/(NALT*NAZI); /* solid angle */
330 normalize(ls->direc); /* direction */
331 }
332 /* compute ambient remainder */
333 for (alt = 0; alt < NALT; alt++)
334 for (azi = 0; azi < NAZI; azi++)
335 if (ssamp[alt][azi].nsamp)
336 addcolor(dlightsets->lamb, ssamp[alt][azi].val);
337 d = 1.0/ncells;
338 scalecolor(dlightsets->lamb, d);
339 done: /* clear sphere sample array */
340 bzero((char *)ssamp, sizeof(ssamp));
341 return(ncells);
342 }
343
344
345 static
346 getdlights(op, force) /* get lights for display object */
347 register DOBJECT *op;
348 int force;
349 {
350 double d2, mind2 = FHUGE*FHUGE;
351 FVECT ocent;
352 VIEW cvw;
353 register DLIGHTS *dl;
354
355 op->ol = NULL;
356 if (op->drawcode != DO_LIGHT)
357 return(0);
358 /* check for usable light set */
359 getdcent(ocent, op);
360 for (dl = dlightsets; dl != NULL; dl = dl->next)
361 if ((d2 = dist2(dl->lcent, ocent)) < mind2) {
362 op->ol = dl;
363 mind2 = d2;
364 }
365 /* the following is heuristic */
366 d2 = 2.*getdrad(op); d2 *= d2;
367 if ((dl = op->ol) != NULL && (mind2 < 0.0625*dl->ravg*dl->ravg ||
368 mind2 < 4.*getdrad(op)*getdrad(op)))
369 return(1);
370 if (!force)
371 return(0);
372 /* need to compute new light set */
373 copystruct(&cvw, &stdview);
374 cvw.type = VT_PER;
375 VCOPY(cvw.vp, ocent);
376 cvw.vup[0] = 1.; cvw.vup[1] = cvw.vup[2] = 0.;
377 cvw.horiz = 90; cvw.vert = 90.;
378 beam_init(1); /* query beams through center */
379 cvw.vdir[0] = cvw.vdir[1] = 0.; cvw.vdir[2] = 1.;
380 setview(&cvw); beam_view(&cvw, 0, 0);
381 cvw.vdir[0] = cvw.vdir[1] = 0.; cvw.vdir[2] = -1.;
382 setview(&cvw); beam_view(&cvw, 0, 0);
383 cvw.vup[0] = cvw.vup[1] = 0.; cvw.vup[2] = 1.;
384 cvw.vdir[0] = cvw.vdir[2] = 0.; cvw.vdir[1] = 1.;
385 setview(&cvw); beam_view(&cvw, 0, 0);
386 cvw.vdir[0] = cvw.vdir[2] = 0.; cvw.vdir[1] = -1.;
387 setview(&cvw); beam_view(&cvw, 0, 0);
388 cvw.vdir[1] = cvw.vdir[2] = 0.; cvw.vdir[0] = 1.;
389 setview(&cvw); beam_view(&cvw, 0, 0);
390 cvw.vdir[1] = cvw.vdir[2] = 0.; cvw.vdir[0] = -1.;
391 setview(&cvw); beam_view(&cvw, 0, 0);
392 /* allocate new light set */
393 dl = (DLIGHTS *)calloc(1, sizeof(DLIGHTS));
394 if (dl == NULL)
395 goto memerr;
396 VCOPY(dl->lcent, ocent);
397 /* push onto our light set list */
398 dl->next = dlightsets;
399 dlightsets = dl;
400 dobj_lightsamp = ssph_sample; /* get beams from server */
401 imm_mode = beam_sync(-1) > 0;
402 while (imm_mode)
403 if (serv_result() == DS_SHUTDOWN)
404 quit(0);
405 if (!ssph_compute()) { /* compute light sources from sphere */
406 dlightsets = dl->next;
407 free((void *)dl);
408 return(0);
409 }
410 op->ol = dl;
411 return(1);
412 memerr:
413 error(SYSTEM, "out of memory in getdlights");
414 }
415
416
417 static
418 cmderror(cn, err) /* report command error */
419 int cn;
420 char *err;
421 {
422 sprintf(errmsg, "%s: %s", rhdcmd[cn], err);
423 error(COMMAND, errmsg);
424 }
425
426
427 int
428 dobj_command(cmd, args) /* run object display command */
429 char *cmd;
430 register char *args;
431 {
432 int somechange = 0;
433 int cn, na, doxfm;
