root/radiance/ray/src/hd/rhdisp3.c
Revision: 3.8
Committed: Fri Dec 19 11:54:16 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.7: +21 -5 lines
changed visit_cells() so it makes at least one call to (*vf)()
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Holodeck beam support for display process
9 */
10
11 #include "rholo.h"
12 #include "rhdisp.h"
13 #include "view.h"
14
15 struct cellist {
16 GCOORD *cl;
17 int n;
18 };
19
20
21 int
22 npixels(vp, hr, vr, hp, bi) /* compute appropriate number to evaluate */
23 register VIEW *vp;
24 int hr, vr;
25 HOLO *hp;
26 int bi;
27 {
28 VIEW vrev;
29 GCOORD gc[2];
30 FVECT cp[4], ip[4];
31 double af, ab;
32 register int i;
33 /* compute cell corners in image */
34 if (!hdbcoord(gc, hp, bi))
35 error(CONSISTENCY, "bad beam index in npixels");
36 hdcell(cp, hp, gc+1); /* find cell on front image */
37 for (i = 0; i < 4; i++) {
38 viewloc(ip[i], vp, cp[i]);
39 if (ip[i][2] < 0.) {
40 af = 0;
41 goto getback;
42 }
43 ip[i][0] *= (double)hr; /* scale by resolution */
44 ip[i][1] *= (double)vr;
45 }
46 /* compute front area */
47 af = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
48 (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
49 af += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
50 (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
51 if (af >= 0) af *= 0.5;
52 else af *= -0.5;
53 getback:
54 copystruct(&vrev, vp); /* compute reverse view */
55 for (i = 0; i < 3; i++) {
56 vrev.vdir[i] = -vp->vdir[i];
57 vrev.vup[i] = -vp->vup[i];
58 vrev.hvec[i] = -vp->hvec[i];
59 vrev.vvec[i] = -vp->vvec[i];
60 }
61 hdcell(cp, hp, gc); /* find cell on back image */
62 for (i = 0; i < 4; i++) {
63 viewloc(ip[i], &vrev, cp[i]);
64 if (ip[i][2] < 0.)
65 return((int)(af + 0.5));
66 ip[i][0] *= (double)hr; /* scale by resolution */
67 ip[i][1] *= (double)vr;
68 }
69 /* compute back area */
70 ab = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) -
71 (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]);
72 ab += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) -
73 (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]);
74 if (ab >= 0) ab *= 0.5;
75 else ab *= -0.5;
76 /* round off smaller area */
77 if (af <= ab)
78 return((int)(af + 0.5));
79 return((int)(ab + 0.5));
80 }
81
82
83 /*
84 * The ray directions that define the pyramid in visit_cells() needn't
85 * be normalized, but they must be given in clockwise order as seen
86 * from the pyramid's apex (origin).
87 * If no cell centers fall within the domain, the closest cell is visited.
88 */
89 int
90 visit_cells(orig, pyrd, hp, vf, dp) /* visit cells within a pyramid */
91 FVECT orig, pyrd[4]; /* pyramid ray directions in clockwise order */
92 register HOLO *hp;
93 int (*vf)();
94 char *dp;
95 {
96 int ncalls = 0, n = 0;
97 int inflags = 0;
98 FVECT gp, pn[4], lo, ld;
99 double po[4], lbeg, lend, d, t;
100 GCOORD gc, gc2[2];
101 register int i;
102 /* figure out whose side we're on */
103 hdgrid(gp, hp, orig);
104 for (i = 0; i < 3; i++) {
105 inflags |= (gp[i] > FTINY) << (i<<1);
106 inflags |= (gp[i] < hp->grid[i]-FTINY) << (i<<1 | 1);
107 }
108 /* compute pyramid planes */
109 for (i = 0; i < 4; i++) {
