--- ray/src/hd/rhdobj.c 1998/08/19 17:45:24 3.1 +++ ray/src/hd/rhdobj.c 1998/12/18 11:06:45 3.7 @@ -5,7 +5,7 @@ static char SCCSid[] = "$SunId$ SGI"; #endif /* - * Routines for loading and displaying Radiance objects under OpenGL in rholo. + * Routines for loading and displaying Radiance objects in rholo with GLX. */ #include "radogl.h" @@ -22,10 +22,10 @@ int (*dobj_lightsamp)() = NULL; /* pointer to function #define AVGREFL 0.5 /* assumed average reflectance */ -#define MAXAC 64 /* maximum number of args */ +#define MAXAC 512 /* maximum number of args */ #ifndef MINTHRESH -#define MINTHRESH 7.0 /* source threshold w.r.t. mean */ +#define MINTHRESH 5.0 /* source threshold w.r.t. mean */ #endif #ifndef NALT @@ -69,6 +69,9 @@ static DOBJECT *curobj; /* current (last referred) ob static int lastxfac; /* last number of transform args */ static char *lastxfav[MAXAC+1]; /* saved transform arguments */ +#define getdcent(c,op) multp3(c,(op)->center,(op)->xfb.f.xfm) +#define getdrad(op) ((op)->radius*(op)->xfb.f.sca) + #define RTARGC 8 static char *rtargv[RTARGC+1] = {"rtrace", "-h-", "-w-", "-fdd", "-x", "1", "-oL"}; @@ -279,8 +282,8 @@ ssph_compute() /* compute source set from sphere sam ncells++; } if (dlightsets == NULL | ncells < NALT*NAZI/4) { - bzero((char *)ssamp, sizeof(ssamp)); - return(0); + ncells = 0; + goto done; } /* harmonic mean distance */ if (dlightsets->ravg > FTINY) @@ -289,11 +292,15 @@ ssph_compute() /* compute source set from sphere sam dlightsets->ravg = FHUGE; /* light source threshold */ thresh = MINTHRESH*bright(csum)/ncells; + if (thresh <= FTINY) { + ncells = 0; + goto done; + } /* avg. reflected brightness */ d = AVGREFL / (double)ncells; scalecolor(csum, d); if (tmCvColors(&dlightsets->larb, TM_NOCHROM, csum, 1) != TM_E_OK) - error(CONSISTENCY, "bad tone mapping in ssph_compute"); + error(CONSISTENCY, "tone mapping problem in ssph_compute"); /* greedy light source clustering */ while (dlightsets->nl < MAXLIGHTS) { maxbr = 0.; /* find brightest cell */ @@ -313,9 +320,11 @@ ssph_compute() /* compute source set from sphere sam continue; /* too dim */ ssph_direc(v, alt, azi); /* else add it in */ VSUM(ls->direc, ls->direc, v, d); - ls->omega++; + ls->omega += 1.; addcolor(ls->val, ssamp[alt][azi].val); + /* remove from list */ setcolor(ssamp[alt][azi].val, 0., 0., 0.); + ssamp[alt][azi].nsamp = 0; } d = 1./ls->omega; /* avg. brightness */ scalecolor(ls->val, d); @@ -329,7 +338,7 @@ ssph_compute() /* compute source set from sphere sam addcolor(dlightsets->lamb, ssamp[alt][azi].val); d = 1.0/ncells; scalecolor(dlightsets->lamb, d); - /* clear sphere sample array */ +done: /* clear sphere sample array */ bzero((char *)ssamp, sizeof(ssamp)); return(ncells); } @@ -349,16 +358,16 @@ int force; if (op->drawcode != DO_LIGHT) return(0); /* check for usable light set */ - multp3(ocent, op->center, op->xfb.f.xfm); + getdcent(ocent, op); for (dl = dlightsets; dl != NULL; dl = dl->next) if ((d2 = dist2(dl->lcent, ocent)) < mind2) { op->ol = dl; mind2 = d2; } /* the following is heuristic */ - d2 = 2.