root/radiance/ray/src/hd/rhdisp3.c
Revision: 3.11
Committed: Thu Nov 5 13:58:37 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.10: +4 -1 lines
changed beam management to allow temporary override
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck beam support for display process
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "view.h"
14
15 struct cellist {
16 GCOORD *cl;
17 int n;
18 };
19
20
21 int
22 npixels(vp, hr, vr, hp, bi) /* compute appropriate nrays to evaluate */
23 register VIEW *vp;
24 int hr, vr;
25 HOLO *hp;
26 int bi;
27 {
28 VIEW vrev;
29 GCOORD gc[2];
30 FVECT cp[4], ip[4], pf, pb;
31 double af, ab, sf2, sb2, dfb2, df2, db2, penalty;
32 register int i;
33 /* special case */
34 if (hr <= 0 | vr <= 0)
35 return(0);
36 /* compute cell corners in image */
37 if (!hdbcoord(gc, hp, bi))
38 error(CONSISTENCY, "bad beam index in npixels");
39 hdcell(cp, hp, gc+1); /* find cell on front image */
40 for (i = 3; i--; ) /* compute front center */
41 pf[i] = 0.5*(cp[0][i] + cp[2][i]);
42 sf2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */
43 for (i = 0; i < 4; i++) { /* compute visible quad */
44 viewloc(ip[i], vp, cp[i]);
45 if (ip[i][2] < 0.) {
46 af = 0;
47 goto getback;
48 }
49 ip[i][0] *= (double)hr; /* scale by resolution */
50 ip[i][1] *= (double)vr;
51 }
52 /* compute front area */
53 af = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
54 (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
55 af += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
56 (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
57 af *= af >= 0 ? 0.5 : -0.5;
58 getback:
59 copystruct(&vrev, vp); /* compute reverse view */
60 for (i = 0; i < 3; i++) {
61 vrev.vdir[i] = -vp->vdir[i];
62 vrev.vup[i] = -vp->vup[i];
63 vrev.hvec[i] = -vp->hvec[i];
64 vrev.vvec[i] = -vp->vvec[i];
65 }
66 hdcell(cp, hp, gc); /* find cell on back image */
67 for (i = 3; i--; ) /* compute rear center */
68 pb[i] = 0.5*(cp[0][i] + cp[2][i]);
69 sb2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */
70 for (i = 0; i < 4; i++) { /* compute visible quad */
71 viewloc(ip[i], &vrev, cp[i]);
72 if (ip[i][2] < 0.) {
73 ab = 0;
74 goto finish;
75 }
76 ip[i][0] *= (double)hr; /* scale by resolution */
77 ip[i][1] *= (double)vr;
78 }
79 /* compute back area */
80 ab = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
81 (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
82 ab += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
83 (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
84 ab *= ab >= 0 ? 0.5 : -0.5;
85 finish: /* compute penalty based on dist. sightline - viewpoint */
86 df2 = dist2(vp->vp, pf);
87 db2 = dist2(vp->vp, pb);
88 dfb2 = dist2(pf, pb);
89 penalty = dfb2 + df2 - db2;
90 penalty = df2 - 0.25*penalty*penalty/dfb2;
91 if (df2 > db2) penalty /= df2 <= dfb2 ? sb2 : sb2*df2/dfb2;
92 else penalty /= db2 <= dfb2 ? sf2 : sf2*db2/dfb2;
93 if (penalty < 1.) penalty = 1.;
94 /* round off smaller non-zero area */
95 if (ab <= FTINY || (af > FTINY && af <= ab))
96 return((int)(af/penalty + 0.5));
97 return((int)(ab/penalty + 0.5));
98 }
99
100
101 /*
102 * The ray directions that define the pyramid in visit_cells() needn't
103 * be normalized, but they must be given in clockwise order as seen
104 * from the pyramid's apex (origin).
105 * If no cell centers fall within the domain, the closest cell is visited.
