root/radiance/ray/src/hd/rhdisp3.c
Revision: 3.7
Committed: Wed Nov 26 20:12:19 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.6: +28 -13 lines
fixed bug in gridlines()
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck beam support for display process
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "view.h"
14
15 struct cellist {
16 GCOORD *cl;
17 int n;
18 };
19
20
21 int
22 npixels(vp, hr, vr, hp, bi) /* compute appropriate number to evaluate */
23 register VIEW *vp;
24 int hr, vr;
25 HOLO *hp;
26 int bi;
27 {
28 VIEW vrev;
29 GCOORD gc[2];
30 FVECT cp[4], ip[4];
31 double af, ab;
32 register int i;
33 /* compute cell corners in image */
34 if (!hdbcoord(gc, hp, bi))
35 error(CONSISTENCY, "bad beam index in npixels");
36 hdcell(cp, hp, gc+1); /* find cell on front image */
37 for (i = 0; i < 4; i++) {
38 viewloc(ip[i], vp, cp[i]);
39 if (ip[i][2] < 0.) {
40 af = 0;
41 goto getback;
42 }
43 ip[i][0] *= (double)hr; /* scale by resolution */
44 ip[i][1] *= (double)vr;
45 }
46 /* compute front area */
47 af = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
48 (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
49 af += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
50 (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
51 if (af >= 0) af *= 0.5;
52 else af *= -0.5;
53 getback:
54 copystruct(&vrev, vp); /* compute reverse view */
55 for (i = 0; i < 3; i++) {
56 vrev.vdir[i] = -vp->vdir[i];
57 vrev.vup[i] = -vp->vup[i];
58 vrev.hvec[i] = -vp->hvec[i];
59 vrev.vvec[i] = -vp->vvec[i];
60 }
61 hdcell(cp, hp, gc); /* find cell on back image */
62 for (i = 0; i < 4; i++) {
63 viewloc(ip[i], &vrev, cp[i]);
64 if (ip[i][2] < 0.)
65 return((int)(af + 0.5));
66 ip[i][0] *= (double)hr; /* scale by resolution */
67 ip[i][1] *= (double)vr;
68 }
69 /* compute back area */
70 ab = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
71 (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
72 ab += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
73 (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
74 if (ab >= 0) ab *= 0.5;
75 else ab *= -0.5;
76 /* round off smaller area */
77 if (af <= ab)
78 return((int)(af + 0.5));
79 return((int)(ab + 0.5));
80 }
81
82
83 /*
84 * The ray directions that define the pyramid in visit_cells() needn't
85 * be normalized, but they must be given in clockwise order as seen
86 * from the pyramid's apex (origin).
87 */
88 int
89 visit_cells(orig, pyrd, hp, vf, dp) /* visit cells within a pyramid */
90 FVECT orig, pyrd[4]; /* pyramid ray directions in clockwise order */
91 HOLO *hp;
92 int (*vf)();
93 char *dp;
94 {
95 int n = 0;
96 int inflags = 0;
97 FVECT gp, pn[4], lo, ld;
98 double po[4], lbeg, lend, d, t;
99 GCOORD gc;
100 register int i;
101 /* figure out whose side we're on */
102 hdgrid(gp, hp, orig);
103 for (i = 0; i < 3; i++) {
104 inflags |= (gp[i] > FTINY) << (i<<1);
105 inflags |= (gp[i] < hp->grid[i]-FTINY) << (i<<1 | 1);
106 }
107 /* compute pyramid planes */