434 register int nn;
435 char *alist[MAXAC+1], *nm;
436 /* find command */
437 for (cn = 0; cn < DO_NCMDS; cn++)
438 if (!strcmp(cmd, rhdcmd[cn]))
439 break;
440 if (cn >= DO_NCMDS)
441 return(-1); /* not in our list */
442 /* make argument list */
443 for (na = 0; *args; na++) {
444 if (na > MAXAC)
445 goto toomany;
446 alist[na] = args;
447 while (*args && !isspace(*args))
448 args++;
449 while (isspace(*args))
450 *args++ = '\0';
451 }
452 alist[na] = NULL;
453 /* execute command */
454 switch (cn) {
455 case DO_LOAD: /* load an octree */
456 if (na == 1)
457 dobj_load(alist[0], alist[0]);
458 else if (na == 2)
459 dobj_load(alist[0], alist[1]);
460 else {
461 cmderror(cn, "need octree [name]");
462 return(0);
463 }
464 break;
465 case DO_UNLOAD: /* clear an object */
466 if (na > 1) goto toomany;
467 if (na && alist[0][0] == '*')
468 somechange += dobj_cleanup();
469 else
470 somechange += dobj_unload(na ? alist[0] : curname);
471 break;
472 case DO_XFORM: /* transform object */
473 case DO_MOVE:
474 if (na && alist[0][0] != '-') {
475 nm = alist[0]; nn = 1;
476 } else {
477 nm = curname; nn = 0;
478 }
479 if (cn == DO_MOVE && nn >= na) {
480 cmderror(cn, "missing transform");
481 return(0);
482 }
483 somechange += dobj_xform(nm, cn==DO_MOVE, na-nn, alist+nn);
484 break;
485 case DO_UNMOVE: /* undo last transform */
486 somechange += dobj_unmove();
487 break;
488 case DO_OBJECT: /* print object statistics */
489 if (dobj_putstats(na ? alist[0] : curname, sstdout))
490 if (na && alist[0][0] != '*' && (curobj == NULL ||
491 strcmp(alist[0], curobj->name)))
492 savedxf(curobj = getdobj(alist[0]));
493 break;
494 case DO_DUP: /* duplicate object */
495 for (nn = 0; nn < na; nn++)
496 if (alist[nn][0] == '-')
497 break;
498 switch (nn) {
499 case 0:
500 cmderror(cn, "need new object name");
501 return(0);
502 case 1:
503 nm = curname;
504 break;
505 case 2:
506 nm = alist[0];
507 break;
508 default:
509 goto toomany;
510 }
511 if (!dobj_dup(nm, alist[nn-1]))
512 break;
513 if (na > nn)
514 somechange += dobj_xform(curname, 1, na-nn, alist+nn);
515 else
516 curobj->drawcode = DO_HIDE;
517 savedxf(curobj);
518 break;
519 case DO_SHOW: /* change rendering option */
520 case DO_LIGHT:
521 case DO_HIDE:
522 if (na > 1) goto toomany;
523 dobj_lighting(na ? alist[0] : curname, cn);
524 somechange++;
525 break;
526 default:
527 error(CONSISTENCY, "bad command id in dobj_command");
528 }
529 return(somechange);
530 toomany:
531 return(cmderror(cn, "too many arguments"));
532 }
533
534
535 dobj_load(oct, nam) /* create/load an octree object */
536 char *oct, *nam;
537 {
538 extern char *getlibpath(), *getpath();
539 char *fpp, fpath[128];
540 register DOBJECT *op;
541 /* check arguments */
542 if (oct == NULL) {
543 error(COMMAND, "missing octree");
544 return(0);
545 }
546 if (nam == NULL) {
547 error(COMMAND, "missing name");
548 return(0);
549 }
550 if (*nam == '*' | *nam == '-') {
551 error(COMMAND, "illegal name");
552 return(0);
553 }
554 if (getdobj(nam) != NULL) {