106 */
107 int
108 visit_cells(orig, pyrd, hp, vf, dp) /* visit cells within a pyramid */
109 FVECT orig, pyrd[4]; /* pyramid ray directions in clockwise order */
110 register HOLO *hp;
111 int (*vf)();
112 char *dp;
113 {
114 int ncalls = 0, n = 0;
115 int inflags = 0;
116 FVECT gp, pn[4], lo, ld;
117 double po[4], lbeg, lend, d, t;
118 GCOORD gc, gc2[2];
119 register int i;
120 /* figure out whose side we're on */
121 hdgrid(gp, hp, orig);
122 for (i = 0; i < 3; i++) {
123 inflags |= (gp[i] > FTINY) << (i<<1);
124 inflags |= (gp[i] < hp->grid[i]-FTINY) << (i<<1 | 1);
125 }
126 /* compute pyramid planes */
127 for (i = 0; i < 4; i++) {
128 fcross(pn[i], pyrd[i], pyrd[(i+1)&03]);
129 po[i] = DOT(pn[i], orig);
130 }
131 /* traverse each wall */
132 for (gc.w = 0; gc.w < 6; gc.w++) {
133 if (!(inflags & 1<<gc.w)) /* origin on wrong side */
134 continue;
135 /* scanline algorithm */
136 for (gc.i[1] = hp->grid[hdwg1[gc.w]]; gc.i[1]--; ) {
137 /* compute scanline */
138 gp[gc.w>>1] = gc.w&1 ? hp->grid[gc.w>>1] : 0;
139 gp[hdwg0[gc.w]] = 0;
140 gp[hdwg1[gc.w]] = gc.i[1] + 0.5;
141 hdworld(lo, hp, gp);
142 gp[hdwg0[gc.w]] = 1;
143 hdworld(ld, hp, gp);
144 ld[0] -= lo[0]; ld[1] -= lo[1]; ld[2] -= lo[2];
145 /* find scanline limits */
146 lbeg = 0; lend = hp->grid[hdwg0[gc.w]];
147 for (i = 0; i < 4; i++) {
148 t = DOT(pn[i], lo) - po[i];
149 d = -DOT(pn[i], ld);
150 if (d > FTINY) { /* <- plane */
151 if ((t /= d) < lend)
152 lend = t;
153 } else if (d < -FTINY) { /* plane -> */
154 if ((t /= d) > lbeg)
155 lbeg = t;
156 } else if (t < 0) { /* outside */
157 lend = -1;
158 break;
159 }
160 }
161 if (lbeg >= lend)
162 continue;
163 i = lend + .5; /* visit cells on this scan */
164 for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) {
165 n += (*vf)(&gc, dp);
166 ncalls++;
167 }
168 }
169 }
170 if (ncalls) /* got one at least */
171 return(n);
172 /* else find closest cell */
173 VSUM(ld, pyrd[0], pyrd[1], 1.);
174 VSUM(ld, ld, pyrd[2], 1.);
175 VSUM(ld, ld, pyrd[3], 1.);
176 #if 0
177 if (normalize(ld) == 0.0) /* technically not necessary */
178 return(0);
179 #endif
180 d = hdinter(gc2, NULL, &t, hp, orig, ld);
181 if (d >= FHUGE || t <= 0.)
182 return(0);
183 return((*vf)(gc2+1, dp)); /* visit it */
184 }
185
186
187 sect_behind(hp, vp) /* check if section is "behind" viewpoint */
188 register HOLO *hp;
189 register VIEW *vp;
190 {
191 FVECT hcent;
192 /* compute holodeck section center */
193 VSUM(hcent, hp->orig, hp->xv[0], 0.5);
194 VSUM(hcent, hcent, hp->xv[1], 0.5);
195 VSUM(hcent, hcent, hp->xv[2], 0.5);
196 /* behind if center is behind */
197 return(DOT(vp->vdir,hcent) < DOT(vp->vdir,vp->vp));
198 }
199
200
201 viewpyramid(org, dir, hp, vp) /* compute view pyramid */
202 FVECT org, dir[4];
203 HOLO *hp;
204 VIEW *vp;
205 {
206 register int i;
207 /* check view type */
208 if (vp->type == VT_PAR)
209 return(0);
210 /* in front or behind? */
211 if (!sect_behind(hp, vp)) {
212 if (viewray(org, dir[0], vp, 0., 0.) < -FTINY)
213 return(0);
214 if (viewray(org, dir[1], vp, 0., 1.) < -FTINY)
215 return(0);
216 if (viewray(org, dir[2], vp, 1., 1.) < -FTINY)
217 return(0);
218 if (viewray(org, dir[3], vp, 1., 0.) < -FTINY)
219 return(0);
220 return(1);
221 } /* reverse pyramid */
222 if (viewray(org, dir[3], vp, 0., 0.) < -FTINY)
223 return(0);
224 if (viewray(org, dir[2], vp, 0., 1.) < -FTINY)
225 return(0);
226 if (viewray(org, dir[1], vp, 1., 1.) < -FTINY)
227 return(0);
228 if (viewray(org, dir[0], vp, 1., 0.) < -FTINY)
