--- ray/src/hd/rhdisp3.c 1997/11/20 14:21:41 3.2 +++ ray/src/hd/rhdisp3.c 1997/11/26 20:12:19 3.7 @@ -12,39 +12,71 @@ static char SCCSid[] = "$SunId$ SGI"; #include "rhdisp.h" #include "view.h" +struct cellist { + GCOORD *cl; + int n; +}; + int npixels(vp, hr, vr, hp, bi) /* compute appropriate number to evaluate */ -VIEW *vp; +register VIEW *vp; int hr, vr; HOLO *hp; int bi; { + VIEW vrev; GCOORD gc[2]; - FVECT cp[4]; - FVECT ip[4]; - double d; + FVECT cp[4], ip[4]; + double af, ab; register int i; /* compute cell corners in image */ if (!hdbcoord(gc, hp, bi)) error(CONSISTENCY, "bad beam index in npixels"); - hdcell(cp, hp, gc+1); + hdcell(cp, hp, gc+1); /* find cell on front image */ for (i = 0; i < 4; i++) { viewloc(ip[i], vp, cp[i]); + if (ip[i][2] < 0.) { + af = 0; + goto getback; + } + ip[i][0] *= (double)hr; /* scale by resolution */ + ip[i][1] *= (double)vr; + } + /* compute front area */ + af = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - + (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]); + af += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - + (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]); + if (af >= 0) af *= 0.5; + else af *= -0.5; +getback: + copystruct(&vrev, vp); /* compute reverse view */ + for (i = 0; i < 3; i++) { + vrev.vdir[i] = -vp->vdir[i]; + vrev.vup[i] = -vp->vup[i]; + vrev.hvec[i] = -vp->hvec[i]; + vrev.vvec[i] = -vp->vvec[i]; + } + hdcell(cp, hp, gc); /* find cell on back image */ + for (i = 0; i < 4; i++) { + viewloc(ip[i], &vrev, cp[i]); if (ip[i][2] < 0.) - return(0); + return((int)(af + 0.5)); ip[i][0] *= (double)hr; /* scale by resolution */ ip[i][1] *= (double)vr; } - /* compute quad area */ - d = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - + /* compute back area */ + ab = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]); - d += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - + ab += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]); - if (d < 0) - d = -d; - /* round off result */ - return((int)(.5*d+.5)); + if (ab >= 0) ab *= 0.5; + else ab *= -0.5; + /* round off smaller area */ + if (af <= ab) + return((int)(af + 0.5)); + return((int)(ab + 0.5)); } @@ -102,26 +134,82 @@ char *dp; } else if (d < -FTINY) { /* plane -> */ if ((t /= d) > lbeg) lbeg = t; - } else if (t < 0) /* outside */ - goto nextscan; + } else if (t < 0) { /* outside */ + lend = -1; + break; + } } + if (lbeg >= lend) + continue; i = lend + .5; /* visit cells on this scan */ for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) n += (*vf)(&gc, dp); - nextscan:; } } return(n); } +sect_behind(hp, vp) /* check if section is "behind" viewpoint */ +register HOLO *hp; +register VIEW *vp; +{ + FVECT hcent; + /* compute holodeck section center */ + VSUM(hcent, hp->orig, hp->xv[0], 0.5); + VSUM(hcent, hcent, hp->xv[1], 0.5); + VSUM(hcent, hcent, hp->xv[2], 0.5); + /* behind if center is behind */ + return(DOT(vp->vdir,hcent) < DOT(vp->vdir,vp->vp)); +} + + +viewpyramid(org, dir, hp, vp) /* compute view pyramid */ +FVECT org, dir[4]; +HOLO *hp; +VIEW *vp; +{ + register int i; + /* check view type */ + if (vp->type == VT_PAR) + return(0); + /* in front or behind? */ + if (!sect_behind(hp, vp)) { + if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) + return(0); + if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) + return(0); + if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) + return(0); + if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) + return(0); + return(1); + } /* reverse pyramid */ + if (viewray(org, dir[3], vp, 0., 0.) < -FTINY) + return(0); + if (viewray(org, dir[2], vp, 0., 1.) < -FTINY) + return(0); + if (viewray(org, dir[1], vp, 1., 1.) < -FTINY) + return(0); + if (viewray(org, dir[0], vp, 1., 0.) < -FTINY) + return(0); + for (i = 0; i < 3; i++) { + dir[0][i] = -dir[0][i]; + dir[1][i] = -dir[1][i]; + dir[2][i] = -dir[2][i]; + dir[3][i] = -dir[3][i]; + } + return(-1); +} + + int