root/Development/ray/src/hd/rhdisp3.c
Revision: 3.20
Committed: Thu May 14 20:58:03 2020 UTC (5 years, 6 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, HEAD
Changes since 3.19: +3 -3 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.20 static const char RCSid[] = "$Id: rhdisp3.c,v 3.19 2020/03/12 17:19:18 greg Exp $";
3 gregl 3.1 #endif
4     /*
5 gregl 3.2 * Holodeck beam support for display process
6 gregl 3.1 */
7
8     #include "rholo.h"
9     #include "rhdisp.h"
10
11 gregl 3.4 struct cellist {
12     GCOORD *cl;
13     int n;
14     };
15 gregl 3.1
16 gregl 3.4
17 gregl 3.1 int
18 gwlarson 3.10 npixels(vp, hr, vr, hp, bi) /* compute appropriate nrays to evaluate */
19 greg 3.18 VIEW *vp;
20 gregl 3.1 int hr, vr;
21     HOLO *hp;
22     int bi;
23     {
24 gregl 3.5 VIEW vrev;
25 gregl 3.1 GCOORD gc[2];
26 gwlarson 3.10 FVECT cp[4], ip[4], pf, pb;
27     double af, ab, sf2, sb2, dfb2, df2, db2, penalty;
28 greg 3.18 int i;
29 gwlarson 3.11 /* special case */
30     if (hr <= 0 | vr <= 0)
31     return(0);
32 gregl 3.1 /* compute cell corners in image */
33     if (!hdbcoord(gc, hp, bi))
34     error(CONSISTENCY, "bad beam index in npixels");
35 gregl 3.5 hdcell(cp, hp, gc+1); /* find cell on front image */
36 gwlarson 3.10 for (i = 3; i--; ) /* compute front center */
37     pf[i] = 0.5*(cp[0][i] + cp[2][i]);
38     sf2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */
39     for (i = 0; i < 4; i++) { /* compute visible quad */
40 greg 3.20 if (viewloc(ip[i], vp, cp[i]) != VL_GOOD) {
41 gregl 3.5 af = 0;
42     goto getback;
43 gregl 3.4 }
44 gregl 3.5 ip[i][0] *= (double)hr; /* scale by resolution */
45     ip[i][1] *= (double)vr;
46 gregl 3.4 }
47 gregl 3.5 /* compute front area */
48     af = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
49     (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
50     af += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
51     (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
52 gwlarson 3.10 af *= af >= 0 ? 0.5 : -0.5;
53 gregl 3.5 getback:
54 schorsch 3.14 vrev = *vp; /* compute reverse view */
55 gregl 3.5 for (i = 0; i < 3; i++) {
56     vrev.vdir[i] = -vp->vdir[i];
57     vrev.vup[i] = -vp->vup[i];
58     vrev.hvec[i] = -vp->hvec[i];
59     vrev.vvec[i] = -vp->vvec[i];
60     }
61     hdcell(cp, hp, gc); /* find cell on back image */
62 gwlarson 3.10 for (i = 3; i--; ) /* compute rear center */
63     pb[i] = 0.5*(cp[0][i] + cp[2][i]);
64     sb2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */
65     for (i = 0; i < 4; i++) { /* compute visible quad */
66 greg 3.20 if (viewloc(ip[i], &vrev, cp[i]) != VL_GOOD) {
67 gwlarson 3.10 ab = 0;
68     goto finish;
69     }
70 gregl 3.1 ip[i][0] *= (double)hr; /* scale by resolution */
71     ip[i][1] *= (double)vr;
72     }
73 gregl 3.5 /* compute back area */
74     ab = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
75 gregl 3.1 (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
76 gregl 3.5 ab += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
77 gregl 3.1 (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
78 gwlarson 3.10 ab *= ab >= 0 ? 0.5 : -0.5;
79     finish: /* compute penalty based on dist. sightline - viewpoint */
80     df2 = dist2(vp->vp, pf);
81     db2 = dist2(vp->vp, pb);
82     dfb2 = dist2(pf, pb);
83     penalty = dfb2 + df2 - db2;
84     penalty = df2 - 0.25*penalty*penalty/dfb2;
85     if (df2 > db2) penalty /= df2 <= dfb2 ? sb2 : sb2*df2/dfb2;
86     else penalty /= db2 <= dfb2 ? sf2 : sf2*db2/dfb2;
87     if (penalty < 1.) penalty = 1.;
88     /* round off smaller non-zero area */
89     if (ab <= FTINY || (af > FTINY && af <= ab))
90     return((int)(af/penalty + 0.5));
91     return((int)(ab/penalty + 0.5));
92 gregl 3.1 }
93
94
95     /*
96     * The ray directions that define the pyramid in visit_cells() needn't
97     * be normalized, but they must be given in clockwise order as seen
98     * from the pyramid's apex (origin).
