root/radiance/ray/src/hd/rhdisp3.c
Tue Jun 8 19:48:30 2004 UTC (19 years, 9 months ago) by greg
Changes since 3.15: +1 -2 lines
Diff to previous 3.15 , to selected 3.8
Thu Jan 1 11:21:55 2004 UTC (20 years, 3 months ago) by schorsch
Changes since 3.14: +5 -3 lines
Diff to previous 3.14 , to selected 3.8
Ansification and prototypes.
Mon Jul 21 22:30:18 2003 UTC (20 years, 8 months ago) by schorsch
Diff to previous 3.13 , to selected 3.8
Wed Apr 23 00:52:33 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.12: +1 -1 lines
Diff to previous 3.12 , to selected 3.8
Sat Feb 22 02:07:24 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.11: +2 -5 lines
Diff to previous 3.11 , to selected 3.8
Thu Nov 5 13:58:37 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.10: +4 -1 lines
Diff to previous 3.10 , to selected 3.8
changed beam management to allow temporary override
Tue Jul 7 11:07:42 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.9: +31 -16 lines
Diff to previous 3.9 , to selected 3.8
improved npixels() calculation to consider view position
Tue Jan 6 15:08:50 1998 UTC (26 years, 2 months ago) by gregl
Changes since 3.8: +7 -7 lines
Diff to previous 3.8
Revision 3.8 - (view) (download) (annotate) - [selected]
Fri Dec 19 11:54:16 1997 UTC (26 years, 3 months ago) by gregl
Changes since 3.7: +21 -5 lines
Diff to previous 3.7
changed visit_cells() so it makes at least one call to (*vf)()
Wed Nov 26 20:12:19 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.6: +28 -13 lines
Diff to previous 3.6 , to selected 3.8
fixed bug in gridlines()
Tue Nov 25 16:52:51 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.5: +36 -0 lines
Diff to previous 3.5 , to selected 3.8
created gridlines() function to run through holodeck section grids
Mon Nov 24 15:17:41 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.4: +39 -26 lines
Diff to previous 3.4 , to selected 3.8
improved and fixed npixels()
Fri Nov 21 18:17:37 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.3: +102 -34 lines
Diff to previous 3.3 , to selected 3.8
added check for holodeck behind viewpoint for more robust beam selection
Thu Nov 20 16:43:42 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.2: +6 -3 lines
Diff to previous 3.2 , to selected 3.8
fixed serious error caused by conversion from double to int
Thu Nov 20 14:21:41 1997 UTC (26 years, 4 months ago) by gregl
Changes since 3.1: +9 -12 lines
Diff to previous 3.1 , to selected 3.8
fixed bug in visitcells()
Wed Nov 19 18:01:03 1997 UTC (26 years, 4 months ago) by gregl
Diff to selected 3.8
