| 1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ SGI";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Holodeck beam support for display process
| 9 |
| 10 |
| 11 |
#include "rholo.h"
| 12 |
#include "rhdisp.h"
| 13 |
#include "view.h"
| 14 |
| 15 |
struct cellist {
| 16 |
GCOORD *cl;
| 17 |
int n;
| 18 |
| 19 |
| 20 |
| 21 |
int
| 22 |
npixels(vp, hr, vr, hp, bi) /* compute appropriate number to evaluate */
| 23 |
VIEW *vp;
| 24 |
int hr, vr;
| 25 |
HOLO *hp;
| 26 |
int bi;
| 27 |
| 28 |
static VIEW vdo, vlast;
| 29 |
static HOLO *hplast;
| 30 |
GCOORD gc[2];
| 31 |
FVECT cp[4];
| 32 |
FVECT ip[4];
| 33 |
double d;
| 34 |
register int i;
| 35 |
/* compute cell corners in image */
| 36 |
if (!hdbcoord(gc, hp, bi))
| 37 |
error(CONSISTENCY, "bad beam index in npixels");
| 38 |
/* has holodeck or view changed? */
| 39 |
if (hp != hplast || bcmp((char *)vp, (char *)&vlast, sizeof(VIEW))) {
| 40 |
copystruct(&vdo, vp);
| 41 |
if (sect_behind(hp, &vdo)) { /* reverse view sense */
| 42 |
vdo.vdir[0] = -vdo.vdir[0];
| 43 |
vdo.vdir[1] = -vdo.vdir[1];
| 44 |
vdo.vdir[2] = -vdo.vdir[2];
| 45 |
setview(&vdo);
| 46 |
| 47 |
hplast = hp;
| 48 |
copystruct(&vlast, vp);
| 49 |
| 50 |
hdcell(cp, hp, gc+1); /* find cell on image */
| 51 |
for (i = 0; i < 4; i++) {
| 52 |
viewloc(ip[i], &vdo, cp[i]);
| 53 |
if (ip[i][2] < 0.)
| 54 |
return(0);
| 55 |
ip[i][0] *= (double)hr; /* scale by resolution */
| 56 |
ip[i][1] *= (double)vr;
| 57 |
| 58 |
/* compute quad area */
| 59 |
d = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
| 60 |
(ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
| 61 |
d += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
| 62 |
(ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
| 63 |
if (d < 0)
| 64 |
d = -d;
| 65 |
/* round off result */
| 66 |
return((int)(.5*d+.5));
| 67 |
| 68 |
| 69 |
| 70 |
| 71 |
* The ray directions that define the pyramid in visit_cells() needn't
| 72 |
* be normalized, but they must be given in clockwise order as seen
| 73 |
* from the pyramid's apex (origin).