99 gregl 3.8 * If no cell centers fall within the domain, the closest cell is visited.
100 gregl 3.1 */
101     int
102     visit_cells(orig, pyrd, hp, vf, dp) /* visit cells within a pyramid */
103     FVECT orig, pyrd[4]; /* pyramid ray directions in clockwise order */
104 greg 3.18 HOLO *hp;
105 gregl 3.1 int (*vf)();
106     char *dp;
107     {
108 gregl 3.8 int ncalls = 0, n = 0;
109 gregl 3.1 int inflags = 0;
110     FVECT gp, pn[4], lo, ld;
111     double po[4], lbeg, lend, d, t;
112 gregl 3.8 GCOORD gc, gc2[2];
113 greg 3.18 int i;
114 gregl 3.1 /* figure out whose side we're on */
115     hdgrid(gp, hp, orig);
116     for (i = 0; i < 3; i++) {
117     inflags |= (gp[i] > FTINY) << (i<<1);
118     inflags |= (gp[i] < hp->grid[i]-FTINY) << (i<<1 | 1);
119     }
120     /* compute pyramid planes */
121     for (i = 0; i < 4; i++) {
122     fcross(pn[i], pyrd[i], pyrd[(i+1)&03]);
123     po[i] = DOT(pn[i], orig);
124     }
125     /* traverse each wall */
126     for (gc.w = 0; gc.w < 6; gc.w++) {
127     if (!(inflags & 1<<gc.w)) /* origin on wrong side */
128     continue;
129     /* scanline algorithm */
130 gregl 3.9 for (gc.i[1] = hp->grid[hdwg1[gc.w]]; gc.i[1]--; ) {
131 gregl 3.1 /* compute scanline */
132     gp[gc.w>>1] = gc.w&1 ? hp->grid[gc.w>>1] : 0;
133 gregl 3.9 gp[hdwg0[gc.w]] = 0;
134     gp[hdwg1[gc.w]] = gc.i[1] + 0.5;
135 gregl 3.1 hdworld(lo, hp, gp);
136 gregl 3.9 gp[hdwg0[gc.w]] = 1;
137 gregl 3.1 hdworld(ld, hp, gp);
138 gregl 3.2 ld[0] -= lo[0]; ld[1] -= lo[1]; ld[2] -= lo[2];
139 gregl 3.1 /* find scanline limits */
140 gregl 3.9 lbeg = 0; lend = hp->grid[hdwg0[gc.w]];
141 gregl 3.1 for (i = 0; i < 4; i++) {
142     t = DOT(pn[i], lo) - po[i];
143     d = -DOT(pn[i], ld);
144 gregl 3.2 if (d > FTINY) { /* <- plane */
145 gregl 3.1 if ((t /= d) < lend)
146     lend = t;
147 gregl 3.2 } else if (d < -FTINY) { /* plane -> */
148 gregl 3.1 if ((t /= d) > lbeg)
149     lbeg = t;
150 gregl 3.3 } else if (t < 0) { /* outside */
151     lend = -1;
152     break;
153     }
154 gregl 3.1 }
155 gregl 3.3 if (lbeg >= lend)
156     continue;
157 gregl 3.1 i = lend + .5; /* visit cells on this scan */
158 gregl 3.8 for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) {
159 gregl 3.1 n += (*vf)(&gc, dp);
160 gregl 3.8 ncalls++;
161     }
162 gregl 3.1 }
163     }
164 gregl 3.8 if (ncalls) /* got one at least */
165     return(n);
166     /* else find closest cell */
167     VSUM(ld, pyrd[0], pyrd[1], 1.);
168     VSUM(ld, ld, pyrd[2], 1.);
169     VSUM(ld, ld, pyrd[3], 1.);
170     #if 0
171     if (normalize(ld) == 0.0) /* technically not necessary */
172     return(0);
173     #endif
174     d = hdinter(gc2, NULL, &t, hp, orig, ld);
175 greg 3.19 if (d >= FHUGE*.99 || t <= 0.)