555 error(COMMAND, "name already taken (clear first)");
556 return(0);
557 }
558 /* get octree path */
559 if ((fpp = getpath(oct, getlibpath(), R_OK)) == NULL) {
560 sprintf(errmsg, "cannot find octree \"%s\"", oct);
561 error(COMMAND, errmsg);
562 return(0);
563 }
564 strcpy(fpath, fpp);
565 op = (DOBJECT *)malloc(sizeof(DOBJECT));
566 if (op == NULL)
567 error(SYSTEM, "out of memory in dobj_load");
568 /* set struct fields */
569 strcpy(op->name, nam);
570 op->ol = NULL;
571 op->drawcode = DO_HIDE;
572 setident4(op->xfb.f.xfm); op->xfb.f.sca = 1.;
573 setident4(op->xfb.b.xfm); op->xfb.b.sca = 1.;
574 op->xfav[op->xfac=0] = NULL;
575 /* load octree into display list */
576 dolights = 0;
577 domats = 1;
578 op->listid = rgl_octlist(fpath, op->center, &op->radius, &op->nlists);
579 /* start rtrace */
580 rtargv[RTARGC-1] = fpath;
581 rtargv[RTARGC] = NULL;
582 open_process(op->rtp, rtargv);
583 /* insert into main list */
584 op->next = dobjects;
585 curobj = dobjects = op;
586 savedxf(NULL);
587 return(1);
588 }
589
590
591 dobj_unload(nam) /* free the named object */
592 char *nam;
593 {
594 register DOBJECT *op;
595
596 if ((op = getdobj(nam)) == NULL) {
597 error(COMMAND, "no object");
598 return(0);
599 }
600 freedobj(op);
601 savedxf(curobj = NULL);
602 return(1);
603 }
604
605
606 dobj_cleanup() /* free all resources */
607 {
608 register DLIGHTS *lp;
609
610 while (dobjects != NULL)
611 freedobj(dobjects);
612 savedxf(curobj = NULL);
613 while ((lp = dlightsets) != NULL) {
614 dlightsets = lp->next;
615 free((void *)lp);
616 }
617 return(1);
618 }
619
620
621 dobj_xform(nam, rel, ac, av) /* set/add transform for nam */
622 char *nam;
623 int rel, ac;
624 char **av;
625 {
626 register DOBJECT *op;
627 FVECT cent;
628 double rad;
629 char scoord[16];
630 int i;
631
632 if ((op = getdobj(nam)) == NULL) {
633 error(COMMAND, "no object");
634 return(0);
635 }
636 if (rel)
637 rel = op->xfac + 8;
638 if (ac + rel > MAXAC) {
639 error(COMMAND, "too many transform arguments");
640 return(0);
641 }
642 savedxf(curobj = op); /* remember current transform */
643 if (rel && ac == 4 && !strcmp(av[0], "-t"))
644 rel = -1; /* don't move for translate */
645 else {
646 getdcent(cent, op); /* don't move if near orig. */
647 rad = getdrad(op);
648 if (DOT(cent,cent) < rad*rad)
649 rel = -1;
650 }
651 if (!rel) { /* remove old transform */
652 while (op->xfac)
653 freestr(op->xfav[--op->xfac]);
654 } else if (rel > 0) { /* relative move */
655 op->xfav[op->xfac++] = savestr("-t");
656 for (i = 0; i < 3; i++) {
657 sprintf(scoord, "%.4e", -cent[i]);
658 op->xfav[op->xfac++] = savestr(scoord);
659 }
660 }
661 while (ac--)
662 op->xfav[op->xfac++] = savestr(*av++);
663 if (rel > 0) { /* move back */
664 op->xfav[op->xfac++] = savestr("-t");
665 for (i = 0; i < 3; i++) {
666 sprintf(scoord, "%.4e", cent[i]);
667 op->xfav[op->xfac++] = savestr(scoord);
668 }
669 }
670 op->xfav[op->xfac] = NULL;
671 if (fullxf(&op->xfb, op->xfac, op->xfav) != op->xfac) {
672 error(COMMAND, "bad transform arguments");
673 dobj_unmove();