| 74 |
| 75 |
int
| 76 |
visit_cells(orig, pyrd, hp, vf, dp) /* visit cells within a pyramid */
| 77 |
FVECT orig, pyrd[4]; /* pyramid ray directions in clockwise order */
| 78 |
HOLO *hp;
| 79 |
int (*vf)();
| 80 |
char *dp;
| 81 |
| 82 |
int n = 0;
| 83 |
int inflags = 0;
| 84 |
FVECT gp, pn[4], lo, ld;
| 85 |
double po[4], lbeg, lend, d, t;
| 86 |
GCOORD gc;
| 87 |
register int i;
| 88 |
/* figure out whose side we're on */
| 89 |
hdgrid(gp, hp, orig);
| 90 |
for (i = 0; i < 3; i++) {
| 91 |
inflags |= (gp[i] > FTINY) << (i<<1);
| 92 |
inflags |= (gp[i] < hp->grid[i]-FTINY) << (i<<1 | 1);
| 93 |
| 94 |
/* compute pyramid planes */
| 95 |
| 96 |
fcross(pn[i], pyrd[i], pyrd[(i+1)&03]);
| 97 |
po[i] = DOT(pn[i], orig);
| 98 |
| 99 |
/* traverse each wall */
| 100 |
for (gc.w = 0; gc.w < 6; gc.w++) {
| 101 |
if (!(inflags & 1<<gc.w)) /* origin on wrong side */
| 102 |
continue;
| 103 |
/* scanline algorithm */
| 104 |
for (gc.i[1] = hp->grid[((gc.w>>1)+2)%3]; gc.i[1]--; ) {
| 105 |
/* compute scanline */
| 106 |
gp[gc.w>>1] = gc.w&1 ? hp->grid[gc.w>>1] : 0;
| 107 |
gp[((gc.w>>1)+1)%3] = 0;
| 108 |
gp[((gc.w>>1)+2)%3] = gc.i[1] + 0.5;
| 109 |
hdworld(lo, hp, gp);
| 110 |
gp[((gc.w>>1)+1)%3] = 1;
| 111 |
hdworld(ld, hp, gp);
| 112 |
ld[0] -= lo[0]; ld[1] -= lo[1]; ld[2] -= lo[2];
| 113 |
/* find scanline limits */
| 114 |
lbeg = 0; lend = hp->grid[((gc.w>>1)+1)%3];
| 115 |
| 116 |
t = DOT(pn[i], lo) - po[i];
| 117 |
d = -DOT(pn[i], ld);
| 118 |
if (d > FTINY) { /* <- plane */
| 119 |
if ((t /= d) < lend)
| 120 |
lend = t;
| 121 |
} else if (d < -FTINY) { /* plane -> */
| 122 |
if ((t /= d) > lbeg)
| 123 |
lbeg = t;
| 124 |
} else if (t < 0) { /* outside */
| 125 |
lend = -1;
| 126 |
break;
| 127 |
| 128 |
| 129 |
if (lbeg >= lend)
| 130 |
continue;
| 131 |
i = lend + .5; /* visit cells on this scan */
| 132 |
for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++)
| 133 |
n += (*vf)(&gc, dp);
| 134 |
| 135 |
| 136 |
return(n);
| 137 |
| 138 |
| 139 |
| 140 |
sect_behind(hp, vp) /* check if section is "behind" viewpoint */
| 141 |
register HOLO *hp;
| 142 |
register VIEW *vp;
| 143 |
| 144 |
FVECT hcent;
| 145 |
/* compute holodeck section center */
| 146 |
VSUM(hcent, hp->orig, hp->xv[0], 0.5);
| 147 |
VSUM(hcent, hcent, hp->xv[1], 0.5);
| 148 |
VSUM(hcent, hcent, hp->xv[2], 0.5);
| 149 |
/* behind if center is behind */
| 150 |
return(DOT(vp->vdir,hcent) < DOT(vp->vdir,vp->vp));
| 151 |
| 152 |
| 153 |
| 154 |
viewpyramid(org, dir, hp, vp) /* compute view pyramid */
| 155 |
FVECT org, dir[4];
| 156 |
HOLO *hp;
| 157 |
VIEW *vp;
| 158 |
| 159 |
register int i;
| 160 |
/* check view type */
| 161 |
if (vp->type == VT_PAR)
| 162 |
return(0);
| 163 |
/* in front or behind? */
| 164 |
if (!sect_behind(hp, vp)) {
| 165 |
if (viewray(org, dir[0], vp, 0., 0.) < -FTINY)
