1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Holodeck beam tracking for display process |
9 |
10 |
11 |
#include "rholo.h" |
12 |
#include "rhdisp.h" |
13 |
#include "rhdriver.h" |
14 |
15 |
extern int *getviewcells(); |
16 |
17 |
typedef struct { |
18 |
int hd; /* holodeck section number (-1 if inactive) */ |
19 |
int i[3]; /* voxel index (may be outside section) */ |
20 |
} VOXL; /* a voxel */ |
21 |
22 |
static VOXL voxel[8] = { /* current voxel list */ |
23 |
{-1}, {-1}, {-1}, {-1}, |
24 |
{-1}, {-1}, {-1}, {-1} |
25 |
26 |
27 |
#define CBEAMBLK 1024 /* cbeam allocation block size */ |
28 |
29 |
static struct beamcomp { |
30 |
short wants; /* flags telling which voxels want us */ |
31 |
short hd; /* holodeck section number */ |
32 |
int bi; /* beam index */ |
33 |
} *cbeam = NULL; /* current beam list */ |
34 |
35 |
static int ncbeams = 0; /* number of sorted beams in cbeam */ |
36 |
static int xcbeams = 0; /* extra (unregistered) beams past ncbeams */ |
37 |
static int maxcbeam = 0; /* size of cbeam array */ |
38 |
39 |
struct cellact { |
40 |
short vi; /* voxel index */ |
41 |
short add; /* zero means delete */ |
42 |
}; /* action for cell */ |
43 |
44 |
struct beamact { |
45 |
struct cellact ca; /* cell action */ |
46 |
GCOORD gc; /* grid coordinate */ |
47 |
}; /* beam origin and action */ |
48 |
49 |
50 |
int |
51 |
newcbeam() /* allocate new entry at end of cbeam array */ |
52 |
53 |
int i; |
54 |
55 |
if ((i = ncbeams + xcbeams++) >= maxcbeam) { /* grow array */ |
56 |
maxcbeam += CBEAMBLK; |
57 |
if (cbeam == NULL) |
58 |
cbeam = (struct beamcomp *)malloc( |
59 |
maxcbeam*sizeof(struct beamcomp) ); |
60 |
else |
61 |
cbeam = (struct beamcomp *)realloc( (char *)cbeam, |
62 |
63 |
64 |
error(SYSTEM, "out of memory in newcbeam"); |
65 |
66 |
return(i); |
67 |
68 |
69 |
70 |
int |
71 |
cbeamcmp(cb1, cb2) /* compare two cbeam entries for sort: keep orphans */ |
72 |
register struct beamcomp *cb1, *cb2; |
73 |
74 |
register int c; |
75 |
76 |
if ((c = cb1->bi - cb2->bi)) /* sort on beam index first */ |
77 |
return(c); |
78 |
return(cb1->hd - cb2->hd); /* use hd to resolve matches */ |
79 |
80 |
81 |
82 |
int |
83 |
cbeamcmp2(cb1, cb2) /* compare two cbeam entries for sort: no orphans */ |
84 |
85 |
86 |
register int c; |
87 |
88 |
if (!cb1->wants) /* put orphans at the end, unsorted */ |
89 |
return(cb2->wants); |
90 |
91 |
return(c); |
92 |
93 |
94 |
95 |
96 |
int |
97 |
findcbeam(hd, bi) /* find the specified beam in our sorted list */ |
98 |
int hd, bi; |
99 |
100 |
struct beamcomp cb; |
101 |
register struct beamcomp *p; |
102 |
103 |
if (ncbeams <= 0) |
104 |
return(-1); |
105 |
cb.wants = 0; cb.hd = hd; cb.bi = bi; |
106 |
p = (struct beamcomp *)bsearch((char *)&cb, (char *)cbeam, ncbeams, |
107 |
sizeof(struct beamcomp), cbeamcmp); |
108 |
if (p == NULL) |
109 |
return(-1); |
110 |
return(p - cbeam); |
111 |
112 |
113 |
114 |
int |
115 |
getcbeam(hd, bi) /* get the specified beam, allocating as necessary */ |
116 |
register int hd; |
117 |
int bi; |
118 |
119 |
register int n; |
120 |
/* first, look in sorted list */ |
121 |
if ((n = findcbeam(hd, bi)) >= 0) |
122 |
return(n); |
123 |
/* linear search through xcbeams to be sure */ |