674 savedxf(op); /* save current transform instead */
675 return(0);
676 }
677 /* don't know local lights anymore */
678 getdlights(op, 0);
679 return(1);
680 }
681
682
683 dobj_putstats(nam, fp) /* put out statistics for nam */
684 char *nam;
685 FILE *fp;
686 {
687 FVECT ocent;
688 register DOBJECT *op;
689 register int i;
690
691 if (nam == NULL) {
692 error(COMMAND, "no current object");
693 return(0);
694 }
695 if (nam[0] == '*') {
696 i = 0;
697 for (op = dobjects; op != NULL; op = op->next)
698 i += dobj_putstats(op->name, fp);
699 return(i);
700 }
701 if ((op = getdobj(nam)) == NULL) {
702 error(COMMAND, "unknown object");
703 return(0);
704 }
705 getdcent(ocent, op);
706 fprintf(fp, "%s: %s, center [%g %g %g], radius %g", op->name,
707 op->drawcode==DO_HIDE ? "hidden" :
708 op->drawcode==DO_LIGHT && op->ol!=NULL ? "lighted" :
709 "shown",
710 ocent[0],ocent[1],ocent[2], getdrad(op));
711 if (op->xfac)
712 fputs(", (xform", fp);
713 for (i = 0; i < op->xfac; i++) {
714 putc(' ', fp);
715 fputs(op->xfav[i], fp);
716 }
717 if (op->xfac)
718 fputc(')', fp);
719 fputc('\n', fp);
720 return(1);
721 }
722
723
724 dobj_unmove() /* undo last transform change */
725 {
726 int txfac;
727 char *txfav[MAXAC+1];
728
729 if (curobj == NULL) {
730 error(COMMAND, "no current object");
731 return(0);
732 }
733 /* hold last transform */
734 bcopy((char *)lastxfav, (char *)txfav,
735 (txfac=lastxfac)*sizeof(char *));
736 /* save this transform */
737 bcopy((char *)curobj->xfav, (char *)lastxfav,
738 (lastxfac=curobj->xfac)*sizeof(char *));
739 /* copy back last transform */
740 bcopy((char *)txfav, (char *)curobj->xfav,
741 (curobj->xfac=txfac)*sizeof(char *));
742 /* set matrices */
743 fullxf(&curobj->xfb, curobj->xfac, curobj->xfav);
744 /* don't know local lights anymore */
745 getdlights(curobj, 0);
746 return(1);
747 }
748
749
750 dobj_dup(oldnm, nam) /* duplicate object oldnm as nam */
751 char *oldnm, *nam;
752 {
753 register DOBJECT *op, *opdup;
754 /* check arguments */
755 if ((op = getdobj(oldnm)) == NULL) {
756 error(COMMAND, "no object");
757 return(0);
758 }
759 if (nam == NULL) {
760 error(COMMAND, "missing name");
761 return(0);
762 }
763 if (*nam == '*' | *nam == '-') {
764 error(COMMAND, "illegal name");
765 return(0);
766 }
767 if (getdobj(nam) != NULL) {
768 error(COMMAND, "name already taken (clear first)");
769 return(0);
770 }
771 /* allocate and copy struct */
772 opdup = (DOBJECT *)malloc(sizeof(DOBJECT));
773 if (opdup == NULL)
774 error(SYSTEM, "out of memory in dobj_dup");
775 copystruct(opdup, op);
776 /* rename */
777 strcpy(opdup->name, nam);
778 /* get our own copy of transform */
779 for (opdup->xfac = 0; opdup->xfac < op->xfac; opdup->xfac++)
780 opdup->xfav[opdup->xfac] = savestr(op->xfav[opdup->xfac]);
781 opdup->xfav[opdup->xfac] = NULL;
782 /* insert it into our list */
783 opdup->next = dobjects;
784 curobj = dobjects = opdup;
785 return(1);
786 }
787
788
789 dobj_lighting(nam, cn) /* set up lighting for display object */
790 char *nam;
791 int cn;
792 {
793 int i, res[2];