229 return(0);
230 for (i = 0; i < 3; i++) {
231 dir[0][i] = -dir[0][i];
232 dir[1][i] = -dir[1][i];
233 dir[2][i] = -dir[2][i];
234 dir[3][i] = -dir[3][i];
235 }
236 return(-1);
237 }
238
239
240 int
241 addcell(gcp, cl) /* add a cell to a list */
242 GCOORD *gcp;
243 register struct cellist *cl;
244 {
245 copystruct(cl->cl+cl->n, gcp);
246 cl->n++;
247 return(1);
248 }
249
250
251 int
252 cellcmp(gcp1, gcp2) /* visit_cells() cell ordering */
253 register GCOORD *gcp1, *gcp2;
254 {
255 register int c;
256
257 if ((c = gcp1->w - gcp2->w))
258 return(c);
259 if ((c = gcp2->i[1] - gcp1->i[1])) /* wg1 is reverse-ordered */
260 return(c);
261 return(gcp1->i[0] - gcp2->i[0]);
262 }
263
264
265 GCOORD *
266 getviewcells(np, hp, vp) /* get ordered cell list for section view */
267 int *np; /* returned number of cells (negative if reversed) */
268 register HOLO *hp;
269 VIEW *vp;
270 {
271 FVECT org, dir[4];
272 int orient;
273 struct cellist cl;
274 /* compute view pyramid */
275 *np = 0;
276 orient = viewpyramid(org, dir, hp, vp);
277 if (!orient)
278 return(NULL);
279 /* allocate enough list space */
280 cl.n = 2*( hp->grid[0]*hp->grid[1] +
281 hp->grid[0]*hp->grid[2] +
282 hp->grid[1]*hp->grid[2] );
283 cl.cl = (GCOORD *)malloc(cl.n*sizeof(GCOORD));
284 if (cl.cl == NULL)
285 goto memerr;
286 cl.n = 0; /* add cells within pyramid */
287 visit_cells(org, dir, hp, addcell, (char *)&cl);
288 if (!cl.n) {
289 free((char *)cl.cl);
290 return(NULL);
291 }
292 *np = cl.n * orient;
293 #if 0
294 /* We're just going to free this memory in a moment, and list is
295 * sorted automatically by visit_cells(), so we don't need this.
296 */
297 /* optimize memory use */
298 cl.cl = (GCOORD *)realloc((char *)cl.cl, cl.n*sizeof(GCOORD));
299 if (cl.cl == NULL)
300 goto memerr;
301 /* sort the list */
302 qsort((char *)cl.cl, cl.n, sizeof(GCOORD), cellcmp);
303 #endif
304 return(cl.cl);
305 memerr:
306 error(SYSTEM, "out of memory in getviewcells");
307 }
308
309
310 gridlines(f) /* run through holodeck section grid lines */
311 int (*f)();
312 {
313 register int hd, w, i;
314 int g0, g1;
315 FVECT wp[2], mov;
316 double d;
317 /* do each wall on each section */
318 for (hd = 0; hdlist[hd] != NULL; hd++)
319 for (w = 0; w < 6; w++) {
320 g0 = hdwg0[w];
321 g1 = hdwg1[w];
322 d = 1.0/hdlist[hd]->grid[g0];
323 mov[0] = d * hdlist[hd]->xv[g0][0];
324 mov[1] = d * hdlist[hd]->xv[g0][1];
325 mov[2] = d * hdlist[hd]->xv[g0][2];
326 if (w & 1) {
327 VSUM(wp[0], hdlist[hd]->orig,
328 hdlist[hd]->xv[w>>1], 1.);
329 VSUM(wp[0], wp[0], mov, 1.);
330 } else
331 VCOPY(wp[0], hdlist[hd]->orig);
332 VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.);
333 for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */
334 (*f)(wp);
335 if (!--i) break;
336 wp[0][0] += mov[0]; wp[0][1] += mov[1];
337 wp[0][2] += mov[2]; wp[1][0] += mov[0];
338 wp[1][1] += mov[1]; wp[1][2] += mov[2];
339 }
340 d = 1.0/hdlist[hd]->grid[g1];
341 mov[0] = d * hdlist[hd]->xv[g1][0];
342 mov[1] = d * hdlist[hd]->xv[g1][1];
343 mov[2] = d * hdlist[hd]->xv[g1][2];
344 if (w & 1)
345 VSUM(wp[0], hdlist[hd]->orig,
346 hdlist[hd]->xv[w>>1], 1.);
347 else
348 VSUM(wp[0], hdlist[hd]->orig, mov, 1.);
349 VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.);
350 for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */
351 (*f)(wp);
352 if (!--i) break;
353 wp[0][0] += mov[0]; wp[0][1] += mov[1];
354 wp[0][2] += mov[2]; wp[1][0] += mov[0];
355 wp[1][1] += mov[1]; wp[1][2] += mov[2];
356 }
357 }
358 }