110 fcross(pn[i], pyrd[i], pyrd[(i+1)&03]);
111 po[i] = DOT(pn[i], orig);
112 }
113 /* traverse each wall */
114 for (gc.w = 0; gc.w < 6; gc.w++) {
115 if (!(inflags & 1<<gc.w)) /* origin on wrong side */
116 continue;
117 /* scanline algorithm */
118 for (gc.i[1] = hp->grid[((gc.w>>1)+2)%3]; gc.i[1]--; ) {
119 /* compute scanline */
120 gp[gc.w>>1] = gc.w&1 ? hp->grid[gc.w>>1] : 0;
121 gp[((gc.w>>1)+1)%3] = 0;
122 gp[((gc.w>>1)+2)%3] = gc.i[1] + 0.5;
123 hdworld(lo, hp, gp);
124 gp[((gc.w>>1)+1)%3] = 1;
125 hdworld(ld, hp, gp);
126 ld[0] -= lo[0]; ld[1] -= lo[1]; ld[2] -= lo[2];
127 /* find scanline limits */
128 lbeg = 0; lend = hp->grid[((gc.w>>1)+1)%3];
129 for (i = 0; i < 4; i++) {
130 t = DOT(pn[i], lo) - po[i];
131 d = -DOT(pn[i], ld);
132 if (d > FTINY) { /* <- plane */
133 if ((t /= d) < lend)
134 lend = t;
135 } else if (d < -FTINY) { /* plane -> */
136 if ((t /= d) > lbeg)
137 lbeg = t;
138 } else if (t < 0) { /* outside */
139 lend = -1;
140 break;
141 }
142 }
143 if (lbeg >= lend)
144 continue;
145 i = lend + .5; /* visit cells on this scan */
146 for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) {
147 n += (*vf)(&gc, dp);
148 ncalls++;
149 }
150 }
151 }
152 if (ncalls) /* got one at least */
153 return(n);
154 /* else find closest cell */
155 VSUM(ld, pyrd[0], pyrd[1], 1.);
156 VSUM(ld, ld, pyrd[2], 1.);
157 VSUM(ld, ld, pyrd[3], 1.);
158 #if 0
159 if (normalize(ld) == 0.0) /* technically not necessary */
160 return(0);
161 #endif
162 d = hdinter(gc2, NULL, &t, hp, orig, ld);
163 if (d >= FHUGE || t <= 0.)
164 return(0);
165 return((*vf)(gc2+1, dp)); /* visit it */
166 }
167
168
169 sect_behind(hp, vp) /* check if section is "behind" viewpoint */
170 register HOLO *hp;
171 register VIEW *vp;
172 {
173 FVECT hcent;
174 /* compute holodeck section center */
175 VSUM(hcent, hp->orig, hp->xv[0], 0.5);
176 VSUM(hcent, hcent, hp->xv[1], 0.5);
177 VSUM(hcent, hcent, hp->xv[2], 0.5);
178 /* behind if center is behind */
179 return(DOT(vp->vdir,hcent) < DOT(vp->vdir,vp->vp));
180 }
181
182
183 viewpyramid(org, dir, hp, vp) /* compute view pyramid */
184 FVECT org, dir[4];
185 HOLO *hp;
186 VIEW *vp;
187 {
188 register int i;
189 /* check view type */
190 if (vp->type == VT_PAR)
191 return(0);
192 /* in front or behind? */
193 if (!sect_behind(hp, vp)) {
194 if (viewray(org, dir[0], vp, 0., 0.) < -FTINY)
195 return(0);
196 if (viewray(org, dir[1], vp, 0., 1.) < -FTINY)
197 return(0);
198 if (viewray(org, dir[2], vp, 1., 1.) < -FTINY)
199 return(0);
200 if (viewray(org, dir[3], vp, 1., 0.) < -FTINY)
201 return(0);
202 return(1);
203 } /* reverse pyramid */
204 if (viewray(org, dir[3], vp, 0., 0.) < -FTINY)
205 return(0);
206 if (viewray(org, dir[2], vp, 0., 1.) < -FTINY)
207 return(0);
208 if (viewray(org, dir[1], vp, 1., 1.) < -FTINY)
209 return(0);
210 if (viewray(org, dir[0], vp, 1., 0.) < -FTINY)
211 return(0);
212 for (i = 0; i < 3; i++) {
213 dir[0][i] = -dir[0][i];
214 dir[1][i] = -dir[1][i];
215 dir[2][i] = -dir[2][i];
216 dir[3][i] = -dir[3][i];
217 }
218 return(-1);
219 }
220
221
222 int
223 addcell(gcp, cl) /* add a cell to a list */
224 GCOORD *gcp;
225 register struct cellist *cl;
226 {