794 VIEW *dv;
795 register DOBJECT *op;
796
797 if (nam == NULL) {
798 error(COMMAND, "no current object");
799 return(0);
800 }
801 if (nam[0] == '*') {
802 for (op = dobjects; op != NULL; op = op->next)
803 if ((op->drawcode = cn) == DO_LIGHT)
804 getdlights(op, 1);
805 else
806 op->ol = NULL;
807 } else if ((op = getdobj(nam)) == NULL) {
808 error(COMMAND, "unknown object");
809 return(0);
810 } else if ((op->drawcode = cn) == DO_LIGHT) {
811 if (!getdlights(op, 1))
812 error(COMMAND, "insufficient samples to light object");
813 } else
814 op->ol = NULL;
815
816 if (dobj_lightsamp != NULL) { /* restore beam set */
817 dobj_lightsamp = NULL;
818 beam_init(1);
819 for (i = 0; (dv = dev_auxview(i, res)) != NULL; i++)
820 beam_view(dv, res[0], res[1]);
821 beam_sync(1); /* update server */
822 }
823 }
824
825
826 double
827 dobj_trace(nm, rorg, rdir) /* check for ray intersection with object(s) */
828 char nm[];
829 FVECT rorg, rdir;
830 {
831 register DOBJECT *op;
832 FVECT xorg, xdir;
833 double darr[6];
834 /* check each visible object? */
835 if (nm == NULL || *nm == '*') {
836 double dist, mindist = 1.01*FHUGE;
837
838 if (nm != NULL) nm[0] = '\0';
839 for (op = dobjects; op != NULL; op = op->next) {
840 if (op->drawcode == DO_HIDE)
841 continue;
842 dist = dobj_trace(op->name, rorg, rdir);
843 if (dist < mindist) {
844 if (nm != NULL) strcpy(nm, op->name);
845 mindist = dist;
846 }
847 }
848 return(mindist);
849 }
850 /* else check particular object */
851 if ((op = getdobj(nm)) == NULL) {
852 error(COMMAND, "unknown object");
853 return(FHUGE);
854 }
855 if (op->xfac) { /* put ray in local coordinates */
856 multp3(xorg, rorg, op->xfb.b.xfm);
857 multv3(xdir, rdir, op->xfb.b.xfm);
858 VCOPY(darr, xorg); VCOPY(darr+3, xdir);
859 } else {
860 VCOPY(darr, rorg); VCOPY(darr+3, rdir);
861 }
862 /* trace it */
863 if (process(op->rtp, (char *)darr, (char *)darr, sizeof(double),
864 6*sizeof(double)) != sizeof(double))
865 error(SYSTEM, "rtrace communication error");
866 /* return distance */
867 if (darr[0] >= .99*FHUGE)
868 return(FHUGE);
869 return(darr[0]*op->xfb.f.sca);
870 }
871
872
873 int
874 dobj_render() /* render our objects in OpenGL */
875 {
876 int nrendered = 0;
877 GLboolean normalizing;
878 GLfloat vec[4];
879 FVECT v1;
880 register DOBJECT *op;
881 register int i;
882 /* anything to render? */
883 for (op = dobjects; op != NULL; op = op->next)
884 if (op->drawcode != DO_HIDE)
885 break;
886 if (op == NULL)
887 return(0);
888 /* set up general rendering params */
889 glGetBooleanv(GL_NORMALIZE, &normalizing);
890 glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT|GL_ENABLE_BIT|
891 GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT|GL_POLYGON_BIT);
892 glDepthFunc(GL_LESS);
893 glEnable(GL_DEPTH_TEST);
894 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
895 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
896 glShadeModel(GL_SMOOTH);
897 glFrontFace(GL_CCW);
898 glDisable(GL_CULL_FACE);
899 for (i = MAXLIGHTS; i--; )
900 glDisable(glightid[i]);
