--- ray/src/hd/rhdisp3.c 1997/11/21 18:17:37 3.4 +++ ray/src/hd/rhdisp3.c 2020/05/14 20:58:03 3.20 @@ -1,16 +1,12 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhdisp3.c,v 3.20 2020/05/14 20:58:03 greg Exp $"; #endif - /* * Holodeck beam support for display process */ #include "rholo.h" #include "rhdisp.h" -#include "view.h" struct cellist { GCOORD *cl; @@ -19,51 +15,80 @@ struct cellist { int -npixels(vp, hr, vr, hp, bi) /* compute appropriate number to evaluate */ +npixels(vp, hr, vr, hp, bi) /* compute appropriate nrays to evaluate */ VIEW *vp; int hr, vr; HOLO *hp; int bi; { - static VIEW vdo, vlast; - static HOLO *hplast; + VIEW vrev; GCOORD gc[2]; - FVECT cp[4]; - FVECT ip[4]; - double d; - register int i; + FVECT cp[4], ip[4], pf, pb; + double af, ab, sf2, sb2, dfb2, df2, db2, penalty; + int i; + /* special case */ + if (hr <= 0 | vr <= 0) + return(0); /* compute cell corners in image */ if (!hdbcoord(gc, hp, bi)) error(CONSISTENCY, "bad beam index in npixels"); - /* has holodeck or view changed? */ - if (hp != hplast || bcmp((char *)vp, (char *)&vlast, sizeof(VIEW))) { - copystruct(&vdo, vp); - if (sect_behind(hp, &vdo)) { /* reverse view sense */ - vdo.vdir[0] = -vdo.vdir[0]; - vdo.vdir[1] = -vdo.vdir[1]; - vdo.vdir[2] = -vdo.vdir[2]; - setview(&vdo); + hdcell(cp, hp, gc+1); /* find cell on front image */ + for (i = 3; i--; ) /* compute front center */ + pf[i] = 0.5*(cp[0][i] + cp[2][i]); + sf2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */ + for (i = 0; i < 4; i++) { /* compute visible quad */ + if (viewloc(ip[i], vp, cp[i]) != VL_GOOD) { + af = 0; + goto getback; } - hplast = hp; - copystruct(&vlast, vp); + ip[i][0] *= (double)hr; /* scale by resolution */ + ip[i][1] *= (double)vr; } - hdcell(cp, hp, gc+1); /* find cell on image */ - for (i = 0; i < 4; i++) { - viewloc(ip[i], &vdo, cp[i]); - if (ip[i][2] < 0.) - return(0); + /* compute front area */ + af = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - + (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]); + af += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - + (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]); + af *= af >= 0 ? 0.5 : -0.5; +getback: + vrev = *vp; /* compute reverse view */ + for (i = 0; i < 3; i++) { + vrev.vdir[i] = -vp->vdir[i]; + vrev.vup[i] = -vp->vup[i]; + vrev.hvec[i] = -vp->hvec[i]; + vrev.vvec[i] = -vp->vvec[i]; + } + hdcell(cp, hp, gc); /* find cell on back image */ + for (i = 3; i--; ) /* compute rear center */ + pb[i] = 0.5*(cp[0][i] + cp[2][i]); + sb2 = 0.25*dist2(cp[0], cp[2]); /* compute half diagonal length */ + for (i = 0; i < 4; i++) { /* compute visible quad */ + if (viewloc(ip[i], &vrev, cp[i]) != VL_GOOD) { + ab = 0; + goto finish; + } ip[i][0] *= (double)hr; /* scale by resolution */ ip[i][1] *= (double)vr; } - /* compute quad area */ - d = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - + /* compute back area */ + ab = (ip[1][0]-ip[0][0])*(ip[2][1]-ip[0][1]) - (ip[2][0]-ip[0][0])*(ip[1][1]-ip[0][1]); - d += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - + ab += (ip[2][0]-ip[3][0])*(ip[1][1]-ip[3][1]) - (ip[1][0]-ip[3][0])*(ip[2][1]-ip[3][1]); - if (d < 0) - d = -d; - /* round off result */ - return((int)(.5*d+.5)); + ab *= ab >= 0 ? 