124 |
for (n = ncbeams+xcbeams; n-- > ncbeams; ) |
125 |
if (cbeam[n].bi == bi && cbeam[n].hd == hd) |
126 |
return(n); |
127 |
/* check legality */ |
128 |
if (hd < 0 | hd >= HDMAX || hdlist[hd] == NULL) |
129 |
error(INTERNAL, "illegal holodeck number in getcbeam"); |
130 |
if (bi < 1 | bi > nbeams(hdlist[hd])) |
131 |
error(INTERNAL, "illegal beam index in getcbeam"); |
132 |
n = newcbeam(); /* allocate and assign */ |
133 |
cbeam[n].wants = 0; cbeam[n].hd = hd; cbeam[n].bi = bi; |
134 |
return(n); |
135 |
136 |
137 |
138 |
cbeamsort(adopt) /* sort our beam list, possibly turning out orphans */ |
139 |
int adopt; |
140 |
141 |
register int i; |
142 |
143 |
if (!(ncbeams += xcbeams)) |
144 |
return; |
145 |
xcbeams = 0; |
146 |
qsort((char *)cbeam, ncbeams, sizeof(struct beamcomp), |
147 |
adopt ? cbeamcmp : cbeamcmp2); |
148 |
if (adopt) |
149 |
return; |
150 |
for (i = ncbeams; i--; ) /* identify orphans */ |
151 |
if (cbeam[i].wants) |
152 |
break; |
153 |
xcbeams = ncbeams - ++i; /* put orphans after ncbeams */ |
154 |
ncbeams = i; |
155 |
156 |
157 |
158 |
cbeamop(op, bl, n, v, hr, vr) /* update beams on server list */ |
159 |
int op; |
160 |
register struct beamcomp *bl; |
161 |
int n; |
162 |
VIEW *v; |
163 |
int hr, vr; |
164 |
165 |
register PACKHEAD *pa; |
166 |
register int i; |
167 |
168 |
if (n <= 0) |
169 |
return; |
170 |
pa = (PACKHEAD *)malloc(n*sizeof(PACKHEAD)); |
171 |
if (pa == NULL) |
172 |
error(SYSTEM, "out of memory in cbeamadd"); |
173 |
for (i = 0; i < n; i++) { |
174 |
pa[i].hd = bl[i].hd; |
175 |
pa[i].bi = bl[i].bi; |
176 |
pa[i].nr = v==NULL ? 0 : |
177 |
npixels(v, hr, vr, hdlist[bl[i].hd], bl[i].bi); |
178 |
179 |
serv_request(op, n*sizeof(PACKHEAD), (char *)pa); |
180 |
free((char *)pa); |
181 |
182 |
183 |
184 |
int |
185 |
set_voxels(vl, n) /* set new voxel array */ |
186 |
VOXL vl[8]; |
187 |
int n; |
188 |
189 |
short wmap[256]; |
190 |
int vmap[8]; |
191 |
int comn = 0; |
192 |
int no; |
193 |
register int i, j; |
194 |
/* find common voxels */ |
195 |
for (j = 0; j < 8 && voxel[j].hd >= 0; j++) { |
196 |
vmap[j] = -1; |
197 |
for (i = n; i--; ) |
198 |
if (!bcmp((char *)(vl+i), (char *)(voxel+j), |
199 |
sizeof(VOXL))) { |
200 |
vmap[j] = i; |
201 |
comn |= 1<<i; |
202 |
break; |
203 |
204 |
205 |
no = comn ? j : 0; /* compute flag mapping */ |
206 |
for (i = 256; i--; ) { |
207 |
wmap[i] = 0; |
208 |
for (j = no; j--; ) |
209 |
if (vmap[j] >= 0 && i & 1<<j) |
210 |
wmap[i] |= 1<<vmap[j]; |
211 |
212 |
/* fix cbeam flags */ |
213 |
for (i = ncbeams; i--; ) |
214 |
cbeam[i].wants = wmap[cbeam[i].wants]; |
215 |
/* update our voxel list */ |
216 |
bcopy((char *)vl, (char *)voxel, n*sizeof(VOXL)); |
217 |
for (j = n; j < 8; j++) |
218 |
voxel[j].hd = -1; |
219 |
return(comn); /* return bit array of common voxels */ |
220 |
221 |
222 |
223 |
int |
224 |
get_voxels(vl, vp) /* find voxels corresponding to view point */ |
225 |
VOXL vl[8]; |
226 |
FVECT vp; |
227 |
228 |
static int lastn = 0, lastd = -1; |
229 |
int n = 0; |
230 |
FVECT gp; |
231 |
double d; |
232 |
int dist, bestd = 0x7fff; |
233 |
VOXL vox; |
234 |
register int i, j, k; |
235 |
/* find closest voxels */ |
236 |
for (i = 0; n < 8 && hdlist[i]; i++) { |