176 gregl 3.8 return(0);
177     return((*vf)(gc2+1, dp)); /* visit it */
178 gregl 3.1 }
179
180
181 gregl 3.4 sect_behind(hp, vp) /* check if section is "behind" viewpoint */
182 greg 3.18 HOLO *hp;
183     VIEW *vp;
184 gregl 3.4 {
185     FVECT hcent;
186     /* compute holodeck section center */
187     VSUM(hcent, hp->orig, hp->xv[0], 0.5);
188     VSUM(hcent, hcent, hp->xv[1], 0.5);
189     VSUM(hcent, hcent, hp->xv[2], 0.5);
190     /* behind if center is behind */
191     return(DOT(vp->vdir,hcent) < DOT(vp->vdir,vp->vp));
192     }
193
194
195     viewpyramid(org, dir, hp, vp) /* compute view pyramid */
196     FVECT org, dir[4];
197     HOLO *hp;
198     VIEW *vp;
199     {
200 greg 3.18 int i;
201 gregl 3.4 /* check view type */
202     if (vp->type == VT_PAR)
203     return(0);
204     /* in front or behind? */
205     if (!sect_behind(hp, vp)) {
206     if (viewray(org, dir[0], vp, 0., 0.) < -FTINY)
207     return(0);
208     if (viewray(org, dir[1], vp, 0., 1.) < -FTINY)
209     return(0);
210     if (viewray(org, dir[2], vp, 1., 1.) < -FTINY)
211     return(0);
212     if (viewray(org, dir[3], vp, 1., 0.) < -FTINY)
213     return(0);
214     return(1);
215     } /* reverse pyramid */
216     if (viewray(org, dir[3], vp, 0., 0.) < -FTINY)
217     return(0);
218     if (viewray(org, dir[2], vp, 0., 1.) < -FTINY)
219     return(0);
220     if (viewray(org, dir[1], vp, 1., 1.) < -FTINY)
221     return(0);
222     if (viewray(org, dir[0], vp, 1., 0.) < -FTINY)
223     return(0);
224     for (i = 0; i < 3; i++) {
225     dir[0][i] = -dir[0][i];
226     dir[1][i] = -dir[1][i];
227     dir[2][i] = -dir[2][i];
228     dir[3][i] = -dir[3][i];
229     }
230     return(-1);
231     }
232
233
234 gregl 3.1 int
235     addcell(gcp, cl) /* add a cell to a list */
236     GCOORD *gcp;
237 greg 3.18 struct cellist *cl;
238 gregl 3.1 {
239 schorsch 3.14 *(cl->cl+cl->n) = *gcp;
240 gregl 3.4 cl->n++;
241 gregl 3.1 return(1);
242     }
243
244
245     int
246     cellcmp(gcp1, gcp2) /* visit_cells() cell ordering */
247 greg 3.18 GCOORD *gcp1, *gcp2;
248 gregl 3.1 {
249 greg 3.18 int c;
250 gregl 3.1
251     if ((c = gcp1->w - gcp2->w))
252     return(c);
253     if ((c = gcp2->i[1] - gcp1->i[1])) /* wg1 is reverse-ordered */
254     return(c);
255     return(gcp1->i[0] - gcp2->i[0]);
256     }
257
258
259 gregl 3.4 GCOORD *
260     getviewcells(np, hp, vp) /* get ordered cell list for section view */
261     int *np; /* returned number of cells (negative if reversed) */
262 greg 3.18 HOLO *hp;
263 gregl 3.1 VIEW *vp;
264     {
265     FVECT org, dir[4];
266 gregl 3.4 int orient;
267     struct cellist cl;
268 gregl 3.1 /* compute view pyramid */
269 gregl 3.4 *np = 0;
270     orient = viewpyramid(org, dir, hp, vp);
271     if (!orient)
272     return(NULL);
273 gregl 3.1 /* allocate enough list space */
274 gregl 3.4 cl.n = 2*( hp->grid[0]*hp->grid[1] +
275     hp->grid[0]*hp->grid[2] +
276     hp->grid[1]*hp->grid[2] );
277     cl.cl = (GCOORD *)malloc(cl.n*sizeof(GCOORD));
278     if (cl.cl == NULL)
279 gregl 3.1 goto memerr;
280 gregl 3.4 cl.n = 0; /* add cells within pyramid */
281 gwlarson 3.11 visit_cells(org, dir, hp, addcell, (char *)&cl);
282 gregl 3.4 if (!cl.n) {
283 greg 3.12 free((void *)cl.cl);
284 gregl 3.1 return(NULL);
285     }
286 gregl 3.4 *np = cl.n * orient;
287 gregl 3.1 #if 0
288 gregl 3.2 /* We're just going to free this memory in a moment, and list is
289     * sorted automatically by visit_cells(), so we don't need this.
