--- ray/src/hd/rhdisp3.c 1997/11/20 14:21:41 3.2 +++ ray/src/hd/rhdisp3.c 2004/06/08 19:48:30 3.16 @@ -1,50 +1,96 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhdisp3.c,v 3.16 2004/06/08 19:48:30 greg Exp $"; #endif - /* * Holodeck beam support for display process */ #include "rholo.h" #include "rhdisp.h" -#include "view.h" +struct cellist { + GCOORD *cl; + int n; +}; + int -npixels(vp, hr, vr, hp, bi) /* compute appropriate number to evaluate */ -VIEW *vp; +npixels(vp, hr, vr, hp, bi) /* compute appropriate nrays to evaluate */ +register VIEW *vp; int hr, vr; HOLO *hp; int bi; { + VIEW vrev; GCOORD gc[2]; - FVECT cp[4]; - FVECT ip[4]; - double d; + FVECT cp[4], ip[4], pf, pb; + double af, ab, sf2, sb2, dfb2, df2, db2, penalty; register int i; + /* special case */ + if (hr <= 0 | vr <= 0) + return(0); /* compute cell corners in image */ if (!hdbcoord(gc, hp, bi)) error(CONSISTENCY, "bad beam index in npixels"); - hdcell(cp, hp, gc+1); - for (i = 0; i < 4; i++) { + hdcell(cp, hp, gc+1); /* find cell on front image */ + for (i = 3; i--; ) /* compute front center */ + pf[i] = 0.5*(cp[0][i] + cp[2][i]); + sf2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */ + for (i = 0; i < 4; i++) { /* compute visible quad */ viewloc(ip[i], vp, cp[i]); - if (ip[i][2] < 0.) - return(0); + if (ip[i][2] < 0.) { + af = 0; + goto getback; + } ip[i][0] *= (double)hr; /* scale by resolution */ ip[i][1] *= (double)vr; } - /* compute quad area */ - d = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - + /* compute front area */ + af = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]); - d += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - + af += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]); - if (d < 0) - d = -d; - /* round off result */ - return((int)(.5*d+.5)); + af *= af >= 0 ? 0.5 : -0.5; +getback: + vrev = *vp; /* compute reverse view */ + for (i = 0; i < 3; i++) { + vrev.vdir[i] = -vp->vdir[i]; + vrev.vup[i] = -vp->vup[i]; + vrev.hvec[i] = -vp->hvec[i]; + vrev.vvec[i] = -vp->vvec[i]; + } + hdcell(cp, hp, gc); /* find cell on back image */ + for (i = 3; i--; ) /* compute rear center */ + pb[i] = 0.5*(cp[0][i] + cp[2][i]); + sb2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */ + for (i = 0; i < 4; i++) { /* compute visible quad */ + viewloc(ip[i], &vrev, cp[i]); + if (ip[i][2] < 0.) { + ab = 0; + goto finish; + } + ip[i][0] *= (double)hr; /* scale by resolution */ + ip[i][1] *= (double)vr; + } + /* compute back area */ + ab = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - + (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]); + ab += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - + (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]); + ab *= ab >= 0 ? 0.5 : -0.5; +finish: /* compute penalty based on dist. sightline - viewpoint */ + df2 = dist2(vp->vp, pf); + db2 = dist2(vp->vp, pb); + dfb2 = dist2(pf, pb); + penalty = dfb2 + df2 - db2; + penalty = df2 - 0.25*penalty*penalty/dfb2; + if (df2 > db2) penalty /= df2 <= dfb2 ? sb2 : sb2*df2/dfb2; + else penalty /= db2 <= dfb2 ? sf2 : sf2*db2/dfb2; + if (penalty < 1.) penalty = 1.; + /* round off smaller non-zero area */ + if (ab <= FTINY || (af > FTINY && af <= ab)) + return((int)(af/penalty + 0.5)); + return((int)(ab/penalty + 0.5)); } @@ -52,19 +98,20 @@ int bi; * The ray directions that define the pyramid in visit_cells() needn't * be normalized, but they must be given in clockwise order as seen * from the pyramid's apex (origin). + * If no cell centers fall within the domain, the closest cell is visited. */ int visit_cells(orig, pyrd, hp, vf, dp) /* visit cells within a pyramid */ FVECT orig, pyrd[4]; /* pyramid ray directions in clockwise order */ -HOLO *hp; +register HOLO *hp; int (*vf)(); char *dp; { - int n = 0; + int ncalls = 0, n = 0; int inflags = 0; FVECT gp, pn[4], lo, ld; double po[4], lbeg, lend, d, t; - GCOORD gc; + GCOORD gc, gc2[2]; register int i; /* figure out whose side we're on */ hdgrid(gp, hp, orig); @@ -82,17 +129,17 @@ char *dp; if (!