237 |
hdgrid(gp, hdlist[i], vp); |
238 |
for (j = 0; n < 8 && j < 8; j++) { |
239 |
dist = 0; |
240 |
for (k = 0; k < 3; k++) { |
241 |
d = gp[k] - .5 + (j>>k & 1); |
242 |
if (d < 0.) |
243 |
dist += -(vox.i[k] = (int)d - 1); |
244 |
else if ((vox.i[k] = d) >= hdlist[i]->grid[k]) |
245 |
dist += vox.i[k] - |
246 |
hdlist[i]->grid[k] + 1; |
247 |
248 |
if (dist > bestd) /* others were closer */ |
249 |
continue; |
250 |
if (dist < bestd) { /* start closer list */ |
251 |
n = 0; |
252 |
bestd = dist; |
253 |
254 |
vox.hd = i; /* add this voxel */ |
255 |
copystruct(&vl[n], &vox); |
256 |
n++; |
257 |
258 |
259 |
/* warn of dangerous moves */ |
260 |
if (n < lastn && bestd >= lastd) |
261 |
error(WARNING, "moving outside holodeck section"); |
262 |
else if (n > lastn && bestd <= lastd) |
263 |
error(WARNING, "moving inside holodeck section"); |
264 |
lastd = bestd; |
265 |
return(lastn = n); |
266 |
267 |
268 |
269 |
int |
270 |
dobeam(gcp, bp) /* express interest or disintrest in a beam */ |
271 |
GCOORD *gcp; |
272 |
register struct beamact *bp; |
273 |
274 |
GCOORD gc[2]; |
275 |
int bi, i; |
276 |
/* compute beam index */ |
277 |
copystruct(gc, gcp); |
278 |
copystruct(gc+1, &bp->gc); |
279 |
if ((bi = hdbindex(hdlist[voxel[bp->ca.vi].hd], gc)) <= 0) |
280 |
error(CONSISTENCY, "bad grid coordinate in dobeam"); |
281 |
if (bp->ca.add) { /* add it in */ |
282 |
i = getcbeam(voxel[bp->ca.vi].hd, bi); |
283 |
cbeam[i].wants |= 1<<bp->ca.vi; /* say we want it */ |
284 |
return(i == ncbeams+xcbeams-1); /* return 1 if totally new */ |
285 |
286 |
/* else delete it */ |
287 |
i = findcbeam(voxel[bp->ca.vi].hd, bi); |
288 |
if (i >= 0 && cbeam[i].wants & 1<<bp->ca.vi) { |
289 |
cbeam[i].wants &= ~(1<<bp->ca.vi); /* we don't want it */ |
290 |
return(1); /* indicate change */ |
291 |
292 |
return(0); |
293 |
294 |
295 |
296 |
297 |
int |
298 |
docell(gcp, cap) /* find beams corresponding to cell and voxel */ |
299 |
GCOORD *gcp; |
300 |
register struct cellact *cap; |
301 |
302 |
FVECT org, dir[4]; |
303 |
FVECT gp, cv[4], vc; |
304 |
struct beamact bo; |
305 |
register int i; |
306 |
/* compute cell vertices */ |
307 |
hdcell(cv, hdlist[voxel[cap->vi].hd], gcp); |
308 |
/* compute cell and voxel centers */ |
309 |
for (i = 0; i < 3; i++) { |
310 |
org[i] = 0.5*(cv[0][i] + cv[2][i]); |
311 |
gp[i] = voxel[cap->vi].i[i] + 0.5; |
312 |
313 |
hdworld(vc, hdlist[voxel[cap->vi].hd], gp); |
314 |
/* compute voxel pyramid using vector trick */ |
315 |
316 |
dir[0][i] = vc[i] - cv[0][i]; /* to 3 */ |
317 |
dir[2][i] = vc[i] - cv[3][i]; /* to 0 */ |
318 |
if (gcp->w & 1) { /* watch vertex order! */ |
319 |
dir[1][i] = vc[i] - cv[2][i]; /* to 1 */ |
320 |
dir[3][i] = vc[i] - cv[1][i]; /* to 2 */ |
321 |
} else { |
322 |
dir[1][i] = vc[i] - cv[1][i]; /* to 2 */ |
323 |
dir[3][i] = vc[i] - cv[2][i]; /* to 1 */ |
324 |
325 |
326 |
/* visit beams for opposite cells */ |
327 |
copystruct(&bo.ca, cap); |
328 |
copystruct(&bo.gc, gcp); |
329 |
return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], dobeam, &bo)); |
330 |
331 |
332 |
333 |
int |
334 |
doview(cap, vp) /* visit cells for a given view */ |
335 |
336 |
VIEW *vp; |
337 |
338 |
339 |