290     */
291 gregl 3.4 /* optimize memory use */
292 greg 3.13 cl.cl = (GCOORD *)realloc((void *)cl.cl, cl.n*sizeof(GCOORD));
293 gregl 3.4 if (cl.cl == NULL)
294     goto memerr;
295 gregl 3.1 /* sort the list */
296 gregl 3.4 qsort((char *)cl.cl, cl.n, sizeof(GCOORD), cellcmp);
297 gregl 3.1 #endif
298 gregl 3.4 return(cl.cl);
299 gregl 3.1 memerr:
300     error(SYSTEM, "out of memory in getviewcells");
301     }
302 gregl 3.6
303
304 greg 3.18 void
305 schorsch 3.15 gridlines( /* run through holodeck section grid lines */
306     void (*f)(FVECT wp[2])
307     )
308 gregl 3.6 {
309 greg 3.18 int hd, w, i;
310 gregl 3.6 int g0, g1;
311 gregl 3.7 FVECT wp[2], mov;
312 gregl 3.6 double d;
313     /* do each wall on each section */
314     for (hd = 0; hdlist[hd] != NULL; hd++)
315     for (w = 0; w < 6; w++) {
316 gregl 3.9 g0 = hdwg0[w];
317     g1 = hdwg1[w];
318 gregl 3.7 d = 1.0/hdlist[hd]->grid[g0];
319     mov[0] = d * hdlist[hd]->xv[g0][0];
320     mov[1] = d * hdlist[hd]->xv[g0][1];
321     mov[2] = d * hdlist[hd]->xv[g0][2];
322     if (w & 1) {
323 gregl 3.6 VSUM(wp[0], hdlist[hd]->orig,
324     hdlist[hd]->xv[w>>1], 1.);
325 gregl 3.7 VSUM(wp[0], wp[0], mov, 1.);
326     } else
327     VCOPY(wp[0], hdlist[hd]->orig);
328     VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.);
329     for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */
330 gregl 3.6 (*f)(wp);
331 gregl 3.7 if (!--i) break;
332     wp[0][0] += mov[0]; wp[0][1] += mov[1];
333     wp[0][2] += mov[2]; wp[1][0] += mov[0];
334     wp[1][1] += mov[1]; wp[1][2] += mov[2];
335 gregl 3.6 }
336 gregl 3.7 d = 1.0/hdlist[hd]->grid[g1];
337     mov[0] = d * hdlist[hd]->xv[g1][0];
338     mov[1] = d * hdlist[hd]->xv[g1][1];
339     mov[2] = d * hdlist[hd]->xv[g1][2];
340     if (w & 1)
341 gregl 3.6 VSUM(wp[0], hdlist[hd]->orig,
342     hdlist[hd]->xv[w>>1], 1.);
343 gregl 3.7 else
344     VSUM(wp[0], hdlist[hd]->orig, mov, 1.);
345     VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.);
346     for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */
347 gregl 3.6 (*f)(wp);
348 gregl 3.7 if (!--i) break;
349     wp[0][0] += mov[0]; wp[0][1] += mov[1];
350     wp[0][2] += mov[2]; wp[1][0] += mov[0];
351     wp[1][1] += mov[1]; wp[1][2] += mov[2];
352 gregl 3.6 }
353     }
354     }