227 copystruct(cl->cl+cl->n, gcp);
228 cl->n++;
229 return(1);
230 }
231
232
233 int
234 cellcmp(gcp1, gcp2) /* visit_cells() cell ordering */
235 register GCOORD *gcp1, *gcp2;
236 {
237 register int c;
238
239 if ((c = gcp1->w - gcp2->w))
240 return(c);
241 if ((c = gcp2->i[1] - gcp1->i[1])) /* wg1 is reverse-ordered */
242 return(c);
243 return(gcp1->i[0] - gcp2->i[0]);
244 }
245
246
247 GCOORD *
248 getviewcells(np, hp, vp) /* get ordered cell list for section view */
249 int *np; /* returned number of cells (negative if reversed) */
250 register HOLO *hp;
251 VIEW *vp;
252 {
253 FVECT org, dir[4];
254 int orient;
255 struct cellist cl;
256 /* compute view pyramid */
257 *np = 0;
258 orient = viewpyramid(org, dir, hp, vp);
259 if (!orient)
260 return(NULL);
261 /* allocate enough list space */
262 cl.n = 2*( hp->grid[0]*hp->grid[1] +
263 hp->grid[0]*hp->grid[2] +
264 hp->grid[1]*hp->grid[2] );
265 cl.cl = (GCOORD *)malloc(cl.n*sizeof(GCOORD));
266 if (cl.cl == NULL)
267 goto memerr;
268 cl.n = 0; /* add cells within pyramid */
269 visit_cells(org, dir, hp, addcell, &cl);
270 if (!cl.n) {
271 free((char *)cl.cl);
272 return(NULL);
273 }
274 *np = cl.n * orient;
275 #if 0
276 /* We're just going to free this memory in a moment, and list is
277 * sorted automatically by visit_cells(), so we don't need this.
278 */
279 /* optimize memory use */
280 cl.cl = (GCOORD *)realloc((char *)cl.cl, cl.n*sizeof(GCOORD));
281 if (cl.cl == NULL)
282 goto memerr;
283 /* sort the list */
284 qsort((char *)cl.cl, cl.n, sizeof(GCOORD), cellcmp);
285 #endif
286 return(cl.cl);
287 memerr:
288 error(SYSTEM, "out of memory in getviewcells");
289 }
290
291
292 gridlines(f) /* run through holodeck section grid lines */
293 int (*f)();
294 {
295 register int hd, w, i;
296 int g0, g1;
297 FVECT wp[2], mov;
298 double d;
299 /* do each wall on each section */
300 for (hd = 0; hdlist[hd] != NULL; hd++)
301 for (w = 0; w < 6; w++) {
302 g0 = ((w>>1)+1)%3;
303 g1 = ((w>>1)+2)%3;
304 d = 1.0/hdlist[hd]->grid[g0];
305 mov[0] = d * hdlist[hd]->xv[g0][0];
306 mov[1] = d * hdlist[hd]->xv[g0][1];
307 mov[2] = d * hdlist[hd]->xv[g0][2];
308 if (w & 1) {
309 VSUM(wp[0], hdlist[hd]->orig,
310 hdlist[hd]->xv[w>>1], 1.);
311 VSUM(wp[0], wp[0], mov, 1.);
312 } else
313 VCOPY(wp[0], hdlist[hd]->orig);
314 VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.);
315 for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */
316 (*f)(wp);
317 if (!--i) break;
318 wp[0][0] += mov[0]; wp[0][1] += mov[1];
319 wp[0][2] += mov[2]; wp[1][0] += mov[0];
320 wp[1][1] += mov[1]; wp[1][2] += mov[2];
321 }
322 d = 1.0/hdlist[hd]->grid[g1];
323 mov[0] = d * hdlist[hd]->xv[g1][0];
324 mov[1] = d * hdlist[hd]->xv[g1][1];
325 mov[2] = d * hdlist[hd]->xv[g1][2];
326 if (w & 1)
327 VSUM(wp[0], hdlist[hd]->orig,
328 hdlist[hd]->xv[w>>1], 1.);
329 else
330 VSUM(wp[0], hdlist[hd]->orig, mov, 1.);
331 VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.);
332 for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */
333 (*f)(wp);
334 if (!--i) break;
335 wp[0][0] += mov[0]; wp[0][1] += mov[1];
336 wp[0][2] += mov[2]; wp[1][0] += mov[0];
337 wp[1][1] += mov[1]; wp[1][2] += mov[2];
338 }
339 }
340 }