108 for (i = 0; i < 4; i++) {
109 fcross(pn[i], pyrd[i], pyrd[(i+1)&03]);
110 po[i] = DOT(pn[i], orig);
111 }
112 /* traverse each wall */
113 for (gc.w = 0; gc.w < 6; gc.w++) {
114 if (!(inflags & 1<<gc.w)) /* origin on wrong side */
115 continue;
116 /* scanline algorithm */
117 for (gc.i[1] = hp->grid[((gc.w>>1)+2)%3]; gc.i[1]--; ) {
118 /* compute scanline */
119 gp[gc.w>>1] = gc.w&1 ? hp->grid[gc.w>>1] : 0;
120 gp[((gc.w>>1)+1)%3] = 0;
121 gp[((gc.w>>1)+2)%3] = gc.i[1] + 0.5;
122 hdworld(lo, hp, gp);
123 gp[((gc.w>>1)+1)%3] = 1;
124 hdworld(ld, hp, gp);
125 ld[0] -= lo[0]; ld[1] -= lo[1]; ld[2] -= lo[2];
126 /* find scanline limits */
127 lbeg = 0; lend = hp->grid[((gc.w>>1)+1)%3];
128 for (i = 0; i < 4; i++) {
129 t = DOT(pn[i], lo) - po[i];
130 d = -DOT(pn[i], ld);
131 if (d > FTINY) { /* <- plane */
132 if ((t /= d) < lend)
133 lend = t;
134 } else if (d < -FTINY) { /* plane -> */
135 if ((t /= d) > lbeg)
136 lbeg = t;
137 } else if (t < 0) { /* outside */
138 lend = -1;
139 break;
140 }
141 }
142 if (lbeg >= lend)
143 continue;
144 i = lend + .5; /* visit cells on this scan */
145 for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++)
146 n += (*vf)(&gc, dp);
147 }
148 }
149 return(n);
150 }
151
152
153 sect_behind(hp, vp) /* check if section is "behind" viewpoint */
154 register HOLO *hp;
155 register VIEW *vp;
156 {
157 FVECT hcent;
158 /* compute holodeck section center */
159 VSUM(hcent, hp->orig, hp->xv[0], 0.5);
160 VSUM(hcent, hcent, hp->xv[1], 0.5);
161 VSUM(hcent, hcent, hp->xv[2], 0.5);
162 /* behind if center is behind */
163 return(DOT(vp->vdir,hcent) < DOT(vp->vdir,vp->vp));
164 }
165
166
167 viewpyramid(org, dir, hp, vp) /* compute view pyramid */
168 FVECT org, dir[4];
169 HOLO *hp;
170 VIEW *vp;
171 {
172 register int i;
173 /* check view type */
174 if (vp->type == VT_PAR)
175 return(0);
176 /* in front or behind? */
177 if (!sect_behind(hp, vp)) {
178 if (viewray(org, dir[0], vp, 0., 0.) < -FTINY)
179 return(0);
180 if (viewray(org, dir[1], vp, 0., 1.) < -FTINY)
181 return(0);
182 if (viewray(org, dir[2], vp, 1., 1.) < -FTINY)
183 return(0);
184 if (viewray(org, dir[3], vp, 1., 0.) < -FTINY)
185 return(0);
186 return(1);
187 } /* reverse pyramid */
188 if (viewray(org, dir[3], vp, 0., 0.) < -FTINY)
189 return(0);
190 if (viewray(org, dir[2], vp, 0., 1.) < -FTINY)
191 return(0);
192 if (viewray(org, dir[1], vp, 1., 1.) < -FTINY)
193 return(0);
194 if (viewray(org, dir[0], vp, 1., 0.) < -FTINY)
195 return(0);
196 for (i = 0; i < 3; i++) {
197 dir[0][i] = -dir[0][i];
198 dir[1][i] = -dir[1][i];
199 dir[2][i] = -dir[2][i];
200 dir[3][i] = -dir[3][i];
201 }
202 return(-1);
203 }
204
205
206 int
207 addcell(gcp, cl) /* add a cell to a list */
208 GCOORD *gcp;
209 register struct cellist *cl;
210 {
211 copystruct(cl->cl+cl->n, gcp);
212 cl->n++;
213 return(1);
214 }
215
216
217 int
218 cellcmp(gcp1, gcp2) /* visit_cells() cell ordering */
219 register GCOORD *gcp1, *gcp2;
220 {
221 register int c;
222