(inflags & 1<grid[((gc.w>>1)+2)%3]; gc.i[1]--; ) { + for (gc.i[1] = hp->grid[hdwg1[gc.w]]; gc.i[1]--; ) { /* compute scanline */ gp[gc.w>>1] = gc.w&1 ? hp->grid[gc.w>>1] : 0; - gp[((gc.w>>1)+1)%3] = 0; - gp[((gc.w>>1)+2)%3] = gc.i[1] + 0.5; + gp[hdwg0[gc.w]] = 0; + gp[hdwg1[gc.w]] = gc.i[1] + 0.5; hdworld(lo, hp, gp); - gp[((gc.w>>1)+1)%3] = 1; + gp[hdwg0[gc.w]] = 1; hdworld(ld, hp, gp); ld[0] -= lo[0]; ld[1] -= lo[1]; ld[2] -= lo[2]; /* find scanline limits */ - lbeg = 0; lend = hp->grid[((gc.w>>1)+1)%3]; + lbeg = 0; lend = hp->grid[hdwg0[gc.w]]; for (i = 0; i < 4; i++) { t = DOT(pn[i], lo) - po[i]; d = -DOT(pn[i], ld); @@ -102,26 +149,97 @@ char *dp; } else if (d < -FTINY) { /* plane -> */ if ((t /= d) > lbeg) lbeg = t; - } else if (t < 0) /* outside */ - goto nextscan; + } else if (t < 0) { /* outside */ + lend = -1; + break; + } } + if (lbeg >= lend) + continue; i = lend + .5; /* visit cells on this scan */ - for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) + for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) { n += (*vf)(&gc, dp); - nextscan:; + ncalls++; + } } } - return(n); + if (ncalls) /* got one at least */ + return(n); + /* else find closest cell */ + VSUM(ld, pyrd[0], pyrd[1], 1.); + VSUM(ld, ld, pyrd[2], 1.); + VSUM(ld, ld, pyrd[3], 1.); +#if 0 + if (normalize(ld) == 0.0) /* technically not necessary */ + return(0); +#endif + d = hdinter(gc2, NULL, &t, hp, orig, ld); + if (d >= FHUGE || t <= 0.) + return(0); + return((*vf)(gc2+1, dp)); /* visit it */ } +sect_behind(hp, vp) /* check if section is "behind" viewpoint */ +register HOLO *hp; +register VIEW *vp; +{ + FVECT hcent; + /* compute holodeck section center */ + VSUM(hcent, hp->orig, hp->xv[0], 0.5); + VSUM(hcent, hcent, hp->xv[1], 0.5); + VSUM(hcent, hcent, hp->xv[2], 0.5); + /* behind if center is behind */ + return(DOT(vp->vdir,hcent) < DOT(vp->vdir,vp->vp)); +} + + +viewpyramid(org, dir, hp, vp) /* compute view pyramid */ +FVECT org, dir[4]; +HOLO *hp; +VIEW *vp; +{ + register int i; + /* check view type */ + if (vp->type == VT_PAR) + return(0); + /* in front or behind? */ + if (!sect_behind(hp, vp)) { + if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) + return(0); + if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) + return(0); + if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) + return(0); + if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) + return(0); + return(1); + } /* reverse pyramid */ + if (viewray(org, dir[3], vp, 0., 0.) < -FTINY) + return(0); + if (viewray(org, dir[2], vp, 0., 1.) < -FTINY) + return(0); + if (viewray(org, dir[1], vp, 1., 1.) < -FTINY) + return(0); + if (viewray(org, dir[0], vp, 1., 0.) < -FTINY) + return(0); + for (i = 0; i < 3; i++) { + dir[0][i] = -dir[0][i]; + dir[1][i] = -dir[1][i]; + dir[2][i] = -dir[2][i]; + dir[3][i] = -dir[3][i]; + } + return(-1); +} + + int addcell(gcp, cl) /* add a cell to a list */ GCOORD *gcp; -register int *cl; +register struct cellist *cl; { - copystruct((GCOORD *)(cl+1) + *cl, gcp); - (*cl)++; + *(cl->cl+cl->n) = *gcp; + cl->n++; return(1); } @@ -140,50 +258,99 @@ register GCOORD *gcp1, *gcp2; } -int * -getviewcells(hp, vp) /* get ordered cell list for section view */ +GCOORD * +getviewcells(np, hp, vp) /* get ordered cell list for section view */ +int *np; /* returned number of cells (negative if reversed) */ register HOLO *hp; VIEW *vp; { FVECT org, dir[4]; - int n; - register int *cl; + int orient; + struct cellist cl; /* compute view pyramid */ - if (vp->type == VT_PAR) goto viewerr; - if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) goto viewerr; - if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) goto viewerr; - if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) goto viewerr; - if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) goto viewerr; + *np = 0; + orient = viewpyramid(org, dir, hp, vp); + if (!orient) + return(NULL); /* allocate enough list space */ - n = 2*( hp->grid[0]*hp->grid[1] + - hp->grid[0]*hp->grid[2] + - hp->grid[1]*hp->grid[2] ); - cl = (int *)malloc(sizeof(int) + n*sizeof(GCOORD)); - if (cl == NULL) + cl.n = 2*( hp->grid[0]*hp->grid[1] + + hp->grid[0]*hp->grid[2] + + hp->grid[1]*hp->grid[2] ); + cl.cl = (GCOORD *)malloc(cl.n*sizeof(GCOORD)); + if (cl.cl == NULL) goto memerr; - *cl = 0; - /* add cells within pyramid */ - visit_cells(org, dir, hp, addcell, cl); - if (!*cl) { - free((char *)cl); + cl.n = 0; /* add cells within pyramid */ + visit_cells(org, dir, hp, addcell, (char *)&cl); + if (!cl.n) { + free((void *)cl.cl); return(NULL); } + *np = cl.n * orient; #if 0 /* We're just going to free this memory in a moment, and list is * sorted automatically by visit_cells(), so we don't need this. */ - if (*cl < n) { /* optimize memory use */ - cl = (int *)realloc((char *)cl, - sizeof(int) + *cl*sizeof(GCOORD)); - if (cl == NULL) - goto memerr; - } + /* optimize memory use */ + cl.cl = (GCOORD *)realloc((void *)cl.cl, cl.n*sizeof(GCOORD)); + if (cl.cl == NULL) + goto memerr; /* sort the list */ - qsort((char *)(cl+1), *cl, sizeof(GCOORD), cellcmp); + qsort((char *)cl.cl, cl.n, sizeof(GCOORD), cellcmp); #endif - return(cl); -viewerr: - error(INTERNAL, "unusable view in getviewcells"); + return(cl.cl); memerr: error(SYSTEM, "out of memory in getviewcells"); +} + + +extern void +gridlines( /* run through holodeck section grid lines */ + void (*f)(FVECT wp[2]) +) +{ + register int hd, w, i; + int g0, g1; + FVECT wp[2], mov; + double d; + /* do each wall on each section */ + for (hd = 0; hdlist[hd] != NULL; hd++) + for (w = 0; w < 6; w++) { + g0 = hdwg0[w]; + g1 = hdwg1[w]; + d = 1.0/hdlist[hd]->grid[g0]; + mov[0] = d * hdlist[hd]->xv[g0][0]; + mov[1] = d * hdlist[hd]->xv[g0][1]; + mov[2] = d * hdlist[hd]->xv[g0][2]; + if (w & 1) { + VSUM(wp[0], hdlist[hd]->orig, + hdlist[hd]->xv[w>>1], 1.); + VSUM(wp[0], wp[0], mov, 1.); + } else + VCOPY(wp[0], hdlist[hd]->orig); + VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.); + for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */ + (*f)(wp); + if (!--i) break; + wp[0][0] += mov[0]; wp[0][1] += mov[1]; + wp[0][2] += mov[2]; wp[1][0] += mov[0]; + wp[1][1] += mov[1]; wp[1][2] += mov[2]; + } + d = 1.0/hdlist[hd]->grid[g1]; + mov[0] = d * hdlist[hd]->xv[g1][0]; + mov[1] = d * hdlist[hd]->xv[g1][1]; + mov[2] = d * hdlist[hd]->xv[g1][2]; + if (w & 1) + VSUM(wp[0], hdlist[hd]->orig, + hdlist[hd]->xv[w>>1], 1.); + else + VSUM(wp[0], hdlist[hd]->orig, mov, 1.); + VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.); + for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */ + (*f)(wp); + if (!--i) break; + wp[0][0] += mov[0]; wp[0][1] += mov[1]; + wp[0][2] += mov[2]; wp[1][0] += mov[0]; + wp[1][1] += mov[1]; wp[1][2] += mov[2]; + } + } }