0.5 : -0.5; +finish: /* compute penalty based on dist. sightline - viewpoint */ + df2 = dist2(vp->vp, pf); + db2 = dist2(vp->vp, pb); + dfb2 = dist2(pf, pb); + penalty = dfb2 + df2 - db2; + penalty = df2 - 0.25*penalty*penalty/dfb2; + if (df2 > db2) penalty /= df2 <= dfb2 ? sb2 : sb2*df2/dfb2; + else penalty /= db2 <= dfb2 ? sf2 : sf2*db2/dfb2; + if (penalty < 1.) penalty = 1.; + /* round off smaller non-zero area */ + if (ab <= FTINY || (af > FTINY && af <= ab)) + return((int)(af/penalty + 0.5)); + return((int)(ab/penalty + 0.5)); } @@ -71,6 +96,7 @@ int bi; * The ray directions that define the pyramid in visit_cells() needn't * be normalized, but they must be given in clockwise order as seen * from the pyramid's apex (origin). + * If no cell centers fall within the domain, the closest cell is visited. */ int visit_cells(orig, pyrd, hp, vf, dp) /* visit cells within a pyramid */ @@ -79,12 +105,12 @@ HOLO *hp; int (*vf)(); char *dp; { - int n = 0; + int ncalls = 0, n = 0; int inflags = 0; FVECT gp, pn[4], lo, ld; double po[4], lbeg, lend, d, t; - GCOORD gc; - register int i; + GCOORD gc, gc2[2]; + int i; /* figure out whose side we're on */ hdgrid(gp, hp, orig); for (i = 0; i < 3; i++) { @@ -101,17 +127,17 @@ char *dp; if (!(inflags & 1<grid[((gc.w>>1)+2)%3]; gc.i[1]--; ) { + for (gc.i[1] = hp->grid[hdwg1[gc.w]]; gc.i[1]--; ) { /* compute scanline */ gp[gc.w>>1] = gc.w&1 ? hp->grid[gc.w>>1] : 0; - gp[((gc.w>>1)+1)%3] = 0; - gp[((gc.w>>1)+2)%3] = gc.i[1] + 0.5; + gp[hdwg0[gc.w]] = 0; + gp[hdwg1[gc.w]] = gc.i[1] + 0.5; hdworld(lo, hp, gp); - gp[((gc.w>>1)+1)%3] = 1; + gp[hdwg0[gc.w]] = 1; hdworld(ld, hp, gp); ld[0] -= lo[0]; ld[1] -= lo[1]; ld[2] -= lo[2]; /* find scanline limits */ - lbeg = 0; lend = hp->grid[((gc.w>>1)+1)%3]; + lbeg = 0; lend = hp->grid[hdwg0[gc.w]]; for (i = 0; i < 4; i++) { t = DOT(pn[i], lo) - po[i]; d = -DOT(pn[i], ld); @@ -129,17 +155,32 @@ char *dp; if (lbeg >= lend) continue; i = lend + .5; /* visit cells on this scan */ - for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) + for (gc.i[0] = lbeg + .5; gc.i[0] < i; gc.i[0]++) { n += (*vf)(&gc, dp); + ncalls++; + } } } - return(n); + if (ncalls) /* got one at least */ + return(n); + /* else find closest cell */ + VSUM(ld, pyrd[0], pyrd[1], 1.); + VSUM(ld, ld, pyrd[2], 1.); + VSUM(ld, ld, pyrd[3], 1.); +#if 0 + if (normalize(ld) == 0.0) /* technically not necessary */ + return(0); +#endif + d = hdinter(gc2, NULL, &t, hp, orig, ld); + if (d >= FHUGE*.99 || t <= 0.) + return(0); + return((*vf)(gc2+1, dp)); /* visit it */ } sect_behind(hp, vp) /* check if section is "behind" viewpoint */ -register HOLO *hp; -register VIEW *vp; +HOLO *hp; +VIEW *vp; { FVECT hcent; /* compute