Ansification and prototypes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed beam management to allow temporary override
improved npixels() calculation to consider view position
changed visit_cells() so it makes at least one call to (*vf)()
fixed bug in gridlines()
created gridlines() function to run through holodeck section grids
improved and fixed npixels()
added check for holodeck behind viewpoint for more robust beam selection
fixed serious error caused by conversion from double to int
fixed bug in visitcells()