| 166 |
return(0);
| 167 |
if (viewray(org, dir[1], vp, 0., 1.) < -FTINY)
| 168 |
return(0);
| 169 |
if (viewray(org, dir[2], vp, 1., 1.) < -FTINY)
| 170 |
return(0);
| 171 |
if (viewray(org, dir[3], vp, 1., 0.) < -FTINY)
| 172 |
return(0);
| 173 |
return(1);
| 174 |
} /* reverse pyramid */
| 175 |
if (viewray(org, dir[3], vp, 0., 0.) < -FTINY)
| 176 |
return(0);
| 177 |
if (viewray(org, dir[2], vp, 0., 1.) < -FTINY)
| 178 |
return(0);
| 179 |
if (viewray(org, dir[1], vp, 1., 1.) < -FTINY)
| 180 |
return(0);
| 181 |
if (viewray(org, dir[0], vp, 1., 0.) < -FTINY)
| 182 |
return(0);
| 183 |
| 184 |
dir[0][i] = -dir[0][i];
| 185 |
dir[1][i] = -dir[1][i];
| 186 |
dir[2][i] = -dir[2][i];
| 187 |
dir[3][i] = -dir[3][i];
| 188 |
| 189 |
return(-1);
| 190 |
| 191 |
| 192 |
| 193 |
int
| 194 |
addcell(gcp, cl) /* add a cell to a list */
| 195 |
GCOORD *gcp;
| 196 |
register struct cellist *cl;
| 197 |
| 198 |
copystruct(cl->cl+cl->n, gcp);
| 199 |
cl->n++;
| 200 |
return(1);
| 201 |
| 202 |
| 203 |
| 204 |
int
| 205 |
cellcmp(gcp1, gcp2) /* visit_cells() cell ordering */
| 206 |
register GCOORD *gcp1, *gcp2;
| 207 |
| 208 |
register int c;
| 209 |
| 210 |
if ((c = gcp1->w - gcp2->w))
| 211 |
return(c);
| 212 |
if ((c = gcp2->i[1] - gcp1->i[1])) /* wg1 is reverse-ordered */
| 213 |
return(c);
| 214 |
return(gcp1->i[0] - gcp2->i[0]);
| 215 |
| 216 |
| 217 |
| 218 |
GCOORD *
| 219 |
getviewcells(np, hp, vp) /* get ordered cell list for section view */
| 220 |
int *np; /* returned number of cells (negative if reversed) */
| 221 |
register HOLO *hp;
| 222 |
VIEW *vp;
| 223 |
| 224 |
FVECT org, dir[4];
| 225 |
int orient;
| 226 |
struct cellist cl;
| 227 |
| 228 |
*np = 0;
| 229 |
orient = viewpyramid(org, dir, hp, vp);
| 230 |
if (!orient)
| 231 |
return(NULL);
| 232 |
/* allocate enough list space */
| 233 |
cl.n = 2*( hp->grid[0]*hp->grid[1] +
| 234 |
hp->grid[0]*hp->grid[2] +
| 235 |
hp->grid[1]*hp->grid[2] );
| 236 |
cl.cl = (GCOORD *)malloc(cl.n*sizeof(GCOORD));
| 237 |
if (cl.cl == NULL)
| 238 |
goto memerr;
| 239 |
cl.n = 0; /* add cells within pyramid */
| 240 |
visit_cells(org, dir, hp, addcell, &cl);
| 241 |
if (!cl.n) {
| 242 |
free((char *)cl.cl);
| 243 |
return(NULL);
| 244 |
| 245 |
*np = cl.n * orient;
| 246 |
#if 0
| 247 |
/* We're just going to free this memory in a moment, and list is
| 248 |
* sorted automatically by visit_cells(), so we don't need this.
| 249 |
| 250 |
/* optimize memory use */
| 251 |
cl.cl = (GCOORD *)realloc((char *)cl.cl, cl.n*sizeof(GCOORD));
| 252 |
if (cl.cl == NULL)
| 253 |
goto memerr;
| 254 |
/* sort the list */
| 255 |
qsort((char *)cl.cl, cl.n, sizeof(GCOORD), cellcmp);
| 256 |
#endif
| 257 |
return(cl.cl);
| 258 |
memerr:
| 259 |
error(SYSTEM, "out of memory in getviewcells");
| 260 |