addcell(gcp, cl) /* add a cell to a list */ GCOORD *gcp; -register int *cl; +register struct cellist *cl; { - copystruct((GCOORD *)(cl+1) + *cl, gcp); - (*cl)++; + copystruct(cl->cl+cl->n, gcp); + cl->n++; return(1); } @@ -140,50 +228,97 @@ register GCOORD *gcp1, *gcp2; } -int * -getviewcells(hp, vp) /* get ordered cell list for section view */ +GCOORD * +getviewcells(np, hp, vp) /* get ordered cell list for section view */ +int *np; /* returned number of cells (negative if reversed) */ register HOLO *hp; VIEW *vp; { FVECT org, dir[4]; - int n; - register int *cl; + int orient; + struct cellist cl; /* compute view pyramid */ - if (vp->type == VT_PAR) goto viewerr; - if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) goto viewerr; - if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) goto viewerr; - if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) goto viewerr; - if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) goto viewerr; + *np = 0; + orient = viewpyramid(org, dir, hp, vp); + if (!orient) + return(NULL); /* allocate enough list space */ - n = 2*( hp->grid[0]*hp->grid[1] + - hp->grid[0]*hp->grid[2] + - hp->grid[1]*hp->grid[2] ); - cl = (int *)malloc(sizeof(int) + n*sizeof(GCOORD)); - if (cl == NULL) + cl.n = 2*( hp->grid[0]*hp->grid[1] + + hp->grid[0]*hp->grid[2] + + hp->grid[1]*hp->grid[2] ); + cl.cl = (GCOORD *)malloc(cl.n*sizeof(GCOORD)); + if (cl.cl == NULL) goto memerr; - *cl = 0; - /* add cells within pyramid */ - visit_cells(org, dir, hp, addcell, cl); - if (!*cl) { - free((char *)cl); + cl.n = 0; /* add cells within pyramid */ + visit_cells(org, dir, hp, addcell, &cl); + if (!cl.n) { + free((char *)cl.cl); return(NULL); } + *np = cl.n * orient; #if 0 /* We're just going to free this memory in a moment, and list is * sorted automatically by visit_cells(), so we don't need this. */ - if (*cl < n) { /* optimize memory use */ - cl = (int *)realloc((char *)cl, - sizeof(int) + *cl*sizeof(GCOORD)); - if (cl == NULL) - goto memerr; - } + /* optimize memory use */ + cl.cl = (GCOORD *)realloc((char *)cl.cl, cl.n*sizeof(GCOORD)); + if (cl.cl == NULL) + goto memerr; /* sort the list */ - qsort((char *)(cl+1), *cl, sizeof(GCOORD), cellcmp); + qsort((char *)cl.cl, cl.n, sizeof(GCOORD), cellcmp); #endif - return(cl); -viewerr: - error(INTERNAL, "unusable view in getviewcells"); + return(cl.cl); memerr: error(SYSTEM, "out of memory in getviewcells"); +} + + +gridlines(f) /* run through holodeck section grid lines */ +int (*f)(); +{ + register int hd, w, i; + int g0, g1; + FVECT wp[2], mov; + double d; + /* do each wall on each section */ + for (hd = 0; hdlist[hd] != NULL; hd++) + for (w = 0; w < 6; w++) { + g0 = ((w>>1)+1)%3; + g1 = ((w>>1)+2)%3; + d = 1.0/hdlist[hd]->grid[g0]; + mov[0] = d * hdlist[hd]->xv[g0][0]; + mov[1] = d * hdlist[hd]->xv[g0][1]; + mov[2] = d * hdlist[hd]->xv[g0][2]; + if (w & 1) { + VSUM(wp[0], hdlist[hd]->orig, + hdlist[hd]->xv[w>>1], 1.); + VSUM(wp[0], wp[0], mov, 1.); + } else + VCOPY(wp[0], hdlist[hd]->orig); + VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.); + for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */ + (*f)(wp); + if (!--i) break; + wp[0][0] += mov[0]; wp[0][1] += mov[1]; + wp[0][2] += mov[2]; wp[1][0] += mov[0]; + wp[1][1] += mov[1]; wp[1][2] += mov[2]; + } + d = 1.0/hdlist[hd]->grid[g1]; + mov[0] = d * hdlist[hd]->xv[g1][0]; + mov[1] = d * hdlist[hd]->xv[g1][1]; + mov[2] = d * hdlist[hd]->xv[g1][2]; + if (w & 1) + VSUM(wp[0], hdlist[hd]->orig, + hdlist[hd]->xv[w>>1], 1.); + else + VSUM(wp[0], hdlist[hd]->orig, mov, 1.); + VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.); + for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */ + (*f)(wp); + if (!--i) break; + wp[0][0] += mov[0]; wp[0][1] += mov[1]; + wp[0][2] += mov[2]; wp[1][0] += mov[0]; + wp[1][1] += mov[1]; wp[1][2] += mov[2]; + } + } }