/* compute view pyramid */ |
340 |
if (vp->type == VT_PAR) goto viewerr; |
341 |
if (viewray(org, dir[0], vp, 0., 0.) < -FTINY) goto viewerr; |
342 |
if (viewray(org, dir[1], vp, 0., 1.) < -FTINY) goto viewerr; |
343 |
if (viewray(org, dir[2], vp, 1., 1.) < -FTINY) goto viewerr; |
344 |
if (viewray(org, dir[3], vp, 1., 0.) < -FTINY) goto viewerr; |
345 |
/* visit cells within pyramid */ |
346 |
return(visit_cells(org, dir, hdlist[voxel[cap->vi].hd], docell, cap)); |
347 |
viewerr: |
348 |
error(INTERNAL, "unusable view in doview"); |
349 |
350 |
351 |
352 |
mvview(voxi, vold, vnew) /* move view for a voxel */ |
353 |
int voxi; |
354 |
VIEW *vold, *vnew; |
355 |
356 |
int netchange = 0; |
357 |
int *ocl, *ncl; |
358 |
struct cellact ca; |
359 |
int ocnt, ncnt; |
360 |
int c; |
361 |
register GCOORD *ogcp, *ngcp; |
362 |
/* get old and new cell lists */ |
363 |
ocl = getviewcells(hdlist[voxel[voxi].hd], vold); |
364 |
ncl = getviewcells(hdlist[voxel[voxi].hd], vnew); |
365 |
if (ocl != NULL) { |
366 |
ocnt = *ocl; ogcp = (GCOORD *)(ocl+1); |
367 |
} else { |
368 |
ocnt = 0; ogcp = NULL; |
369 |
370 |
if (ncl != NULL) { |
371 |
ncnt = *ncl; ngcp = (GCOORD *)(ncl+1); |
372 |
} else { |
373 |
ncnt = 0; ngcp = NULL; |
374 |
375 |
ca.vi = voxi; /* add and delete cells */ |
376 |
while (ocnt > 0 & ncnt > 0) |
377 |
if ((c = cellcmp(ogcp, ngcp)) > 0) { |
378 |
ca.add = 1; /* new cell */ |
379 |
netchange += docell(ngcp++, &ca); |
380 |
ncnt--; |
381 |
} else if (c < 0) { |
382 |
ca.add = 0; /* obsolete cell */ |
383 |
netchange -= docell(ogcp++, &ca); |
384 |
ocnt--; |
385 |
} else { |
386 |
ogcp++; ocnt--; /* unchanged cell */ |
387 |
ngcp++; ncnt--; |
388 |
389 |
/* take care of list tails */ |
390 |
for (ca.add = 1; ncnt > 0; ncnt--) |
391 |
392 |
for (ca.add = 0; ocnt > 0; ocnt--) |
393 |
394 |
/* clean up */ |
395 |
if (ocl != NULL) free((char *)ocl); |
396 |
if (ncl != NULL) free((char *)ncl); |
397 |
return(netchange); |
398 |
399 |
400 |
401 |
beam_sync() /* synchronize beams on server */ |
402 |
403 |
cbeamop(DR_NEWSET, cbeam, ncbeams, &odev.v, odev.hres, odev.vres); |
404 |
405 |
406 |
407 |
beam_view(vo, vn) /* change beam view */ |
408 |
VIEW *vo, *vn; |
409 |
410 |
411 |
VOXL vlnew[8]; |
412 |
int n, comn; |
413 |
414 |
if (!vn->type) { /* clear our beam list */ |
415 |
set_voxels(vlnew, 0); |
416 |
cbeamop(DR_DELSET, cbeam, ncbeams, NULL, 0, 0); |
417 |
ncbeams = 0; |
418 |
return; |
419 |
420 |
/* find our new voxels */ |
421 |
n = get_voxels(vlnew, vn->vp); |
422 |
/* set the new voxels */ |
423 |
comn = set_voxels(vlnew, n); |
424 |
if (!vo->type) |
425 |
comn = 0; |
426 |
ca.add = 1; /* update our beam list */ |
427 |
for (ca.vi = n; ca.vi--; ) |
428 |
if (comn & 1<<ca.vi) /* change which cells we see */ |
429 |
mvview(ca.vi, vo, vn); |
430 |
else /* else add all new cells */ |
431 |
doview(&ca, vn); |
432 |
/* inform server of new beams */ |
433 |
cbeamop(DR_ADDSET, cbeam+ncbeams, xcbeams, vn, odev.hres, odev.vres); |
434 |
/* sort list to put orphans at end */ |
435 |
cbeamsort(0); |
436 |
/* tell server to delete orphans */ |
437 |
cbeamop(DR_DELSET, cbeam+ncbeams, xcbeams, NULL, 0, 0); |
438 |
xcbeams = 0; /* truncate our list */ |
439 |