223 if ((c = gcp1->w - gcp2->w))
224 return(c);
225 if ((c = gcp2->i[1] - gcp1->i[1])) /* wg1 is reverse-ordered */
226 return(c);
227 return(gcp1->i[0] - gcp2->i[0]);
228 }
229
230
231 GCOORD *
232 getviewcells(np, hp, vp) /* get ordered cell list for section view */
233 int *np; /* returned number of cells (negative if reversed) */
234 register HOLO *hp;
235 VIEW *vp;
236 {
237 FVECT org, dir[4];
238 int orient;
239 struct cellist cl;
240 /* compute view pyramid */
241 *np = 0;
242 orient = viewpyramid(org, dir, hp, vp);
243 if (!orient)
244 return(NULL);
245 /* allocate enough list space */
246 cl.n = 2*( hp->grid[0]*hp->grid[1] +
247 hp->grid[0]*hp->grid[2] +
248 hp->grid[1]*hp->grid[2] );
249 cl.cl = (GCOORD *)malloc(cl.n*sizeof(GCOORD));
250 if (cl.cl == NULL)
251 goto memerr;
252 cl.n = 0; /* add cells within pyramid */
253 visit_cells(org, dir, hp, addcell, &cl);
254 if (!cl.n) {
255 free((char *)cl.cl);
256 return(NULL);
257 }
258 *np = cl.n * orient;
259 #if 0
260 /* We're just going to free this memory in a moment, and list is
261 * sorted automatically by visit_cells(), so we don't need this.
262 */
263 /* optimize memory use */
264 cl.cl = (GCOORD *)realloc((char *)cl.cl, cl.n*sizeof(GCOORD));
265 if (cl.cl == NULL)
266 goto memerr;
267 /* sort the list */
268 qsort((char *)cl.cl, cl.n, sizeof(GCOORD), cellcmp);
269 #endif
270 return(cl.cl);
271 memerr:
272 error(SYSTEM, "out of memory in getviewcells");
273 }
274
275
276 gridlines(f) /* run through holodeck section grid lines */
277 int (*f)();
278 {
279 register int hd, w, i;
280 int g0, g1;
281 FVECT wp[2], mov;
282 double d;
283 /* do each wall on each section */
284 for (hd = 0; hdlist[hd] != NULL; hd++)
285 for (w = 0; w < 6; w++) {
286 g0 = ((w>>1)+1)%3;
287 g1 = ((w>>1)+2)%3;
288 d = 1.0/hdlist[hd]->grid[g0];
289 mov[0] = d * hdlist[hd]->xv[g0][0];
290 mov[1] = d * hdlist[hd]->xv[g0][1];
291 mov[2] = d * hdlist[hd]->xv[g0][2];
292 if (w & 1) {
293 VSUM(wp[0], hdlist[hd]->orig,
294 hdlist[hd]->xv[w>>1], 1.);
295 VSUM(wp[0], wp[0], mov, 1.);
296 } else
297 VCOPY(wp[0], hdlist[hd]->orig);
298 VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.);
299 for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */
300 (*f)(wp);
301 if (!--i) break;
302 wp[0][0] += mov[0]; wp[0][1] += mov[1];
303 wp[0][2] += mov[2]; wp[1][0] += mov[0];
304 wp[1][1] += mov[1]; wp[1][2] += mov[2];
305 }
306 d = 1.0/hdlist[hd]->grid[g1];
307 mov[0] = d * hdlist[hd]->xv[g1][0];
308 mov[1] = d * hdlist[hd]->xv[g1][1];
309 mov[2] = d * hdlist[hd]->xv[g1][2];
310 if (w & 1)
311 VSUM(wp[0], hdlist[hd]->orig,
312 hdlist[hd]->xv[w>>1], 1.);
313 else
314 VSUM(wp[0], hdlist[hd]->orig, mov, 1.);
315 VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.);
316 for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */
317 (*f)(wp);
318 if (!--i) break;
319 wp[0][0] += mov[0]; wp[0][1] += mov[1];
320 wp[0][2] += mov[2]; wp[1][0] += mov[0];
321 wp[1][1] += mov[1]; wp[1][2] += mov[2];
322 }
323 }
324 }