901 glEnable(GL_LIGHTING);
902 rgl_checkerr("setting rendering modes in dobj_render");
903 /* render each object */
904 for (op = dobjects; op != NULL; op = op->next) {
905 if (op->drawcode == DO_HIDE)
906 continue;
907 /* set up lighting */
908 if (op->drawcode == DO_LIGHT && op->ol != NULL) {
909 BYTE pval;
910 double expval, d;
911 /* use computed sources */
912 if (tmMapPixels(&pval, &op->ol->larb, TM_NOCHROM, 1)
913 != TM_E_OK)
914 error(CONSISTENCY, "dobj_render w/o tone map");
915 expval = pval * (WHTEFFICACY/256.) /
916 tmLuminance(op->ol->larb);
917 vec[0] = expval * colval(op->ol->lamb,RED);
918 vec[1] = expval * colval(op->ol->lamb,GRN);
919 vec[2] = expval * colval(op->ol->lamb,BLU);
920 vec[3] = 1.;
921 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
922 for (i = op->ol->nl; i--; ) {
923 VCOPY(vec, op->ol->li[i].direc);
924 vec[3] = 0.;
925 glLightfv(glightid[i], GL_POSITION, vec);
926 d = expval * op->ol->li[i].omega;
927 vec[0] = d * colval(op->ol->li[i].val,RED);
928 vec[1] = d * colval(op->ol->li[i].val,GRN);
929 vec[2] = d * colval(op->ol->li[i].val,BLU);
930 vec[3] = 1.;
931 glLightfv(glightid[i], GL_SPECULAR, vec);
932 glLightfv(glightid[i], GL_DIFFUSE, vec);
933 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
934 glLightfv(glightid[i], GL_AMBIENT, vec);
935 glEnable(glightid[i]);
936 }
937 } else { /* fake lighting */
938 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
939 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
940 getdcent(v1, op);
941 VSUB(v1, odev.v.vp, v1);
942 if (normalize(v1) <= getdrad(op)) {
943 vec[0] = -odev.v.vdir[0];
944 vec[1] = -odev.v.vdir[1];
945 vec[2] = -odev.v.vdir[2];
946 } else
947 VCOPY(vec, v1);
948 vec[3] = 0.;
949 glLightfv(GL_LIGHT0, GL_POSITION, vec);
950 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
951 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
952 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
953 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
954 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
955 glEnable(GL_LIGHT0);
956 }
957 /* set up object transform */
958 if (op->xfac) {
959 if (!normalizing && op->xfb.f.sca < 1.-FTINY |
960 op->xfb.f.sca > 1.+FTINY)
961 glEnable(GL_NORMALIZE);
962 glMatrixMode(GL_MODELVIEW);
963 glPushMatrix();
964 /* matrix order works out to same */
965 #ifdef SMLFLT
966 glMultMatrixf((GLfloat *)op->xfb.f.xfm);
967 #else
968 glMultMatrixd((GLdouble *)op->xfb.f.xfm);
969 #endif
970 }
971 /* render the display list */
972 glCallList(op->listid);
973 nrendered++;
974 /* restore matrix */
975 if (op->xfac) {
976 glMatrixMode(GL_MODELVIEW);
977 glPopMatrix();
978 if (!normalizing)
979 glDisable(GL_NORMALIZE);
980 }
981 /* restore lighting */
982 if (op->drawcode == DO_LIGHT && op->ol != NULL)
983 for (i = op->ol->nl; i--; )
984 glDisable(glightid[i]);
985 else
986 glDisable(GL_LIGHT0);
987 /* check errors */
988 }
989 glPopAttrib(); /* restore rendering params */
990 rgl_checkerr("rendering objects in dobj_render");
991 return(nrendered);
992 }