*op->radius*op->xfb.f.sca; d2 *= d2; + d2 = 2.*getdrad(op); d2 *= d2; if ((dl = op->ol) != NULL && (mind2 < 0.0625*dl->ravg*dl->ravg || - mind2 < 4.*op->radius*op->xfb.f.sca*op->radius*op->xfb.f.sca)) + mind2 < 4.*getdrad(op)*getdrad(op))) return(1); if (!force) return(0); @@ -453,7 +462,7 @@ register char *args; else return(cmderror(cn, "need octree [name]")); break; - case DO_UNLOAD: /* unload an object */ + case DO_UNLOAD: /* clear an object */ if (na > 1) goto toomany; if (na && alist[0][0] == '*') dobj_cleanup(); @@ -475,7 +484,10 @@ register char *args; dobj_unmove(); break; case DO_OBJECT: /* print object statistics */ - dobj_putstats(na ? alist[0] : curname, sstdout); + if (dobj_putstats(na ? alist[0] : curname, sstdout)) + if (na && alist[0][0] != '*' && (curobj == NULL || + strcmp(alist[0], curobj->name))) + savedxf(curobj = getdobj(alist[0])); break; case DO_DUP: /* duplicate object */ for (nn = 0; nn < na; nn++) @@ -499,6 +511,7 @@ register char *args; dobj_xform(curname, 1, na-nn, alist+nn); else curobj->drawcode = DO_HIDE; + savedxf(curobj); break; case DO_SHOW: /* change rendering option */ case DO_LIGHT: @@ -535,6 +548,10 @@ char *oct, *nam; error(COMMAND, "illegal name"); return(0); } + if (getdobj(nam) != NULL) { + error(COMMAND, "name already taken (clear first)"); + return(0); + } /* get octree path */ if ((fpp = getpath(oct, getlibpath(), R_OK)) == NULL) { sprintf(errmsg, "cannot find octree \"%s\"", oct); @@ -542,7 +559,6 @@ char *oct, *nam; return(0); } strcpy(fpath, fpp); - freedobj(getdobj(nam)); /* free previous use of nam */ op = (DOBJECT *)malloc(sizeof(DOBJECT)); if (op == NULL) error(SYSTEM, "out of memory in dobj_load"); @@ -598,28 +614,55 @@ dobj_cleanup() /* free all resources */ } -dobj_xform(nam, add, ac, av) /* set/add transform for nam */ +dobj_xform(nam, rel, ac, av) /* set/add transform for nam */ char *nam; -int add, ac; +int rel, ac; char **av; { register DOBJECT *op; + FVECT cent; + double rad; + char scoord[16]; + int i; if ((op = getdobj(nam)) == NULL) { error(COMMAND, "no object"); return(0); } - if (add) add = op->xfac; - if (ac + add > MAXAC) { + if (rel) + rel = op->xfac + 8; + if (ac + rel > MAXAC) { error(COMMAND, "too many transform arguments"); return(0); } - savedxf(curobj = op); - if (!add) + savedxf(curobj = op); /* remember current transform */ + if (rel && ac == 4 && !strcmp(av[0], "-t")) + rel = -1; /* don't move for translate */ + else { + getdcent(cent, op); /* don't move if near orig. */ + rad = getdrad(op); + if (DOT(cent,cent) < rad*rad) + rel = -1; + } + if (!rel) { /* remove old transform */ while (op->xfac) freestr(op->xfav[--op->xfac]); + } else if (rel > 0) { /* relative move */ + op->xfav[op->xfac++] = savestr("-t"); + for (i = 0; i < 3; i++) { + sprintf(scoord, "%.4e", -cent[i]); + op->xfav[op->xfac++] = savestr(scoord); + } + } while (ac--) op->xfav[op->xfac++] = savestr(*av++); + if (rel > 0) { /* move back */ + op->xfav[op->xfac++] = savestr("-t"); + for (i = 0; i < 3; i++) { + sprintf(scoord, "%.4e", cent[i]); + op->xfav[op->xfac++] = savestr(scoord); + } + } op->xfav[op->xfac] = NULL; if (fullxf(&op->xfb, op->xfac, op->xfav) != op->xfac) { error(COMMAND, "bad transform arguments"); @@ -655,12 +698,12 @@ FILE *fp; error(COMMAND, "unknown object"); return(0); } - multp3(ocent, op->center, op->xfb.f.xfm); - fprintf(fp, "%s: %s, center [%f %f %f], radius %f", op->name, - op->drawcode==DO_HIDE ? "hid" : - op->drawcode==DO_LIGHT && op->ol!=NULL ? "lit" : + getdcent(ocent, op); + fprintf(fp, "%s: %s, center [%g %g %g], radius %g", op->name, + op->drawcode==DO_HIDE ? "hidden" : + op->drawcode==DO_LIGHT && op->ol!=NULL ? "lighted" : "shown", - ocent[0],ocent[1],ocent[2], op->radius*op->xfb.f.sca); + ocent[0],ocent[1],ocent[2], getdrad(op)); if (op->xfac) fputs(", (xform", fp); for (i = 0; i < op->xfac; i++) { @@ -717,6 +760,10 @@ char *oldnm, *nam; error(COMMAND, "illegal name"); return(0); } + if (getdobj(nam) != NULL) { + error(COMMAND, "name already taken (clear first)"); + return(0); + } /* allocate and copy struct */ opdup = (DOBJECT *)malloc(sizeof(DOBJECT)); if (opdup == NULL) @@ -756,9 +803,10 @@ int cn; } else if ((op = getdobj(nam)) == NULL) { error(COMMAND, "unknown object"); return(0); - } else if ((op->drawcode = cn) == DO_LIGHT) - getdlights(op, 1); - else + } else if ((op->drawcode = cn) == DO_LIGHT) { + if (!getdlights(op, 1)) + error(COMMAND, "insufficient samples to light object"); + } else op->ol = NULL; if (dobj_lightsamp != NULL) { /* restore beam set */ @@ -772,39 +820,59 @@ int cn; double -dobj_trace(rorg, rdir) /* check for ray intersection with objects */ +dobj_trace(nm, rorg, rdir) /* check for ray intersection with object(s) */ +char nm[]; FVECT rorg, rdir; { register DOBJECT *op; FVECT xorg, xdir; - double darr[6], mindist = FHUGE; - /* check each visible object */ - for (op = dobjects; op != NULL; op = op->next) { - if (op->drawcode == DO_HIDE) - continue; - if (op->xfac) { /* transform ray */ - multp3(xorg, rorg, op->xfb.b.xfm); - multv3(xdir, rdir, op->xfb.b.xfm); - VCOPY(darr, xorg); VCOPY(darr+3, xdir); - } else { - VCOPY(darr, rorg); VCOPY(darr+3, rdir); + double darr[6]; + /* check each visible object? */ + if (nm == NULL || *nm == '*') { + double dist, mindist = 1.01*FHUGE; + + if (nm != NULL) nm[0] = '\0'; + for (op = dobjects; op != NULL; op = op->next) { + if (op->drawcode == DO_HIDE) + continue; + dist = dobj_trace(op->name, rorg, rdir); + if (dist < mindist) { + if (nm != NULL) strcpy(nm, op->name); + mindist = dist; + } } - /* trace it */ - if (process(op->rtp, darr, darr, sizeof(double), - 6*sizeof(double)) != sizeof(double)) - error(SYSTEM, "rtrace communication error"); - /* get closest */ - if ((darr[0] *= op->xfb.f.sca) < mindist) - mindist = darr[0]; + return(mindist); } - return(mindist); + /* else check particular object */ + if ((op = getdobj(nm)) == NULL) { + error(COMMAND, "unknown object"); + return(FHUGE); + } + if (op->xfac) { /* put ray in local coordinates */ + multp3(xorg, rorg, op->xfb.b.xfm); + multv3(xdir, rdir, op->xfb.b.xfm); + VCOPY(darr, xorg); VCOPY(darr+3, xdir); + } else { + VCOPY(darr, rorg); VCOPY(darr+3, rdir); + } + /* trace it */ + if (process(op->rtp, darr, darr, sizeof(double), + 6*sizeof(double)) != sizeof(double)) + error(SYSTEM, "rtrace communication error"); + /* return distance */ + if (darr[0] >= .99*FHUGE) + return(FHUGE); + return(darr[0]*op->xfb.f.sca); } +int dobj_render() /* render our objects in OpenGL */ { + int nrendered = 0; GLboolean normalizing; GLfloat vec[4]; + FVECT v1; register DOBJECT *op; register int i; /* anything to render? */ @@ -812,11 +880,11 @@ dobj_render() /* render our objects in OpenGL */ if (op->drawcode != DO_HIDE) break; if (op == NULL) - return(1); + return(0); /* set up general rendering params */ glGetBooleanv(GL_NORMALIZE, &normalizing); - glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT| - GL_DEPTH_BUFFER_BIT|GL_POLYGON_BIT); + glPushAttrib(GL_LIGHTING_BIT|GL_TRANSFORM_BIT|GL_ENABLE_BIT| + GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT|GL_POLYGON_BIT); glDepthFunc(GL_LESS); glEnable(GL_DEPTH_TEST); glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE); @@ -836,7 +904,7 @@ dobj_render() /* render our objects in OpenGL */ if (op->drawcode == DO_LIGHT && op->ol != NULL) { BYTE pval; double expval, d; - + /* use computed sources */ if (tmMapPixels(&pval, &op->ol->larb, TM_NOCHROM, 1) != TM_E_OK) error(CONSISTENCY, "dobj_render w/o tone map"); @@ -862,9 +930,25 @@ dobj_render() /* render our objects in OpenGL */ glLightfv(glightid[i], GL_AMBIENT, vec); glEnable(glightid[i]); } - } else { - vec[0] = vec[1] = vec[2] = 1.; vec[3] = 1.; + } else { /* fake lighting */ + vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.; glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec); + getdcent(v1, op); + VSUB(v1, odev.v.vp, v1); + if (normalize(v1) <= getdrad(op)) { + vec[0] = -odev.v.vdir[0]; + vec[1] = -odev.v.vdir[1]; + vec[2] = -odev.v.vdir[2]; + } else + VCOPY(vec, v1); + vec[3] = 0.; + glLightfv(GL_LIGHT0, GL_POSITION, vec); + vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.; + glLightfv(GL_LIGHT0, GL_SPECULAR, vec); + glLightfv(GL_LIGHT0, GL_DIFFUSE, vec); + vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.; + glLightfv(GL_LIGHT0, GL_AMBIENT, vec); + glEnable(GL_LIGHT0); } /* set up object transform */ if (op->xfac) { @@ -882,6 +966,7 @@ dobj_render() /* render our objects in OpenGL */ } /* render the display list */ glCallList(op->listid); + nrendered++; /* restore matrix */ if (op->xfac) { glMatrixMode(GL_MODELVIEW); @@ -893,9 +978,11 @@ dobj_render() /* render our objects in OpenGL */ if (op->drawcode == DO_LIGHT && op->ol != NULL) for (i = op->ol->nl; i--; ) glDisable(glightid[i]); + else + glDisable(GL_LIGHT0); /* check errors */ - rgl_checkerr("rendering object in dobj_render"); } glPopAttrib(); /* restore rendering params */ - return(1); + rgl_checkerr("rendering objects in dobj_render"); + return(nrendered); }