holodeck section center */ @@ -156,7 +197,7 @@ FVECT org, dir[4]; HOLO *hp; VIEW *vp; { - register int i; + int i; /* check view type */ if (vp->type == VT_PAR) return(0); @@ -193,9 +234,9 @@ VIEW *vp; int addcell(gcp, cl) /* add a cell to a list */ GCOORD *gcp; -register struct cellist *cl; +struct cellist *cl; { - copystruct(cl->cl+cl->n, gcp); + *(cl->cl+cl->n) = *gcp; cl->n++; return(1); } @@ -203,9 +244,9 @@ register struct cellist *cl; int cellcmp(gcp1, gcp2) /* visit_cells() cell ordering */ -register GCOORD *gcp1, *gcp2; +GCOORD *gcp1, *gcp2; { - register int c; + int c; if ((c = gcp1->w - gcp2->w)) return(c); @@ -218,7 +259,7 @@ register GCOORD *gcp1, *gcp2; GCOORD * getviewcells(np, hp, vp) /* get ordered cell list for section view */ int *np; /* returned number of cells (negative if reversed) */ -register HOLO *hp; +HOLO *hp; VIEW *vp; { FVECT org, dir[4]; @@ -237,9 +278,9 @@ VIEW *vp; if (cl.cl == NULL) goto memerr; cl.n = 0; /* add cells within pyramid */ - visit_cells(org, dir, hp, addcell, &cl); + visit_cells(org, dir, hp, addcell, (char *)&cl); if (!cl.n) { - free((char *)cl.cl); + free((void *)cl.cl); return(NULL); } *np = cl.n * orient; @@ -248,7 +289,7 @@ VIEW *vp; * sorted automatically by visit_cells(), so we don't need this. */ /* optimize memory use */ - cl.cl = (GCOORD *)realloc((char *)cl.cl, cl.n*sizeof(GCOORD)); + cl.cl = (GCOORD *)realloc((void *)cl.cl, cl.n*sizeof(GCOORD)); if (cl.cl == NULL) goto memerr; /* sort the list */ @@ -257,4 +298,57 @@ VIEW *vp; return(cl.cl); memerr: error(SYSTEM, "out of memory in getviewcells"); +} + + +void +gridlines( /* run through holodeck section grid lines */ + void (*f)(FVECT wp[2]) +) +{ + int hd, w, i; + int g0, g1; + FVECT wp[2], mov; + double d; + /* do each wall on each section */ + for (hd = 0; hdlist[hd] != NULL; hd++) + for (w = 0; w < 6; w++) { + g0 = hdwg0[w]; + g1 = hdwg1[w]; + d = 1.0/hdlist[hd]->grid[g0]; + mov[0] = d * hdlist[hd]->xv[g0][0]; + mov[1] = d * hdlist[hd]->xv[g0][1]; + mov[2] = d * hdlist[hd]->xv[g0][2]; + if (w & 1) { + VSUM(wp[0], hdlist[hd]->orig, + hdlist[hd]->xv[w>>1], 1.); + VSUM(wp[0], wp[0], mov, 1.); + } else + VCOPY(wp[0], hdlist[hd]->orig); + VSUM(wp[1], wp[0], hdlist[hd]->xv[g1], 1.); + for (i = hdlist[hd]->grid[g0]; ; ) { /* g0 lines */ + (*f)(wp); + if (!--i) break; + wp[0][0] += mov[0]; wp[0][1] += mov[1]; + wp[0][2] += mov[2]; wp[1][0] += mov[0]; + wp[1][1] += mov[1]; wp[1][2] += mov[2]; + } + d = 1.0/hdlist[hd]->grid[g1]; + mov[0] = d * hdlist[hd]->xv[g1][0]; + mov[1] = d * hdlist[hd]->xv[g1][1]; + mov[2] = d * hdlist[hd]->xv[g1][2]; + if (w & 1) + VSUM(wp[0], hdlist[hd]->orig, + hdlist[hd]->xv[w>>1], 1.); + else + VSUM(wp[0], hdlist[hd]->orig, mov, 1.); + VSUM(wp[1], wp[0], hdlist[hd]->xv[g0], 1.); + for (i = hdlist[hd]->grid[g1]; ; ) { /* g1 lines */ + (*f)(wp); + if (!--i) break; + wp[0][0] += mov[0]; wp[0][1] += mov[1]; + wp[0][2] += mov[2]; wp[1][0] += mov[0]; + wp[1][1] += mov[1]; wp[1][2] += mov[2]; + } + } }
